AN2.112EGG.00118
AN2.112EGG.00118
    APACERMEMORYAMERICA(宇瞻科技)
    USB 闪存驱动器 16GB FLASH - NAND(TLC) USB 2.0,3.0
AN2.112EGG.00118 数据手册
RoHS Recast Compliant USB Flash Drive UV110-UFD1 Product Specifications December 27, 2021 Version 1.7 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Specifications Overview:   USB 3.1 Gen1 Super Speed compatible, and backward compatible with USB 2.0 & USB 1.1 interfaces – USB 3.1 Gen1 max. transfer rate: 5 Gb/s – Backward compatible with 480Mb/s for USB 2.0 & 12 Mb/s for USB 1.1   Temperature Range – Wide**: -40°C to 85°C –  Storage: -55°C to 100°C Supply Voltage – 16, 32, 64, 128, 256 GB Performance* Operating: Standard: 0°C to 70°C  Capacity –  5.0 V ± 5% Power Consumption* – Sequential read: Up to 260 MB/sec – Active mode: 195 mA – Sequential write: Up to 125 MB/sec – Idle mode: 80 mA – Random read (4K): Up to 2,500 IOPS – Random write (4K): Up to 700 IOPS  Supports Non-Removable Setting  Supports Toggle 2.0 mode/ONFI 3.0  OS Support Flash Management – Built-in hardware Low Density ParityCheck (LDPC) ECC – Windows: Win7/8/10 later – Global Wear Leveling – Mac: 10.2.8/10.8 or later – Flash bad-block management – Linux: 2.4.0/2.4.10 or later – Flash Translation Layer: Page Mapping – Power Failure Management – S.M.A.R.T. – Hyper Cache Technology  LED Indicators for Drive Behavior – SMART Read RefreshTM  RoHS Recast Compliant NAND Flash Type: 3D TLC (BiCS3)  MTBF: >3,000,000 hours  Endurance (in drive writes per day: DWPD) 16 GB: 4.07 DWPD – 32 GB: 4.11 DWPD – 64 GB: 4.11 DWPD – 128 GB: 4.11 DWPD – 256 GB: 4.11 DWPD Dimensions –  –  – 46.85 x 17.2 x 7.7, unit: mm Complies with 2011/65/EU Standard *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Not supported on 16GB 1 © 2021 Apacer Technology Inc. Table of Contents 1. General Descriptions ........................................................................3 2. Functional Block ...............................................................................3 3. Product Specifications ......................................................................4 3.1 Capacity ......................................................................................................................................... 4 3.2 Performance .................................................................................................................................. 4 3.3 Environmental Specifications ........................................................................................................ 5 3.4 Mean Time Between Failures (MTBF) .......................................................................................... 5 3.5 Certification and Compliance......................................................................................................... 5 3.6 Endurance ..................................................................................................................................... 6 3.7 LED Indicator Behavior .................................................................................................................. 6 4. Flash Management ............................................................................7 4.1 Performance-optimized USB Controller ........................................................................................ 7 4.2 Power Saving Implemented........................................................................................................... 7 4.3 Program RAM Architect ................................................................................................................. 7 4.4 Error Correction/Detection (ECC) .................................................................................................. 7 4.5 Global Wear Leveling .................................................................................................................... 7 4.6 S.M.A.R.T. ..................................................................................................................................... 7 4.7 Power Failure Management .......................................................................................................... 8 4.8 Bad Block Management ................................................................................................................ 8 4.9 Flash Translation Layer – Page Mapping...................................................................................... 8 4.10 Hyper Cache Technology ............................................................................................................ 8 4.11 SMART Read RefreshTM ............................................................................................................. 8 5. Electrical Specifications...................................................................9 5.1 Absolute Stress Rating .................................................................................................................. 9 5.2 Absolute Maximum Rating............................................................................................................. 9 5.3 Power Consumption ...................................................................................................................... 9 6. Physical Characteristics .................................................................10 7. Product Ordering Information .........................................................11 7.1 Product Code Designations ......................................................................................................... 11 7.2 Valid Combinations ...................................................................................................................... 12 2 © 2021 Apacer Technology Inc. 1. General Descriptions Apacer’s UV110-UFD1 utilizes 3D NAND for higher capacity up to 256GB and provides more power efficiency than 2D NAND, with the aim of replacing a conventional IDE hard disk drive. With exquisite size and robust metal housing, UV110-UFD1 prevents mechanical interference and enhances environment and ESD protection. UV110-UFD1 is a new generation USB flash drive compatible with the latest USB specification – USB 3.1 Gen1 Super Speed, with a maximum transfer rate of 5 Gb/s. The connector is backward compatible with USB 2.0 and USB 1.1 interfaces. With compliance with USB 3.1 specification, this USB drive can deliver up to 260 MB/s outstanding performance. Reliability wise, UV110-UFD1 is implemented with LDPC (Low Density Parity Check) ECC engine to extend SSD endurance and increase data reliability while reading raw data inside a flash chip. In addition, the drive comes with various implementations including powerful hardware ECC engine, wear leveling, flash block management, S.M.A.R.T., page mapping etc. This product is well suited for portable flash storage applications while operating at minimal power consumption. 2. Functional Block With embedded firmware, Apacer’s UV110-UFD1 contains a controller and flash media with a female connector. It interfaces with the host system allowing data to be written to and read from the flash media. Figure 2-1 Functional Block Diagram 3 © 2021 Apacer Technology Inc. 3. Product Specifications 3.1 Capacity Capacity specifications of UV110-UFD1 are available as shown in Table 3-1. Table 3-1 Capacity Specifications Capacity Total bytes* Total LBA 16 GB 15,557,361,664 30,385,472 32 GB 31,039,324,160 60,623,680 64 GB 62,018,519,040 121,129,920 128 GB 123,936,440,320 242,063,360 256 GB 248,074,076,160 484,519,680 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performance of UV110-UFD1 is listed below in Table 3-2. Table 3-2 Performance Specifications Capacity 16 GB 32 GB 64 GB 128 GB 256 GB Sequential Read* (MB/s) 245 250 255 260 255 Sequential Write* (MB/s) 38 44 90 125 125 Random Read IOPS** (4K) 2,400 2,500 2,400 2,400 2,400 Random Write IOPS** (4K) 400 400 600 700 600 Performance Note: Results may differ from various flash configurations or host system setting, and the above test results are based on the default file structure with FAT 32 file system. *Sequential performance is based on CrystalDiskMark 5.2.1 with file size 1,000MB. **Random performance measured using IOMeter with Queue Depth 32. 4 © 2021 Apacer Technology Inc. 3.3 Environmental Specifications Environmental specifications of UV110-UFD1 product are shown in Table 3-3. Table 3-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Wide) Non-operating temp. -55°C to 100°C Operating vibration 7.69 GRMS, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating vibration 4.02 GRMS, 15~2000 Hz/sine (compliant with MIL-STD-810G) Operating shock 50G, 11ms/half sine (compliant with MIL-STD-202G) Non-operating shock 1500G, 0.5ms/half sine (compliant with MIL-STD-883K) Note: This Environmental Specification table indicates the conditions for testing the device. Real world usages may affect the results. 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in Apacer’s USB flash drive. Serving as statistical reference, the prediction result for Apacer’s UV110-UFD1 is more than 3,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR332, Issue 3” method. 3.5 Certification and Compliance UV110-UFD1 complies with the following standards:     CE FCC RoHS Recast Compliant MIL-STD-810 5 © 2021 Apacer Technology Inc. 3.6 Endurance The endurance of a storage device is predicted by Drive Writes Per Day based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 3-4 Endurance Specifications Capacity Drive Writes Per Day 16 GB 4.07 32 GB 4.11 64 GB 4.11 128 GB 4.11 256 GB 4.11 Note:  This estimation values are based on sequential write behavior. (Apacer EDTestTool, test mode – sequential data pattern -100.00% of disk space with 128K)  Flash vendor guaranteed 3D NAND TLC P/E cycle: 3K  WAF may vary from capacity, flash configurations and writing behavior on each platform.  1 Terabyte = 1,024GB  DWPD (Drive Write s Per Day) is calculated based on the number of times that user overwrites the entire capacity of an SSD per day of its lifetime during the warranty period. 3.7 LED Indicator Behavior The behavior of the UV110-UFD1 LED indicators is described in Table 3-5. Table 3-5 LED Behavior Location LED Color Description As indicated by the red marker below Blue LED blinks when the drive is being accessed such as power on, read or write. The blink frequency is 50ms switch H to L and loop. 6 © 2021 Apacer Technology Inc. 4. Flash Management 4.1 Performance-optimized USB Controller The heart of UV110-UFD1 is the USB controller, which translates standard USB signals into the data and controls of the flash media. This proprietary USB controller is specifically designed to attain high data throughput from host to flash. 4.2 Power Saving Implemented The internal controller of the USB model is designed with power saving implementations, allowing the device to operate at low power consumption. 4.3 Program RAM Architect The internal Program RAM implementation allows the host to upgrade firmware codes anytime when needed. 4.4 Error Correction/Detection (ECC) UV110-UFD1 implements a hardware ECC scheme, based on the Low Density Parity Check (LDPC). LDPC is a class of linear block error correcting code which has apparent coding gain over BCH code because LDPC code includes both hard decoding and soft decoding algorithms. With the error rate decreasing, LDPC can extend SSD endurance and increase data reliability while reading raw data inside a flash chip. 4.5 Global Wear Leveling Flash memory can be erased a limited number of times, This number is called the erase cycle limit, or write endurance limit, The erase cycle limit applies to each individual erase block in the flash device. In a typical application, and especially if a file system is used, specific pages are constantly updated (e.g., the page that contains the FAT, registry, etc.). Without any special handling, these pages would wear out more rapidly than other pages, reducing the lifetime of the entire flash. To overcome this inherent deficiency, Apacer’s UV110-UFD1 uses Global Wear Leveling algorithm. This algorithm ensures that consecutive writes of a specific sector are not written physically to the same page in the flash. This spreads flash media usage evenly across all pages, thereby maximizing flash lifetime. The Global Wear Leveling mechanism provides write/erase cycles for reliable data storage over an extended period. 4.6 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. 7 © 2021 Apacer Technology Inc. 4.7 Power Failure Management Power Failure Management plays a crucial role when power supply becomes unstable. Power disruption may occur when users are storing data into the SSD, leading to instability in the drive. However, with Power Failure Management, a firmware protection mechanism will be activated to scan pages and blocks once power is resumed. Valid data will be transferred to new blocks for merging and the mapping table will be rebuilt. Therefore, data reliability can be reinforced, preventing damage to data stored in the NAND Flash. 4.8 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, page mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.9 Flash Translation Layer – Page Mapping Page mapping is an advanced flash management technology whose essence lies in the ability to gather data, distribute the data into flash pages automatically, and then schedule the data to be evenly written. Page-level mapping uses one page as the unit of mapping. The most important characteristic is that each logical page can be mapped to any physical page on the flash memory device. This mapping algorithm allows different sizes of data to be written to a block as if the data is written to a data pool and it does not need to take extra operations to process a write command. Thus, page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 4.10 Hyper Cache Technology Apacer proprietary Hyper Cache technology uses a portion of the available capacity as SLC (1bit-percell) NAND flash memory, called Hyper cache mode. When data is written to SSD, the firmware will direct the data to Hyper Cache mode, providing excellent performance to handle various scenarios in industrial use. 4.11 SMART Read RefreshTM Apacer’s SMART Read Refresh plays a proactive role in avoiding read disturb errors from occurring to ensure health status of all blocks of NAND flash. Developed for read-intensive applications in particular, SMART Read Refresh is employed to make sure that during read operations, when the read operation threshold is reached, the data is refreshed by re-writing it to a different block for subsequent use. 8 © 2021 Apacer Technology Inc. 5. Electrical Specifications 5.1 Absolute Stress Rating Table 5-1 lists the absolute stress rating for UV110-UFD1. Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 5-1 Absolute Stress Rating Item Range Required power supply 5V ± 5% (4.75-5.25V) 5.2 Absolute Maximum Rating Table 5-2 lists the absolute maximum power ratings for UV110-UFD1. Table 5-2 Absolute Maximum Power Ratings Parameter Min Typ Max Unit Operating Temperature (Commercial) 0 +25 +70 °C Storage Temperature (Commercial) -25 +25 +85 °C Operating Temperature (Industrial) -40 +25 +85 °C Storage Temperature (Industrial) -50 +25 +125 °C 1.1V Regulator Power Supply 1.04 1.12 1.20 V 1.8V Regulator Power Supply 1.76 1.86 2.0 V 3.3V Regulator Power Supply 3.15 3.3 3.45 V 5.0V Regulator Power Supply 3.0 5.0 5.5 V 2.5V Regulator Power Supply 2.35 2.5 2.7 V 1.2V Regulator Power Supply 1.13 1.2 1.3 V 5.3 Power Consumption Table 5-3 lists the power consumption for UV110-UFD1. Table 5-3 Power Consumption Capacity 16 GB 32 GB 64 GB 128 GB 256 GB Active (mA) 175 170 185 195 190 Idle (mA) 80 75 80 75 80 Mode Note: *All values are typical and may vary depending on flash configurations or host system settings. **Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 9 © 2021 Apacer Technology Inc. 6. Physical Characteristics Length Width Height 46.85mm 17.2mm 7.7mm 10 © 2021 Apacer Technology Inc. 7. Product Ordering Information 7.1 Product Code Designations 1 2 3 A N 2 4 5 6 7 8 9 10 11 12 13 14 15 16 1 1 2 X X G . X X X 1 8 Code . Code 1-3 (Product Line & Form Factor) Code 5-6 (Model/Solution) Code 7-8 (Product Capacity) Code 9 (Flash Type & Product Temp) Code 10 (Product Spec) Code 12-14 (Version Number) Code 15-16 (Firmware Version) USB+UFD1 UV110-UFD1 2E: 16GB 2F: 32GB 2G: 64GB 2H: 128GB 2J: 256GB G: 3D TLC Standard temperature H: 3D TLC Wide temperature UV110-UFD1 sliver-gray housing Random numbers generated by system UFPA3ABA 11 © 2021 Apacer Technology Inc. 7.2 Valid Combinations Capacity Standard Temperature Wide Temperature 16GB AN2.112EGG.00118 N/A 32GB AN2.112FGG.00118 AN2.112FHG.00118 64GB AN2.112GGG.00118 AN2.112GHG.00118 128GB AN2.112HGG.00118 AN2.112HHG.00118 256GB AN2.112JGG.00118 AN2.112JHG.00118 Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 12 © 2021 Apacer Technology Inc. Revision History Revision Description Date 0.1 Preliminary release 6/26/2019 1.0 Official release 10/14/2019 1.1 Updated total bytes and max LBA at 3.1 Capacity 11/21/2019 - Updated Performance on Specifications Overview page and 3.2 Performance 1.2 - Updated Power Consumption on Specifications Overview page and 5.3 Power Consumption 2/4/2020 - Updated 7. Product Ordering Information due to FW change 1.3 - Updated storage temperature from -40°C to 100°C to -55°C to 100°C 3/16/2020 - Updated the product photo at 3.7 LED Indicator Behavior 1.4 - Changed MTBF from >1,000,000 hours to >3,000,000 hours - Updated Table 3-1 by changing max LBA to total LBA 6/3/2020 - Updated Performance, Endurance on Power Consumption on Specifications Overview page 1.5 - Updated Table 3-4, 4-1 and 5-3 8/24/2020 - Updated the description of 4.8 Bad Block Management 1.6 Updated 7.1 Product Code Designations by changing the description of code 5-6 to UV110-UFD1 3/19/2021 1.7 Updated Endurance on Specifications Overview page and Table 3-4 12/27/2021 13 © 2021 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 6F, Daiyontamachi Bldg., 2-17-12, Shibaura, Minato-Ku, Tokyo, 108-0023, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, 1874, South End C Cross, 9th Block Jayanagar, Bangalore-560069, India Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com 14 © 2021 Apacer Technology Inc.
AN2.112EGG.00118 价格&库存
很抱歉,暂时无法提供与“AN2.112EGG.00118”相匹配的价格&库存,您可以联系我们找货
AN2.112EGG.00118
  • 1+1426.903011+184.83385
