SEN-11792
SEN-11792
    SPARKFUNELECTRONICS
    FINGERPRINT SCANNER TTL GT-511C3
SEN-11792 数据手册
Contents 1. 2. 3. 4. 5. Concept ................................................................................................................. 4 Protocol: Packet Structure .................................................................................. 6 Command Packet (Command) ....................................................................... 6 Response Packet (Acknowledge) ................................................................... 6 Data Packet (Data)............................................................................................. 6 Protocol: Commands Summary ......................................................................... 8 Protocol: Error Codes ........................................................................................ 10 Protocol: Command Details ............................................................................. 11 5.1. Initialization(Open) ......................................................................... 11 5.2. Termination(Close) .......................................................................... 13 5.3. Fast searching of the device(UsbInternalCheck)...................... 13 5.4. CMOS LED control(CmosLed) ....................................................... 14 5.5. Changing UART baud rate (ChangeBaudrate) ......................... 15 5.6. Get enrolled fingerprint count(GetEnrollCount) ...................... 16 5.7. Check enrollment status(CheckEnrolled) ................................... 16 5.8. Start an enrollment(EnrollStart) .................................................. 17 5.9. Make 1st template for an enrollment(Enroll1) ......................... 17 5.10. Make 2nd template for an enrollment(Enroll2) ........................ 18 5.11. Make 3rd template for an enrollment, merge three templates(Enroll3) ........................................................................................... 18 5.12. Check finger pressing status(IsPressFinger) ............................. 20 5.13. Delete one fingerprint(DeleteID) ................................................ 21 5.14. Delete all fingerprints(DeleteAll) ................................................ 21 5.15. 1:1 Verification(Verify) ................................................................... 22 5.16. 1:N Identification(Identify) ........................................................... 22 5.17. 1:1 Verification of Template(VerifyTemplate) .......................... 23 5.18. 1:N Identification of Template(IdentifyTemplate) .................. 24 5.19. Capture fingerprint(CaptureFinger) ........................................... 25 5.20. Make Template(MakeTemplate)................................................... 26 5.21. Get fingerprint image(GetImage) ................................................ 27 5.22. Get raw image(GetRawImage) ...................................................... 28 5.23. Get template(GetTemplate) ........................................................... 28 5.24. Set template(SetTemplate) ............................................................ 29 6. 7. 8. 5.25. Start database download, obsolete(GetDatabaseStart) ......... 29 5.26. End database download, obsolete(GetDatabaseEnd) ............. 30 5.27. Upgrade Firmware(UpgradeFirmware) ...................................... 31 5.28. Upgrade ISO CD Image(UpgradeISOCDImage) ....................... 31 5.29. Set IAP Mode(SetIAPMode).......................................................... 31 Protocol: Flowchart, description ...................................................................... 32 6.1 Capture of the fingerprint image ................................................ 32 6.2 Identifying and Verifying .............................................................. 32 6.3 Enrollment ......................................................................................... 32 PC Demo ............................................................................................................. 34 Mechanical Dimensions .................................................................................... 36 Storage environment Temperatur e Humidity -20℃ ~ +60℃ 10% ~ 80% 2. Protocol: Packet Structure (Multi-byte item is represented as Little Endian.) Command Packet (Command) OFFSET 0 1 2 4 8 ITEM 0x55 0xAA Device ID Parameter Command TYPE BYTE BYTE WORD DWORD WORD 10 Check Sum WORD DESCRIPTION Command start code1 Command start code2 Device ID: default is 0x0001, always fixed Input parameter Command code Check Sum (byte addition) OFFSET[0]+…+OFFSET[9]=Check Sum Response Packet (Acknowledge) OFFSET 0 1 2 ITEM 0x55 0xAA Device ID TYPE BYTE BYTE WORD 4 Parameter DWORD 8 Response WORD 10 Check Sum WORD DESCRIPTION Response start code1 Response start code2 Device ID: default is 0x0001, always fixed Response == 0x30: (ACK) Output Parameter Response == 0x31: (NACK) Error code 0x30: Acknowledge (ACK). 0x31: Non-acknowledge (NACK). Check Sum (byte addition) OFFSET[0]+…+OFFSET[9]=Check Sum Data Packet (Data) OFFSET 0 1 2 ITEM 0x5A 0xA5 Device ID TYPE BYTE BYTE WORD 4 Data N BYTES DESCRIPTION Data start code1 Data start code2 Device ID: default is 0x0001, always fixed N bytes Data The size is pre-defined per protocol stage 4+N Check Sum WORD Check Sum (byte addition) OFFSET[0]+…+OFFSET[4+N-1]=Check Sum 3. Protocol: Commands Summary In a command packet Command can be one of below. Number Alias Description (HEX) 01 Open Initialization 02 Close Termination 03 UsbInternalCheck Check if the connected USB device is valid 04 ChangeBaudrate Change UART baud rate Enter IAP Mode 05 SetIAPMode In this mode, FW Upgrade is available 12 CmosLed Control CMOS LED 20 GetEnrollCount Get enrolled fingerprint count Check whether the specified ID is already 21 CheckEnrolled enrolled 22 EnrollStart Start an enrollment 23 Enroll1 Make 1st template for an enrollment 24 Enroll2 Make 2nd template for an enrollment Make 3rd template for an enrollment, merge 25 Enroll3 three templates into one template, save merged template to the database 26 IsPressFinger Check if a finger is placed on the sensor 40 DeleteID Delete the fingerprint with the specified ID 41 DeleteAll Delete all fingerprints from the database 1:1 Verification of the capture fingerprint 50 Verify image with the specified ID 1:N Identification of the capture fingerprint 51 Identify image with the database 1:1 Verification of a fingerprint template with 52 VerifyTemplate the specified ID 1:N Identification of a fingerprint template 53 IdentifyTemplate with the database Capture a fingerprint image(256x256) from 60 CaptureFinger the sensor 61 MakeTemplate Make template for transmission Number (HEX) Alias 62 GetImage 63 GetRawImage 70 71 72 73 80 81 30 31 GetTemplate SetTemplate GetDatabaseStart GetDatabaseEnd UpgradeFirmware UpgradeISOCDImage Ack Nack Description Download the captured fingerprint image(256x256) Capture & Download raw fingerprint image(320x240) Download the template of the specified ID Upload the template of the specified ID Start database download, obsolete End database download, obsolete Not supported Not supported Acknowledge. Non-acknowledge. 4. Protocol: Error Codes When response packet is Non-acknowledge, Parameter represents an error code as below. NACK Parameter Value Description NACK_TIMEOUT 0x1001 Obsolete, capture timeout NACK_INVALID_BAUDRATE 0x1002 Obsolete, Invalid serial baud rate NACK_INVALID_POS 0x1003 NACK_IS_NOT_USED 0x1004 The specified ID is not between 0~199 The specified ID is not used NACK_IS_ALREADY_USED 0x1005 The specified ID is already used NACK_COMM_ERR 0x1006 Communication Error NACK_VERIFY_FAILED 0x1007 1:1 Verification Failure NACK_IDENTIFY_FAILED 0x1008 1:N Identification Failure NACK_DB_IS_FULL 0x1009 The database is full NACK_DB_IS_EMPTY 0x100A The database is empty NACK_TURN_ERR 0x100B NACK_BAD_FINGER 0x100C Obsolete, Invalid order of the enrollment (The order was not as: EnrollStart -> Enroll1 -> Enroll2 -> Enroll3) Too bad fingerprint NACK_ENROLL_FAILED 0x100D Enrollment Failure NACK_IS_NOT_SUPPORTED 0x100E NACK_DEV_ERR 0x100F NACK_CAPTURE_CANCELED 0x1010 The specified command is not supported Device Error, especially if Crypto-Chip is trouble Obsolete, The capturing is canceled NACK_INVALID_PARAM 0x1011 Invalid parameter NACK_FINGER_IS_NOT_PRESSED 0x1012 Finger is not pressed Duplicated ID There is duplicated fingerprint (while enrollment or setting template), This error describes just duplicated ID 0 – 199 5. Protocol: Command Details 5.1. Initialization(Open) Host Device COMMAND PACKET Command = Open Parameter = 0: not to get extra info Nonzero: to get extra info RESPONSE PACKET Response = Ack If host requested to get extra DATA PACKET Data = typedefstruct_devinfo { DWORDFirmwareVersion; DWORD IsoAreaMaxSize; BYTEDeviceSerialNumber[16]; } devinfo; Open command is used to initialize the device; especially it gets device’s static info. Description of devinfo structure Field FirmwareVersion IsoAreaMaxSize DeviceSerialNumber Sample Description Firmware version Maximum size of ISO CD image Unique serial number of the device If the Device’s Serial Number is zero, then there is no guarantee for stable operation of the device. 5.2. Termination(Close) Device Host COMMAND PACKET Command = Close RESPONSE PACKET Response = Ack Close command does nothing. 5.3. Fast searching of the device(UsbInternalCheck) Host Device COMMAND PACKET Command = UsbInternalCheck RESPONSE PACKET Response = Ack Parameter = 0x55 The device operates as removable CD drive. If another removable CD drive exists in the system, connection time maybe will be long. To prevent this, UsbInternalCheck command is used for fast searching of the device. 5.4. CMOS LED control(CmosLed) Device Host COMMAND PACKET Command = CmosLed Parameter = 0: Off LED Nonzero: On LED RESPONSE PACKET Response = Ack Default state of CMOS (Sensor) LED is OFF state. (But while booting, LED blinks once, this says the LED is OK.) Therefore, please issue LED ON command prior to any capture. 5.5. Changing UART baud rate (ChangeBaudrate) Device Host COMMAND PACKET Command = ChangeBaudrate Parameter = baud rate (9600~115200) RESPONSE PACKET Response = Ack: Response = Nack: Error NACK_INVALID_PARAM This command changes the UART baud rate at the run-time. The device initializes its UART baud rate to 9600 bps after power on. 5.6. Get enrolled fingerprint count(GetEnrollCount) Host Device COMMAND PACKET Command = GetEnrollCount RESPONSE PACKET Response = Ack Parameter = Enrolled Fingerprint Count 5.7. Check enrollment status(CheckEnrolled) Host COMMAND PACKET Command = CheckEnrolled Parameter = ID(0~199) Device RESPONSE PACKET Response = Ack: This ID is enrolled Response = Nack: Error NACK_INVALID_POS NACK_IS_NOT_USED 5.8. Start an enrollment(EnrollStart) Device Host COMMAND PACKET Command = EnrollStart Parameter = ID(0~199) If ID == -1, then “Enrollment without saving” will be stated. RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_DB_IS_FULL NACK_INVALID_POS NACK_IS_ALREADY_USED 5.9. Make 1st template for an enrollment(Enroll1) Host Device COMMAND PACKET Command = Enroll1 RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_ENROLL_FAILED NACK_BAD_FINGER Duplicated ID(0~199) 5.10. Make 2nd template for an enrollment(Enroll2) Device Host COMMAND PACKET Command = Enroll2 RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_ENROLL_FAILED NACK_BAD_FINGER Duplicated ID(0~199) 5.11. Make 3rd template for an enrollment, merge three templates(Enroll3) Host COMMAND PACKET Command = Enroll3 Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_ENROLL_FAILED NACK_BAD_FINGER Duplicated ID(0~199) If EnrollStart was called with ID == -1, then the enrolled template will not be saved, it will be transferred to the host, as below. DATA PACKET Data = enrolled template (498bytes) To enroll a fingerprint, the host must issue above 4 commands, later chapter describes how to organize these commands. 5.12. Check finger pressing status(IsPressFinger) Host Device COMMAND PACKET Command = IsPressFinger RESPONSE PACKET Response = Ack: Parameter = 0: finger is pressed Parameter = nonzero: finger is not pressed This command is used while enrollment, the host waits to take off the finger per enrollment stage. 5.13. Delete one fingerprint(DeleteID) Host COMMAND PACKET Command = DeleteID Parameter = ID(0~199) Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_INVALID_POS 5.14. Delete all fingerprints(DeleteAll) Host Device COMMAND PACKET Command = DeleteAll RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_DB_IS_EMPTY 5.15. 1:1 Verification(Verify) Host COMMAND PACKET Command = Verify Parameter = ID(0~199) Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_INVALID_POS NACK_IS_NOT_USED NACK_VERIFY_FAILED 5.16. 1:N Identification(Identify) Host Device COMMAND PACKET Command = Identify RESPONSE PACKET Response = Ack: OK Parameter = 0~199: identified ID Response = Nack: Error NACK_DB_IS_EMPTY NACK_IDENTIFY_FAILED 5.17. 1:1 Verification of Template(VerifyTemplate) Host COMMAND PACKET Command = Verify Parameter = ID(0~199) Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_INVALID_POS NACK_IS_NOT_USED DATA PACKET Data = a template (498 bytes) RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_COMM_ERR NACK_VERIFY_FAILED 5.18. 1:N Identification of Template(IdentifyTemplate) Host Device COMMAND PACKET Command = IdentifyTemplate RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_DB_IS_EMPTY DATA PACKET Data = a template (498 bytes) RESPONSE PACKET Response = Ack: OK Parameter = 0~499: identified ID Response = Nack: Error NACK_COMM_ERR NACK_IDENTIFY_FAILED 5.19. Capture fingerprint(CaptureFinger) Host COMMAND PACKET Command = CaptureFinger Parameter = 0: not best image, but fast Nonzero: best image, but slow Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_FINGER_IS_NOT_PRESSED The fingerprint algorithm uses 450dpi 256x256 image for its input. This command captures raw image from the sensor and converts it to 256x256 image for the fingerprint algorithm. If the finger is not pressed, this command returns with non-acknowledge. Please use best image for enrollment to get best enrollment data. Please use not best image for identification (verification) to get fast user sensibility. 5.20. Make Template(MakeTemplate) Host Device COMMAND PACKET Command = MakeTemplate RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_BAD_FINGER DATA PACKET Data = made template (498 bytes) This function makes template for transmission. CaptureFinger command should be previously issued. Do not use the template for registration. 5.21. Get fingerprint image(GetImage) Host Device COMMAND PACKET Command = GetImage RESPONSE PACKET Response = Ack: OK DATA PACKET Data = 258x202 image (52116 bytes) 5.22. Get raw image(GetRawImage) Host COMMAND PACKET Command = GetRawImage Device Capture raw image RESPONSE PACKET Response = Ack: OK DATA PACKET Data = 160x120 (19200 bytes) QVGA image 5.23. Get template(GetTemplate) Host COMMAND PACKET Command = GetTemplate Parameter = ID(0~199) Device RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_INVALID_POS NACK_IS_NOT_USED DATA PACKET Data = a template (498 bytes) 5.24. Set template(SetTemplate) Device Host COMMAND PACKET Command = SetTemplate Parameter = ID(0~199) (If Parameter’s HIWORD is non-zero, fingerprint duplication check will not be performed ) DATA PACKET Data = a template (498 bytes) RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_INVALID_POS RESPONSE PACKET Response = Ack: OK Response = Nack: Error NACK_COMM_ERR NACK_DEV_ERR Duplicated ID(0~199) 5.25. Start database download, obsolete(GetDatabaseStart) Host Device COMMAND PACKET Command = GetDatabaseStart RESPONSE PACKET Response = Ack GetDatabaseStart command does nothing. It exists for historical reason; it was used for RS232 communication. 5.26. End database download, obsolete(GetDatabaseEnd) Host Device COMMAND PACKET Command = GetDatabaseEnd RESPONSE PACKET Response = Ack GetDatabaseEnd command does nothing. It exists for historical reason; it was used for RS232 communication. 5.27. Upgrade Firmware(UpgradeFirmware) Not supported 5.28. Upgrade ISO CD Image(UpgradeISOCDImage) Not supported 5.29. Set IAP Mode(SetIAPMode) Host Device COMMAND PACKET Command = SetIAPMode RESPONSE PACKET Response = Ack The Device enter in IAP Mode, In this mode, FW upgrade is available. 6. Protocol: Flowchart, description 6.1 Capture of the fingerprint image IsPressFinger checks whether a finger placed on the sensor. This function is used especially while enrollment. CaptureFinger captures a fingerprint image (256x256), if a finger isn’t placed on the sensor, it returns with error. If this function returns with success, the device’s internal RAM keeps valid fingerprint image for the subsequent commands. If the host issues other command, the fingerprint image will be used and destroyed. GetRawImage captures a raw live image (320x240), it doesn’t check whether a finger placed on the sensor, this function is used for debug or calibration. 6.2 Identifying and Verifying Identify and IdentifyTemplate perform 1: N matching operation. Verify and VerifyTemplate perform 1: 1 matching operation. Just before calling of image-related matching functions (Identify, Verify), the host must call CaptureFinger. 6.3 Enrollment An enrollment flowchart is as below. 1. 2. 3. 4. 5. 6. EnrollStart with a (not used) ID CaptureFinger Enroll1 Wait to take off the finger using IsPressFinger CaptureFinger Enroll2 7. Wait to take off the finger using IsPressFinger 8. CaptureFinger 9. Enroll3 7. PC Demo PC demo program describes how to use the device with its source code. Command Alias UI item to test it Open, UsbInternalCheck, ChangeBaudrate Close GetEnrollCount CheckEnrolled, EnrollStart, Enroll1, Enroll2, Enroll3, IsPressFinger , Command Alias UI item to test it DeleteID DeleteAll Verify Identify VerifyTemplate IdentifyTemplate CaptureFinger, GetImage GetRawImage GetTemplate, GetDatabaseStart, GetDatabaseEnd , SetTemplate UpgradeFirmware UpgradeISOCDImage Demo program is supported with its source code. The project is Microsoft Visual C++ 6.0 project. We selected VC6.0 to minimize the size of the executable. The demo program checks whether it is running on removable CD drive, if it is the case, it copies itself to “My Document” folder and executes copied version. This is for direct access to the device’s removable CD drive.
SEN-11792 价格&库存
很抱歉,暂时无法提供与“SEN-11792”相匹配的价格&库存,您可以联系我们找货
