MM042602-4
MM042602-4
    DBUNLIMITED
    DIGITAL MEMS MICROPHONE
MM042602-4 数据手册
4 3 2 1 Part Number: DRAWN 9/23/2016 CJ MM042602-4 CHECKED 9/23/2016 P.D Description: D APPROVED Digital MEMS Microphone 9/23/2016 J.S This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View 3.76 1.24 Bottom View 0.21 C 0.71 C Top View D 0. 91 3.56 1 5 2 4 3 XX 1.65 Ø0.84 4.72 4.52 0.21 1.65 6 Ø0.91 2.34 0.71 Identification Number B B PIN 1 GND A Items Specifications Directivity Omnidirectional PIN 2 LR SEL PIN 3 GND PIN 4 CLOCK PIN 5 OUTPUT PIN 6 VDD Conditions Sensitivity -26 dB Frequency Range 100 ~ 7,000 Hz Rated Voltage 2.1 V Voltage Range 1.64 ~ 3.6 V REVISION HISTORY REV DESCRIPTION DATE Released from Engineering 9/23/2016 J.S. 1 Added pin out 7/7/2017 C.E. 2 Updated current, pin labels, voltage range, height 12/21/2017 C.E. Max. Rated Current 800 µA Storage Temperature -40 ~ +125 °C NOTES Operating Temperature -40 ~ +100 °C 1) All dimensions are in mm unless otherwise noted 2) All tolerances are ± 0.15 mm unless otherwise noted Signal to Noise Ratio 58 dBA Max. Rated Current (SLEEP mode) 50 µA Mount Type Surface Mount Connection Method 4 Surface Mount Pads APPROVED 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MM042602-4 价格&库存
很抱歉,暂时无法提供与“MM042602-4”相匹配的价格&库存,您可以联系我们找货
MM042602-4
  • 1250+11.188041250+1.44735
  • 2500+10.434942500+1.34992
  • 3750+10.403313750+1.34583
库存:1500
MM042602-4
  • 1+21.605421+2.79499
  • 10+16.9192510+2.18877
  • 25+15.4055925+1.99295
  • 50+14.3627950+1.85805
  • 100+13.40211100+1.73377
  • 250+12.73367250+1.64730
库存:1500
