072160-120-2EB
072160-120-2EB
    DESCO
    FUME ABSORBER MOBILE UNIT 120V
072160-120-2EB 数据手册
Purex has upgraded one of their bestselling products and made it even better! FumeCube is now multi-voltage and can adapt to any voltage requirement. Perfect for bench soldering and other similar applications. Recirculating fume extraction is now extremely important with the rising concern for our environment and employee safety. Purex Fume Extractors provide not only a flexible and portable process for plant designs and expansions, but also a more stable process by providing a controlled airflow to remove harmful fumes. All this while eliminating the added costs of Multi-Voltage FumeCube building modifications, increased air handling systems and lost energy. Purex Systems ❖ Automatic Flow Control maintains constant extraction rate ❖ HEPA filtration removes 99.997% of particles down to .3 microns ❖ Adjustable Air Flow extends filter life ❖ Remote Machine Interface ❖ Blocked Filter Warning ❖ Welded stainless steel construction ❖ Easy to change filters ❖ Continuous run brushless motors ❖ Quiet operation ❖ Multi-voltage, use anywhere in the ❖ Low Energy consumption world FumeCube Variable Speed Control Power Switch w/ Indicator Light Filter Status Indicator Main Filter Options HEPA/Chemical Chemical HEPA Chemical Cleanroom* Solvent Lock 110536∆ 110537 110538 110543 6 *Use F8/F9 Pre-filter Pre-Filter F5 (4pk) F6 (4pk) F8/F9 (4pk) 1) 2) 3) 4) 5) 6) 200225∆ 200226 200316 ∆Standard Filter Supplied Standard 38mm Stainless Arm Kit Including: FumeCube Single Port Model Voltage (50hz/60Hz)* Wattage Airflow Vacuum Air Inlet Ports -Sound Rating Dimensions (L/W/H) Weight Dual Port 072155 072160 100-230 Volt Single Phase .14Kw 135 cfm (225 m3/Hr) 13 inwg (3.2 kPa) 57mm I.D./62mm O.D. 60 dBA 12.15in x 12in x 14.5in 37.5 lbs Dual Air inlet Pre-filter Main filter (HEPA Location) Main filter (Carbon Location) Clean air return Filter I.D. label 1- 51mm x 2m flexible hose w/ connecting cuffs 1-Clamped Bracket 1-SS Flexible arm and valve 1-SS slim nozzle 1-SS conical cowl 1-Plug for 2nd air inlet 2246 Palmer Drive, Unit 108, Schaumburg, IL 60173 Toll Free 866.360.5675
072160-120-2EB 价格&库存
很抱歉,暂时无法提供与“072160-120-2EB”相匹配的价格&库存,您可以联系我们找货
