MO044202-1
MO044202-1
    DBUNLIMITED
    MIC COND ANALOG OMNI -42DB 4MM D
MO044202-1 数据手册
Insert Graphics Specifications Description Value Unit Directivity Omnidirectional Technology Electret Condenser Sensitivity Frequency Range Rated Voltage -42 (dB) (Hz) 2 (V) 2,200 Connection Method Solderless Voltage Range 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS 100 ~ 16,000 Output Impedance 2 ~ 10 Notes Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S (Ohm) (V) Max Rated Current 0.5 (mA) Drawn by Date Checked by Date Approved by Date Minimum Signal to Noise Ratio >60 (dB) A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Operating Temperature -20 ~ +60 °C Storage Temperature -25 ~ +70 °C Electret Condenser Microphone MO044202-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
MO044202-1 价格&库存
很抱歉,暂时无法提供与“MO044202-1”相匹配的价格&库存,您可以联系我们找货
MO044202-1
  • 1+19.984241+2.59735
  • 10+15.9424810+2.07205
  • 100+13.24798100+1.72184
库存:200
MO044202-1
  • 7+19.984247+2.59735
库存:200
