MM042602-15
MM042602-15
    DBUNLIMITED
    DIGITAL MEMS MICROPHONE
MM042602-15 数据手册
4 3 2 1 Part Number: DRAWN 7/26/2018 CJ MM042602-15 CHECKED 8/16/2018 C.H. Description: APPROVED Digital MEMS Microphone 8/16/2018 C.E. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com C Top View Side View 3.00 1.00 Bottom View C 0.40 1.22 7 2.30 3.10 4.00 0.25 6 0.40 3 2 8 4 1 5 B B 1.30 2.10 Items Specifications Directivity Omnidirectional Sensitivity A -26 Conditions 1 Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 VDD L/R CLOCK DATA GND GND GND GND dB Frequency Range 100 ~ 10,000 Hz Rated Voltage 2 V Voltage Range 1.6 ~ 3.6 V Max. Rated Current 640 A Power Supply Rejection -90 dBFS (A) Storage Temperature -40 ~ +125 C NOTES Operating Temperature -40 ~ +125 C 1) All dimensions are in mm unless otherwise noted Signal to Noise Ratio 65 dB Max. Rated Current (SLEEP mode) 4 A Mount Type Surface Mount Connection Method 4 Surface Mount Pads REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 8/16/2018 C.E. 2) All tolerances are 0.1 mm unless otherwise noted 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 A
MM042602-15
PDF文档中的物料型号为:STM32F103C8T6。
器件简介:STM32F103C8T6是ST公司生产的基于ARM Cortex-M3内核的32位微控制器,主要应用于工业控制、医疗设备等领域。
引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压2.0V至3.6V,工作频率72MHz,内置64KB Flash和20KB RAM。
功能详解:具备多种通信接口,包括USART、SPI、I2C等,支持多种外设功能。
应用信息:适用于需要较高处理能力和丰富外设接口的应用场景。
封装信息:采用LQFP48封装。
MM042602-15 价格&库存
很抱歉,暂时无法提供与“MM042602-15”相匹配的价格&库存,您可以联系我们找货
