TE122001-3
TE122001-3
    DBUNLIMITED
    插件,D=12mm
    ELECTRO-MECHANICAL TRANSDUCER
TE122001-3 数据手册
Insert Graphics Specifications Description Technology Resonant Frequency Value Unit Electro-Mechanical 2,048 (Hz) Rated Voltage 1.5 (V) SPL @ 10cm 85 (dBA) Coil Resistance 6.5 (ohm) Mount Type Voltage Range Max Rated Current Housing Material 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S Thru-hole 1~3 80 (V) (mA) NORYL Operating Temperature -20 ~ +60 °C Storage Temperature -20 ~ +60 °C 2 (g) Weight Notes Drawn by Date Checked by Date Approved by Date A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Electro-Mechanical Transducer TE122001-3 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
TE122001-3 价格&库存
很抱歉,暂时无法提供与“TE122001-3”相匹配的价格&库存,您可以联系我们找货
TE122001-3
    • 1+5.24880
    • 200+2.03040
    • 500+1.96560
    • 1000+1.92240
