21109154
21109154
    LAIRD(莱尔德)
    ECCOSORB ELASTOMER ..040X12X24
21109154 数据手册
Eccosorb® MCS High-Loss, Thin, Elastomeric Microwave Absorber HIGH-LOSS ELASTOMERIC ABSORBER Eccosorb MCS is a thin, flexible, high-loss, magnetically loaded, electrically non-conductive silicone rubber sheet. It is designed for the frequency range from 800 MHz to 18 GHz. The material is impervious to moisture and can be subjected to high altitudes with no adverse effects. Being a silicone based absorber, it has low out-gassing properties for space applications. FEATURES AND BENEFITS MARKETS • High power performance • Low outgassing properties • High magnetic loss • Commercial Telecom • Security and Defense • Automotive and Industrial Electronics SPECIFICATIONS TYPICAL PROPERTIES ECCOSORB MCS Frequency Range (GHz) Max Service Temperature °C (°F) 0.8 to 18 170 (338) Fire Retardancy Hardness (Shore A) Volume Resistivity (ohm-cm) UL94 V-0 >80 8 2x 10 Weight kg/m² (lbs/ft²) Relative Impedance 4.4 (0.9) 0.66 – 0.23 Tensile Strength (MPa) Elongation (%) Dielectric Strength (volts/mil) >3.5 >20 >20 Outgassing (%TML) (%CVCM)* 0.3/0.05 Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. * Outgassing data per ASTM E595-07; criteria for acceptability is 1.00% TML and 0.10% CVCM. APPLICATIONS • When placed within a cavity, Eccosorb MCS has proven to be very effective at dampening resonances due to the absorbers high permittivity and permeability as well as high loss values, which in turn reduces the overall VSWR. • It is designed for the suppression of surface currents over a wide range of frequencies. • It can be used for the suppression of creeping waves and reduction of cavity resonances in microwave modules. • It is also useful in reducing RF coupling of antennas and microwave components. AVAILABILITY • Standard sheets are 305 x 305mm (12”x12”), standard thickness is 1 mm (.040”) • It can be supplied with a Pressure Sensitive Adhesive (PSA) • Eccosorb MCS is available in other sizes, thicknesses and customer specified configurations upon request. Americas: +1.866.928.8181 Europe: +49.(0)8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com Eccosorb® MCS INSTRUCTIONS FOR USE • Eccosorb MCS is designed to function directly in front of a metallic surface. • The material can be bonded by use of an RTV silicone based adhesive in conjunction with a suitable primer. • To obtain a strong bond of the absorber to the object, the metallic surface should first be thoroughly cleaned with a degreasing solvent. • Eccosorb MCS can be readily cut with a sharp knife and template. It is a very flexible material and conforms to contoured surfaces. Typical Attenuation Eccosorb MCS RFP-DS-MCS 093015 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
21109154 价格&库存
很抱歉,暂时无法提供与“21109154”相匹配的价格&库存,您可以联系我们找货
