NUS-0505A
NUS-0505A
    DIWELL
    SMD8_4Pin Module
    DC/DC CONVERTER 5V INPUT, 5V OUT
NUS-0505A 数据手册
NU SERIES 1W~2W UNREGULATED FEATURES           UP TO 1W~2W UNREGULATED OUTPUT POWER 100% BURN IN HIGH EFFICIENCY SMD TECHNOLOGY LOW COST UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE MTBF>2,000,000 HOURS RoHS COMPLIANT 2 YEARS WARRANTY OUTPUT SPECIFICATIONS Voltage Set-point Accuracy Temperature Coefficient Ripple & Noise(20MHz BW) 1 INPUT SPECIFICATIONS +/-2% max Input Voltage Range Capacitor Type 100mVp-p max Protection Fuse Recommended Line Regulation 2 +/-1.2% max Line Regulation 3 +/-1.5% max Load Regulation 4 Load Regulation 5 Minimum Load Short Circuit Protection GENERAL SPECIFICATIONS +/-8% max Efficiency Humidity Cooling 6 1000 VDC min 9 10% of Full Load Isolation Resistance 10 ohms min Momentary Isolation Capacitance 80pF max Switching Frequency 100KHz Typ ENVIRONMENTAL SPECIFICATIONS Storage Temperature 70%-79% +/-12% max Isolation Voltage 7 >2,000,000 Hours Weight 3g Typ MTBF Operating Temperature +/-10% max +/-0.03%/°C Input Filter -40 °C to +71°C Case Material -55°C to +125°C Case Size A 95% max B Free-Air Convection Conducted Emissions Radiated Emissions Non-Conductive Plastic 13.8mm*12.8mm*9.3mm 25.4mm*12.8mm*9.3mm EN55022 Class A EN55022 Class A ALL SPECIFICATIONS TYPICAL AT NOMINAL LINE, FULL LOAD , AND 25 °C UNLESS OTHERWISE NOTED. 1 2 3 4 5 6 7 Measured with 1uF ceramic capacitor connect to the output pins. Line Regulation is for a 1% change in input voltage. Line Regulation is for a 1% change in input voltage when input voltage is 3V and 3.3V. Load Regulation is for output load current change from 20% to 100%. Load Regulation is for output load current change from 20% to 100% when input voltage is 3V and 3.3V. For 10 seconds. MIL-HDBK-217F@25°C, Ground Benign. DANUBE http://www.danube.com.tw 1 2014/04/28  SELECTION GUIDE(1) 0.25W~0.5W 1000VDC ISOLATION INPUT MODEL NUMBER OUTPUT OUTPUT 8 INPUT VOLTAGE VOLTAGE CURRENT CURRENT(mA) EFF ISOLATION (VDC) NUS-03.305A-0.25W (VDC) 3.3 (mA) 5 50 FULL NO LOAD LOAD 125 35 9 PACKAGE (%) (VDC) 61 1000 A Note: Other input to output voltages may be available. Please contact factory.  SELECTION GUIDE(2) 1W 1000VDC ISOLATION INPUT MODEL NUMBER OUTPUT OUTPUT 10 INPUT VOLTAGE VOLTAGE CURRENT CURRENT(mA) EFF ISOLATION (VDC) NUS-03.303.3A (VDC) (mA) FULL NO LOAD LOAD 11 PACKAGE (%) (VDC) 3.3 3.3 303 425 45 71 1000 A NUS-0505A 5 5 200 283 35 71 1000 A NUS-0509A 5 9 111 257 25 78 1000 A NUS-0512A 5 12 84 257 25 78 1000 A NUS-0515A 5 15 67 253 28 79 1000 A NUS-1203.3A 12 3.3 300 112 13 74 1000 A NUS-1205A 12 5 200 112 14 74 1000 A NUS-1209A 12 9 111 107 11 78 1000 A NUS-1212A 12 12 84 102 10 82 1000 A NUS-1215A 12 15 67 102 12 82 1000 A NUS-2405A-0.75W 24 5 150 41 11 76 1000 A NUS-2405A 24 5 200 54 11 76 1000 A NUS-2412A 24 12 84 54 11 76 1000 A NUS-2415A 24 15 67 54 11 76 1000 A Note: Other input to output voltages may be available. Please contact factory. 8 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. 10 NOMINAL INPUT VOLTAGE. 11 NOMINAL INPUT VOLTAGE, FULL LOAD. 9 DANUBE http://www.danube.com.tw 2 2014/04/28  SELECTION GUIDE(3) 1.8W 1000VDC ISOLATION INPUT MODEL NUMBER OUTPUT OUTPUT 12 INPUT VOLTAGE VOLTAGE CURRENT CURRENT(mA) EFF ISOLATION (VDC) (VDC) (mA) FULL NO LOAD LOAD 13 PACKAGE (%) (VDC) NUS-0505B 5 5 360 500 70 72 1000 B NUS-0509B 5 9 200 480 70 75 1000 B NUS-0512B 5 12 150 467 70 77 1000 B NUS-0515B 5 15 120 467 70 77 1000 B NUS-1205B 12 5 360 206 40 73 1000 B NUS-1209B 12 9 200 197 40 76 1000 B NUS-1212B 12 12 150 192 40 78 1000 B NUS-1215B 12 15 120 192 40 78 1000 B Note: Other input to output voltages may be available. Please contact factory.  SELECTION GUIDE(4) 2W 1000VDC ISOLATION 14 INPUT MODEL NUMBER INPUT OUTPUT OUTPUT CURRENT(mA) EFF ISOLATION VOLTAGE VOLTAGE CURRENT (VDC) (VDC) (mA) FULL NO LOAD LOAD 15 PACKAGE (%) (VDC) NUS-0505B2 5 5 400 520 50 77 1000 B NUS-0509B2 5 9 222 506 50 79 1000 B NUS-0512B2 5 12 167 500 50 80 1000 B NUS-0515B2 5 15 133 488 50 82 1000 B NUS-1205B2 12 5 400 214 20 78 1000 B NUS-1209B2 12 9 222 214 20 78 1000 B NUS-1212B2 12 12 167 200 20 83 1000 B NUS-1215B2 12 15 133 196 20 85 1000 B NUS-2405B2 24 5 400 107 15 78 1000 B NUS-2409B2 24 9 222 107 15 78 1000 B NUS-2412B2 24 12 167 104 15 80 1000 B NUS-2415B2 24 15 133 104 15 80 1000 B Note: Other input to output voltages may be available. Please contact factory. 12 13 14 15 NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. NOMINAL INPUT VOLTAGE. NOMINAL INPUT VOLTAGE, FULL LOAD. DANUBE http://www.danube.com.tw 3 2014/04/28  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS (1) PACKAGE ”A” 7 .62(0 .3) 0.6(0.0 235) 2.54(0.1) 9.3(0.366 ) PIN SINGLE 1 -Vin 2 +Vin 4 -Vout 5 +Vout NOTE : All Dimensions In mm(Inches) 1. Pin Size is 0.55mx0.30mm[0.022x0.01”] 10.5(0.413 5) 13.8(0.543 ) 2. Pin is Tolerance .XX= ±0.07mm 3. Tolerance .X 12.8(0.504) or .XX= ±0.5mm 2.54mm Unit:mm(inch)+/-0.25(0.010) 1.54[0.06] 13.1[0.52] 14.63[0.58] 2.54mm 5 TOP VIEW 1 2 4 1.54[0.06] 2.54[0.1] DANUBE http://www.danube.com.tw 4 2014/04/28  MECHANICAL DIMENSIONS & RECOMMENDED FOOTPRINT DETAILS (2) PACKAGE ”B” 1 7.78(0.700) 0.6(0.0 235 ) 2.54(0 .100) 9.3(0.3 66) 10.5 0(0.41 35) SINGLE 1 -Vin 3 +Vin 7 +Vout 8 -Vout NOTE : All Dimensions In mm(Inches) 1. Pin Size is 0.55x0.30mm[0.022x0.01”] 12.8 (0.504 ) 25.4 (1.000 ) PIN 2. Pin is Tolerance .XX= ±0.07mm 3. Tolerance .X or .XX= ±0.5mm 2.54mm Unit: mm(inch)+/-0.25(0.010) 13.1[0.52] 14.63[0.58] 2.54mm 16 14 10 9 TOP VIEW 1 7 8 1.54[0.06] 2.54[0.1] 1.54[0.06] REFLOW SOLDERING CURVE Remark:The curve applies only to the hot air reflow soldering. DANUBE http://www.danube.com.tw 5 2014/04/28  SIMPLIFIED SCHEMATIC  TYPICAL APPLICATIONS INPUT +Vin OUTPUT +Vin +Vout +Vout OSCILLATOR DRIVER LOAD DC-DC CONVERTER -Vout -Vin -Vin DERATING CURVES -Vout EFFICIENCY VS LOAD EFFICIENCY(%) % OF RATED LOAD(%) 125% 100% 75% SAFE 50% OPERATING 25% AREA 0% -40 -20 0 80.0 60.0 40.0 20.0 0.0 30 70 100 120 0 20 40 60 80 100 % OF RATED LOAD(%) TA(degree C)  INPUT FUSE SELECTION GUIDE(1) 1W 1000VDC ISOLATION 4.5-5.5V 10.8-13.2V 21.6-26.4V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 750mA Slow-Blow Type 300mA Slow-Blow Type INPUT 150mA Slow-Blow Type OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input.  INPUT FUSE SELECTION GUIDE(2) 1.8W~2W 1000VDC ISOLATION 4.5-5.5V 10.8-13.2V 21.6-26.4V INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) INPUT VOLTAGE(VDC) 1500mA Slow-Blow Type 600mA Slow-Blow Type INPUT 300mA Slow-Blow Type OUTPUT Fuse +Vin +Vout DC-DC CONVERTER -Vin -Vout Note: Certain applications may require the installation of external fuse in front of the input. DANUBE http://www.danube.com.tw 6 2014/04/28 NU SERIES APPLICATION NOTES: EXTERNAL CAPACITANCE REQUIREMENTS: Output filtering is required for operation. A minimum of 10uF is needed. Output capacitance may be increased for additional filtering, not to exceed 220uF. To meet the reflected ripple requirements of the converter, an input impedance of less than 0.5 ohm from DC to 250KHz is required. We Can Offer EMC-Filter According To EN55011/22 Class B. Negative Outputs: A negative output voltage may be obtained by connecting the +OUT to circuit ground and connecting –OUT as the negative output. FOR MORE INFORMATION CALL: Danube Enterprise Co., Ltd. Tel: 886-7-3755165 Fax: 886-7-3755330 Home Page http://www.danube.com.tw DANUBE E-mail: danube@ms10.hinet.net http://www.danube.com.tw 7 2014/04/28
NUS-0505A 价格&库存
很抱歉,暂时无法提供与“NUS-0505A”相匹配的价格&库存,您可以联系我们找货
