AL-WS-DR1
AL-WS-DR1
    ATXLED
    WALL SWITCH, 24W DIMMER / DRIVER
AL-WS-DR1 数据手册
ATX LED Consultants Inc 1108 Lavaca St STE 110-489 Austin TX, 78701 512 377 6052 http://atx-led.com AL-WS-DR1 Decorator style Constant Current LED Dimmer / Driver with integrated switch 24 watts 3-Way Product Description - AL-WS-DR1 wall switch This switch operates just like any standard residential light switch – however it takes 24-54v DC instead of 120VAC, and directly drives up to 24 watts of driverless LED fixtures and bulbs. This Decorator style switch in a standard residential style outline fits into any home, looks like any switch yet meets NEC article 411 for low voltage lighting. For 3-way operation – a simple 2 wire link with AWG24 or better allows 2, 3, or an unlimited numbers of switches to control one set of LED’s. Any single pole switch found at Home Depot can be used to add a 3-Way remote switch, or dual pole switch for an unlimited number of switch points. Stand alone it operates as a simple switch for a string of LED’s. Typically 1 to 4 LEDs with 660 mA ( 6 watts) each are connected for 24 watts total. Use AWG 16 or 18 to bring 48v ( or 24 to 54 volts ) from a central power supply over to the switches, then use AWG 18 to connect to your LEDs – no tools are required to wire this device. A proven rocker switch and brightness slider leverages mass production of decorator switches, now for low voltage applications – any casual user requires no training, no App to use this switch. Perfect, flicker free dimming from off to 10% to 100%. To enable Home / Business automation – the AL-WS-DR1 can be replaced by a AL-WS-DR2 which uses the DALI protocol, or the AL-WS-DR2W which uses WiFi – the wiring to the power panel and LEDs is the same. Specifications Power source and load LED constant current output 300 mA option Constant Voltage Input voltage range Standby power consumption Conversion efficiency Protection Operating Temperature Size Dimming FCC and interference Maximum output voltage Minimum output voltage Hot Swap External Switch Spring loaded connectors ( 2 pairs ) for AWG 16-20 wire 660 mA max current – one channel Spring loaded connectors Connect 4 LEDs with 660mA each Contact us for a 300 mA current option See the AL-WS-PWM2 for CV LEDs 24v to 54 volts DC 10 milliwatts Over 95% Reverse protection and static protection 0°C ~ 50°C 108H (metal) 70H x 34 D x 42 W mm 10 to 100 %, , Current control with temperature tracking All outputs are RF filtered for minimal interference Input minus 4 volts 6 volts Yes - can unplug and connect LEDs with power applied. Use with simple contact to turn the light on closed contact is ON Wiring the AL-WS-DR1 for up to 4 LEDs See http://atxled.com/How2 for more examples Powering the AL-WS-DR1 Power the switch via the Power input connectors, 48 to 54vdc is recommended. You can feed from the input to the output up to 2 amps. The output connectors allow multiple switches to share one home run. External switch input connection (N-Way) This input is used to turn the light on from a remote switch. A simple closed contact will turn the light on. Door Jam Operation A simple Normally Closed door alarm switch can be wired to the N-way input. Then – when the door opens – the light will go on. 3-Way diagrams Recommended ETL/UL listed LED’s LED rated watts Type Model Hole Size inch LED rating mA Max Count @54v Max Count @51v Total power output Watts 6 Flat Ceiling P023R6 4 660 5 4 30 5 in series 12 Flat Ceiling P023R11 6 1440 5 4 32*** 5 in series 6 Recessed DL-120 4 660 5 4 30 5 in series 6 Gimbal Spot MS31008 2.75 660 5 4 30 5 in series 6 Bulb AL-E26-660mA E26 660 5 4 30 5 in series 3 Bulb AL-E12-660mA E12 65 10 8 30 Use ALWS-DR1K 6 Bulb AL-E26-48v6w E26 120 5 5 36 use ALWS-DR1K 14 Closet FMMCL 18 840 S1 M4 18 360 * 2* 2 28 2x Parallel 7 Closet FMMCL 840 S1 M4 7 360 * 4* 4 28 2x Parallel 2x in series 4 / ft linear P023S12 18 1440 7.5 ft 6 ft 30 2 / ft linear P023S6 7,9,12 660 15 ft 14 ft 30 35 Strip AL-GL-48v30w 195 700 15 ft 15 ft 35 use ALWS-DR1K 6 Outdoor Small ODB6 5 660 5 4 30 5 in series Note
AL-WS-DR1 价格&库存
很抱歉,暂时无法提供与“AL-WS-DR1”相匹配的价格&库存,您可以联系我们找货
