MO044202-5
MO044202-5
    DBUNLIMITED
    OMNIDIRECTIONAL ELECTRET CONDENS
MO044202-5 数据手册
Insert Graphics Specifications Description Value Unit Directivity Omnidirectional Technology Electret Condenser Sensitivity Frequency Range Rated Voltage -42 (dB) (Hz) 2 (V) 2,200 Connection Method Solderless Voltage Range 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS 50 ~ 16,000 Output Impedance 2 ~ 10 Notes Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S (Ohm) (V) Max Rated Current 0.5 (mA) Drawn by Date Checked by Date Approved by Date Minimum Signal to Noise Ratio >60 (dB) A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Operating Temperature -20 ~ +70 °C Storage Temperature -40 ~ +85 °C Electret Condenser Microphone MO044202-5 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
MO044202-5 价格&库存
很抱歉,暂时无法提供与“MO044202-5”相匹配的价格&库存,您可以联系我们找货
