725-28920
725-28920
    LIGHTWARE
    LIGHTWARE MICROLIDAR ACCESSORY
725-28920 数据手册
Web Site: www.parallax.com Forums: forums.parallax.com Sales: sales@parallax.com Technical: support@parallax.com Office: (916) 624-8333 Fax: (916) 624-8003 Sales: (888) 512-1024 Tech Support: (888) 997-8267 Aluminum Stand Kit for Laser Rangefinders (#725-28920), fits Lightware SF10, SF11, and SF30 This precision-machined bracket mounts your Lightware SF10, SF11, and SF30 series laser rangefinder to your project. The stand is made from high-grade aluminum and it conveniently positions and protects the laser rangefinder in both stationary and mobile applications. Assembly is quick and easy. Kit Contents Assembled View Features • • • • Fits Lightware #SF10 series of laser rangefinders o SF10-A – 25m (#28051) o SF10-B – 50m (#28052) o SF10-C – 100m (#28053) Custom CNC-machined in Rocklin, CA USA from 6061 high-grade aluminum Hardware for mounting the sensor to the stand and then attaching the stand to your project is included Dimensions (without sensor): 2.52 x 2.57 x 0.35 in (63.86 x 65.36 x 8.84 mm) Kit Contents • • • • (1) (2) (2) (1) SF10 Laser Aluminum Stand (#720-28006) Screw, #4-40 x 1/4” Socket Head (#710-00047) Screw, #6-32 x 1/2” Socket Head (#710-00033) 3/32” Hex Key (#725-00025) Note: kits made after May 1st 2018 no longer included the 7/64” Ball End Hex Key, available separately from Parallax if you don’t already have one, #725-00021. Copyright © Parallax Inc. Aluminum Stand Kit for SF10 Lasers (#725 28920) v2.0 5/14/2018 Page 1 of 2 Tools Required (not included) • A 7/64” Ball-end Hex Key, if using the included Two #6-32 x 1/2” Socket Head machine screws to attach the stand to your project. Assembly Instructions Step 1: Place the stand on a clean, smooth, flat surface with the two blind tapped holes facing up. Step 2: Insert the SF10/11/30 laser rangefinder (as shown below) into the figure-8 shaped opening. Secure with two #4-40 x 1/4” long, socket-head screws using the 3/32” hex key. Do not overtighten. Step 3: Mount the sensor to your project with two 6-32 x 1/2” socket-head screws using a ball-end 7/64” hex key (not included, available separately from Parallax if you don’t have one, #725-00021). Dimensional /Assembly Drawing Revision History Version 2.0: List of compatible Lightware Laser Rangefinder models updated. Updated to reflect removal of the 7/64” Ball End Hex Key from the kit (available separately from Parallax if you don’t have one, #725-00021). Copyright © Parallax Inc. Aluminum Stand Kit for SF10 Lasers (#725 28920) v2.0 5/14/2018 Page 2 of 2
725-28920 价格&库存
很抱歉,暂时无法提供与“725-28920”相匹配的价格&库存,您可以联系我们找货
