RoHS Compliant
8GB DDR5 SDRAM SO-DIMM
Halogen free
Product Specifications
April 19, 2022
Version 1.0
Apacer Technology Inc.
1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
Table of Contents
General Description ....................................................................................................... 2
Ordering Information ..................................................................................................... 2
Key Parameters .............................................................................................................. 2
Features: ......................................................................................................................... 3
Pin Assignments ............................................................................................................. 4
Pin Descriptions ............................................................................................................. 6
INPUT/OUTPUT FUNCTIONAL DESCRIPTION...................................................... 7
Functional Block Diagram ........................................................................................... 10
Absolute Maximum Ratings ........................................................................................ 11
DRAM Component Operating Temperature Range..................................................... 12
AC & DC OPERATING CONDITION ....................................................................... 13
DIMM Voltage Requirements ...................................................................................... 13
Mechanical Drawing .................................................................................................... 14
©Apacer Technology Inc.
1
General Description
Apacer D22.31491S.001 is a 8GB DDR5 SDRAM (Synchronous DRAM)
SO-DIMM. This memory module consists of 4 pieces 1G x 16 bits DDR5
synchronous DRAMs in FBGA packages and 8K Bits EEPROM. The module is
a 262-pins dual in-line memory module and is intended for mounting into a
connector socket. The following provides general specifications of this module.
Part Number
Density
Speed
Organization
DRAM Composition
Rank
D22.31491S.001
8GB
4800 Mbps
1Gx64
1Gx16 *4
1
Key Parameters
DDR5-4800
Speed
-CL40
Unit
tCK (min)
0.416
ns
CAS latency
40
nCK
tRCD (min)
16
ns
tRP (min)
16
ns
tRAS (min)
32
ns
tRC (min)
48
ns
CL-tRCD-tRP
40-39-39
nCK
2
Features:
JEDEC standard compliant
On-DIMM thermal sensor : Yes
PCB: height 30 mm, lead pitch 0.5 mm (pin),
VDD = VDDQ= 1.1V (1.067V to 1.166V)
VPP = 1.8V (1.746V to 1.908V)、VDDSPD = 1.8V
32 internal banks (x4, x8): 8 groups of 4 banks each
16 internal banks (x16): 4 groups of 4 banks each
CAS Latency (CL): 22,26,28,30,32,36,40,42
CAS Write Latency (CWL): RL-2
Operating temperature Tcase–(0℃~85℃)
Average Refresh period 3.9us at lower than Tcase 85°C, 1.95us at 85°C <
Tcase < 95 °C.
All bank and same bank refresh
Bi-Directional Differential Data Strobe
16-bit prefetch architecture
On-die ECC
ECC transparency and error scrub
sPPR and hPPR capability
Halogen free、Lead-free (RoHS compliant)
3
Pin Assignments
Pin
No.
Front Side
Pin
No.
Back Side
Pin
No.
Front Side
Pin
No.
Back Side
1
VIN_BULK
2
HSA
133
CK0_A_c
134
CK1_A_c
3
VIN_BULK
4
HSCL
135
VSS
136
VSS
5
RFU
6
HSDA
137
CK0_B_t
138
CK1_B_t
7
PWR_GOOD
8
PWR_EN
139
CK0_B_c
140
CK1_B_c
9
VSS
10
VSS
141
VSS
142
VSS
11
DQ0_A
12
DQ1_A
143
RFU
144
CA12_B
13
VSS
14
VSS
145
CA11_B
146
CA10_B
15
DQ2_A
16
DQ3_A
147
VSS
148
VSS
17
VSS
18
VSS
149
CA9_B
150
CA8_B
19
DM0_A_n
DQS0_A_c
151
CA7_B
152
CA6_B
21
VSS
22
DQS0_A_t
153
VSS
154
VSS
23
DQ4_A
24
VSS
155
CA5_B
156
CA4_B
25
VSS
26
DQ5_A
157
CA3_B
158
CA2_B
27
DQ6_A
28
VSS
159
VSS
160
VSS
29
VSS
30
DQ7_A
161
CS0_B_n
162
CA1_B
31
DQ8_A
32
VSS
163
RESET_n
164
CA0_B
33
VSS
34
DQ09_A
165
CS1_B_n
166
VSS
35
DQ10_A
36
VSS
167
VSS
168
CB0_B
37
VSS
38
DQ11_A
169
DQS4_B_c
170
VSS
39
DQS1_A_c
40
VSS
171
DQS4_B_t
172
CB1_B
41
DQS1_A_t
42
DM1_A_n
173
VSS
174
VSS
43
VSS
44
VSS
175
CB3_B
176
CB2_B
45
DQ12_A
46
DQ13_A
177
VSS
178
VSS
47
VSS
48
VSS
179
DQ0_B
180
DQ1_B
49
DQ14_A
50
DQ15_A
181
VSS
182
VSS
51
VSS
52
VSS
183
DQ2_B
184
DQ3_B
53
DQ16_A
54
DQ17_A
185
VSS
186
VSS
55
VSS
56
VSS
187
DM0_B_n
188
DQS0_B_c
57
DQ18_A
58
DQ19_A
189
VSS
190
DQS0_B_t
59
VSS
60
VSS
191
DQ4_B
192
VSS
61
DM2_A_n
62
DQS2_A_c
193
VSS
194
DQ5_B
63
VSS
64
DQS2_A_t
195
DQ6_B
196
VSS
65
DQ20_A
66
VSS
197
VSS
198
DQ7_B
67
VSS
68
DQ21_A
199
DQ8_B
200
VSS
69
DQ22_A
70
VSS
201
VSS
202
DQ9_B
4
Pin
No.
Front Side
Pin
No.
Back Side
Pin
No.
Front Side
Pin
No.
Back Side
71
VSS
72
DQ23_A
203
DQ10_B
204
VSS
73
DQ24_A
74
VSS
205
VSS
206
DQ11_B
75
VSS
76
DQ25_A
207
DQS1_B_c
208
VSS
77
DQ26_A
78
VSS
209
DQS1_B_t
210
DM1_B_n
79
VSS
80
DQ27_A
211
VSS
212
VSS
81
DQS3_A_c
82
VSS
213
DQ12_B
214
DQ13_B
83
DQS3_A_t
84
DM3_A_n
215
VSS
216
VSS
85
VSS
86
VSS
217
DQ14_B
218
DQ15_B
87
DQ28_A
88
DQ29_A
219
VSS
220
VSS
89
VSS
90
VSS
221
DQ16_B
222
DQ17_B
91
DQ30_A
92
DQ31_A
223
VSS
224
VSS
93
VSS
94
VSS
225
DQ18_B
226
DQ19_B
95
CB0_A
96
CB1_A
227
VSS
228
VSS
97
VSS
98
VSS
229
DM2_B_n
230
DQS2_B_c
99
CB2_A
100
DQS4_A_c
231
VSS
232
DQS2_B_t
101
VSS
102
DQS4_A_t
233
DQ20_B
234
VSS
103
CB3_A
104
VSS
235
VSS
236
DQ21_B
105
VSS
106
CS0_A_n
237
DQ22_B
238
VSS
107
CA0_A
108
ALERT_n
239
VSS
240
DQ23_B
109
CA1_A
110
CS1_A_n
241
DQ24_B
242
VSS
111
VSS
112
VSS
243
VSS
244
DQ25_B
113
CA2_A
114
CA3_A
245
DQ26_B
246
VSS
115
CA4_A
116
CA5_A
247
VSS
248
DQ27_B
117
VSS
118
VSS
249
DQS3_B_c
250
VSS
119
CA6_A
120
CA7_A
251
DQS3_B_t
252
DM3_B_n
121
CA8_A
122
CA9_A
253
VSS
254
VSS
123
VSS
124
VSS
255
DQ28_B
256
DQ29_B
125
CA10_A
126
CA11_A
257
VSS
258
VSS
127
CA12_A
128
RFU
259
DQ30_B
260
DQ31_B
129
VSS
130
VSS
261
VSS
262
VSS
131
CK0_A_t
132
CK1_A_t
5
Pin Descriptions
Pin Name
CA0_A – CA12_A,
Descripti
SDRAM Command/Address bus
CA0_B – CA12_B
CS0_A_n – CS1_A_n,
SDRAM Chip Select
CS0_B_n – CS1_B_n
DQ0_A – DQ31_A,
DIMM memory data bus
DQ0 B – DQ31 B
CB0_A – CB3_A,
DIMM ECC check bits (Only applicable on ECC SODIMM or
CB0 B – CB3 B
ECC UDIMM)
DQS0_A_t – DQS4_A_t,
SDRAM data strobes (positive line of differential pair)
DQS0_B_t – DQS4_B_t
DQS0_A_c – DQS4_A_c,
SDRAM data strobes (negative line of differential pair)
DQS0_B_c – DQS4_B_c
DM0_A_n – DM3_A_n,
DM0_B_n – DM3_B_n
CK0_A_t, CK1_A_t,
CK0_B_t, CK1_B_t
SDRAM data masks
SDRAM clocks (positive line of differential pair)
CK0_A_c, CK1_A_c,
CK0_B_c, CK1_B_c
SDRAM clocks (negative line of differential pair)
HSCL
Side Band bus clock
HSDA
Side Band bus data
HSA
Side Band bus address
ALERT_n
SDRAM ALERT_n
RESET_n
Set DRAMs to a Known State
VIN_BULK
5 V power input supply to the PMIC for analog circuits
VSS
Power supply return (ground)
PWR_GOOD
Power good indicator
PWR_EN
PMIC Enable
RFU
Reserved for future use
*Notes:
DDR5 SO-DIMM has 2 channels (channel-A and channel-B) of signal bus.
The signals with suffix: _A (e.g. DQ0_A) are for channel-A, and the signals with suffix: _B (e.g. DQ0_B) are for
channel-B
6
Symbol
Type
I/O Levels
Description
CK[1:0]_A_t,
CK[1:0]_B_t,
Clock: CK_t and CK_c are differential clock inputs. All
Input
VDD
CK[1:0]_A_c,
address and con- trol input signals are sampled on the
crossing of the positive edge of CK_t and negative
edge of CK_c.
CK[1:0]_B_c
Command/Address Inputs: CA signals provide the
command and address inputs according to the
CA[12:0]_A
Input
VDD
CA[12:0]_B
Command Truth Table.
Note: Since some commands are multi-cycle, the pins
may not be interchanged between devices on the
same bus.
Chip Select: All commands are masked when CS_n is
CS[1:0]_A_n
Input
VDD
CS[1:0]_B_n
registered HIGH. CS_n pro- vides for external rank
selection on systems with multiple ranks.
Alert: If there is an error in CRC, then ALERT_n drives
LOW for the period time interval and returns HIGH.
ALERT_n
Output
VDD
During connectivity test mode, this pin functions as an
input. Usage of this signal is system-dependent. In the
case where this pin is not connected, ALERT_n must
be bonded to VDDQ on the system board.
Active Low Asynchronous Reset: Reset is active when
CMOS
RESET_n
Input
RESET_n is LOW, and inactive when RESET_n is HIGH.
VDD
RESET_n must be HIGH during normal operation.
RESET_n is a CMOS rail-to-rail signal with DC HIGH
and LOW at 80% and 20% of VDDQ.
7
Symbol
Type
I/O Levels
Description
Power Good Indicator: Open drain output. The PMIC
ensures this pin HIGH when VIN_Bulk input supply, as
well as all enabled output buck regulators and all LDO
regulators tolerance threshold is maintained as
configured in the appropri- ate register. The PMIC
Input /
PWR_GOOD
Output
drives this pin LOW when VIN_Bulk input goes below
VDD
the threshold or when any of the enabled output buck
regulator exceeds the thresh- olds configured in the
appropriate register or when any LDO output
regulator exceeds the threshold configured in the
appropriate register. As an input, the PMIC disables its
output regulator when this pin is LOW. The LDO
outputs remain on.
Host Sideband Bus Clock: Bus clock used to strobe
HSCL
data into HUB device. When open drain, a pull-up
Input
resistor is required on the system motherboard.
Host Sideband Bus Data:I2C/I3C-Basic data. When
Input /
open drain, a pull-up resis- tor is required on the
Output
system motherboard.
HSDA
Host Sideband Bus Device ID: Address input to a hub
or other client device to distinguish between identical
devices in the I3C basic address range. Tied to GND,
HSA
Input
HSA has different resistor values on the motherboard
to identify DIMM slot address. Refer to the SPD Hub
spec for more information.
Data Input/ Output: Bi-directional data bus.
DQ[31:0]_A
Input /
DQ[31:0]_B
Output
CB[3:0]_A
Input /
VDD
added at the end of Data Burst.
DIMM ECC check bits.
VDD
CB[3:0]_B
Output
If CRC is enabled via Mode register then CRC code is
(Only applicable on ECC SODIMM or ECC UDIMM)
8
Symbol
Type
I/O Levels
Description
Data Strobe: Output with read data, input with write
DQS[4:0]_A_t
data. Edge-aligned with read data, centered in write
DQS[4:0]_B_t
data. The data strobe DQS_t is paired with differenInput /
VDD
Output
tial signals DQS_c, respectively, to provide differential
DQS[4:0]_A_c
pair signaling to the system during reads and writes.
DQS[4:0]_B_c
DDR5 SDRAM only supports differential data strobe. It
does not support single-ended strobe.
Input Data Mask: DM_n is an input mask signal for
write data. Input data is masked when DM_n is
sampled LOW coincident with that input data during a
write access. DM_n is sampled on both edges of DQS.
DM[3:0]_A_n
Input
DM[3:0]_B_n
VDD
DM function is shared with TDQS on x8 devices. The
function of DM_n is enabled by MR5:OP[5] = 1. Refer
to Micron DDR5 component data sheet specification
for further detail.
VIN_BULK
Supply
External Power Supply: 5V, 4.25V (min), 5.5V (max)
PMIC Enable: When this pin is HIGH, the PMIC turns
on the regulator. When this pin is LOW, the PMIC turns
PWR_EN
Input
off the regulator. This signal is connected to the
PMIC's VR_EN pin.
VSS
Supply
Ground
Reserved for future use. No on DIMM electrical
RFU
connection is present.
No connect: No internal electrical connection is
NC
present.
No function: May have internal connection present,
NF
but has no
9
function.
Note 1: Unless otherwise noted resistors are 15Ω ± 5%
Note 2: ZQ resistors are 240Ω ± 1%.
Note 3: CK1_[A:B]_t/c edge pin signals are each terminated with 33Ω ± 5% resistor to VSS.
Note 4: CS1_[A:B]_n edge pin signals are each terminated with 39Ω ± 5% resistor to VSS.
HSCL
HSDA
HSA
SCL
LSCL
SDA
LSDA
LSCL
LSDA
SCL
SDA
SAA
PMIC
SPD Hub
PMIC
VDDSPD
Hub
PMIC_Vin
VIN
VPP
D0 – D3
PWR_EN
VR_EN
VDD
D0 – D3
VDDQ
D0 – D3
PWR_GOOD
PWR_GOOD
VDDIO
Hub
VSS
GND
10
Parameter
Symbol
Rating
Units
Notes
Voltage on VDD pin relative to Vss
VDD
- 0.3 ~ 1.4
V
1
Voltage on VDDQ pin relative to Vss
VDDQ
- 0.3 ~ 1.4
V
1
Voltage on VPP pin relative to Vss
VPP
- 0.3 ~ 2.1
V
Voltage on any pin relative to Vss
VIN, VOUT
- 0.3 ~ 1.4
V
1
Storage temperature
TSTG
–55 to +100
°C
1,2
Notes:
1.
Stresses greater than those listed in this table may cause permanent damage to the device. This is a stress rating
only and functional operation of the device at these or any other conditions above those indicated in the
operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect reliability.
2.
Storage temperature is the case surface temperature on the center/top side of the device. For the measurement
conditions, refer to JESD51-2 standard.
11
Range
Temperature Range
Symbol
(Units : ℃)
Parameter
Min
Max
Grade
Notes
Toper normal
Normal Operating Temperature
NT
1,2,3,4
Toper extended
Extended Operating Temperature
XT
1,2,3,4,5
Notes:
1.
All operating temperature symbols, ranges, acronyms are referred from JESD402-1.
2.
Operating Temperature is the case surface temperature on the center/top side of the DRAM. For the
measurement conditions, please refer to JESD51-2 standard.
3.
All DDR5 SDRDAMs are required to operate in NT and XT temperature ranges.
4.
If TC exceeds 85°C, the DRAM must be refreshed externally at 2X refresh, which is a 1.95μs interval refresh rate.
5.
Operating Temperature for 3DS needs to be derated by the number of DRAM dies as: [TOPER – (2.5°C ×
log2N)], where N is the number of the stacked dies.
12
Voltage Rating (Volts)
Maximum
Power
Symbol
Parameter
Expected Current
Minimum
Typical
State
Maximum
(Amps)
VIN_BULK
Host Supply Voltage
4.25
5.0
5.5
2.A
Operational
SWA,SWB
PMIC Output Supply Voltage
1.1
6
Operational
SWA+SWB
1.1
12
Operational
SWC
1.8
2
Operational
1.8V LDO
1.8
0.025(maximum)
Operational
1.0V LDO
1.0
0.020(maximum)
Operational
NOTE :
1.
Input supplies referenced in this table are VIN_BULK and VIN.
2.
During first power-on, the input voltage supply must reach a minimum of 4.25V for the PMIC to detect a valid
input supply.
3.
The ramp up rate is between 300mV and 4.0V.
4.
The ramp down rate is between 4.0V and 300mV.
5.
The area under the curve and above VIN_Bulk = TBD. The VIN_Bulk_AC spec must also be satisfied.
6.
The minimum input current requirement is equal to the maximum output current on VOUT_1.8V and VOUT_1.0V
LDO, plus the current required by the PMIC for its own use. The maximum input current is equal to the all
VIN_Bulk input on the PMIC.
7.
VIN_Bulk = 5.0V measured at room temperature. All circuitry, including output regulators and LDOs are off. The
VR_EN signal is static LOW or HIGH. The GSI_n signal is pulled HIGH. I2C or 13C basic interface access is not
allowed, and the bus is pulled HIGH. The PID signal is pulled either HIGH or LOW
8.
VIN_Bulk = 5.0V measured at room temperature. All output regulators and LDOs are on the 0A output load. The
allowed, and the bus is pulled HIGH. The PID signal is pulled either HIGH or LOW.
13
Mechanical Drawing
Unit: mm
(All dimensions are in millimeters with ±0.15mm tolerance unless specified otherwise.)
14
Revision History
Revision
Date
Description
1.0
4/12/2022
Initial release
15
Remark
Global Presence
Taiwan (Headquarters)
New Taipei City 236, Taiwan R.O.C.
amtsales@apacer.com
U.S.A.
Apacer Memory America, Inc.
46732 Lakeview Blvd., Fremont, CA 94538
Tel: 1-408-518-8699
Fax: 1-510-249-9568
sa@apacerus.com
Japan
Apacer Technology Corp.
5F, Matsura Bldg., Shiba, Minato-Ku
Tokyo, 105-0014, Japan
Tel: 81-3-5419-2668
Fax: 81-3-5419-0018
jpservices@apacer.com
Europe
Apacer Technology B.V.
Science Park Eindhoven 5051 5692 EB Son,
The Netherlands
Tel: 31-40-267-0000
Fax: 31-40-290-0686
sales@apacer.nl
China
Apacer Electronic (Shanghai) Co., Ltd.
Room D, 22/FL, No.2, Lane 600, JieyunPlaza,
Tianshan RD , Shanghai , 200051, China
Tel: 86-21-6228-9939
Fax:86-21-6228-9936
sales@apacer.com.cn
India
Apacer Technologies Pvt Ltd.
1874, South End C Cross,9th Block Jayanagar,
Bangalore-560069,INDIA.
Tel: 91-80-4152-9061/62
Fax: 91-80-4170-0215
sales_india@apacer.com
16
