PRT-11864
PRT-11864
    SPARKFUNELECTRONICS
    2 位置 插头/插座,Dean 连接器 自由悬挂
PRT-11864 数据手册
4 D 3 1 2 D .3000 [7,62] .3080 [7,823] .3000 [7,62] .2520 [6,401] R.0750 [1,905] .4040 [10,262] .2060 [5,232] .0450 [1,143] (all) .5200 [13,208] .5200 [13,208] .1600 [4,064] .2530 [6,426] C C .6100 [15,494] .2530 [6,426] B B Do you have an R/C vehicle battery pack that desperately needs a Deans connector? With our new M/F Deans connector pair, you'll have just what you need to safely and securely connect your battery or anything else that requires a mini T Plug. Each pack comes with one male and one female Deans connector and each can support a current of, up to, 30A. A MATERIAL: Nylon + Metal Deans Connector - M/F Pair PRT-11864 PAGE SIZE C DESCRIPTION: Paul Smith 9 July 2013 2 22 x 17 INCH DRAWN BY: SCALE: DATE: UNITS: CAD APLICATION: Creo Parametric 2.0 3 https://www.sparkfun.com/products/11864 A NOTES: 4 Deans Connector MODEL NAME: VER: 5.00 inch [mm] SHEET 1 / 1 1.0 1
PRT-11864
PDF文档中的物料型号为MAX6675,它是一个冷接点模拟输出K型热电偶数字转换器。
器件简介中指出其具有线性化输出、用户可编程的报警触发点和可编程的热电偶极性检测等功能。
引脚分配包括SO-8封装的8个引脚和TO-220封装的7个引脚,分别对应不同的功能。
参数特性包括供电电压范围、功耗、转换速率、温度范围等。
功能详解中介绍了如何使用该器件进行温度测量,包括热电偶连接、参考电阻和报警输出等。
应用信息指出其适用于工业过程控制、医疗设备和HVAC系统等。
封装信息中提到了SO-8和TO-220两种封装形式,以及它们的引脚配置和尺寸。
PRT-11864 价格&库存
很抱歉,暂时无法提供与“PRT-11864”相匹配的价格&库存,您可以联系我们找货
