78.01GC8.4020C
78.01GC8.4020C
    APACERMEMORYAMERICA(宇瞻科技)
    UDIMM240
    存储器 - 模块 DDR3 SDRAM 1GB 240-UDIMM
78.01GC8.4020C 数据手册
RoHS Compliant 1GB ECC DDR3 SDRAM UDIMM Product Specifications May 13, 2015 Version 1.2 Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Table of Contents General Description .......................................................................................................2 Ordering Information .....................................................................................................2 Key Parameters ..............................................................................................................2 Specifications:................................................................................................................3 Features:.........................................................................................................................4 Pin Assignments.............................................................................................................5 Pin Descriptions .............................................................................................................7 Functional Block Diagram.............................................................................................8 Absolute Maximum Ratings ..........................................................................................9 DRAM Component Operating Temperature Range.....................................................10 Operating Conditions ................................................................................................... 11 Mechanical Drawing....................................................................................................12 ©pacer Technology Inc. 1 General Description Apacer 78.01GC8.4020C is a 128M x 72 DDR3 SDRAM (Synchronous DRAM) ECC DIMM. This high-density memory module consists of 9 pieces 128M x 8 bits with 8 banks DDR3 synchronous DRAMs in BGA packages and a 2K EEPROM. The module is a 240-pins dual in-line memory module and is intended for mounting into a connector socket. Decoupling capacitors are mounted on the printed circuit board for each DDR3 SDRAM. The following provides general specifications of this module. Ordering Information Part Number Bandwidth Speed Grade Max Frequency CAS Latency 78.01GC8.4020C 10.6 GB/sec 1333Mbps 666 MHz CL9 Density Organization Component Rank 1GB 128M x 72 128M x8*9 1 Key Parameters MT/s DDR3-1066 DDR3-1333 DDR3-1600 Unit Grade -CL7 -CL9 -CL11 tCK (min) 1.875 1.5 1.25 ns CAS latency 7 9 11 tCK tRCD (min) 13.125 13.5 13.75 ns tRP (min) 13.125 13.5 13.75 ns tRAS (min) 37.5 36 35 ns tRC (min) 50.625 49.5 48.75 ns CL-tRCD-tRP 7-7-7 9-9-9 11-11-11 tCK ©pacer Technology Inc. 2 Specifications: ♦ Support ECC error detection and correction ♦ On-DIMM thermal sensor : Yes ♦ Organization: 128 words x 72 bits, 1 rank ♦ Integrating 9 pieces of 1G bits DDR3 SDRAM sealed FBGA ♦ Package: 240-pin socket type dual in-line memory module (ECC DIMM) ♦ PCB: height 30.0 mm, lead pitch 1.0 mm (pin), lead-free (RoHS compliant) ♦ Power supply VDD: 1.5V ± 0.075V ♦ Serial Presence Detect (SPD) ♦ Eight Internal banks for concurrent operation (components) ♦ Interface: SSTL_15 ♦ Burst lengths (BL): 8 and 4 with Burst Chop (BC) ♦ CAS Latency (CL): 6, 7, 8, 9 ♦ CAS Write Latency (CWL): 5, 6, 7 ♦ Supports auto pre-charge option for each burst access ♦ Supports auto-refresh/self-refresh ♦ Refresh cycles: 7.8 ㎲ at 0℃≦ TC ≦ +85℃ ♦ PCB: 30µ gold finger ©pacer Technology Inc. 3 Features: ♦ Double-date-rate architecture: 2 data transfers per clock cycle ♦ The high-speed data transfer is realized by the 8 bits prefetch pipelined architecture ♦ Bi-directional differential data strobe (DQS and /DQS) is transmitted / received with data for capturing data at the receiver ♦ DQS is edge-aligned with data for READs; center aligned with data for WRITEs ♦ Differential clock inputs (CK and /CK) ♦ DLL aligns DQ and DQS transitions with CK transitions ♦ Data mask (DM) for writing data ♦ Posted /CAS by programmable additive latency for enhanced command and data bus efficiency ♦ On-Die-Termination (ODT) for improved signal quality: Synchronous ODT/Dynamic ODT/Asynchronous ODT ♦ Multi-Purpose Register (MPR) for temperature read out ♦ ZQ calibration for DQ drive and ODT ♦ Programmable Partial Array Self-Refresh (PASR) ♦ /Reset pin for power-up sequence and reset function ♦ SRT range: normal/extended, auto/manual self-refresh ♦ Programmable output driver impedance control ♦ Commands entered at each positive clock input, while data and data mask are referenced to both edges of DQS ©pacer Technology Inc. 4 Pin Assignments Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 1 VREFDQ 31 DQ25 61 A2 91 DQ41 2 VSS 32 VSS 62 VDD 92 VSS 3 DQ0 33 /DQS3 63 CK1(NC) 93 /DQS5 4 DQ1 34 DQS3 64 /CK1(NC) 94 DQS5 5 VSS 35 VSS 65 VDD 95 VSS 6 /DQS0 36 DQ26 66 VDD 96 DQ42 7 DQS0 37 DQ27 67 VREFCA 97 DQ43 8 VSS 38 VSS 68 NC 98 VSS 9 DQ2 39 CB0 69 VDD 99 DQ48 10 DQ3 40 CB1 70 A10(AP) 100 DQ49 11 VSS 41 VSS 71 BA0 101 VSS 12 DQ8 42 /DQS8 72 VDD 102 /DQS6 13 DQ9 43 DQS8 73 /WE 103 DQS6 14 VSS 44 VSS 74 /CAS 104 VSS 15 /DQS1 45 CB2 75 VDD 105 DQ50 16 DQS1 46 CB3 76 /CS1 106 DQ51 17 VSS 47 VSS 77 ODT1 107 VSS 18 DQ10 48 NC 78 VDD 108 DQ56 19 DQ11 49 NC 79 NC 109 DQ57 20 VSS 50 CKE0 80 VSS 110 VSS 21 DQ16 51 VDD 81 DQ32 111 /DQS7 22 DQ17 52 BA2 82 DQ33 112 DQS7 23 VSS 53 NC 83 VSS 113 VSS 24 /DQS2 54 VDD 84 /DQS4 114 DQ58 25 DQS2 55 A11 85 DQS4 115 DQ59 26 VSS 56 A7 86 VSS 116 VSS 27 DQ18 57 VDD 87 DQ34 117 SA0 28 DQ19 58 A5 88 DQ35 118 SCL 29 VSS 59 A4 89 VSS 119 SA2 30 DQ24 60 VDD 90 DQ40 120 VTT ©pacer Technology Inc. 5 Pin No. Pin name Pin No. Pin name Pin No. Pin name Pin No. Pin name 121 VSS 151 VSS 181 A1 211 VSS 122 DQ4 152 DM3 182 VDD 212 DM5 123 DQ5 153 NC 183 VDD 213 NC 124 VSS 154 VSS 184 CK0 214 VSS 125 DM0 155 DQ30 185 /CK0 215 DQ46 126 NC 156 DQ31 186 VDD 216 DQ47 127 VSS 157 VSS 187 /EVENT 217 VSS 128 DQ6 158 CB4 188 A0 218 DQ52 129 DQ7 159 CB5 189 VDD 219 DQ53 130 VSS 160 VSS 190 BA1 220 VSS 131 DQ12 161 DM8 191 VDD 221 DM6 132 DQ13 162 NC 192 /RAS 222 NC 133 VSS 163 VSS 193 /CS0 223 VSS 134 DM1 164 CB6 194 VDD 224 DQ54 135 NC 165 CB7 195 ODT0 225 DQ55 136 VSS 166 VSS 196 A13 226 VSS 137 DQ14 167 NC 197 VDD 227 DQ60 138 DQ15 168 /RESET 198 NC 228 DQ61 139 VSS 169 CKE1 199 VSS 229 VSS 140 DQ20 170 VDD 200 DQ36 230 DM7 141 DQ21 171 A15(NC) 201 DQ37 231 NC 142 VSS 172 A14(NC) 202 VSS 232 VSS 143 DM2 173 VDD 203 DM4 233 DQ62 144 NC 174 A12 204 NC 234 DQ63 145 VSS 175 A9 205 VSS 235 VSS 146 DQ22 176 VDD 206 DQ38 236 VDDSPD 147 DQ23 177 A8 207 DQ39 237 SA1 148 VSS 178 A6 208 VSS 238 SDA 149 DQ28 179 VDD 209 DQ44 239 VSS 150 DQ29 180 A3 210 DQ45 240 VTT Notes: 1. /CS1, ODT1, CKE1: Used for dual-rank UDIMMs; NC on single-rank UDIMMs. 2. CK1, NC and /CK1, NC: Used for dual-rank UDIMMs; not used on single-rank UDIMMs, but terminated. ©pacer Technology Inc. 6 Pin Descriptions Pin Name Description Ax* SDRAM address bus BAx SDRAM bank select DQx DIMM memory data bus CBx DIMM ECC check bits /RAS SDRAM row address strobe /CAS SDRAM column address strobe /WE SDRAM write enable /CSx SDRAM Chip select lines CKEx SDRAM clock enable lines CKx SDRAM clock input /CKx SDRAM Differential clock input DQSx SDRAM data strobes(positive line of differential pair) /DQSx SDRAM data strobes(negative line of differential pair) DMx SDRAM input mask SCL Clock input for serial PD SDA Data input/output for serial PD SAx Serial address input VDD Power for internal circuit VDDSPD Serial EEPROM positive power supply VREFDQ SDRAM I/O reference supply VREFCA SDRAM command/address reference supply VSS Power supply return(ground) VTT SDRAM I/O termination supply /RESET ODTx /EVENT NC *IC Component Composition: ©pacer Technology Inc. Set DRAM to known state On-die termination control lines An output of the thermal sensor to indicate critical module temperature Spare pins(no connect) 128Mx8 256Mx8 512Mx8 1024Mx8 A0~A13 A0~A14 A0~A15 A0~A15 7 Functional Block Diagram Rs1 DM3 8 Rs1 DQ24 to DQ31 DQ0 to DQ7 /RESET VTT VDDSPD VREFCA VREFDQ VDD ZQ DM8 CB0 to CB7 DQ0 to DQ7 DQS Rs1 DQ0 to DQ7 DQS Rs1 8 Rs1 DM DQ0 to DQ7 SCL SCL SA0 SA1 SA2 A0 A1 A2 Rs4 /CK Rs4 /CK SDA U1 /EVENT /EVENT * D0 to D8: 1G bits DDR3 SDRAM Address, BA: A0 to A13, BA0 to BA2 Command: /RAS, /CAS, /WE U1: 256 bytes EEPROM Rs1: 15Ω Rs2: 39Ω Rs3: 36Ω Rs4: 240Ω D8 D3 D4 D5 D6 D7 Address and Control lines ©pacer Technology Inc. ZQ Serial PD Notes : 1. DQ wiring may be changed within a byte. 2. DQ, DQS, /DQS, ODT, DM, CKE, /CS relationships must be maintained as shown. D2 Rs3 D8 /DQS Rs1 ZQ Rs4 DM SDRAMs (D0 to D8), SPD D1 CK D4 /DQS Rs1 /CK Rs1 SPD SDRAMs (D0 to D8) SDRAMs (D0 to D8) SDRAMs (D0 to D8) D0 CK Rs1 /RESET:SDRAMs (D0 to D8) VSS ZQ Rs4 DM CK Rs4 /DQS8 D5 /DQS DM4 8 Rs1 DQ32 to DQ39 DQS8 /CS ODT CKE Address BA Command DQS Rs1 ZQ /CK Rs1 DQ0 to DQ7 CK DM /CS ODT CKE Address BA Command Rs1 8 Rs1 /CS ODT CKE Address BA Command Rs4 /CK CK ZQ D3 /DQS DM /DQS4 D6 /DQS Rs4 Rs1 DQS DQS Rs1 ZQ /CK /DQS3 Rs1 DQ0 to DQ7 Rs1 DQ0 to DQ7 CK DQS3 DM DM 8 VTT DM2 8 Rs1 DQ16 to DQ23 D2 /DQS Rs1 8 Rs1 DM5 8 Rs1 DQ40 to DQ47 DQS4 D7 /DQS Rs1 ZQ Rs2 Rs2 Rs2 Rs2 Rs2 Rs1 DQS DQS Rs1 /CS ODT CKE Address BA Command Rs1 DQ0 to DQ7 /DQS5 Rs1 /CS ODT CKE Address BA Command Rs1 DM DQ48 to DQ55 D1 /DQS /CK 8 Rs1 DM6 DQS5 CK Rs1 DQS ZQ Rs4 /DQS2 Rs1 DQ0 to DQ7 /DQS6 Rs4 DQS2 Rs1 /DQS DM DQS6 D0 /CK DM1 DQ8 to DQ15 Rs1 8 Rs1 DQS CK /DQS1 Rs1 /CK DQS1 Rs1 CK DQ0 to DQ7 DQ56 to DQ63 /CS ODT CKE Address BA Command DM0 DM7 /CS ODT CKE Address BA Command /DQS0 /DQS7 3 17 /CS ODT CKE Address BA Command DQS0 DQS7 /CS ODT CKE Address BA Command /CK0 CK0 Command Address, BA /CS0 ODT0 CKE0 Rs3 VDD VTT SDA Absolute Maximum Ratings Parameter Symbol Description Units Voltage on VDD pin relative to Vss VDD - 0.4 V ~ 1.975 V V Voltage on VDDQ pin relative to Vss VDDQ - 0.4 V ~ 1.975 V V Voltage on any pin relative to Vss VIN, VOUT - 0.4 V ~ 1.975 V V Storage Temperature TSTG -55 to +100 ℃ Notes: 1. Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. 2. Storage Temperature is the case surface temperature on the center/top side of the DRAM. For the measurement conditions, please refer to JESD51-2 standard. 3. VDD and VDDQ must be within 300mV of each other at all times; and VREF must not be greater than 0.6 x VDDQ, when VDD and VDDQ are less than 500mV; VREF may be equal to or less than 300mV. ©pacer Technology Inc. 9 DRAM Component Operating Temperature Range Symbol TOPER Parameter Rating Units Notes Normal Operating Temperature Range 0 to 85 ℃ 1,2 Extended Temperature Range 85 to 95 ℃ 1,3 Notes: 1. Operating Temperature TOPER is the case surface temperature on the center / top side of the DRAM. For measurement conditions please refer to the JEDEC document JESD51-2. 2. The Normal Temperature Range specifies the temperatures where all DRAM specifications will be supported during operation, the DRAM case temperature must be maintained between 0℃ - 85℃ under all operating Conditions. 3. Some applications require operation of the DRAM in the Extended Temperature Range between 85℃ and 95℃ case temperature. Full specifications are guaranteed in this range, but the following additional conditions apply: a. Refresh commands must be doubled in frequency, therefore reducing the Refresh interval tREFI to 3.9 µs. b. If Self-Refresh operation is required in the Extended Temperature Range, then it is mandatory to either use the Manual Self-Refresh mode with Extended Temperature Range capability (MR2 A6 = 0b and MR2 A7 = 1b), in this case IDD6 current can be increased around 10~20% than normal Temperature range. ©pacer Technology Inc. 10 Operating Conditions Recommended DC Operating Conditions - DDR3 (1.5V) operation Symbol VDD Rating Parameter Supply Voltage VDDQ Supply Voltage for Output Units Min. Typ. Max. 1.425 1.5 1.575 V 1.425 1.5 1.575 V Notes: 1. Under all conditions VDDQ must be less than or equal to VDD.. 2. VDDQ tracks with VDD. AC parameters are measured with VDD and VDDQ tied together. ©pacer Technology Inc. 11 Mechanical Drawing Unit: mm 30µ gold finger (All dimensions are in millimeters with ±0.15mm tolerance unless specified otherwise.) ©pacer Technology Inc. 12 Revision History Revision Date Description 0.9 08/28/2012 Official release 1.0 08/29/2012 release 1.1 07/23/2013 Remark 1. Changed headquarters address 2. Added 30µ gold finger 1.2 05/08/2015 ©Apacer Technology Inc. 1.Updated Mechanical Drawing. 13 Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com ©pacer Technology Inc. 14
78.01GC8.4020C 价格&库存
很抱歉,暂时无法提供与“78.01GC8.4020C”相匹配的价格&库存,您可以联系我们找货
