OC57216
OC57216
    LAIRD(莱尔德)
    RF ANT WHIP STR CONN MT
OC57216 数据手册
VERTICALLY POLARIZED BROADBAND OMNI ANTENNAS OC57216 5725-6000 MHz VERTICALLY POLARIZED OMNIDIRECTIONAL ANTENNA The Laird OC57216 broadband omnidirectional antenna has a UV-stable fiberglass radome and is IP67 rated for dust and water intrusion providing excellent durability, reliability and performance. The OC57216 is available with either Fixed N-male or Fixed N-female bulkhead connector. The vertical pattern is a full 360 degrees with 6 dBi gain to improve high-speed broadband system performance in a highly rugged and durable package for both indoor and outdoor applications. FEATURES • • • • • • 6.8 dBi antenna gain. Type N female, or Type N male w/integrated bulkhead connector. IP67 Rated, lightweight design for indoor & outdoor use. UV Stable polycarbonate radome. All stainless steel bracket for better corrosion protection. Performance engineered for optimum high speed broadband performance. PARAMETER MARKETS - APPLICATIONS • Wireless broadband systems • DSRC (Dedicated Short Range Communications) • ITS (Intelligent Transportation Systems) • Point-to-multi-point systems • WLAN access points SPECIFICATIONS OC57216 Model Frequency Bands, MHz Peak Gain, dBi (Typ) 5725-6000 MHz 6.5 dBi 6.8 dBi
OC57216 价格&库存
很抱歉,暂时无法提供与“OC57216”相匹配的价格&库存,您可以联系我们找货
