LVHC-LPW150/1-PC36K-18
    LUMINUS(朗明纳斯)
    15A 18V LED 驱动器 AC DC 转换器 拓扑 1 输出
LVHC-LPW150/1-PC36K-18 数据手册
DATASHEET / LVHC-LPW150/1-PC36K-18 LVHC (Low Voltage High Current) LED Driver Product Offering LED driver board capable of driving 36A at low voltages Adjustment to set max current Fast Driver Switching Frequency (420KHz) Custom Pulse Shaping • • Opto-isolated Input terminals Fast Switching Response (Min. Pulse Width = 8µs) Monitor Driver and LED parameters through test points: • Forward Voltage (Vf) and Forward Current (If) • Forward Current (If) with Pulsed Input (Measured w/Duty Cycle) Active thermal management • • Monitor LED Temperature Back off drive current to maintain safe working temperatures Board size: 70 x 70 x 35mm (including fan) Input / Output Characteristics Input Voltage 12 or 24Vdc Output Power (Max.) (onboard dial) 150W Up to 8Vdc (Vin=12V) Up to 18Vdc (Vin=24V) 1 – 30A (static current) 1 – 36A (pulse current) Output Current Ripple < 5% @ 420KHz Efficiency (with 1.2W fan) 92% (typ.) Driver Switching Frequency 420KHz Output Voltage Output Current Range Custom Pulse Shaping (Pulse+ / Pulse-) * Monitoring Features LED Temp. Monitoring Input Thermistor_IN LED Temp. Monitoring Output LED_TEMP_SCALED LED Output Voltage Monitoring Pulse Input: ACTIVE LOW Opto-isolator 5V (min) 8V (max) LED output ON when Pulse Input is LOW Min. Pulse Width Output Current Switching Response Time 8µs Rise Time < 2µs Fall Time < 5.5µs LED Output Current Pulsed LED Output Current (Pulsed Duty Cycle Current) LED_VOUT IL_SCALED (Accuracy ± 5%) I_LED_SCALED (Accuracy ± 5%) Pulsed Output Current Overshoot < 35% Pulse Input (Isolated Input) Pulse Input Voltage (Pk-Pk) * J5 - Thermistor input is required for driver operation. Driver will limit output current to less than 2A if no thermistor connection is detected. The LED thermal protection function can be bypassed by placing a 10KΩ resistor across J5. Note that in doing so, the LVHC driver will not be able to detect excessive high-temperature LED operation. Thermistor wiring is interchangeable (no polarity) ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 Functional Block Diagram Input Ports VDC Input [J1] Vin+ Vin- Pulse Shaping [J3] Pulse+ Pulse- Thermistor Input [J5] +5V Thermistor_IN Output Ports LED Output [J2] Scaled Output [J4] LED+ LED- • • • • • • • • Vin=12V (Support Vout up to 8Vdc) Vin=24V (Support Vout up to 18Vdc) Opto-isolated Input terminals Pk-Pk 5V (min) / 8V (max) LED output ON when Pulse Input is LOW Fast Switching Response (Min. Pulse Width = 8µs) 10KΩ thermistor input Thermistor wiring is interchangeable (no polarity) • LED Output ports for LED connection By measuring voltage across monitoring pins to calculate the required parameters - LED Output Current IL_SCALED • • LED Output Current (without Pulse Duty Cycle counted Current (A) = 0.88 + [Voltage (V) x 20.7 - Pulsed LED Output Current I_LED_SCALED • • LED Output Current (with Pulse Duty Cycle counted) i.e. 36A LED Output Current with 10% Duty-Cycle Pulse = 3.6A Current (A) = 0.88 + [Voltage (V) x 20.7 LED_VOUT • Measure the LED voltage LED_TEMP_SCALED • translates LED temperature into a voltage (tuned with Murata NCP18XH103J03RB)  LED Temperature (°C) = 39*LN(LED_TEMP_SCALED) + 90 - LED Output Voltage Monitoring - LED Temp. Monitoring Output 12VDC Output [J6, J7] 2x 12V DC output connectors (J6 & J7) are provided +/- [J6] +/- [J7] • Used – for driver on-board cooling fan • Available for user – i.e. for LED cooling fan) ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 LED Output Current Setting [R12] • LED output current is set by turning R12  clockwise to increase current  counterclockwise to decrease current LED Output Current Monitoring [J4]  IL_SCALED  LED Output Current (without Pulse Duty Cycle counted  Current (A) = 0.88 + [Voltage (V) x 20.7  Current Accuracy ± 5%  I_LED_SCALED  LED Output Current (with Pulse Duty Cycle counted)  i.e. 36A LED Output Current with 10% Duty-Cycle Pulse = 3.6A  Current (A) = 0.88 + [Voltage (V) x 20.7  Current Accuracy ± 5% ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 Custom Pulse Shaping [J3]  Pulse +  Pulse • Input Signal (Pk-Pk): 5V (min) / 8V (max) • Pulse Input: ACTIVE LOW  LED output ON when Pulse Input is LOW • Fast Switching Response (Min. Pulse Width = 8µs) Output Current Pulse Switching Response • Output Current / Voltage dependent Output Voltage (V) 3 Output Current (A) 30 Rise Time (µs) 1.2 Fall Time (µs) 3.9 5 30 1.4 5.5 10 30 1.2 2.8 18 15 2 1 ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 LED Temperature Monitoring [J4]  LED_TEMP_SCALED  Translates LED temperature into a voltage (tuned with Murata NCP18XH103J03RB)  LED Temperature (°C) = 39*LN(LED_TEMP_SCALED) + 90 ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 Active Thermal Management with Thermistor Input [J5]  THERMISTOR_IN / +5V  10KΩ thermistor input  Thermistor wiring is interchangeable (no polarity)  90°C maximum LED temperature: If thermistor readings are over 90°C, driver will reduce current output to LED, reducing overall power to prevent the LED from overheating. The more the temperature is exceeded, the greater the reduction of output current.  Thermistor input is required for driver operation. Driver will limit maximum current output to less than 2A if no thermistor connection is detected. o The LED thermal protection function can be bypassed by placing a 2KΩ-10KΩ resistor across J5. Note that in doing so, the LVHC driver will not be able to detect excessive high-temperature LED operation.  The below graph shows how the LVHC driver limits maximum current output to protect the LED. Note that using a different thermistor from the one specified will alter its behavior during high-temperature operation (per the above graph). ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03 DATASHEET / LVHC-LPW150/1-PC36K-18 LVHC Compatibility Table With Luminus Specialty LEDs CBM-90 CBT-39 CFT-90 PT-26 SBT-70 IR / IRD UV / W W / CG B / CG / RA B/G CBM-120 CBT-90 PT-39-TE SBT-90 UV / FR W/B/G/R UV B / G / DR W/R CBT-140 PTM-40 W B / CG / RA PT-50 B / CG / RA PT-54 B / G / RAX PT-120/121 B / G / RAX ©2021 Cuvee Systems. All rights reserved. All content contained herein is subject to change without prior notice. More product documentation and Cuvée Systems’ warranty and terms and conditions are available at www.cuveesystems.com. LVHC-LPW150 rev03
LVHC-LPW150/1-PC36K-18 价格&库存
很抱歉,暂时无法提供与“LVHC-LPW150/1-PC36K-18”相匹配的价格&库存,您可以联系我们找货
