MM042602-5
MM042602-5
    DBUNLIMITED
    DIGITAL MEMS MICROPHONE
MM042602-5 数据手册
4 3 2 1 Part Number: DRAWN MM042602-5 4/25/2016 CJ CHECKED 4/25/2016 P.D Description: D Digital MEMS Microphone APPROVED 4/25/2016 J.S This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View 0.40 3.00 1.00 1.50 D 0.40 0.45 0.45 C 0.40 C 1 4 8 6 2.30 0.95 4.00 3.64 0.40 1.40 5 XX 2 0.45 3 2.85 0.25 0.40 7 0.40 1.30 Identification Number 0.85 B B PIN 1 CLOCK A Items Specifications Directivity Omnidirectional PIN 2 OUTPUT PIN 3 VDD PIN 5 GND PIN 4 LR SEL PIN 6 GND PIN 7 GND PIN 8 GND Conditions Sensitivity -26 dB Frequency Range 100 ~ 7,000 Hz Rated Voltage 2.1 V Voltage Range 1.64 ~ 3.6 V REVISION HISTORY REV 1 DESCRIPTION DATE Released from Engineering 4/25/2016 J.S. 12/21/2017 C.E. Updated max rated current, SLEEP current, dimension Max. Rated Current 800 µA Storage Temperature -40 ~ +125 °C NOTES Operating Temperature -40 ~ +100 °C 1) All dimensions are in mm unless otherwise noted 2) All tolerances are ± 0.15 mm unless otherwise noted Signal to Noise Ratio 58 dBA Max. Rated Current (SLEEP mode) 50 µA Mount Type Surface Mount Connection Method 4 Surface Mount Pads callout, PIN table APPROVED 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MM042602-5 价格&库存
很抱歉,暂时无法提供与“MM042602-5”相匹配的价格&库存,您可以联系我们找货
