TP393409-1
TP393409-1
    DBUNLIMITED
    插件,D=39mm
    PIEZO TRANSDUCER
TP393409-1 数据手册
4 3 2 1 Part Number: DRAWN 5/23/2019 CJ TP393409-1 CHECKED 5/28/2019 C.H. Description: APPROVED Piezo Transducer D 5/28/2019 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View C Bottom View Side View Ø39.9 15.7 C 3 - 4.0 120° 4.0 G 8 ± 0.3 10.5 ± 0.3 D 17.9 2 - 2.0 Date Code Marking "19 E" 19=2019, E=May M 120° 4.8 11.9 Sound Emission Hole 2.5 5.8 2.0 B 19.6 ± 0.4 A 7.5 F Items Specifications Conditions Min. Sound Pressure Level 104 dB (@ 10cm) Resonant Frequency 3,400 Hz Rated Voltage 9 V Voltage Range 3 ~ 15 Max. Rated Current B 25.0 REVISION HISTORY REV DESCRIPTION DATE APPROVED V Released from Engineering 10/21/2013 J.S. 9 mA Updated to new template, temps, current, voltage range, Storage Temperature -40 ~ +90 °C 5/28/2019 C.E. Operating Temperature -40 ~ +85 °C 1 dimensions, housing material NOTES Connection Method PC Pins 1) All dimensions are in mm unless otherwise noted Mount Type Thru Hole 2) All tolerances are ± 0.5 mm unless otherwise noted Housing Material PBT Weight 14.5 4 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
TP393409-1 价格&库存
很抱歉,暂时无法提供与“TP393409-1”相匹配的价格&库存,您可以联系我们找货
