D12.31492S.001
D12.31492S.001
    APACERMEMORYAMERICA(宇瞻科技)
    UDIMM288
    存储器 - 模块 DDR5 SDRAM 8GB 288-UDIMM
D12.31492S.001 数据手册
RoHS Compliant 8GB DDR5 SDRAM UDIMM Halogen free Product Specifications April 20, 2022 Version 1.0 Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Table of Contents General Description ....................................................................................................... 2 Ordering Information ..................................................................................................... 2 Key Parameters .............................................................................................................. 2 Features: ......................................................................................................................... 3 Pin Assignments ............................................................................................................. 4 Pin Descriptions ............................................................................................................. 6 INPUT/OUTPUT FUNCTIONAL DESCRIPTION...................................................... 7 Functional Block Diagram ........................................................................................... 10 Absolute Maximum Ratings ........................................................................................ 11 DRAM Component Operating Temperature Range..................................................... 12 AC & DC OPERATING CONDITION ....................................................................... 13 DIMM Voltage Requirements ...................................................................................... 13 Mechanical Drawing .................................................................................................... 14 ©Apacer Technology Inc. 1 General Description Apacer D12.31492S.001 is a 8GB DDR5 SDRAM (Synchronous DRAM) DIMM. This memory module consists of 4 pieces 1G x 16 bits DDR5 synchronous DRAMs in FBGA packages and 8K Bits EEPROM. The module is a 288-pins dual in-line memory module and is intended for mounting into a connector socket. The following provides general specifications of this module. Ordering Information Part Number Density Speed Organization DRAM Composition Rank D12.31492S.001 8GB 4800 Mbps 1Gx64 1Gx16 *4 1 Key Parameters DDR5-4800 Speed -CL40 Unit tCK (min) 0.416 ns CAS latency 40 nCK tRCD (min) 16 ns tRP (min) 16 ns tRAS (min) 32 ns tRC (min) 48 ns CL-tRCD-tRP 40-39-39 nCK ©Apacer Technology Inc. 2 Features: ♦ JEDEC standard compliant ♦ On-DIMM thermal sensor : Yes ♦ PCB: height 31.25 mm, lead pitch 0.85 mm (pin), ♦ VDD = VDDQ= 1.1V (1.067V to 1.166V) ♦ VPP = 1.8V (1.746V to 1.908V)、VDDSPD = 1.8V ♦ 32 internal banks (x4, x8): 8 groups of 4 banks each ♦ 16 internal banks (x16): 4 groups of 4 banks each ♦ CAS Latency (CL): 22,26,28,30,32,36,40,42 ♦ CAS Write Latency (CWL): RL-2 ♦ Operating temperature Tcase–(0℃~85℃) ♦ Average Refresh period 3.9us at lower than Tcase 85°C, 1.95us at 85°C < Tcase < 95 °C. ♦ All bank and same bank refresh ♦ Bi-Directional Differential Data Strobe ♦ 16-bit prefetch architecture ♦ On-die ECC ♦ ECC transparency and error scrub ♦ sPPR and hPPR capability ♦ Halogen free、Lead-free (RoHS compliant) ©Apacer Technology Inc. 3 Pin Assignments Pin No. Front Side Pin No. Back Side Pin No. Front Side Pin No. Back Side 1 VIN_BULK 145 VIN_BULK 74 VSS 218 VSS 2 RFU 146 VIN_BULK 75 RFU 219 RFU 3 RFU 147 PWR_- GOOD 76 RFU 220 RFU 4 HSCL 148 HSA 77 VSS 221 VSS 5 HSDA 149 RFU 78 CK0_B_t 222 CK1_B_t 6 VSS 150 VSS 79 CK0_B_c 223 CK1_B_c 7 RFU 151 PWR_EN 80 VSS 224 VSS 8 VSS 152 RFU 81 RFU 225 RFU 9 DQ0_A 153 VSS 82 CA12_B 226 RFU 10 VSS 154 DQ2_A 83 VSS 227 VSS 11 DQ1_A 155 VSS 84 CA10_B 228 CA11_B 12 VSS 156 DQ3_A 85 CA8_B 229 CA9_B 13 DQS0_A_c 157 VSS 86 VSS 230 VSS 14 DQS0_A_t 158 DM0_A_n 87 CA6_B 231 CA7_B 15 VSS 159 VSS 88 CA4_B 232 CA5_B 16 DQ4_A 160 DQ6_A 89 VSS 233 VSS 17 VSS 161 VSS 90 CA2_B 234 CA3_B 18 DQ5_A 162 DQ7_A 91 CA0_B 235 CA1_B 19 VSS 163 VSS 92 VSS 236 VSS 20 DQ8_A 164 DQ10_A 93 CS0_B_n 237 CS1_B_n 21 VSS 165 VSS 94 VSS 238 VSS 22 DQ9_A 166 DQ11_A 95 RESET_n 239 DQS4_B_c 23 VSS 167 VSS 96 VSS 240 DQS4_B_t 24 DM1_A_n 168 DQS1_A_c 97 CB0_B 241 VSS 25 VSS 169 DQS1_A_t 98 VSS 242 CB2_B 26 DQ12_A 170 VSS 99 CB1_B 243 VSS 27 VSS 171 DQ14_A 100 VSS 244 CB3_B 28 DQ13_A 172 VSS 101 DQ0_B 245 VSS 29 VSS 173 DQ15_A 102 VSS 246 DQ2_B 30 DQ16_A 174 VSS 103 DQ1_B 247 VSS 31 VSS 175 DQ18_A 104 VSS 248 DQ3_B 32 DQ17_A 176 VSS 105 DQS0_B_c 249 VSS 33 VSS 177 DQ19_A 106 DQS0_B_t 250 DM0_B_n 34 DQS2_A_c 178 VSS 107 VSS 251 VSS 35 DQS2_A_t 179 DM2_A_n 108 DQ4_B 252 DQ6_B 36 VSS 180 VSS 109 VSS 253 VSS 37 DQ20_A 181 DQ22_A 110 DQ5_B 254 DQ7_B 38 VSS 182 VSS 111 VSS 255 VSS 39 DQ21_A 183 DQ23_A 112 DQ8_B 256 DQ10_B ©Apacer Technology Inc. 4 Pin No. Front Side Pin No. Back Side Pin No. Front Side Pin No. Back Side 40 VSS 184 VSS 113 VSS 257 VSS 41 DQ24_A 185 DQ26_A 114 DQ9_B 258 DQ11_B 42 VSS 186 VSS 115 VSS 259 VSS 43 DQ25_A 187 DQ27_A 116 DM1_B_n 260 DQS1_B_c 44 VSS 188 VSS 117 VSS 261 DQS1_B_t 45 DM3_A_n 189 DQS3_A_c 118 DQ12_B 262 VSS 46 VSS 190 DQS3_A_t 119 VSS 263 DQ14_B 47 DQ28_A 191 VSS 120 DQ13_B 264 VSS 48 VSS 192 DQ30_A 121 VSS 265 DQ15_B 49 DQ29_A 193 VSS 122 DQ16_B 266 VSS 50 VSS 194 DQ31_A 123 VSS 267 DQ18_B 51 CB0_A 195 VSS 124 DQ17_B 268 VSS 52 VSS 196 CB2_A 125 VSS 269 DQ19_B 53 CB1_A 197 VSS 126 DQS2_B_c 270 VSS 54 VSS 198 CB3_A 127 DQS2_B_t 271 DM2_B_n 55 DQS4_A_c 199 VSS 128 VSS 272 VSS 56 DQS4_A_t 200 ALERT_n 129 DQ20_B 273 DQ22_B 57 VSS 201 VSS 130 VSS 274 VSS 58 CS0_A_n 202 CS1_A_n 131 DQ21_B 275 DQ23_B 59 VSS 203 VSS 132 VSS 276 VSS 60 CA0_A 204 CA1_A 133 DQ24_B 277 DQ26_B 61 CA2_A 205 CA3_A 134 VSS 278 VSS 62 VSS 206 VSS 135 DQ25_B 279 DQ27_B 63 CA4_A 207 CA5_A 136 VSS 280 VSS 64 CA6_A 208 CA7_A 137 DM3_B_n 281 DQS3_B_c 65 VSS 209 VSS 138 VSS 282 DQS3_B_t 66 CA8_A 210 CA9_A 139 DQ28_B 283 VSS 67 CA10_A 211 CA11_A 140 VSS 284 DQ30_B 68 VSS 212 VSS 141 DQ29_B 285 VSS 69 CA12_A 213 RFU 142 VSS 286 DQ31_B 70 RFU 214 RFU 143 RFU 287 VSS 71 VSS 215 VSS 144 RFU 288 RFU 72 CK0_A_t 216 CK1_A_t 73 CK0_A_c 217 CK1_A_c ©Apacer Technology Inc. 5 Pin Descriptions Pin Name CA0_A – CA12_A, Descripti SDRAM Command/Address bus CA0_B – CA12_B CS0_A_n – CS1_A_n, SDRAM Chip Select CS0_B_n – CS1_B_n DQ0_A – DQ31_A, DIMM memory data bus DQ0 B – DQ31 B CB0_A – CB3_A, DIMM ECC check bits (Only applicable on ECC SODIMM or CB0 B – CB3 B ECC UDIMM) DQS0_A_t – DQS4_A_t, DQS0_B_t – DQS4_B_t DQS0_A_c – DQS4_A_c, SDRAM data strobes (positive line of differential pair) SDRAM data strobes (negative line of differential pair) DQS0_B_c – DQS4_B_c DM0_A_n – DM3_A_n, DM0_B_n – DM3_B_n CK0_A_t, CK1_A_t, CK0_B_t, CK1_B_t CK0_A_c, CK1_A_c, CK0_B_c, CK1_B_c SDRAM data masks SDRAM clocks (positive line of differential pair) SDRAM clocks (negative line of differential pair) HSCL Side Band bus clock HSDA Side Band bus data HSA Side Band bus address ALERT_n SDRAM ALERT_n RESET_n Set DRAMs to a Known State VIN_BULK 5 V power input supply to the PMIC for analog circuits VSS Power supply return (ground) PWR_GOOD Power good indicator PWR_EN PMIC Enable RFU Reserved for future use *Notes: DDR5 UDIMM has 2 channels (channel-A and channel-B) of signal bus. The signals with suffix: _A (e.g. DQ0_A) are for channel-A, and the signals with suffix: _B (e.g. DQ0_B) are for channel-B ©Apacer Technology Inc. 6 INPUT/OUTPUT FUNCTIONAL DESCRIPTION Symbol Type I/O Levels Description CK[1:0]_A_t, CK[1:0]_B_t, Clock: CK_t and CK_c are differential clock inputs. All Input VDD CK[1:0]_A_c, address and con- trol input signals are sampled on the crossing of the positive edge of CK_t and negative edge of CK_c. CK[1:0]_B_c Command/Address Inputs: CA signals provide the command and address inputs according to the CA[12:0]_A Input VDD CA[12:0]_B Command Truth Table. Note: Since some commands are multi-cycle, the pins may not be interchanged between devices on the same bus. Chip Select: All commands are masked when CS_n is CS[1:0]_A_n Input VDD CS[1:0]_B_n registered HIGH. CS_n pro- vides for external rank selection on systems with multiple ranks. Alert: If there is an error in CRC, then ALERT_n drives LOW for the period time interval and returns HIGH. ALERT_n Output VDD During connectivity test mode, this pin functions as an input. Usage of this signal is system-dependent. In the case where this pin is not connected, ALERT_n must be bonded to VDDQ on the system board. Active Low Asynchronous Reset: Reset is active when CMOS RESET_n Input RESET_n is LOW, and inactive when RESET_n is HIGH. VDD RESET_n must be HIGH during normal operation. RESET_n is a CMOS rail-to-rail signal with DC HIGH and LOW at 80% and 20% of VDDQ. ©Apacer Technology Inc. 7 Symbol Type I/O Levels Description Power Good Indicator: Open drain output. The PMIC ensures this pin HIGH when VIN_Bulk input supply, as well as all enabled output buck regulators and all LDO regulators tolerance threshold is maintained as configured in the appropri- ate register. The PMIC Input / PWR_GOOD Output drives this pin LOW when VIN_Bulk input goes below VDD the threshold or when any of the enabled output buck regulator exceeds the thresh- olds configured in the appropriate register or when any LDO output regulator exceeds the threshold configured in the appropriate register. As an input, the PMIC disables its output regulator when this pin is LOW. The LDO outputs remain on. Host Sideband Bus Clock: Bus clock used to strobe HSCL data into HUB device. When open drain, a pull-up Input resistor is required on the system motherboard. Host Sideband Bus Data:I2C/I3C-Basic data. When Input / open drain, a pull-up resis- tor is required on the Output system motherboard. HSDA Host Sideband Bus Device ID: Address input to a hub or other client device to distinguish between identical devices in the I3C basic address range. Tied to GND, HSA Input HSA has different resistor values on the motherboard to identify DIMM slot address. Refer to the SPD Hub spec for more information. Data Input/ Output: Bi-directional data bus. DQ[31:0]_A Input / DQ[31:0]_B Output CB[3:0]_A Input / VDD added at the end of Data Burst. DIMM ECC check bits. VDD CB[3:0]_B Output ©Apacer Technology Inc. If CRC is enabled via Mode register then CRC code is (Only applicable on ECC SODIMM or ECC UDIMM) 8 Symbol Type I/O Levels Description Data Strobe: Output with read data, input with write DQS[4:0]_A_t data. Edge-aligned with read data, centered in write DQS[4:0]_B_t data. The data strobe DQS_t is paired with differenInput / VDD Output tial signals DQS_c, respectively, to provide differential DQS[4:0]_A_c pair signaling to the system during reads and writes. DQS[4:0]_B_c DDR5 SDRAM only supports differential data strobe. It does not support single-ended strobe. Input Data Mask: DM_n is an input mask signal for write data. Input data is masked when DM_n is sampled LOW coincident with that input data during a write access. DM_n is sampled on both edges of DQS. DM[3:0]_A_n Input DM[3:0]_B_n VDD DM function is shared with TDQS on x8 devices. The function of DM_n is enabled by MR5:OP[5] = 1. Refer to Micron DDR5 component data sheet specification for further detail. VIN_BULK Supply External Power Supply: 5V, 4.25V (min), 5.5V (max) PMIC Enable: When this pin is HIGH, the PMIC turns on the regulator. When this pin is LOW, the PMIC turns PWR_EN Input off the regulator. This signal is connected to the PMIC's VR_EN pin. VSS Supply Ground Reserved for future use. No on DIMM electrical RFU connection is present. No connect: No internal electrical connection is NC present. No function: May have internal connection present, NF ©Apacer Technology Inc. but has no 9 function. Functional Block Diagram ©Apacer Technology Inc. 10 Absolute Maximum Ratings Parameter Symbol Rating Units Notes Voltage on VDD pin relative to Vss VDD - 0.3 ~ 1.4 V 1 Voltage on VDDQ pin relative to Vss VDDQ - 0.3 ~ 1.4 V 1 Voltage on VPP pin relative to Vss VPP - 0.3 ~ 2.1 V Voltage on any pin relative to Vss VIN, VOUT - 0.3 ~ 1.4 V 1 Storage temperature TSTG –55 to +100 °C 1,2 Notes: 1. Stresses greater than those listed in this table may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. 2. Storage temperature is the case surface temperature on the center/top side of the device. For the measurement conditions, refer to JESD51-2 standard. ©Apacer Technology Inc. 11 DRAM Component Operating Temperature Range Temperature Range Symbol (Units : ℃) Parameter Min Max Grade Notes Toper normal Normal Operating Temperature 0 85 NT 1,2,3,4 Toper extended Extended Operating Temperature 0 95 XT 1,2,3,4,5 Notes: 1. All operating temperature symbols, ranges, acronyms are referred from JESD402-1. 2. Operating Temperature is the case surface temperature on the center/top side of the DRAM. For the measurement conditions, please refer to JESD51-2 standard. 3. All DDR5 SDRDAMs are required to operate in NT and XT temperature ranges. 4. If TC exceeds 85°C, the DRAM must be refreshed externally at 2X refresh, which is a 1.95μs interval refresh rate. 5. Operating Temperature for 3DS needs to be derated by the number of DRAM dies as: [TOPER – (2.5°C × log2N)], where N is the number of the stacked dies. ©Apacer Technology Inc. 12 AC & DC OPERATING CONDITION DIMM Voltage Requirements Voltage Rating (Volts) Maximum Power Symbol Parameter Expected Current Minimum Typical State Maximum (Amps) VIN_BULK Host Supply Voltage 4.25 5.0 5.5 2.A Operational SWA,SWB PMIC Output Supply Voltage - 1.1 - 6 Operational SWA+SWB PMIC Output Supply Voltage - 1.1 - 12 Operational SWC PMIC Output Supply Voltage - 1.8 - 2 Operational 1.8V LDO PMIC Output Supply Voltage - 1.8 - 0.025(maximum) Operational 1.0V LDO PMIC Output Supply Voltage - 1.0 - 0.020(maximum) Operational NOTE : 1. Input supplies referenced in this table are VIN_BULK and VIN. 2. During first power-on, the input voltage supply must reach a minimum of 4.25V for the PMIC to detect a valid input supply. 3. The ramp up rate is between 300mV and 4.0V. 4. The ramp down rate is between 4.0V and 300mV. 5. The area under the curve and above VIN_Bulk = TBD. The VIN_Bulk_AC spec must also be satisfied. 6. The minimum input current requirement is equal to the maximum output current on VOUT_1.8V and VOUT_1.0V LDO, plus the current required by the PMIC for its own use. The maximum input current is equal to the all VIN_Bulk input on the PMIC. 7. VIN_Bulk = 5.0V measured at room temperature. All circuitry, including output regulators and LDOs are off. The VR_EN signal is static LOW or HIGH. The GSI_n signal is pulled HIGH. I2C or 13C basic interface access is not allowed, and the bus is pulled HIGH. The PID signal is pulled either HIGH or LOW 8. VIN_Bulk = 5.0V measured at room temperature. All output regulators and LDOs are on the 0A output load. The VR_EN signal is static LOW or HIGH. The GSI_n signal is pulled HIGH. I2C or 13C basic interface access is not allowed, and the bus is pulled HIGH. The PID signal is pulled either HIGH or LOW. ©Apacer Technology Inc. 13 Mechanical Drawing Unit: mm (All dimensions are in millimeters with ±0.15mm tolerance unless specified otherwise.) ©Apacer Technology Inc. 14 Revision History Revision Date Description 1.0 4/12/2022 Initial release ©Apacer Technology Inc. 15 Remark Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd. Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD , Shanghai , 200051, China Tel: 86-21-6228-9939 Fax:86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd. 1874, South End C Cross,9th Block Jayanagar, Bangalore-560069,INDIA. Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com ©Apacer Technology Inc. 16
D12.31492S.001 价格&库存
很抱歉,暂时无法提供与“D12.31492S.001”相匹配的价格&库存,您可以联系我们找货
