AA2.255HGA.002EM
AA2.255HGA.002EM
    APACERMEMORYAMERICA(宇瞻科技)
    存储卡 CFast 120GB TLC
AA2.255HGA.002EM 数据手册
RoHS Compliant CFast 2.0 SV250-CFast 2.0 BiCS5 Product Specifications July 28, 2022 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Specifications Overview:   Compliance with SATA Revision 3.2 – SATA 6 Gb/s interface – Backward compatible with SATA 1.5 and 3 Gb/s interfaces – ATA-8 command set   Temperature Range – Operating: Standard: 0°C to 70°C Wide: -40°C to 85°C – Capacity –   120, 240, 480, 960 GB Storage: -55°C to 100°C Power Consumption1 – Supply voltage: 3.3V Performance1 – Active mode: 380 mA – Burst read/write: 600 MB/sec – Idle mode: 60 mA – Sequential read: Up to 560 MB/sec – Sequential write: Up to 470 MB/sec – CFast – Random read (4K): Up to 50,000 IOPS – Dimensions: 42.80 x 36.45 x 3.60, unit: mm – Random write (4K): Up to 68,000 IOPS – Net weight: 9.35g ± 5% Flash Management   Form Factor Connector Type – Low-Density Parity-Check (LDPC) Code – Global Wear Leveling – Flash bad-block management – Flash Translation Layer: Page Mapping – DataDefenderTM – S.M.A.R.T. – Device Sleep – ATA Secure Erase – Thermal Sensor – TRIM – End-to-End Data Protection – Hyper Cache Technology – Over-provisioning – DataRAIDTM2 – SMART Read RefreshTM NAND Flash Type: 3D TLC (BiCS5)  MTBF: >3,000,000 hours  Endurance (in drive writes per day: DWPD) 120 GB: 2.03 DWPD – 240 GB: 2.28 DWPD – 480 GB: 2.21 DWPD – 960 GB: 2.34 DWPD    – – 7 + 17 pin female connector Security – AES 256-bit hardware encryption – Trusted Computing Group (TCG) Opal 2.0 (optional) Reliability  Write Protect Switch (optional)  RoHS Compliant Notes: 1. Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. 2. Supported on standard model and TCG Opal-supported model of 240-960GB capacities. 1 © 2022 Apacer Technology Inc. Table of Contents 1. General Description ..........................................................................4 2. Functional Block ...............................................................................4 3. Pin Assignments ................................................................................5 4. Product Specifications ......................................................................7 4.1 Capacity ......................................................................................................................................... 7 4.2 Performance .................................................................................................................................. 7 4.3 Environmental Specifications ........................................................................................................ 8 4.4 Mean Time Between Failures (MTBF) .......................................................................................... 8 4.5 Certification and Compliance......................................................................................................... 8 4.6 Endurance ..................................................................................................................................... 9 5. Flash Management ..........................................................................10 5.1 Error Correction/Detection ........................................................................................................... 10 5.2 Bad Block Management .............................................................................................................. 10 5.3 Global Wear Leveling .................................................................................................................. 10 5.4 Flash Translation Layer – Page Mapping.................................................................................... 10 5.5 TRIM ............................................................................................................................................ 10 5.6 DataDefenderTM ........................................................................................................................... 11 5.7 ATA Secure Erase ....................................................................................................................... 11 5.8 Hyper Cache Technology ............................................................................................................ 11 5.9 Over-provisioning ........................................................................................................................ 11 5.10 DataRAIDTM ............................................................................................................................... 11 5.11 SMART Read RefreshTM ........................................................................................................... 11 5.12 Device Sleep (DevSleep or DEVSLP) Mode ............................................................................. 12 5.13 SATA Power Management ........................................................................................................ 12 6. Security and Reliability Features ...................................................13 6.1 Advanced Encryption Standard ................................................................................................... 13 6.2 TCG Opal (optional) .................................................................................................................... 13 6.3 Thermal Sensor ........................................................................................................................... 13 6.4 End-to-End Data Protection......................................................................................................... 13 7. Software Interface ..........................................................................14 7.1 Command Set .............................................................................................................................. 14 2 © 2022 Apacer Technology Inc. 7.2 S.M.A.R.T. ................................................................................................................................... 15 8. Electrical Specifications.................................................................17 8.1 Operating Voltage ........................................................................................................................ 17 8.2 Power Consumption .................................................................................................................... 17 9. Mechanical Specifications..............................................................18 9.1 Dimensions .................................................................................................................................. 18 9.2 Write Protect Switch (optional) .................................................................................................... 19 9.3 Net Weight ................................................................................................................................... 19 10. Product Ordering Information .......................................................20 10.1 Product Code Designations ....................................................................................................... 20 10.2 Valid Combinations .................................................................................................................... 21 3 © 2022 Apacer Technology Inc. 1. General Description Apacer SV250-CFast 2.0, utilizing 3D NAND for higher capacity up to 960GB and providing more power efficiency than 2D NAND, is the latest enhancement of conventional CFast form factor that delivers various technological advantages. This new flash memory card comes with SATA 6 Gb/s interface for exceptional performance with data transfer rates up to 560MB/s in sequential access and 68,000 IOPS in 4KB random access, and consists of SATA-based 7-pin signal segment and 17-pin for power and control purposes. Designed without DRAM on the internal controlling unit, SV250-CFast 2.0 ensures data integrity by preventing data loss during a sudden power outage. SV250-CFast 2.0 guarantees reliability of applications in harsh environments by implementing intelligent Flash Management algorithms and LDPC (Low Density Parity Check) ECC engine to extend SSD endurance and increase data reliability. Furthermore, SV250-CFast 2.0 is equipped with a built-in thermal sensor to monitor the temperature of the SSD via S.M.A.R.T commands to prevent overheating. Operating under 6 Gb/s interface, SV250-CFast 2.0 is provided with Apacer latest S.M.A.R.T. that is primarily oriented for the latest SATA interface SSD, for drive lifetime monitoring and analysis. For highly-intensive applications, End-to-End Data Protection ensures that data integrity can be assured at multiple points in the path to enable reliable delivery of data transfers. Security-wise, Advanced Encryption Standard (AES) and Trusted Computing Group (TCG) Opal (optional) ensure data security and provide users with peace of mind knowing their data is safeguarded against unauthorized use at all times. SV250-CFast 2.0 also adopts the latest page mapping file translation layer and comes with various implementations including power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, Hyper Cache technology, overprovisioning, DataDefenderTM, DataRAIDTM and SMART Read RefreshTM. 2. Functional Block Apacer SV250-CFast 2.0 includes a single-chip controller and flash media. The controller integrates the flash management unit to support multi-channel, multi-bank flash arrays. Figure 2-1 shows the functional block diagram. Controller Flash data bus & ECC engine Host Interface SATAI/O & PHY SATA 6 Gb/s Interface Flash Flash Figure 2-1 Functional Block Diagram 4 © 2022 Apacer Technology Inc. 3. Pin Assignments Table 3-1 describes SV250-CFast 2.0 signal segment, and Table 3-2, its power segment. Figure 3-1 Pin Assignment Table 3-1 Signal Segment Pin Definition Description S1 GND Ground S2 A+ S3 A- S4 GND S5 B- S6 B+ S7 GND SATA Differential Signal Pair A Ground SATA Differential Signal Pair B Ground 5 © 2022 Apacer Technology Inc. Table 3-2 Power Segment Pin Definition Type Description PC1 CDI Input Card Detect In PC2 PGND Device GND Device GND PC3 DEVSLP DEVSLP card input DEVSLP enable PC4 No connect Not available Reserved PC5 No connect Not available Reserved PC6 No connect Not available Reserved PC7 PGND Device GND Device GND PC8 LED1 LED Output Power indicator PC9 LED2 LED Output Access indicator PC10 No connect Not available Reserved for Apacer use only1 PC11 No connect Not available Reserved for Apacer use only1 PC12 IFDet GND Reserved for Apacer use only1 PC13 PWR 3.3V Device power (3.3V) PC14 PWR w PGND 3.3V Device power (3.3V) PC15 Device GND Device GND PC16 PGND Device GND Device GND PC17 CDO Output Card Detect Out Note: 1. Reserved by Apacer, please do not connect to a host. Figure 3-2 SATA Cable / Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable while the connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 6 © 2022 Apacer Technology Inc. 4. Product Specifications 4.1 Capacity Capacity specifications of the SV250-CFast 2.0 are available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1 Capacity Specifications Capacity Total bytes Cylinders Heads Sectors Total LBA 120 GB 120,034,123,776 16,383 16 63 234,441,648 240 GB 240,057,409,536 16,383 16 63 468,862,128 480 GB 480,103,981,056 16,383 16 63 937,703,088 960 GB 960,197,124,096 16,383 16 63 1,875,385,008 Notes:  Display of total bytes varies from operating systems.  1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes.  LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of SV250-CFast 2.0 product family is available as shown in Table 4-2. Table 4-2 Performance Specifications Capacity 120 GB 240 GB 480 GB 960 GB Sequential Read (MB/s) 440 560 560 560 Sequential Write (MB/s) 190 470 470 470 Random Read IOPS (4K) 22,000 35,000 50,000 50,000 Random Write IOPS (4K) 43,000 68,000 60,000 60,000 Performance Notes:  Results may differ from various flash configurations or host system setting.  Sequential read/write is based on CrystalDiskMark 8.0.4 with file size 1,000MB.  Random read/write is measured using IOMeter with Queue Depth 32. 7 © 2022 Apacer Technology Inc. 4.3 Environmental Specifications Environmental specifications of SV250-CFast 2.0 are shown in Table 4-3. Table 4-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Wide) Non-operating temp. -55°C to 100°C Operating vibration 7.69 GRMS, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating vibration 4.02 GRMS, 15~2000 Hz/random (compliant with MIL-STD-810G) Operating shock 50G, 11ms Non-operating shock 1500G, 0.5ms (compliant with MIL-STD-883K) Note: This Environmental Specification table indicates the conditions for testing the device. Real world usages may affect the results. 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SV250-CFast 2.0. Serving as statistical reference, the prediction result for SV250CFast is more than 3,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 3” method. 4.5 Certification and Compliance SV250-CFast 2.0 complies with the following standards:     CE FCC RoHS MIL-STD-810G 8 © 2022 Apacer Technology Inc. 4.6 Endurance The endurance of a storage device is predicted by Drive Writes Per Day based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 4-4 Endurance Specifications Capacity Drive Writes Per Day 120 GB 2.03 240 GB 2.28 480 GB 2.21 960 GB 2.34 Notes:  This estimation complies with JEDEC JESD-219, Enterprise endurance workload of random data with payload size distribution.  Flash vendor guaranteed 3D NAND TLC P/E cycle: 3K  WAF may vary from capacity, flash configurations and writing behavior on each platform.  1 Terabyte = 1,024 GB  DWPD (Drive Write Per Day) is calculated based on the number of times that user overwrites the entire capacity of an SSD per day of its lifetime during the warranty period. (3D NAND TLC warranty: 3 years) 9 © 2022 Apacer Technology Inc. 5. Flash Management 5.1 Error Correction/Detection SV250-CFast implements a hardware ECC scheme, based on the Low Density Parity Check (LDPC). LDPC is a class of linear block error correcting code which has apparent coding gain over BCH code because LDPC code includes both hard decoding and soft decoding algorithms. With the error rate decreasing, LDPC can extend SSD endurance and increase data reliability while reading raw data inside a flash chip. 5.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, page mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.3 Global Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Global wear leveling is an important mechanism that levels out the wearing of all blocks so that the wearing-down of all blocks can be almost evenly distributed. This will increase the lifespan of SSDs. 5.4 Flash Translation Layer – Page Mapping Page mapping is an advanced flash management technology whose essence lies in the ability to gather data, distribute the data into flash pages automatically, and then schedule the data to be evenly written. Page-level mapping uses one page as the unit of mapping. The most important characteristic is that each logical page can be mapped to any physical page on the flash memory device. This mapping algorithm allows different sizes of data to be written to a block as if the data is written to a data pool and it does not need to take extra operations to process a write command. Thus, page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 5.5 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 10 © 2022 Apacer Technology Inc. 5.6 DataDefenderTM Apacer’s DataDefender is an advanced technology of power failure management which combines both firmware and hardware mechanisms to ensure data integrity. When power disruption occurs, the low voltage detector will be triggered. When this happens, the SSD’s protection mechanism is activated and cuts off data transmission from the host. Once the power supply is resumed, the firmware protection mechanism will ensure the integrity of the firmware as well as the data already written into the NAND flash media. 5.7 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 5.8 Hyper Cache Technology Apacer proprietary Hyper Cache technology uses a portion of the available capacity as SLC (1bit-percell) NAND flash memory, called Hyper cache mode. When data is written to SSD, the firmware will direct the data to Hyper Cache mode, providing excellent performance to handle various scenarios in industrial use. 5.9 Over-provisioning Over-provisioning (OP) is a certain portion of the SSD capacity exclusively for increasing Garbage Collection (GC) efficiency, especially when the SSD is filled to full capacity or performs a heavy mixed-random workload. OP has the advantages of providing extended life expectancy, reliable data integrity, and high sustained write performance. 5.10 DataRAIDTM Apacer’s DataRAID algorithm applies an additional level of protection and error-checking. Using this algorithm, a certain amount of space is given over to aggregating and resaving the existing parity data used for error checking. So, in the event that data becomes corrupted, the parity data can be compared to the existing uncorrupted data and the content of the corrupted data can be rebuilt. 5.11 SMART Read RefreshTM Apacer’s SMART Read Refresh plays a proactive role in avoiding read disturb errors from occurring to ensure health status of all blocks of NAND flash. Developed for read-intensive applications in particular, SMART Read Refresh is employed to make sure that during read operations, when the read operation threshold is reached, the data is refreshed by re-writing it to a different block for subsequent use. 11 © 2022 Apacer Technology Inc. 5.12 Device Sleep (DevSleep or DEVSLP) Mode Device Sleep is a feature that allows SATA devices to enter a low power mode by designating a particular pin as DEVSLP signal with an aim to reducing power consumption. Figure 5-1 Device Sleep 5.13 SATA Power Management By complying with SATA 6 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, TX & RX operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: The behaviors of power management features would depend on host/device settings. 12 © 2022 Apacer Technology Inc. 6. Security and Reliability Features 6.1 Advanced Encryption Standard Advanced Encryption Standard (AES) is a specification for the encryption of electronic data. AES has been adopted by the U.S. government since 2001 to protect classified information and is now widely implemented in embedded computing applications. The AES algorithm used in software and hardware is symmetric so that encrypting/decrypting requires the same encryption key. Without the key, the encrypted data is inaccessible to ensure information security. Notably in flash memory applications, AES 256-bit hardware encryption is the mainstream to protect sensitive or confidential data. The hardware encryption provides better performance, reliability, and security than software encryption. It uses a dedicated processor, which is built inside the controller, to process the encryption and decryption. This enormously shortens the processing time and makes it efficient. 6.2 TCG Opal (optional) Developed by the Trusted Computing Group (TCG), an organization whose members work together to formulate industry standards, Opal is a set of security specifications used for applying hardwarebased encryption to storage devices. Hardware encryption has many advantages. First of all, it transfers the computational load of the encryption process to dedicated processors, reducing the stress on the host system's CPU. In addition, storage devices complying with Opal specifications are self-encryption devices. Opal specifications also feature boot authentication. When the drive is being accessed, the shadow MBR will request the drive password at boot. The drive will only unlock and decrypt if the correct password is supplied. The other feature is LBA-specific permissions. Users are assigned different permissions for LBA ranges created by the device administrator. Each LBA range is password-protected and can only be accessed by users with the correct key to perform permitted actions (read/write/erase). 6.3 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using a designated pin for transmission, storage device owners are able to read temperature data. 6.4 End-to-End Data Protection End-to-End Data Protection is a feature implemented in Apacer SSD products that extends error control to cover the entire path from the host computer to the drive and back, and ensure data integrity at multiple points in the path to enable reliable delivery of data transfers. Unlike ECC which does not exhibit the ability to determine the occurrence of errors throughout the process of data transmission, End-to-End Data Protection allows SSD controller to identify an error created anywhere in the path and report the error to the host computer before it is written to the drive. This errorchecking and error-reporting mechanism therefore guarantees the trustworthiness and reliability of the SSD. 13 © 2022 Apacer Technology Inc. 7. Software Interface 7.1 Command Set This section defines the software requirements and the format of the commands the host sends to SV250-CFast. Commands are issued to SV250-CFast by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 7-1 Command Set Code Command Code Command E5h CHECK POWER MODE F4h SECURITY ERASE UNIT 06h DATA SET MANAGEMENT F5h SECURITY FREEZE LOCK 92h DOWNLOAD MICROCODE F1h SECURITY SET PASSWORD 90h EXECUTE DEVICE DIAGNOSTIC F2h SECURITY UNLOCK E7h FLUSH CACHE 70h SEEK EAh FLUSH CACHE EXT EFh SET FEATURES ECh IDENTIFY DEVICE C6h SET MULTIPLE MODE E3h IDLE E6h SLEEP E1h IDLE IMMEDIATE B0h SMART 91h INITIALIZE DEVICE PARAMETERS E2h STANDBY E4h READ BUFFER E0h STANDBY IMMEDIATE C8h READ DMA E8h WRITE BUFFER 25h READ DMA EXT CAh WRITE DMA 60h READ FPDMA QUEUED 35h WRITE DMA EXT C4h READ MULTIPLE 3Dh WRITE DMA FUA EXT 29h READ MULTIPLE EXT 61h WRITE FPDMA QUEUED 2Fh READ LOG EXT 3Fh WRITE LOG EXT 47h READ LOG DMA EXT 57h WRITE LOG DMA EXT 20h READ SECTOR C5h WRITE MULTIPLE 24h READ SECTOR EXT 39h WRITE MULTIPLE EXT 40h READ VERIFY SECTORS CEh WRITE MULTIPLE FUA EXT 42h READ VERIFY SECTORS EXT 30h WRITE SECTOR 10h RECALIBRATE 34h WRITE SECTOR EXT F6h SECURITY DISABLE PASSWORD 45h WRITE UNCORRECTABLE EXT F3h SECURITY ERASE PREPARE Table 7-2 Trusted Computing Feature Set Code Command Code Command 5Ch TRUSTED RECEIVE 5Eh TRUSTED SEND 5Dh TRUSTED RECEIVE DMA 5Fh TRUSTED SEND DMA Note: This feature set is only applicable to products implemented with AES and Opal functions. 14 © 2022 Apacer Technology Inc. 7.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Table 7-3 SMART Subcommand Set Code SMART Subcommand D0h READ DATA D1h READ ATTRIBUTE THRESHOLDS D2h ENABLE/DISABLE ATTRIBUTE AUTOSAVE D4h EXECUTE OFF-LINE IMMEDIATE D5h SMART READ LOG D6h SMART WRITE LOG D8h ENABLE OPERATIONS D9h DISABLE OPERATIONS DAh RETURN STATUS Table 7-4 General SMART Attribute Structure Byte Description 0 ID (Hex) 1–2 Status Flag 3 Value 4 Worst 5*-11 Raw Data *Byte 5: LSB 15 © 2022 Apacer Technology Inc. Table 7-5 SMART Attribute ID List ID (Hex) Attribute Name 9 (0x09) Power-on Hours 12 (0x0C) Power Cycle Count 163 (0xA3) Maximum Erase Count 164 (0xA4) Average Erase Count 166 (0xA6) Total Later Bad Block Count 167 (0xA7) SSD Protect Mode (Vendor Specific) 168 (0xA8) SATA PHY Error Count 171 (0xAB) Program Fail Count 172 (0xAC) Erase Fail Count 175 (0xAF) Bad Cluster Table Count 192 (0xC0) Unexpected Power Loss Count 194 (0xC2) Temperature 231 (0xE7) Lifetime Left 241 (0xF1) Total Sectors of Write 16 © 2022 Apacer Technology Inc. 8. Electrical Specifications 8.1 Operating Voltage Table 8-1 lists the supply voltage for SV250-CFast 2.0. Table 8-1 Operating Range Parameter Power Supply Symbol Min Type Max Units Vcc 3.135 3.3 3.465 V 8.2 Power Consumption Table 8-2 lists the power consumption for SV250-CFast 2.0. Table 8-2 Power Consumption Capacity 120 GB 240 GB 480 GB 960 GB Active (mA) 300 370 370 380 Idle (mA) 60 60 60 60 Mode Notes:  All values are typical and may vary depending on flash configurations or host system settings.  Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 17 © 2022 Apacer Technology Inc. 9. Mechanical Specifications 9.1 Dimensions Figure 9-1 Physical Dimensions Unit: mm 18 © 2022 Apacer Technology Inc. 9.2 Write Protect Switch (optional) Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Once the system is reset and rebooted, the temporarily stored data will be lost and nowhere to be found in the system. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. Figure 9-2 Write Protect Switch 9.3 Net Weight Table 9-1 Net Weight Capacity Net Weight (g ± 5%) 120GB 9.28 240GB 9.33 480GB 9.32 960GB 9.35 19 © 2022 Apacer Technology Inc. 10. Product Ordering Information 10.1 Product Code Designations Apacer’s SV250-CFast SSD is available in different configurations and densities. See the chart below for a comprehensive list of options for the SV250-CFast series devices. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 A A 2 . X X 5 X X X . X X X E X Code Code 1-3 (Product Line & Form Factor) Code 5-6 (Model/Solution) Code 7-8 (Product Capacity) Code 9 (Flash Type & Product Temp) Code 10 (Product Spec) Code 12-14 (Version Number) Code 15-16 (Firmware Version) MDC+CFS 25: SV250 A1: SV250 with TCG Opal 5H: 120GB 5J: 240GB 5K: 480GB 5L: 960GB G: 3D TLC Standard temperature H: 3D TLC Wide temperature A: STD without Write Protect Switch B: With Write Protect Switch Random numbers generated by system EM: Thermal Sensor DEVSLP OP Standard Temp EF: Thermal Sensor DEVSLP OP Wide Temp EE: Thermal Sensor DEVSLP TCG Opal OP Standard Temp EB: Thermal Sensor DEVSLP TCG Opal OP Wide Temp 20 © 2022 Apacer Technology Inc. 10.2 Valid Combinations The following tables list the available models of the SV250-CFast series which are in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 10.2.1 Without Write Protect Switch Capacity Standard Temperature Wide Temperature 120GB AA2.255HGA.002EM AA2.255HHA.002EF 240GB AA2.255JGA.003EM AA2.255JHA.002EF 480GB AA2.255KGA.003EM AA2.255KHA.002EF 960GB AA2.255LGA.001EM AA2.255LHA.001EF 10.2.2 With Write Protect Switch (optional) Capacity Standard Temperature Wide Temperature 120GB AA2.255HGB.003EM AA2.255HHB.002EF 240GB AA2.255JGB.002EM AA2.255JHB.002EF 480GB AA2.255KGB.002EM AA2.255KHB.002EF 960GB AA2.255LGB.001EM AA2.255LHB.001EF 10.2.3 TCG Opal without Write Protect Switch (optional) Capacity Standard Temperature Wide Temperature 120GB AA2.A15HGA.002EE AA2.A15HHA.002EB 240GB AA2.A15JGA.002EE AA2.A15JHA.002EB 480GB AA2.A15KGA.002EE AA2.A15KHA.002EB 960GB AA2.A15LGA.001EE AA2.A15LHA.001EB 10.2.4 TCG Opal with Write Protect Switch (optional) Capacity Standard Temperature Wide Temperature 120GB AA2.A15HGB.002EE AA2.A15HHB.002EB 240GB AA2.A15JGB.002EE AA2.A15JHB.002EB 480GB AA2.A15KGB.002EE AA2.A15KHB.003EB 960GB AA2.A15LGB.001EE AA2.A15LHB.001EB 21 © 2022 Apacer Technology Inc. Revision History Revision Description Date 1.0 Initial release 11/29/2021 1.1 Updated endurance rating at Endurance on Specifications Overview page and Table 4-4 6/29/2022 - Added 120GB, 960GB, wide temperature and TCG Opal support - Updated Performance, Endurance and Power Consumption on Specifications Overview page and Table 4-2, 4-4 and 8-2 1.2 - Updated warranty period from 2 years to 3 years at the notes for 4.6 Endurance 7/28/2022 - Added 6.2 TCG Opal and Table 7-2 - Updated 10. Product Ordering Information by adding codes for 120GB and 960GB, wide temperature and firmware versions 22 © 2022 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 6F, Daiyontamachi Bldg., 2-17-12, Shibaura, Minato-Ku, Tokyo, 108-0023, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, 1874, South End C Cross, 9th Block Jayanagar, Bangalore-560069, India Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com 23 © 2022 Apacer Technology Inc.
AA2.255HGA.002EM
物料型号:Apacer SV250-CFast 2.0 器件简介:Apacer SV250-CFast 2.0是一款使用3D NAND技术的存储卡,提供高达960GB的容量,支持SATA 6 Gb/s接口,提供高性能数据传输。
引脚分配:7针信号段和17针电源段,包括地线、SATA差分信号对、电源和卡片检测等。
参数特性:支持SATA 6 Gb/s接口、多种容量选择、随机读写性能高、低功耗、宽温操作、高MTBF、支持AES 256位硬件加密等。
功能详解:包括先进的闪存管理算法、LDPC纠错、全局磨损均衡、坏块管理、TRIM命令支持、Hyper Cache技术、DataRAID算法等。
应用信息:适用于需要高可靠性和高性能数据传输的应用,如工业自动化、视频监控、网络附加存储等。
封装信息:CFast封装,尺寸42.80×36.45×3.60 mm,重量约9.35g。
以上信息摘自Apacer SV250-CFast 2.0的产品规格书,详细描述了产品的主要特点和规格。
AA2.255HGA.002EM 价格&库存
很抱歉,暂时无法提供与“AA2.255HGA.002EM”相匹配的价格&库存,您可以联系我们找货
AA2.255HGA.002EM
  • 1+3765.399171+489.38836
