CWD-24050 5E3TM
CWD-24050 5E3TM
    DIWELL
    DIP8 模块
    隔离模块 直流转换器 2 输出 5V -5V 300mA,300mA 18V - 72V 输入
CWD-24050 5E3TM 数据手册
CW SERIES 3W-6W WIDE INPUT RANGE FEATURES         3W TO 6W DIL & SMD PACKAGE 4.5-9V,9-18V,18-36V,36-72V,9-36V,18-72V WIDE INPUT RANGE 100% BURN IN HIGH EFFICIENCY UL94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE RoHS COMPLIANT 3 YEARS WARRANTY OUTPUT SPECIFICATIONS INPUT SPECIFICATIONS Voltage Setpoint Accuracy Input Voltage Range Single/Dual Dual Separate Triple 2:1 or 4:1 Input Range +/-2% max. Input Filter Pi Network Out1 +/-2% max. Protection Fuse Recommended Out2 +/-5% max. Remote ON/OFF Control Out1 +/-2% max. Start up Time(Nominal Input) Out2/Out3 +/-5% max. +/-0.05%/°C Temperature Coefficient 1 Ripple & Noise(20MHz BW) Table 1 50mS max. GENERAL SPECIFICATIONS 100mVp-p max. Efficiency 2 70% min. 3 Line Regulation Isolation Voltage Single/Dual Dual Separate Triple +/-1% max. Single/Dual/Triple Out1 +/-1% max. Dual Separate Out2 +/-3% max. Out1 +/-1% max. Isolation Resistance Out2/Out3 +/-3% max. Isolation Capacitance 4 Load Regulation 1500VDC or 3000VDC min. In to Out 9 40pF max. Switching Frequency Dual Separate Triple 50KHz min. >900,000 Hours Output:3.3V +/-1% max. Weight Out1 +/-1% max. Case Material Five-Side Shielded Case Out2 +/-5% max. Case Size(DIL) 31.8mm*20.3mm*12.2mm Out1 +/-1% max. Case Size(SMD) 31.8mm*20.3mm*11.4mm Out2/Out3 +/-5% max. Potting Material(DIL) Minimum Load 17.5g typ. 20% of Full Load Potting Material(SMD) Short Circuit Protection Continuous Radiated Emissions Short Circuit Restart Over Load Protection 3W~6W Transient Response Capacitive Load 110%~180% 200uS max. Operating Temperature 5V:1000uF max. Storage Temperature 15V: 330uF max. Humidity Other Output: ±220uF max. Cooling ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 °C UNLESS OTHERWISE NOTED. 3 4 5 6 Non potting EN55032 Class B ENVIRONMENTAL SPECIFICATIONS 12V:470uF max. Case Temperature 2 Epoxy(UL94V-0) Automatic 6 1 500VDC min. 10 ohms min. +/-0.5% max. MTBF5 Single/Dual 1500VDC min. Out1 to Out2 -40°C to +71°C -55°C to +125°C +95°C max. 95% max. Free-Air Convection Measured with 1uF ceramic capacitor connect to the output pins. High Line to Low Line. 1500VDC for 10 seconds,2000VDC~3000VDC for 3 seconds. Load Regulation is for output load current change from 20% to 100%. MIL-HDBK-217F @25 °C , Ground Benign. 25% Step Load Change. DANUBE http://www.danube.com.tw 1 2018/9/6  SELECTION GUIDE(1) 2:1 3W OUTPUT 1500VDC ISOLATION INPUT VOLTAGE (VDC) OUTPUT VOLTAGE (VDC) OUTPUT CURRENT (mA) CWS-0503.3(ABC)3M 4.5-9 3.3 CWS-0505(ABCD)3M 4.5-9 5 CWS-0512(ABCD)3M 4.5-9 CWS-0515(ABCD)3M 4.5-9 CWD-0505A3M CWD-0512(ABC)3M MODEL NUMBER INPUT7 CURRENT(mA) EFF (%)8 ISOLATION (VDC) 40 73 1500 40 73 1500 789 40 76 1500 200 789 40 76 1500 +/-5 +/-300 855 40 70 1500 +/-12 +/-125 810 40 74 1500 +/-15 +/-100 800 60 75 1500 9-18 3.3 700 267 18 72 1500 CWS-1205(ABCD)3M 9-18 5 600 338 18 74 1500 CWS-1209(ABCD)3M 9-18 9 330 313 18 79 1500 CWS-1212(ABCD)3M 9-18 12 250 313 18 80 1500 CWS-1215(ABCD)3M 9-18 15 200 313 18 80 1500 CWS-1224(ABCD)3M 9-18 24 125 313 18 80 1500 CWD-1205(ABC)3M 9-18 +/-5 +/-300 338 18 74 1500 CWD-1212(ABC)3M 9-18 +/-12 +/-125 316 30 79 1500 CWD-1215(ABC)3M 9-18 +/-15 +/-100 316 32 79 1500 CWS-2403.3(ABCD)3M 18-36 3.3 910 163 10 76 1500 CWS-2405(ABCD)3M 18-36 5 600 167 10 75 1500 CWS-2409(ABCD)3M 18-36 9 330 158 10 79 1500 CWS-2412(ABCD)3M 18-36 12 250 156 10 80 1500 CWS-2415(ABCD)3M 18-36 15 200 156 10 80 1500 CWS-2424(ABCD)3M 18-36 24 125 156 10 80 1500 CWD-2405(ABC)3M 18-36 +/-5 +/-300 167 10 75 1500 CWD-2412(ABC)3M 18-36 +/-12 +/-125 156 15 80 1500 CWD-2415(ABC)3M 18-36 +/-15 +/-100 156 25 80 1500 CWS-4803.3(ABCD)3M 36-72 3.3 700 69 5 72 1500 CWS-4805(ABCD)3M 36-72 5 600 82 5 76 1500 CWS-4809(ABCD)3M 36-72 9 330 79 5 79 1500 CWS-4812(ABCD)3M 36-72 12 250 78 5 80 1500 CWS-4815(ABCD)3M 36-72 15 200 76 5 82 1500 CWS-4824(ABCD)3M 36-72 24 125 76 5 82 1500 CWD-4805(ABC)3M 36-72 +/-5 +/-300 82 5 76 1500 CWD-4812(ABC)3M 36-72 +/-12 +/-125 80 5 78 1500 CWD-4815(ABC)3M 36-72 +/-15 +/-100 79 5 79 1500 FULL LOAD NO LOAD 755 683 500 685 12 250 15 4.5-9 4.5-9 CWD-0515(ABC)3M 4.5-9 CWS-1203.3(ABCD)3M Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A3M (A PACKAGE 3W SINGLE OUTPUT) CWD-2405B3M (B PACKAGE 3W DUAL OUTPUT) 7 8 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 2 2018/9/6  SELECTION GUIDE(2) 4:1 3W OUTPUT 1500VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-1203.3(ABC)3TM 9-36 3.3 CWS-1205(ABC)3TM 9-36 CWS-1212(ABC)3TM INPUT9 CURRENT(mA) EFF ISOLATION FULL NO (%)10 (VDC) LOAD LOAD 700 260 20 74 1500 5 600 338 18 74 1500 9-36 12 250 321 18 78 1500 CWS-1215(ABC)3TM 9-36 15 200 321 18 78 1500 CWS-1224(ABC)3TM 9-36 24 125 321 20 78 1500 CWD-1205(ABC)3TM 9-36 +/-5 +/-300 333 18 75 1500 CWD-1212(ABC)3TM 9-36 +/-12 +/-125 320 18 78 1500 CWD-1215(ABC)3TM 9-36 +/-15 +/-100 320 18 78 1500 CWS-2403.3(ABC)3TM 18-72 3.3 700 136 10 71 1500 CWS-2405(ABC)3TM 18-72 5 600 169 10 74 1500 CWS-2412(ABC)3TM 18-72 12 250 160 10 78 1500 CWS-2415(ABC)3TM 18-72 15 200 156 10 80 1500 CWS-2424(ABC)3TM 18-72 24 125 160 10 78 1500 CWD-2405(ABC)3TM 18-72 +/-5 +/-300 169 10 74 1500 CWD-2409(ABC)3TM 18-72 +/-9 +/-167 158 10 79 1500 CWD-2412(ABC)3TM 18-72 +/-12 +/-125 160 10 78 1500 CWD-2415(ABC)3TM 18-72 +/-15 +/-100 160 15 78 1500 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A3TM (A PACKAGE 3W SINGLE OUTPUT) CWD-2405B3TM (B PACKAGE 3W DUAL OUTPUT) 9 10 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 3 2018/9/6  SELECTION GUIDE(3) 2:1 3W OUTPUT 2000VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-0505P3(M) 4.5-9 5 CWS-0512P3(M) 4.5-9 CWS-0515P3(M) INPUT11 CURRENT(mA) EFF ISOLATION FULL NO (%)12 (VDC) LOAD LOAD 500 685 40 73 2000 12 250 821 40 73 2000 4.5-9 15 200 789 40 76 2000 CWS-1203.3P3(M) 9-18 3.3 910 358 18 70 2000 CWS-1205P3(M) 9-18 5 600 338 18 74 2000 CWS-1209P3(M) 9-18 9 330 313 18 79 2000 CWS-1212P3(M) 9-18 12 250 313 18 80 2000 CWS-1215P3(M) 9-18 15 200 313 18 80 2000 CWS-2403.3P3(M) 18-36 3.3 910 163 10 76 2000 CWS-2405P2.5(M) 18-36 5 500 143 10 73 2000 CWS-2405P3(M) 18-36 5 600 167 10 75 2000 CWS-2409P3(M) 18-36 9 330 158 10 79 2000 CWS-2412P3(M) 18-36 12 250 156 10 80 2000 CWS-2415P3(M) 18-36 15 200 156 10 80 2000 CWS-4803.3P3(M) 36-72 3.3 910 87 5 72 2000 CWS-4805P3(M) 36-72 5 600 82 5 76 2000 CWS-4809P3(M) 36-72 9 330 79 5 79 2000 CWS-4812P3(M) 36-72 12 250 76 5 82 2000 CWS-4815P3(M) 36-72 15 200 76 5 82 2000 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: 11 12 CWS-1205P3M (P PACKAGE 3W SINGLE OUTPUT) NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 4 2018/9/6  SELECTION GUIDE(4) 2:1 4W-6W OUTPUT 1500VDC ISOLATION MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) INPUT13 CURRENT(mA) EFF ISOLATION FULL NO (%)14 (VDC) LOAD LOAD CWS-0505(AB)5M 4.5-9 5 800 1081 40 74 1500 CWS-0512(AB)5M 4.5-9 12 333 1066 40 75 1500 CWS-0515(AB)5M 4.5-9 15 267 1068 40 75 1500 CWD-0505(AB)5M 4.5-9 +/-5 +/-400 1125 40 71 1500 CWD-0512(AB)5M 4.5-9 +/-12 +/-167 1073 120 75 1500 CWD-0515(AB)5M 4.5-9 +/-15 +/-133 1060 100 75 1500 CWS-1203.3(AB)5M 9-18 3.3 1200 438 40 75 1500 CWS-1205(AB)5M 9-18 5 1000 556 40 75 1500 CWS-1209(AB)5M 9-18 9 556 520 40 80 1500 CWS-1212(AB)5M 9-18 12 470 587 40 80 1500 CWS-1215(AB)5M 9-18 15 400 617 41 81 1500 CWS-1224(AB)5M 9-18 24 208 520 41 80 1500 CWD-1205(AB)5M 9-18 +/-5 +/-500 556 40 75 1500 CWD-1209(AB)5M 9-18 +/-9 +/-280 525 20 80 1500 CWD-1212(AB)5M 9-18 +/-12 +/-230 585 40 79 1500 CWD-1215(AB)5M 9-18 +/-15 +/-190 586 48 81 1500 CWS-2403.3(AB)5M 18-36 3.3 1200 217 20 76 1500 CWS-2405(AB)5M 18-36 5 1000 270 20 77 1500 CWS-2409(AB)5M 18-36 9 556 257 20 81 1500 CWS-2412(AB)5M 18-36 12 470 292 22 80 1500 CWS-2415(AB)5M 18-36 15 400 301 21 83 1500 CWS-2424(AB)5M 18-36 24 208 260 21 80 1500 CWD-2405(AB)5M 18-36 +/-5 +/-500 270 20 77 1500 CWD-2412(AB)5M 18-36 +/-12 +/-230 288 20 80 1500 CWD-2415(AB)5M 18-36 +/-15 +/-190 286 21 83 1500 CWS-4803.3(AB)5M 36-72 3.3 1200 108 10 76 1500 CWS-4805(AB)5M 36-72 5 1000 135 10 77 1500 CWS-4809(AB)5M 36-72 9 556 130 9 80 1500 CWS-4812(AB)5M 36-72 12 470 145 9 81 1500 CWS-4815(AB)5M 36-72 15 400 154 10 81 1500 CWS-4824(AB)5M 36-72 24 208 130 10 80 1500 CWD-4805(AB)5M 36-72 +/-5 +/-500 135 10 77 1500 CWD-4812(AB)5M 36-72 +/-12 +/-230 144 12 80 1500 CWD-4815(AB)5M 36-72 +/-15 +/-190 146 10 81 1500 Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A5M (A PACKAGE 5W SINGLE OUTPUT) CWD-1205B5M (B PACKAGE 5W DUAL OUTPUT) 13 14 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 5 2018/9/6  SELECTION GUIDE(5) 4:1 4W-5W OUTPUT 1500VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-1203.3A5TM 9-36 3.3 CWS-1205A5TM 9-36 CWS-1209A5TM INPUT15 CURRENT(mA) EFF ISOLATION FULL NO (%)16 (VDC) LOAD LOAD 1200 471 40 70 1500 5 1000 548 40 76 1500 9-36 9 556 542 40 77 1500 CWS-1212A5TM 9-36 12 417 542 20 77 1500 CWS-1215A5TM 9-36 15 333 534 20 78 1500 CWD-1205A5TM 9-36 +/-5 +/-500 563 40 74 1500 CWD-1212A5TM 9-36 +/-12 +/-208 533 40 78 1500 CWD-1215A5TM 9-36 +/-15 +/-167 535 40 78 1500 CWS-2403.3A5TM 18-72 3.3 1200 229 20 72 1500 CWS-2405A5TM 18-72 5 1000 271 20 77 1500 CWS-2409A5TM 18-72 9 556 264 20 79 1500 CWS-2412A5TM 18-72 12 417 264 20 79 1500 CWS-2415A5TM 18-72 15 333 260 20 80 1500 CWD-2405A5TM 18-72 +/-5 +/-500 280 20 74 1500 CWD-2412A5TM 18-72 +/-12 +/-208 270 10 77 1500 CWD-2415A5TM 18-72 +/-15 +/-167 260 10 80 1500 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-2405A5TM (A PACKAGE 5W SINGLE OUTPUT) CWD-2405A5TM (A PACKAGE 5W DUAL OUTPUT) 15 16 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 6 2018/9/6  SELECTION GUIDE(6) 2:1 or 4:1 3W~5W DUAL SEPARATE OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) 9-18 V1:5V V1:300 V2:5V V2:300 V1:5V V1:300 V2:5V V2:300 V1:5V V1:450 V2:5V V2:450 V1:15V V1:100 V2:15V V2:100 V1:15V V1:150 V2:15V V2:150 V1:24V V1:95 V2:24V V2:95 V1:12V V1:188 V2:12V V2:188 V1:15V V1:100 V2:15V V2:100 V1:5V V1:300 V2:5V V2:300 V1:5V V1:300 V2:5V V2:300 V1:12V V1:125 V2:12V V2:125 V1:15V V1:100 V2:15V V2:100 CWD-120505E3M CWD-120505E3TM 9-36 CWD-120505E5TM 9-36 CWD-121515E3M 9-18 CWD-121515E5TM 9-36 CWD-122424E5TM 9-36 CWD-241212E5M 18-36 CWD-241515E3M 18-36 CWD-240505E3TM 18-72 CWD-480505E3M 36-72 CWD-481212E3M 36-72 CWD-481515E3M 36-72 INPUT17 CURRENT(mA) EFF ISOLATION FULL NO (%)18 (VDC) LOAD LOAD 329 40 76 1500 348 40 72 1500 520 40 72 1500 348 40 72 1500 510 40 74 1500 510 40 74 1500 241 25 78 1500 169 16 74 1500 169 15 74 1500 80 10 78 1500 83 10 75 1500 79 10 79 1500 Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWD-121515E3M (E PACKAGE 3W DUAL OUTPUT) CWD-241212E5M (E PACKAGE 5W DUAL OUTPUT) 17 18 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 7 2018/9/6  SELECTION GUIDE(7) 2:1 or 4:1 3W DUAL SEPARATE OUTPUT MODEL NUMBER INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) 9-18 V1:15V V1:100 V2:15V V2:100 V1:5V V1:300 V2:5V V2:300 V1:12V V1:125 V2:12V V2:125 V1:15V V1:100 V2:15V V2:100 V1:24V V1:63 V2:24V V2:63 V1:5V V1:300 V2:5V V2:300 V1:12V V1:125 V2:12V V2:125 V1:12V V1:125 V2:12V V2:125 V1:15V V1:100 V2:15V V2:100 V1:24V V1:63 V2:24V V2:63 CWD-121515F3M CWD-120505F3TM 9-36 CWD-121212F3TM 9-36 CWD-121515F3TM 9-36 CWD-122424F3TM 9-36 CWD-240505F3TM 18-72 CWD-241212F3M 18-36 CWD-241212F3TM 18-72 CWD-241515F3TM 18-72 CWD-242424F3TM 18-72 INPUT19 CURRENT(mA) EFF ISOLATION FULL NO (%)20 (VDC) LOAD LOAD 315 33 79 1500 338 35 74 1500 331 33 76 1500 320 20 78 1500 320 20 78 1500 169 15 74 1500 156 15 80 1500 156 15 80 1500 156 15 80 1500 152 15 82 1500 Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: 19 20 CWD-242424F3TM (F PACKAGE 3W DUAL OUTPUT) NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 8 2018/9/6  SELECTION GUIDE(8) 2:1 4W TRIPLE OUTPUT MODEL NUMBER OUTPUT OUTPUT INPUT21 INPUT VOLTAGE CURRENT CURRENT VOLTAGE (VDC) (mA) (mA) (VDC) FULL NO LOAD LOAD EFF ISOLATION (%)22 (VDC) OUT1 OUT2 OUT3 OUT1 OUT2 OUT3 CWT-0505-12 4.5-9 +5 +12V -12V 300 100 100 1085 20 74 1500 CWT-0505-15 4.5-9 +5 +15 -15 300 80 80 1280 20 70 1500 CWT-1205-12 9-18 +5 +12V -12V 300 100 100 406 20 80 1500 CWT-1205-15 9-18 +5 +15 -15 300 80 80 417 20 78 1500 CWT-2405-12 18-36 +5 +12V -12V 300 100 100 200 20 81 1500 CWT-2405-15 18-36 +5 +15 -15 300 80 80 225 20 74 1500 CWT-4805-12 36-72 +5 +12V -12V 300 100 100 114 20 73 1500 CWT-4805-15 36-72 +5 +15 -15 300 80 80 113 20 74 1500 Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: 21 22 CWT-1205-15 (T PACKAGE 4W TRIPLE OUTPUT) NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 9 2018/9/6  SELECTION GUIDE(9) 2:1 3W OUTPUT 3000VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-0503.3A3M-3K 4.5-9 3.3 CWS-0505A3M-3K 4.5-9 5 CWS-0512A3M-3K 4.5-9 CWS-0515A3M-3K INPUT23 CURRENT(mA) EFF ISOLATION FULL NO (%)24 (VDC)25 LOAD LOAD 755 683 40 73 3000 500 684 40 73 3000 12 250 789 40 76 3000 4.5-9 15 200 789 40 76 3000 CWS-1203.3A3M-3K 9-18 3.3 700 267 18 72 3000 CWS-1205A3M-3K 9-18 5 600 338 18 74 3000 CWS-1209A3M-3K 9-18 9 330 316 18 79 3000 CWS-1212A3M-3K 9-18 12 250 313 18 80 3000 CWS-1215A3M-3K 9-18 15 200 313 18 80 3000 CWD-1205A3M-3K 9-18 +/-5 +/-300 338 18 74 3000 CWD-1212A3M-3K 9-18 +/-12 +/-125 316 18 79 3000 CWD-1215A3M-3K 9-18 +/-15 +/-100 316 18 79 3000 CWS-2403.3A3M-3K 18-36 3.3 910 163 10 77 3000 CWS-2405A3M-3K 18-36 5 600 167 10 75 3000 CWS-2409A3M-3K 18-36 9 330 158 10 79 3000 CWS-2412A3M-3K 18-36 12 250 156 10 80 3000 CWS-2415A3M-3K 18-36 15 200 156 10 80 3000 CWS-2424A3M-3K 18-36 24 125 154 10 81 3000 CWD-2405A3M-3K 18-36 +/-5 +/-300 167 10 75 3000 CWD-2412A3M-3K 18-36 +/-12 +/-125 156 10 80 3000 CWD-2415A3M-3K 18-36 +/-15 +/-100 156 25 80 3000 CWS-4803.3A3M-3K 36-72 3.3 700 69 5 72 3000 CWS-4805A3M-3K 36-72 5 600 82 5 76 3000 CWS-4809A3M-3K 36-72 9 330 79 5 79 3000 CWS-4812A3M-3K 36-72 12 250 78 5 80 3000 CWS-4815A3M-3K 36-72 15 200 76 5 82 3000 CWD-4805A3M-3K 36-72 +/-5 +/-300 82 5 76 3000 CWD-4812A3M-3K 36-72 +/-12 +/-125 80 5 78 3000 CWD-4815A3M-3K 36-72 +/-15 +/-100 79 5 79 3000 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A3M-3K (A PACKAGE 3W SINGLE OUTPUT) CWD-2405A3M-3K (A PACKAGE 3W DUAL OUTPUT) 23 24 25 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. FOR 3 SECONDS. DANUBE http://www.danube.com.tw 10 2018/9/6  SELECTION GUIDE(10) 4:1 3W OUTPUT 3000VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-1203.3A3TM-3K 9-36 3.3 CWS-1205A3TM-3K 9-36 CWS-1209A3TM-3K INPUT26 CURRENT(mA) EFF ISOLATION FULL NO (%)27 (VDC)28 LOAD LOAD 700 260 20 74 3000 5 600 338 18 74 3000 9-36 9 330 320 18 77 3000 CWS-1212A3TM-3K 9-36 12 250 320 18 78 3000 CWS-1215A3TM-3K 9-36 15 200 320 18 78 3000 CWD-1205A3TM-3K 9-36 +/-5 +/-300 333 18 75 3000 CWD-1212A3TM-3K 9-36 +/-12 +/-125 320 18 78 3000 CWD-1215A3TM-3K 9-36 +/-15 +/-100 320 18 78 3000 CWS-2403.3A3TM-3K 18-72 3.3 700 136 10 71 3000 CWS-2405A3TM-3K 18-72 5 600 169 10 74 3000 CWS-2409A3TM-3K 18-72 9 330 158 10 79 3000 CWS-2412A3TM-3K 18-72 12 250 156 10 80 3000 CWS-2415A3TM-3K 18-72 15 200 156 10 80 3000 CWD-2405A3TM-3K 18-72 +/-5 +/-300 169 10 74 3000 CWD-2412A3TM-3K 18-72 +/-12 +/-125 160 10 78 3000 CWD-2415A3TM-3K 18-72 +/-15 +/-100 160 10 78 3000 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A3TM-3K (A PACKAGE 3W SINGLE OUTPUT) CWD-2405A3TM-3K (A PACKAGE 3W DUAL OUTPUT) 26 27 28 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. FOR 3 SECONDS. DANUBE http://www.danube.com.tw 11 2018/9/6  SELECTION GUIDE(11) 2:1 4W-6W OUTPUT 3000VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-0505A5M-3K 4.5-9 5 CWS-1203.3A5M-3K 9-18 CWS-1205A5M-3K INPUT29 CURRENT(mA) EFF ISOLATION FULL NO (%)30 (VDC)31 LOAD LOAD 800 1081 40 74 3000 3.3 1200 438 40 75 3000 9-18 5 1000 556 40 75 3000 CWS-1209A5M-3K 9-18 9 556 520 40 80 3000 CWS-1212A5M-3K 9-18 12 470 587 40 80 3000 CWS-1215A5M-3K 9-18 15 400 617 30 81 3000 CWD-1205A5M-3K 9-18 +/-5 +/-500 556 40 75 3000 CWD-1212A5M-3K 9-18 +/-12 +/-230 585 40 79 3000 CWD-1215A5M-3K 9-18 +/-15 +/-190 586 41 81 3000 CWS-2403.3A5M-3K 18-36 3.3 1200 217 20 76 3000 CWS-2405A5M-3K 18-36 5 1000 270 20 77 3000 CWS-2409A5M-3K 18-36 9 556 257 20 81 3000 CWS-2412A5M-3K 18-36 12 470 287 22 82 3000 CWS-2415A5M-3K 18-36 15 400 301 21 83 3000 CWD-2405A5M-3K 18-36 +/-5 +/-500 270 20 77 3000 CWD-2412A5M-3K 18-36 +/-12 +/-230 279 20 82 3000 CWD-2415A5M-3K 18-36 +/-15 +/-190 286 21 83 3000 CWS-4803.3A5M-3K 36-72 3.3 1200 112 10 74 3000 CWS-4805A5M-3K 36-72 5 1000 135 10 77 3000 CWS-4809A5M-3K 36-72 9 556 126 9 83 3000 CWS-4812A5M-3K 36-72 12 470 146 9 80 3000 CWS-4815A5M-3K 36-72 15 400 147 10 85 3000 CWD-4805A5M-3K 36-72 +/-5 +/-500 135 10 77 3000 CWD-4812A5M-3K 36-72 +/-12 +/-230 138 12 83 3000 CWD-4815A5M-3K 36-72 +/-15 +/-190 146 10 81 3000 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A5M-3K (A PACKAGE 5W SINGLE OUTPUT) CWD-2405A5M-3K (A PACKAGE 5W DUAL OUTPUT) 29 30 31 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. FOR 3 SECONDS. DANUBE http://www.danube.com.tw 12 2018/9/6  SELECTION GUIDE(12) 4:1 5W OUTPUT 3000VDC ISOLATION INPUT OUTPUT OUTPUT VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) CWS-1203.3A5TM-3K 9-36 3.3 CWS-1205A5TM-3K 9-36 CWS-1209A5TM-3K INPUT32 CURRENT(mA) EFF ISOLATION FULL NO (%)33 (VDC)34 LOAD LOAD 1200 470 40 70 3000 5 1000 550 40 76 3000 9-36 9 556 540 40 77 3000 CWS-1212A5TM-3K 9-36 12 417 540 20 77 3000 CWS-1215A5TM-3K 9-36 15 333 535 20 78 3000 CWD-1205A5TM-3K 9-36 +/-5 +/-500 560 40 74 3000 CWD-1212A5TM-3K 9-36 +/-12 +/-208 535 40 78 3000 CWD-1215A5TM-3K 9-36 +/-15 +/-167 536 40 78 3000 CWS-2403.3A5TM-3K 18-72 3.3 1200 230 20 72 3000 CWS-2405A5TM-3K 18-72 5 1000 270 20 77 3000 CWS-2409A5TM-3K 18-72 9 556 260 20 80 3000 CWS-2412A5TM-3K 18-72 12 417 265 20 79 3000 CWS-2415A5TM-3K 18-72 15 333 260 20 80 3000 CWD-2405A5TM-3K 18-72 +/-5 +/-500 280 20 74 3000 CWD-2412A5TM-3K 18-72 +/-12 +/-208 270 10 77 3000 CWD-2415A5TM-3K 18-72 +/-15 +/-167 260 10 80 3000 MODEL NUMBER Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A5TM-3K (A PACKAGE 5W SINGLE OUTPUT) CWD-2405A5TM-3K(A PACKAGE 5W DUAL OUTPUT) 32 33 34 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. FOR 3 SECONDS. DANUBE http://www.danube.com.tw 13 2018/9/6  SELECTION GUIDE(13) 2:1 3W OUTPUT(SMD PACKAGE) INPUT VOLTAGE (VDC) OUTPUT VOLTAGE (VDC) OUTPUT CURRENT (mA) CWS-1205(ABC)3MS 9-18 5 CWS-1212(ABC)3MS 9-18 CWS-1215(ABC)3MS MODEL NUMBER INPUT35 CURRENT(mA) EFF (%)36 ISOLATION (VDC) 18 80 1500 301 35 83 1500 200 298 18 84 1500 +/-5 +/-300 313 18 80 1500 9-18 +/-12 +/-125 301 30 83 1500 CWD-1215(ABC)3MS 9-18 +/-15 +/-100 298 32 84 1500 CWS-2405(ABC)3MS 18-36 5 600 154 10 81 1500 CWS-2412(ABC)3MS 18-36 12 250 149 10 84 1500 CWS-2415(ABC)3MS 18-36 15 200 147 10 85 1500 CWD-2405(ABC)3MS 18-36 +/-5 +/-300 154 10 81 1500 CWD-2412(ABC)3MS 18-36 +/-12 +/-125 149 15 84 1500 CWD-2415(ABC)3MS 18-36 +/-15 +/-100 149 15 84 1500 CWS-4805(ABC)3MS 36-72 5 600 75 5 83 1500 CWS-4812(ABC)3MS 36-72 12 250 74 5 85 1500 CWS-4815(ABC)3MS 36-72 15 200 74 5 85 1500 CWD-4805(ABC)3MS 36-72 +/-5 +/-300 75 5 83 1500 CWD-4812(ABC)3MS 36-72 +/-12 +/-125 74 5 85 1500 CWD-4815(ABC)3MS 36-72 +/-15 +/-100 74 5 85 1500 FULL LOAD NO LOAD 600 313 12 250 9-18 15 CWD-1205(ABC)3MS 9-18 CWD-1212(ABC)3MS Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A3MS (SMD A PACKAGE 3W SINGLE OUTPUT) CWD-2405B3MS (SMD B PACKAGE 3W DUAL OUTPUT) 35 36 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 14 2018/9/6  SELECTION GUIDE(14) 2:1 4W-6W OUTPUT(SMD PACKAGE) INPUT VOLTAGE (VDC) OUTPUT VOLTAGE (VDC) OUTPUT CURRENT (mA) CWS-1203.3(ABC)5MS 9-18 3.3 CWS-1205(ABC)5MS 9-18 CWS-1212(ABC)5MS MODEL NUMBER INPUT37 CURRENT(mA) EFF (%)38 ISOLATION (VDC) 50 78 1500 521 50 80 1500 470 573 50 82 1500 15 400 595 50 84 1500 9-18 +/-5 +/-500 521 50 80 1500 CWD-1212(ABC)5MS 9-18 +/-12 +/-230 554 50 83 1500 CWD-1215(ABC)5MS 9-18 +/-15 +/-190 579 50 82 1500 CWS-2405(ABC)5MS 18-36 5 1000 257 25 81 1500 CWS-2412(ABC)5MS 18-36 12 470 283 25 83 1500 CWS-2415(ABC)5MS 18-36 15 400 294 25 85 1500 CWD-2405(ABC)5MS 18-36 +/-5 +/-500 257 25 81 1500 CWD-2412(ABC)5MS 18-36 +/-12 +/-230 274 25 84 1500 CWD-2415(ABC)5MS 18-36 +/-15 +/-190 283 25 84 1500 CWS-4805(ABC)5MS 36-72 5 1000 127 10 82 1500 CWS-4812(ABC)5MS 36-72 12 470 138 10 85 1500 CWS-4815(ABC)5MS 36-72 15 400 147 10 85 1500 CWD-4805(ABC)5MS 36-72 +/-5 +/-500 127 10 82 1500 CWD-4812(ABC)5MS 36-72 +/-12 +/-230 135 10 85 1500 CWD-4815(ABC)5MS 36-72 +/-15 +/-190 140 10 85 1500 FULL LOAD NO LOAD 1200 423 5 1000 9-18 12 CWS-1215(ABC)5MS 9-18 CWD-1205(ABC)5MS Note: Other input to output voltages may be available. Please contact factory. ORDERING INFORMATION: FOR EXAMPLE: CWS-1205A5MS (SMD A PACKAGE 5W SINGLE OUTPUT) CWD-2405B5MS (SMD B PACKAGE 5W DUAL OUTPUT) 37 38 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 15 2018/9/6  MECHANICAL DIMENSIONS PACKAGE "A" PIN SINGLE DUAL 2&3 -Vin -Vin 9 NC Common 11 NC -Vout 14 +Vout +Vout 16 -Vout Common 22 & 23 +Vin +Vin NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(Inches) Tolerance .X or .XX= ±0.5mm PACKAGE "B" PIN SINGLE DUAL 1 & 24 +Vin +Vin 2 & 23 NP -Vout 3 & 22 NP Common 10 & 15 -Vout Common 11 & 14 +Vout +Vout 12 & 13 -Vin -Vin NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(Inches) Tolerance .X or .XX= ±0.5mm PACKAGE "C" PIN SINGLE DUAL 1&2 +Vin +Vin 10 & 11 NC Common 12 -Vout NC 13 +Vout -Vout 15 NC +Vout 23 & 24 -Vin -Vin NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X DANUBE or .XX= ±0.5mm http://www.danube.com.tw 16 2018/9/6 PACKAGE "D" PIN SINGLE 1 & 24 + Vin 2 & 23 -Vin 10 & 15 -Vout 11 & 14 NC 12 & 13 +Vout NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X or .XX= ±0.5mm PACKAGE "E" PIN SEPARATE 2&3 - Vin 9 -Vout2 11 +Vout2 14 +Vout1 16 -Vout1 22 & 23 +Vin NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X or .XX= ±0.5mm PACKAGE "F" PIN SEPARATE 1 & 24 + Vin 2 & 23 -Vout2 3 & 22 +Vout2 10 & 15 -Vout1 11 & 14 +Vout1 12 & 13 -Vin NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X DANUBE or .XX= ±0.5mm http://www.danube.com.tw 17 2018/9/6 PACKAGE "P" PIN SINGLE 1&2 +Vin 23 & 24 -Vin 9 & 10 -Vout 11 & 12 +Vout 13 & 14 NC 15 & 16 NC NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X or .XX= ±0.5mm PACKAGE "T" PIN TRIPLE 1&2 -Vin 23 & 24 +Vin 9 & 16 -Vout(Out3) 10 & 15 Common 11 & 14 +5V/300mA(Out1) 12 & 13 +Vout(Out2) NOTE:Pin Size is Tolerance 0.6Φ ±0.05mm All dimensions are in mm(inches) Tolerance .X DANUBE or .XX= ±0.5mm http://www.danube.com.tw 18 2018/9/6 SMD PACKAGE SMD PACKAGE "B" SMD PACKAGE "A" PIN SINGLE DUAL 1 ON/OFF ON/OFF 2&3 -Vin -Vin 4&5 NC NC 9 NC COM 10 & 12 NC NC 11 NC -VOUT 13 & 15 NC NC 14 +VOUT +VOUT 16 -VOUT COM 20 & 21 NC NC 22 & 23 +VIN +VIN 24 NC NC SMD PACKAGE "C" PIN SINGLE DUAL PIN SINGLE DUAL 1 & 24 +Vin +Vin 1&2 +Vin +Vin 2 & 23 NC -Vout 3&4 NC NC 3 & 22 NC Common 5&9 NC NC 4 & 21 NC NC 10 & 11 NC Common 5 & 20 NC NC 12 -Vout NC 9 & 16 NC NC 13 +Vout -Vout 10 & 15 -Vout Common 14 & 16 NC NC 11 & 14 +Vout +Vout 15 NC +Vout 12 & 13 -Vin -Vin 20 & 21 NC NC 22 NC NC 23 & 24 -Vin -Vin NOTE: All Dimensions Are In mm(Inches) Pin Size is Tolerance 0.5 ±0.05mm Tolerance .X or .XX= ±0.5mm DANUBE http://www.danube.com.tw 19 2018/9/6  RECOMMENDED FOOTPRINT DETAILS PACKAGE "A" PACKAGE "B" PACKAGE “C” PACKAGE “D” PACKAGE "E" PACKAGE "F" PACKAGE “P” PACKAGE “T” DANUBE http://www.danube.com.tw 20 2018/9/6 PACKAGE“S”[SMD]  RECOMMENDED REFLOW SOLDERING PROFILE Peak. Temp 240 °C (10 Sec. Max.) 250 Temperature (° C ) 220 °C 200 60 Sec. Max. (> 2 20°C) 150 100 50 0 Time (s ec. )  SIMPLIFIED SCHEMATIC SINGLE OUTPUT DUAL OUTPUT +Vin +Vout +Vin +Vout Common -Vout -Vout -Vin -Vin PFM CONTROLLER ISOLATION REFERENCE & ERROR AMP PFM CONTROLLER SEPARATE OUTPUT REFERENCE & ERROR AMP TRIPLE OUTPUT +Vout1 +Vin ISOLATION +Vin +5V/300mA(Out1) -Vout1 +Vout2 +Vout(Out2) -Vout2 Common -Vin -Vout(Out3) -Vin PFM CONTROLLER ISOLATION DANUBE REFERENCE & ERROR AMP PFM CONTROLLER ISOLATION REFERENCE & ERROR AMP http://www.danube.com.tw 21 2018/9/6  TYPICAL APPLICATIONS SINGLE OUTPUT INPUT DUAL OUTPUT OUTPUT +Vin INPUT OUTPUT +Vout +Vin +Vout LOAD1 LOAD DC-DC CONVERTER -Vi n Common DC-DC CONVERTER -Vi n -Vout SEPARATE OUTPUT INPUT TRIPLE OUTPUT OUTPUT +Vin LOAD2 -Vout INPUT +Vout1 OUTPUT +Vout +Vin LOAD1 Out2 LOAD2 +5V Out1 LOAD1 -Vout1 Common DC-DC CONVERTER +Vout2 DC-DC CONVERTER -Vi n LOAD2 -Vin LOAD3 -Vout Out3 -Vout2  TYPICAL PERFORMANCE CURVES Specifications typical at Ta=25 °C, nominal input voltage , rated output current unless otherwise specified. 80.0 60.0 40.0 20.0 0.0 0 20 40 60 80 100 TEMPERATURE DERATING % OF RATED LOAD(%) EFFICIENCY(%) OUTPUT LOAD VS EFFICIENCY 125% 100% 50% SAFE OPERATING 25% AREA 75% 0% -40 -20 % OF RATED LOAD(%) 0 30 70 100 120 TA(degree C)  Table1 (Remote On/Off Control) Remote On/Off Control Parameter Supply On Supply Off Min Max Under 1 VDC or Open Circuit 4VDC Standby Input Current 0.2mA Control Input Current(On) -0.5mA Control Input Current(Off) 5mA Control Common DANUBE Referenced to -Vin http://www.danube.com.tw 22 2018/9/6  INPUT FUSE SELECTION GUIDE 4.5-6.0V or 4.5-9V 9-18V or 9-36V 18-36V or 18-72V 36-72V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 1500mA Slow-Blow Type 800mA Slow-Blow Type 400mA Slow-Blow Type 3000mA Slow-Blow Type INPUT OUTPUT +Vin +Vout Fuse DC-DC CONVERTER -Vi n -Vout Note: Certain applications may require the installation of external fuse in front of the input. CW SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: No external capacitance is required for operation of the CW series. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 100KHz is required. External output capacitance is not required for operation, however it is recommended that 10uF tantalum and 0.1uF ceramic capacitance be selected for reduced system noise. Additional output capacitance may be added for increased filtering, but should not exceed 1000uF. We Can Offer EMC-Filter According To EN55032 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 23 2018/9/6
CWD-24050 5E3TM 价格&库存
很抱歉,暂时无法提供与“CWD-24050 5E3TM”相匹配的价格&库存,您可以联系我们找货
