OC58509
OC58509
    LAIRD(莱尔德)
    RF ANT 5.9GHZ WHIP STR CONN MT
OC58509 数据手册
VERTICALLY POLARIZED BROADBAND OMNI ANTENNAS OC58509 5850-6000 MHz VERTICALLY POLARIZED OMNIDIRECTIONAL ANTENNA The Laird OC58509 broadband omnidirectional antenna has a UV-stable fiberglass radome and is IP67 rated for dust and water intrusion providing excellent durability, reliability and performance. The OC58509 is availbale with either Fixed N-male or Fixed N-female bulkhead connector. The vertical pattern is a full 360 degrees with 9 dBi gain to improve high-speed broadband system performance in a highly rugged and durable package for both indoor and outdoor applications. FEATURES • • • • • • 9.3 dBi antenna gain. Type N female, or Type N male w/integrated bulkhead connector. IP67 Rated, lightweight design for inddoor & outdoor use. UV Stable polycarbonate radome. All stainless steel bracket for better corrosion protection. Performance engineered for optimum high speed broadband performance. PARAMETER MARKETS - APPLICATIONS • Wireless broadband systems • DSRC (Dedicated Short Range Communications) • ITS (Intelligent Transportation Systems) • Point-to-multi-point systems • WLAN access points SPECIFICATIONS OC58509 Model Frequency Bands, MHz Peak Gain, dBi (Typ) 5850-6000 MHz 9.1 dBi 9.3 dBi
OC58509 价格&库存
很抱歉,暂时无法提供与“OC58509”相匹配的价格&库存,您可以联系我们找货
