47202
47202
    PROTEKTIVEPAK
    TURNTABLE, ESD PLASTEK, 12-1/2''
47202 数据手册
Specifications • Ideal for use where corrugated and/or paper products cannot be used • Durable 1/4" (6mm) thick dissipative, crosslink polyethylene foam laminated to conductive fluted Plastek • Galvanized Steel Turntable located at the bottom • Size: Choice of 12-1/2" (318mm) or 15-1/2" (395mm) circle • Very low profile - 1" high • Weight capacity 50 lbs (23Kg), ideal for working on heavier assemblies • Volume Resistance 1 x 106 to < 1 x 109 ohms per ANSI/ESD STM11.12 • Meets worksurface required limit of ANSI/ESD S20.20 per ANSI/ESD S4.1 and ESD TR53 • Electrostatic charges removed to ground via contact on grounded ESD worksurface or via our 47204 ground cord • Made in the United States of America Item Size (Diameter) 47202 12-1/2" (318mm) 47203 15-1/2" (394mm) 47203 in use (47204 Ground cord sold separately) Galvanized Steel Turntable Specifications and procedures are subject to change without notice Unless specified tolerances are +/- 10% ESD PLASTEK TURNTABLE PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578 ProtektivePak.com © 2016 DESCO INDUSTRIES INC. Employee Owned Made in the United States of America DRAWING NUMBER 47202 DATE: March 2016
47202 价格&库存
很抱歉,暂时无法提供与“47202”相匹配的价格&库存,您可以联系我们找货
    • 1+1608.480001+208.08145
    • 10+1491.9054610+193.00075
    • 25+1454.9436925+188.21918
    • 50+1429.7982050+184.96623
    库存:16
