TG.46.8113
TG.46.8113
    TAOGLASLIMITED
    ANT APEX III WIDEBAND 5G/4G DIPO
TG.46.8113 数据手册
Apex IV Part No: TG.46.8113 Description: Apex IV Wideband 5G/4G Dipole Terminal Antenna 400MHz – 6000MHz with 90° Hinged SMA(M) Connector Features: Highest efficiency for 400-6000MHz wideband applications Worldwide 5G/4G Coverage Dipole Antenna Design – No Ground Plane Required Hinged 90° Termination with SMA(M) Connector Robust Metal Hinge Design for Improved Connection Reliability. Dimensions: 218 * 58mm RoHS & Reach Compliant SPE-20-8-094-B 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 8 4. Radiation Patterns 11 5. Mechanical Drawing 68 6. Installation Recommendations 69 7. Packaging 70 Changelog 71 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-20-8-094-B www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction Apex IV TG.46.8113 is a wideband 5G/4G dipole antenna that has been designed to cover all 1.The Taoglas Introduction sub 6GHz 5G/4G Cellular, ISM and Wi-Fi bands with frequencies in the 400 to 6000MHz spectrum. Evolved from the highly successful Apex range of products, the TG.46 has the highest wideband efficiency of any terminal antenna on the market today. Designed specifically for optimum performance 1.on 5G Introduction NR bands between 3.3-4.2GHz, the TG.46 exhibits a uniform omnidirectional radiation pattern that allows for truly uninterrupted 360° 5G connection reliability. Additionally, the extended lower frequency coverage at 410Mhz (Band 87) and 450Mhz (Band 31), makes the TG.46 ideal for a range of IoT applications, such as remote monitoring of smart utilities. 1. Introduction This attractive slim-line antenna is ground plane independent, meaning it does not need to be connected to the ground-plane of a device to radiate efficiently and neither is it in any way detuned by connecting to a ground-plane, thus avoiding a problem that is synonymous with smaller terminal mount 1.antennas. Introduction The TG.46 includes an SMA(M) connector as standard, and the swivel mechanism that allows the antenna to be rotated to fit in tight environments and positioned for optimum performance. The 90° metal hinge structure has been designed so that when the antenna is mounted in a 90° position, it retains its position if used in environments prone to vibration. The Apex IV has been primarily designed for use with wideband 5G/4G modules and devices that require the highest possible efficiency and peak gain to deliver best in class throughput on all major worldwide cellular bands for access points, terminals and routers. High efficiency is vital for applications such as high-speed video and real-time streaming or high capacity MIMO networks on public transportation. The Apex IV is backward compatible with 3G and 2G cellular applications such as HSPA, GSM, GPRS, UMTS, Wi-Fi and even has GPS included for Assisted GPS and/or E911 applications. SPE-20-8-094-B www.taoglas.com 3 In summary, the Apex IV is the ideal solution for any device requiring high, reliable performance. It will meet most types of approval or carrier certification requirements from an efficiency standpoint. The antenna also makes an excellent reference antenna for test purposes. It has been designed as an omnidirectional antenna and the radiation patterns prove this, being stable across all bands. The connector type is customizable and the housing is also available in white. Contact your regional Taoglas customer support team for more information. SPE-20-8-094-B www.taoglas.com 4 2. Specifications Electrical 3. Frequency Efficiency Average Gain Peak Gain Impedance Antenna Characteristics2. Specifications (MHz) (%) (dB) (dBi) Band B87 3. -0.84 Straight GP 36.5 -4.38 0.20 -5.57 -0.07 Straight FS 46.4 -3.34 1.84 Bent FS 45.7 -3.40 0.96 Straight GP 43.6 -3.61 1.52 Straight FS 63.7 -1.96 1.70 10W Linear Omni-Directional 450~470 Specifications Bent FS 76.2 -1.18 2.19 617~698 Straight GP 64.9 -1.87 2.21 Bent GP 71.0 -1.49 1.90 Straight FS 50.0 -3.01 1.70 Straight GP 48.4 -3.15 1.97 Bent GP 50.5 -2.96 1.26 Straight FS 36.7 -4.35 1.76 -3.03 2.57 Specifications -2.53 2.12 698~806 50 Ω 824~960 Straight GP 50.1 -3.01 3.12 Bent GP 57.0 -2.44 3.87 1427~1518 Straight GP 66.6 -1.77 2.31 Bent GP 66.7 -1.76 2.84 Straight FS 79.6 -0.99 3.98 Bent FS 87.3 -0.59 4.90 Straight GP 75.1 -1.24 Antenna Radiation Patterns 3.67 Bent GP 76.0 -1.19 4.43 Straight FS 69.9 -1.55 3.77 Bent FS 77.9 -1.09 5.05 Characteristics 4G/3G Band 1,2,3,4,9,23,25,35,39,66 4G/3G Band 7,30,38,40,41 1710~2200 2300~2690 Straight GP 64.7 -1.89 4.24 Antenna Radiation Patterns3. Antenna Characteristics 5GNR/4G Band 22,42,48,77,78,79 4. -5.84 Straight FS 69.1 -1.60 2.11 Antenna Radiation Patterns3. Antenna Bent FS 77.9 -1.09 3.15 5GNR/4G Band 21,32,74,75,76 4. 26.1 Antenna Characteristics Bent FS 49.8 4G/3G/NB-IoT/Cat M Band 5,8,18,19,20,26,27 4. Bent FS Antenna Characteristics2. Bent FS 55.9 4G/3G Band 12,13,14,17,28,29 4. 0.20 Radiation Pattern Antenna Radiation Patterns3. Antenna Bent GP 43.6 -3.61 1.27 Band 71 3. -4.38 Polarization 410~425 Characteristics2. 5GNR/4G 3. 36.5 Antenna Characteristics Bent GP 27.7 LTE 450 4. Straight FS Max Input Power Bent GP 66.1 -1.80 4.34 Straight FS 52.0 -2.84 4.36 Bent FS 58.2 -2.35 4.52 Straight GP 48.2 -3.17 3.70 Bent GP 47.1 -3.27 4.20 3300~4200 Antenna Radiation Patterns3.Antenna SPE-20-8-094-B Characteristics2. Specifications www.taoglas.com 5 LTE5200/ Wi-Fi 5800 Straight FS 56.7 -2.46 3.92 Bent FS 61.1 -2.14 4.45 Straight GP 41.1 -3.86 4.29 Bent GP 40.8 -3.90 4.64 5150~5925 *Test ground plane size: 150*90mm Mechanical Enclosure UV Resistant PC/ABS Connector SMA Male Hinged 90° Weight 75g Dimensions 218 * 58mm Recommended Torque for Mounting 0.9N∙m Max torque for Mounting 1.176N∙m Environmental Storage & Usage Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-20-8-094-B www.taoglas.com 6 Band Number B1 B2 B3 B4 B5 B7 B8 B9* B11 B12 B13 B14 B17 B18 B19 B20 B21 B22* B23* B24 B25 B26 B27* B28 B29 B30 B31 B32 B34 B35 B36 B37 B38 B39 B40 B41 B42 B43 B45 B46 B47 B48 B49 B50 B51 B52 B53 B65 B66 B68 B69 B70 B71 B72 B73 B74 B75 B76 B77 B78 B79 B85 B87 B88 SPE-20-8-094-B Uplink 1920 to 1980 1850 to 1910 1710 to 1785 1710 to 1755 824 to 849 2500 to 2570 880 to 915 1749.9 to 1784.9 1427.9 to 1447.9 699 to 716 777 to 787 788 to 798 704 to 716 815 to 830 830 to 845 832 to 862 1447.9 to 1462.9 3410 to 3490 2000 to 2020 1626.5 to 1660.5 1850 to 1915 814 to 849 807 to 824 703 to 748 2305 to 2315 452.5 to 457.5 1920 to 2010 1710 to 1780 698 to 728 1695 to 1710 663 to 698 451 to 456 450 to 455 1427 to 1470 698 to 716 410 to 415 412 to 417 5G/4G Bands 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Downlink Covered 2110 to 2170 ✓ 1930 to 1990 ✓ 1805 to 1880 ✓ 2110 to 2155 ✓ 869 to 894 ✓ 2620 to 2690 ✓ 925 to 960 ✓ 1844.9 to 1879.9 ✓ 1475.9 to 1495.9 ✓ 729 to 746 ✓ 746 to 756 ✓ 758 to 768 ✓ 734 to 746 ✓ 860 to 875 ✓ 875 to 890 ✓ 791 to 821 ✓ 1495.9 to 1510.9 ✓ 3510 to 3590 ✓ 2180 to 2200 ✓ 1525 to 1559 ✓ 1930 to 1995 ✓ 859 to 894 ✓ 852 to 869 ✓ 758 to 803 ✓ 717 to 728 ✓ 2350 to 2360 ✓ 462.5 to 467.5 ✓ 1452 to 1496 ✓ 2010 to 2025 ✓ 1850 to 1910 ✓ 1930 to 1990 ✓ 1910 to 1930 ✓ 2570 to 2620 ✓ 1880 to 1920 ✓ 2300 to 2400 ✓ 2496 to 2690 ✓ 3400 to 3600 ✓ 3600 to 3800 ✓ 1447 to 1467 ✓ 5150 to 5925 ✓ 5855 to 5925 ✓ 3550 to 3700 ✓ 3550 to 3700 ✓ 1432 to 1517 ✓ 1427 to 1432 ✓ 3300 to 3400 ✓ 2483.5 to 2495 ✓ 2110 to 2200 ✓ 2110 to 2200 ✓ 753 to 783 ✓ 2570 to 2620 ✓ 1995 to 2020 ✓ 617 to 652 ✓ 461 to 466 ✓ 460 to 465 ✓ 1475 to 1518 ✓ 1432 to 1517 ✓ 1427 to 1432 ✓ 3300 to 4200 ✓ 3300 to 3800 ✓ 4400 to 5000 ✓ 728 to 746 ✓ 420 to 425 ✓ 422 to 427 ✓ www.taoglas.com 7 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 VSWR 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-20-8-094-B www.taoglas.com 8 3.3 Efficiency 3.4 Peak Gain SPE-20-8-094-B www.taoglas.com 9 3.5 Average Gain SPE-20-8-094-B www.taoglas.com 10 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X Z 4. Antenna Radiation Patterns Teste on 150x90mm ground plane 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Test in free space SPE-20-8-094-B www.taoglas.com 11 4.2 3D and 2D Radiation Patterns – Bent on Ground Plane 418MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 12 4.3 3D and 2D Radiation Patterns – Bent in Free Space 418MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 13 4.4 3D and 2D Radiation Patterns – Straight on Ground Plane 418MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 14 4.5 3D and 2D Radiation Patterns – Straight in Free Space 418MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 15 4.6 3D and 2D Radiation Patterns – Bent on Ground Plane 460MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 16 4.7 3D and 2D Radiation Patterns – Bent in Free Space 460MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 17 4.8 3D and 2D Radiation Patterns –Straight on Ground Plane 460MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 18 4.9 3D and 2D Radiation Patterns – Straight in Free Space 460MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 19 4.10 3D and 2D Radiation Patterns – Bent on Ground Plane 658MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 20 4.11 3D and 2D Radiation Patterns – Bent in Free Space 658MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 21 4.12 3D and 2D Radiation Patterns – Straight on Ground Plane 658MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 22 4.13 3D and 2D Radiation Patterns – Straight in Free Space 658MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 23 4.14 3D and 2D Radiation Patterns – Bent on Ground Plane 752MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 24 4.15 3D and 2D Radiation Patterns – Bent in Free Space 752MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 25 4.16 3D and 2D Radiation Patterns –Straight on Ground Plane 752MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 26 4.17 3D and 2D Radiation Patterns – Straight in Free Space 752MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 27 4.18 3D and 2D Radiation Patterns – Bent on Ground Plane 892MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 28 4.19 3D and 2D Radiation Patterns – Bent in Free Space 892MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 29 4.20 3D and 2D Radiation Patterns – Straight on Ground Plane 892MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 30 4.21 3D and 2D Radiation Patterns – Straight in Free Space 892MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 31 4.22 3D and 2D Radiation Patterns – Bent on Ground Plane 1473MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 32 4.23 3D and 2D Radiation Patterns – Bent in Free Space 1473MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 33 4.24 3D and 2D Radiation Patterns –Straight on Ground Plane 1473MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 34 4.25 3D and 2D Radiation Patterns – Straight in Free Space 1473MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 35 4.26 3D and 2D Radiation Patterns – Bent on Ground Plane 1582MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 36 4.27 3D and 2D Radiation Patterns – Bent in Free Space 1582MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 37 4.28 3D and 2D Radiation Patterns – Straight on Ground Plane 1582MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 38 4.29 3D and 2D Radiation Patterns – Straight in Free Space 1582MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 39 4.30 3D and 2D Radiation Patterns – Bent on Ground Plane 1795MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 40 4.31 3D and 2D Radiation Patterns – Bent in Free Space 1795MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 41 4.32 3D and 2D Radiation Patterns –Straight on Ground Plane 1795MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 42 4.33 3D and 2D Radiation Patterns – Straight in Free Space 1795MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 43 4.34 3D and 2D Radiation Patterns – Bent on Ground Plane 1920MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 44 4.35 3D and 2D Radiation Patterns – Bent in Free Space 1920MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 45 4.36 3D and 2D Radiation Patterns – Straight on Ground Plane 1920MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 46 4.37 3D and 2D Radiation Patterns – Straight in Free Space 1920MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 47 4.38 3D and 2D Radiation Patterns – Bent on Ground Plane 2045MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 48 4.39 3D and 2D Radiation Patterns – Bent in Free Space 2045MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 49 4.40 3D and 2D Radiation Patterns –Straight on Ground Plane 2045MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 50 4.41 3D and 2D Radiation Patterns – Straight in Free Space 2045MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 51 4.42 3D and 2D Radiation Patterns – Bent on Ground Plane 2333MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 52 4.43 3D and 2D Radiation Patterns – Bent in Free Space 2333MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 53 4.44 3D and 2D Radiation Patterns – Straight on Ground Plane 2333MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 54 4.45 3D and 2D Radiation Patterns – Straight in Free Space 2333MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 55 4.46 3D and 2D Radiation Patterns – Bent on Ground Plane 2590MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 56 4.47 3D and 2D Radiation Patterns – Bent in Free Space 2590MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 57 4.47 3D and 2D Radiation Patterns –Straight on Ground Plane 2333MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 58 4.48 3D and 2D Radiation Patterns – Straight in Free Space 2590MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 59 4.49 3D and 2D Radiation Patterns – Bent on Ground Plane 3550MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 60 4.50 3D and 2D Radiation Patterns – Bent in Free Space 3550MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 61 4.51 3D and 2D Radiation Patterns – Straight on Ground Plane 3550MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 62 4.52 3D and 2D Radiation Patterns – Straight in Free Space 3550MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 63 4.53 3D and 2D Radiation Patterns – Bent on Ground Plane 5538MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 64 4.54 3D and 2D Radiation Patterns – Bent in Free Space 5538MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 65 4.55 3D and 2D Radiation Patterns –Straight on Ground Plane 5538MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 66 4.56 3D and 2D Radiation Patterns – Straight in Free Space 5538MHz XZ Plane SPE-20-8-094-B YZ Plane XY Plane www.taoglas.com 67 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-094-B Mechanical Drawing www.taoglas.com 68 6. TG.46 Installation Instructions The TG.46 antenna has an independent rotating SMA connector which enables the user to install the antenna in their preferred orientation. Once tightened, the SMA connector will hold the antenna in 4.place. Antenna Patterns3. Antenna The following Radiation illustrations show the TG.46 used on a wall mounted device as an example. Characteristics Step 1: Adjust the antenna to the preferred orientation having placed it on the SMA(F) connector of the device. Step 2: the antenna with on hand, rotate the SMA(M) connector with the other until it is fully 4.While holding Antenna Radiation Patterns tightened. When tightened with the required force, the antenna will hold it’s position without shifting, even when exposed to high vibration environments. 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Note: If using a torque wrench, the recommended force for mounting the antenna is 0.9Nm, maximum torque to prevent damage to the antenna is 1.17Nm. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-20-8-094-B www.taoglas.com 69 8. 7. Packaging 6. 1pc TG.46.8113 Packaging5. Mechanical Drawing per Small PE Bag with Video Link label 6. 280mm Dimensions: 100*280mm Weight: 73.5g Packaging 100mm 7. Application Note6. Packaging5. Mechanical 25pcs per Large PE Bag Dimensions: 280*430mm Weight: 1.85Kg 430mm Drawing 6. 6. Packaging5. Mechanical Drawing 280mm 75pcs TG.46.8113 per Carton Carton Dimensions: 320*250*290mm Weight: 6.1Kg Packaging 7. Application Note6. Packaging 290mm 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. 320mm 250mm Mechanical Drawing 6. Packaging5. SPE-20-8-094-B Mechanical Drawing www.taoglas.com 70 Changelog for the datasheet SPE-20-8-094 – TG.46.8113 Revision: B (Update)) Date: Notes: Author: 2023-10-04 Updated Spec Table to include Band 87. Gary West Previous Revisions Revision: A (Original First Release) Date: Notes: 2020-09-15 Author: Jack Conroy SPE-20-8-094-B www.taoglas.com 71 www.taoglas.com SPE-20-8-094-B © Taoglas 72 www.taoglas.com
TG.46.8113 价格&库存
很抱歉,暂时无法提供与“TG.46.8113”相匹配的价格&库存,您可以联系我们找货
TG.46.8113
    • 1+186.20280
    • 200+72.05760
    • 500+69.53040
    • 1000+68.27760
    TG.46.8113
