OP58509
OP58509
    LAIRD(莱尔德)
    RF ANT WHIP STR N MALE BRKT MT
OP58509 数据手册
VERTICALLY POLARIZED BROADBAND OMNI ANTENNAS OP58509 5850-6000 MHz VERTICALLY POLARIZED OMNIDIRECTIONAL ANTENNA The Laird OP58509 broadband omnidirectional antenna has a UV-stable fiberglass radome and is IP67 rated for dust and water intrusion providing excellent durability, reliability and performance. The OP58509 is available with a 914 mm (3') RG58 Low Temperature Rated Plenum cable with Type N-male connector. The vertical pattern is a full 360 degrees with 9.1 dBi gain to improve high-speed broadband system performance in a highly rugged and durable package for both indoor and outdoor applications. FEATURES MARKETS - APPLICATIONS • 9.1 dBi antenna gain. • Type N male connector with 914 mm (3') RG58 Low Temperature Rated Plenum cable. • • • • • Wireless broadband systems • DSRC (Dedicated Short Range Communications) IP67 Rated, lightweight design for inddoor & outdoor use. UV Stable polycarbonate radome. All stainless steel bracket for better corrosion protection. Performance engineered for optimum high speed broadband performance. PARAMETER • ITS (Intelligent Transportation Systems) • Point-to-multi-point systems • WLAN access points SPECIFICATIONS Model OP58509-91NM Frequency Bands, MHz Peak Gain, dBi (Typ) 5850-6000 MHz 8.8 dBi 9.1 dBi
OP58509 价格&库存
很抱歉,暂时无法提供与“OP58509”相匹配的价格&库存,您可以联系我们找货
