21544143
21544143
    LAIRD(莱尔德)
    SF-16.0 A11622 037-004197-003 RE
21544143 数据手册
Eccosorb® SF Thin, Flexible, Resonant Microwave Absorber RESONANT MICROWAVE ABSORBER Eccosorb SF is a narrow banded, magnetically loaded resonant absorber sheet for free-space applications. These silicone rubber sheets are designed to be bonded to flat or curved metallic surfaces to reduce the reflectivity in a narrow band of frequencies. Eccosorb SF reflects -20 dB or less of normally incident microwave energy at the design frequency in the range of 1 to 26 GHz. FEATURES AND BENEFITS MARKETS • High power performance • Narrow band performance • Low outgassing properties • Commercial Telecom • Security and Defense • Automotive SPECIFICATIONS TYPICAL PROPERTIES ECCOSORB SF Max service temperature °C (°F) Power Handling W/cm² 163 (325) 0.2 Hardness (Shore A) Density Range g/cm³ 73 2.4-4.5 Tensile Strength (MPa) Elongation at break % Tear Strength N/mm 1.0-6.0 20 - 100 0.2-2.0 Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. APPLICATIONS • Lining radar nacelles and the exterior of airframes particularly where high power is present. • Lining of cavity backed and shrouded telecommunication antennas where narrowband performance is required. • Lining metal surfaces of vehicles to reduce overall radar signature. • Attaching to masts of ships, walls, etc to reduce reflections and echoes from nearby antennas. • Lining magnetron housings to prevent detuning. • Fabricating into tapered shapes for impedance matching in waveguide or microstrip applications. • Lining metal surfaces to attenuate surface currents, suppressing reflections inside microwave modules, and dampening cavity resonances in microwave modules. • For module interference, cavity resonance and surface current problems, ECCOSORB® GDS, ECCOSORB® MCS and ECCOSORB® BSR are recommended due to their high magnetic loss properties, broad band performance, as well as the availability of a wider range of thicknesses (0.010” to 0.100”). Americas: +1.866.928.8181 Europe: +49.(0)8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com Eccosorb® SF AVAILABILITY • • • • Standard sheets are 305 x 305mm (12”x12”) Thickness varies depending on resonant frequency desired. Other resonant frequencies from 0.7 to 40 GHz can be supplied on special order The material can also be supplied in customized shapes and can be supplied with a pressure sensitive adhesive (PSA). INSTRUCTIONS FOR USE • Eccosorb SF is designed to function directly in front of a metallic surface. If this is not the case, a metallic foil should first be bonded to the object. • For optimum performance, material is recommended and can be supplied with a metal backing (-ML) • To obtain a strong bond of the absorber to the object, clean the surface with a degreasing solvent, apply a thin coat of primer to the dried surface and apply an RTV silicone adhesive. • Eccosorb SF can be readily cut with a sharp knife and template. It is a very flexible material and will conform to mild curvatures. RELATED PRODUCTS ® • For corrosive environments, see Eccosorb DSF ® • For better abrasion resistance, see Eccosorb SF-U Typical Reflectivity Performance The performance of ECCOSORB® SF is defined by reflectivity at a single frequency. A generalized performance curve is shown above. The design frequency f0, has a ±5% bandwidth, designated as f1 and f2. Although performance degrades with increased incidence angle, at incident angles out to 45°, reflectivity of -16dB has been demonstrated. RFP-DS-SF 081815 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. 2
21544143
物料型号:Eccosorb® SF
器件简介:Eccosorb SF是一种设计用于粘附在平坦或曲面金属表面的硅橡胶片,用于在1至26 GHz的频率范围内减少反射率。
引脚分配:文档中未提及引脚分配,因为Eccosorb SF是一种吸收材料,不是电子元件。
参数特性: - 最大工作温度:163°C (325°F) - 功率处理能力:0.2 W/cm² - 硬度(邵氏A):73 - 密度范围:2.4-4.5 g/cm³ - 拉伸强度:1.0-6.0 MPa - 断裂伸长率:20-100% - 撕裂强度:0.2-2.0 N/mm
功能详解:Eccosorb SF在设计频率下反射的微波能量通常低于-20 dB,适用于雷达整流罩衬里、通信天线、车辆金属表面、船桅、墙壁等,以减少雷达信号、反射和回声。
应用信息:适用于雷达整流罩衬里、通信天线衬里、车辆金属表面、船桅、墙壁等,以减少雷达信号、反射和回声。
封装信息:标准片尺寸为305 x 305mm (12”x12”),厚度根据所需的共振频率而变化。其他0.7至40 GHz的共振频率可以根据特殊订单提供。材料也可以提供定制形状,并可提供带压敏胶(PSA)的版本。
使用说明:Eccosorb SF设计为直接在金属表面前使用。如果不是这种情况,应首先将金属箔粘附到物体上。为了获得吸收材料与物体之间的强粘合,清洁表面,涂上一层底漆,然后涂上RTV硅胶粘合剂。
相关产品:对于腐蚀性环境,可查看Eccosorb® DSF;对于更好的耐磨性,可查看Eccosorb® SF-U。
典型反射率性能图表显示了Eccosorb® SF在单一频率下的反射率性能。设计频率f0具有±5%的带宽,指定为f1和f2。尽管在增加入射角时性能会降低,但在45°的入射角下,已经证明了-16dB的反射率。
版权信息:Laird Technologies, Inc. 版权所有。
21544143 价格&库存
很抱歉,暂时无法提供与“21544143”相匹配的价格&库存,您可以联系我们找货
