MB312-500M02EFY
MB312-500M02EFY
    DECA(进联端子)
    PCB TERMINAL BLOCK, 5.00MM, 2 PO
MB312-500M02EFY 数据手册
MB312 PCB Terminal Block, 2.54mm, 5.00mm, 5.08mm, 7.50 mm and 7.62mm pitches MB312-254, 500, 500M, 500M..W, 508, 508M, 750, 750M, 750M..W, 762M MB312 PCB Terminal Block, Single Mold MB MB312-254 MB312-500 DIMENSIONS/POSITIONS MB312-254 MB312-500 敺巄 Pitch 2.54mm 5.00mm ἴ㕟 Poles 2 ~ 24Poles 2 ~ 24Poles ⠸冇㜓檻 Housing Material PA 66 PA 66 ⢺䷁⛯ Cage Clamp Brass, Ni Plated Brass, Ni Plated 䫖⬷ Contact Brass, Tin Plated Brass, Tin Plated 垡䳲 Screw Thread M1.6, Steel, Zinc Plated M2.6, Steel, Zinc Plated 曢䷁䷁⽸ Wire Size 20 ~ 26AWG 12 ~ 26AWG ≄䷁敞⺍ Wire Strip Length 4.5mm 7mm PCB⬻⽸ PCB Hole Diameter 1.2mm 1.5mm 㛧⤎䶱⛡㉔䟐 Tightening Torque, Max. 1.32 Lb-in 5.0 Lb-in 䒗⡪ὃ㥔㺒⺍ Operating Temperature Û&WRÛ& Û&WRÛ& 6A 16A TECHNICAL DATA 怊㎌䬍⏯㨀㹽 Connection in acc. with standard EN-VDE 栴⮁曢㴨lN Nominal Current lN 栴⮁㩒㈑杉 Nominal Cross Section 2.5mm 㛧⤎岇廰曢㴨 Maximum load current 6A 16A 䴼䷊㜷㖀 Insulating Material PA PA V0 V0 栴⮁曢⢺,UL/CUL Nominal voltage, UL/CUL 125V 300V 栴⮁曢㴨,UL/CUL Nominal current, UL/CUL 6A 16A 10.2 (0.402”) 3.10 (0.122”) 0.90 0.50 (0.035”) (0.020”) 1.50 (0.059”) 3.10 2.54 (0.122”) (0.100”) 1.50 (0.059”) Ø1.2 (Ø0.047”) 2.54 (0.100”) 3.50 (0.138”) 8.50 (0.334”) 3.50 (0.138”) 5.00xP 0.80 (0.031”) 5.40 (0.213”) 2.50 (0.098”) 2.50 (0.098”) 5.40 (0.213”) 2.54xP+0.46mm 14.0 (0.551”) 6.20 (0.244”) 2.5mm2 1.00 (0.039”) 5.00 (0.197”) Ø1.5 (Ø0.059”) 10.2 (0.402”) 昢䆪䬰䴁,䬍⏯UL94 ,QÀDPPDELOLW\FODVVDFFWR8/ 2 5.00 (0.197”) 58
MB312-500M02EFY 价格&库存
很抱歉,暂时无法提供与“MB312-500M02EFY”相匹配的价格&库存,您可以联系我们找货
