4
3
2
1
Part Number:
DRAWN
MM034202-15
7/26/2018
CJ
CHECKED
8/16/2018
C.H.
Description:
APPROVED
Analog MEMS Microphone
D
8/16/2018
C.E.
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
C
Top View
Side View
2.95
1.10
Bottom View
1.70
C
2.55
0.80
1
4
2
3
2.46
0.50
3.76
3.36
1.18
R0.25
B
B
0.80
Pin 1
VDD
Items
Specifications
Directivity
Omnidirectional
Sensitivity
A
-42
Pin 2
GND
Pin 3
GND
Pin 4
OUTPUT
Conditions
1
dB
Frequency Range
30 ~ 10,000
Hz
Rated Voltage
2
V
Voltage Range
1.6 ~ 3.6
V
Output Impedance
300
Max. Rated Current
0.1
mA
Power Supply Rejection
-90
dB
NOTES
Storage Temperature
-40 ~ +105
C
1) All dimensions are in mm unless otherwise noted
Operating Temperature
-40 ~ +105
C
Signal to Noise Ratio
60
dB
Mount Type
Surface Mount
Connection Method
4
Surface Mount Pads
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
8/16/2018
C.E.
2) All tolerances are
0.1 mm unless otherwise noted
3) All parts meet RoHS
4) Subject to change or redrawn without notice
3
2
1
A
很抱歉,暂时无法提供与“MM034202-15”相匹配的价格&库存,您可以联系我们找货
