A72.255FGA.00146
A72.255FGA.00146
    APACERMEMORYAMERICA(宇瞻科技)
    固态硬盘(SSD) FLASH - NAND(TLC) 30GB SATA III mSATA 3.3V
A72.255FGA.00146 数据手册
RoHS Recast Compliant Serial ATA Flash Drive SV250-300 Product Specifications November 8, 2021 Version 2.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Specifications Overview:   Compliance with SATA Revision 3.2  Temperature Range – SATA 6 Gb/s interface – ATA-8 command set Standard: 0°C to 70°C – Backward compatible with SATA 1.5/3 Gb/s Wide: -40°C to 85°C – – Capacity –    30, 60, 120, 240, 480 GB Storage: -55°C to 100°C Supply Voltage – Performance* Operating: 3.3 V ± 5% – Burst read/write: 600 MB/sec – Sequential read: Up to 560 MB/sec – Active mode: 390 mA – Sequential write: Up to 515 MB/sec – Idle mode: 70 mA – Random read (4K): Up to 56,000 IOPS – Random write (4K): Up to 71,000 IOPS  Flash Management – Low-Density Parity-Check (LDPC) Code – Global Wear Leveling – Flash bad-block management – Flash Translation Layer: Page Mapping – S.M.A.R.T. – DataDefenderTM – Device Sleep – ATA Secure Erase – TRIM – Hyper Cache Technology – Over-Provisioning – DataRAIDTM** – SMART Read Refresh  Connector Type – 52-pin mSATA connector  SATA Power Management Modes  Form Factor   TM Power Consumption* – JEDEC MO-300 – Dimensions: 50.80 x 29.85 x 4.85, unit: mm – Net Weight: 7.17g ± 5% Security – Trusted Computing Group (TCG) Opal 2.0 (optional) – AES 256-bit hardware encryption Reliability – Thermal Sensor – End-to-End Data Protection  LED Indicators for Drive Behavior  NAND Flash Type: 3D TLC (BiCS3)  Write Protect Switch (optional)  MTBF: >3,000,000 hours   Endurance (in drive writes per day: DWPD) RoHS Recast Compliant (Complies with 2011/65/EU Standard) – 30 GB: 3.27 DWPD – 60 GB: 3.45 DWPD – 120 GB: 3.27 DWPD – 240 GB: 3.45 DWPD – 480 GB: 3.3 DWPD *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Supported on standard model of all capacities and TCG Opal-supported model of 120-480GB capacities. 1 © 2021 Apacer Technology Inc. Table of Contents 1. General Descriptions ........................................................................4 2. Functional Block ...............................................................................4 3. Pin Assignments ................................................................................5 4. Product Specifications ......................................................................7 4.1 Capacity ......................................................................................................................................... 7 4.2 Performance .................................................................................................................................. 7 4.3 Environmental Specifications ........................................................................................................ 8 4.4 Mean Time Between Failures (MTBF) .......................................................................................... 8 4.5 Certification and Compliance......................................................................................................... 8 4.6 Endurance ..................................................................................................................................... 9 4.7 LED Indicator Behavior .................................................................................................................. 9 5. Flash Management ..........................................................................10 5.1 Error Correction/Detection ........................................................................................................... 10 5.2 Bad Block Management .............................................................................................................. 10 5.3 Global Wear Leveling .................................................................................................................. 10 5.4 DataDefenderTM ........................................................................................................................... 10 5.5 ATA Secure Erase ....................................................................................................................... 10 5.6 TRIM ............................................................................................................................................ 11 5.7 Flash Translation Layer – Page Mapping.................................................................................... 11 5.8 Device Sleep (DevSleep or DEVSLP) Mode ............................................................................... 11 5.9 Hyper Cache Technology ............................................................................................................ 11 5.10 Over-Provisioning ...................................................................................................................... 12 5.11 SATA Power Management ........................................................................................................ 12 5.12 DataRAIDTM ............................................................................................................................... 12 5.13 SMART Read RefreshTM ........................................................................................................... 12 6. Security and Reliability Features ...................................................13 6.1 TCG Opal (optional) .................................................................................................................... 13 6.2 Advanced Encryption Standard ................................................................................................... 13 6.3 End-to-End Data Protection......................................................................................................... 13 6.4 Thermal Sensor ........................................................................................................................... 13 7. Software Interface ..........................................................................14 7.1 Command Set .............................................................................................................................. 14 2 © 2021 Apacer Technology Inc. 7.2 S.M.A.R.T. ................................................................................................................................... 15 8. Electrical Specifications.................................................................17 8.1 Operating Voltage ........................................................................................................................ 17 8.2 Power Consumption .................................................................................................................... 17 9. Physical Characteristics .................................................................18 9.1 Dimensions .................................................................................................................................. 18 9.2 Net Weight ................................................................................................................................... 18 9.3 Write Protect Switch (optional) .................................................................................................... 19 10. Product Ordering Information .......................................................20 10.1 Product Code Designations ....................................................................................................... 20 10.2 Valid Combinations .................................................................................................................... 21 3 © 2021 Apacer Technology Inc. 1. General Descriptions Apacer’s SV250-300 is a well-balanced solid-state disk (SSD) drive with standard form factor and great performance. Designed in SATA 6 Gb/s interface, the SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading industrial or server operations. SV250-300 utilizes 3D NAND for higher capacity up to 480GB and provides more power efficiency than 2D NAND. Appearing in SV250-300 mechanical dimensions, SV250-300 is believed to be the leading add-in storage solution for future host computing systems. Regarding reliability, SV250-300 is implemented with LDPC (Low Density Parity Check) ECC engine to extend SSD endurance and increase data reliability. In addition, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM and DataDefender. In terms of security, Advanced Encryption Standard (AES) and Trusted Computing Group (TCG) Opal ensure data security and provide users with a peace of mind knowing their data is safeguarded against unauthorized use at all times. Furthermore, with End-to-End Data Protection, data integrity can be assured at multiple points in the path to enable reliable delivery of data transfers. 2. Functional Block Controller Flash data bus & ECC engine Host Interface SATAI/O & PHY SATA 6 Gb/s Interface Flash Flash Figure 2-1 Block Diagram 4 © 2021 Apacer Technology Inc. 3. Pin Assignments Pin assignment of the SV250-300 is shown in Figure 3-1 and described in Table 3-1. Pin 1 Pin 51 Figure 3-1 Pin Assignment Table 3-1 Pin Assignment Description Pin 1 2 3 4 Type Reserved +3.3V Reserved GND Description No Connect* 3.3V source No Connect* Ground Pin 27 28 29 30 Type GND Reserved GND Reserved 5 Reserved No Connect* 31 -A 6 Reserved No Connect* 32 Reserved 7 Reserved No Connect* 33 +A 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Reserved GND Reserved Reserved Reserved Reserved Reserved GND Reserved Reserved GND Reserved Reserved GND Reserved No Connect* Ground No Connect* No Connect* No Connect* No Connect* No Connect* Ground No Connect* No Connect* Ground No Connect* No Connect* Ground No Connect* 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 GND GND Reserved GND Reserved +3.3V GND +3.3V Reserved Device Type DEVSLP Reserved Reserved Reserved Reserved 23 +B Host Receiver Differential Signal Pair 49 DAS/DSS 24 +3.3V 50 GND Description Ground No Connect* Ground No Connect* Host Transmitter Differential Signal Pair No Connect* Host Transmitter Differential Signal Pair Ground Ground No Connect* Ground No Connect* 3.3V source Ground 3.3V source No Connect* No Connect* Device Sleep No Connect* No Connect* No Connect* No Connect* Device Activity Signal/Disable Staggered Spin-up Ground 25 -B 51* Detect 0 ohm 26 GND 52 +3.3V 3.3V source 3.3V Source Host Receiver Differential Signal Pair Ground *Reserved by Apacer, please do not connect to a host. **It is a presence detection pin that shall be connected to GND by a 0 ohm to 220 ohm Resistor on device. Please see the diagram below. 5 © 2021 Apacer Technology Inc. 6 © 2021 Apacer Technology Inc. 4. Product Specifications 4.1 Capacity Capacity specifications of SV250-300 are available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Total LBA 30 GB 30,016,659,456 16,383 16 63 58,626,288 60 GB 60,022,480,896 16,383 16 63 117,231,408 120 GB 120,034,123,776 16,383 16 63 234,441,648 240 GB 240,057,409,536 16,383 16 63 468,862,128 480 GB 480,103,981,056 16,383 16 63 937,703,088 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of SV250-300 is listed below in Table 4-2. Table 4-2 Performance Specifications Capacity 30 GB 60 GB 120 GB 240 GB 480 GB Sequential Read* (MB/s) 220 430 560 560 560 Sequential Write* (MB/s) 125 260 490 510 515 Random Read IOPS** (4K) 8,000 19,000 33,000 52,000 56,000 Random Write IOPS** (4K) 17,000 58,000 71,000 71,000 71,000 Performance Note: Results may differ from various flash configurations or host system setting. *Sequential performance is based on CrystalDiskMark 5.2.1 with file size 1,000MB. **Random performance measured using IOMeter with Queue Depth 32. 7 © 2021 Apacer Technology Inc. 4.3 Environmental Specifications Environmental specifications of SV250-300 product are shown in Table 4-3. Table 4-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Wide) Non-operating temp. -55°C to 100°C Operating vibration 7.69 GRMS, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating vibration 4.02 GRMS, 15~2000 Hz/random (compliant with MIL-STD-810G) Operating shock 50G, 11ms Non-operating shock 1500G, 0.5ms (compliant with MIL-STD-883K) Note: This Environmental Specification table indicates the conditions for testing the device. Real world usages may affect the results. 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SV250-300. The prediction result for SV250-300 is more than 3,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR332, Issue 3” method. 4.5 Certification and Compliance SV250-300 complies with the following standards:     CE FCC RoHS Recast MIL-STD-810G 8 © 2021 Apacer Technology Inc. 4.6 Endurance The endurance of a storage device is predicted by Drive Writes Per Day based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 4-4 Endurance Specifications Capacity Drive Writes Per Day 30 GB 3.27 60 GB 3.45 120 GB 3.27 240 GB 3.45 480 GB 3.3 Note:  This estimation complies with JEDEC JESD-219, Enterprise endurance workload of random data with payload size distribution.  Flash vendor guaranteed 3D NAND TLC P/E cycle: 3K  WAF may vary from capacity, flash configurations and writing behavior on each platform.  1 Terabyte = 1,024GB  DWPD (Drive Writes Per Day) is calculated based on the number of times that user overwrites the entire capacity of an SSD per day of its lifetime during the warranty period. (3D NAND TLC warranty: 2 years) 4.7 LED Indicator Behavior The behavior of the SV250-300 LED indicators is described in Table 4-5. Table 4-5 LED Behavior Location LED Description LED A HDDA1 LED blinks when the drive is being accessed 9 © 2021 Apacer Technology Inc. 5. Flash Management 5.1 Error Correction/Detection SV250-300 implements a hardware ECC scheme, based on the Low Density Parity Check (LDPC). LDPC is a class of linear block error correcting code which has apparent coding gain over BCH code because LDPC code includes both hard decoding and soft decoding algorithms. With the error rate decreasing, LDPC can extend SSD endurance and increase data reliability while reading raw data inside a flash chip. 5.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, page mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.3 Global Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Global wear leveling is an important mechanism that levels out the wearing of all blocks so that the wearing-down of all blocks can be almost evenly distributed. This will increase the lifespan of SSDs. 5.4 DataDefenderTM Apacer’s DataDefender combines both firmware and hardware mechanisms to ensure data integrity. When power disruption occurs, the hardware mechanism will notice and trigger the controller to run multiple write-to-flash cycles to store data. Then the firmware will check that the data was correctly written to the NAND flash after the power disruption, preventing data loss. 5.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 10 © 2021 Apacer Technology Inc. 5.6 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 5.7 Flash Translation Layer – Page Mapping Page mapping is an advanced flash management technology whose essence lies in the ability to gather data, distribute the data into flash pages automatically, and then schedule the data to be evenly written. Page-level mapping uses one page as the unit of mapping. The most important characteristic is that each logical page can be mapped to any physical page on the flash memory device. This mapping algorithm allows different sizes of data to be written to a block as if the data is written to a data pool and it does not need to take extra operations to process a write command. Thus, page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 5.8 Device Sleep (DevSleep or DEVSLP) Mode Device Sleep is a feature that allows SATA devices to enter a low power mode by designating a particular pin as DEVSLP signal with an aim to reducing power consumption. 5.9 Hyper Cache Technology Apacer proprietary Hyper Cache technology uses a portion of the available capacity as SLC (1bit-percell) NAND flash memory, called Hyper cache mode. When data is written to SSD, the firmware will direct the data to Hyper Cache mode, providing excellent performance to handle various scenarios in industrial use. 11 © 2021 Apacer Technology Inc. 5.10 Over-Provisioning Over-Provisioning (OP) is a certain portion of the SSD capacity exclusively for increasing Garbage Collection (GC) efficiency, especially when the SSD is filled to full capacity or performs a heavy mixed-random workload. OP has the advantages of providing extended life expectancy, reliable data integrity, and high sustained write performance. 5.11 SATA Power Management By complying with SATA 6 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, TX & RX operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: The behaviors of power management features would depend on host/device settings. 5.12 DataRAIDTM Apacer’s DataRAID algorithm applies an additional level of protection and error-checking. Using this algorithm, a certain amount of space is given over to aggregating and resaving the existing parity data used for error checking. So, in the event that data becomes corrupted, the parity data can be compared to the existing uncorrupted data and the content of the corrupted data can be rebuilt. 5.13 SMART Read RefreshTM Apacer’s SMART Read Refresh plays a proactive role in avoiding read disturb errors from occurring to ensure health status of all blocks of NAND flash. Developed for read-intensive applications in particular, SMART Read Refresh is employed to make sure that during read operations, when the read operation threshold is reached, the data is refreshed by re-writing it to a different block for subsequent use. 12 © 2021 Apacer Technology Inc. 6. Security and Reliability Features 6.1 TCG Opal (optional) Developed by the Trusted Computing Group (TCG), an organization whose members work together to formulate industry standards, Opal is a set of security specifications used for applying hardwarebased encryption to storage devices. Hardware encryption has many advantages. First of all, it transfers the computational load of the encryption process to dedicated processors, reducing the stress on the host system's CPU. In addition, storage devices complying with Opal specifications are self-encryption devices. Opal specifications also feature boot authentication. When the drive is being accessed, the shadow MBR will request the drive password at boot. The drive will only unlock and decrypt if the correct password is supplied. The other feature is LBA-specific permissions. Users are assigned different permissions for LBA ranges created by the device administrator. Each LBA range is password-protected and can only be accessed by users with the correct key to perform permitted actions (read/write/erase). 6.2 Advanced Encryption Standard Advanced Encryption Standard (AES) is a specification for the encryption of electronic data. AES has been adopted by the U.S. government since 2001 to protect classified information and is now widely implemented in embedded computing applications. The AES algorithm used in software and hardware is symmetric so that encrypting/decrypting requires the same encryption key. Without the key, the encrypted data is inaccessible to ensure information security. Notably in flash memory applications, AES 256-bit hardware encryption is the mainstream to protect sensitive or confidential data. The hardware encryption provides better performance, reliability, and security than software encryption. It uses a dedicated processor, which is built inside the controller, to process the encryption and decryption. This enormously shortens the processing time and makes it efficient. 6.3 End-to-End Data Protection End-to-End Data Protection is a feature implemented in Apacer SSD products that extends error control to cover the entire path from the host computer to the drive and back, and ensure data integrity at multiple points in the path to enable reliable delivery of data transfers. Unlike ECC which does not exhibit the ability to determine the occurrence of errors throughout the process of data transmission, End-to-End Data Protection allows SSD controller to identify an error created anywhere in the path and report the error to the host computer before it is written to the drive. This errorchecking and error-reporting mechanism therefore guarantees the trustworthiness and reliability of the SSD. 6.4 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using a designated pin for transmission, storage device owners are able to read temperature data. 13 © 2021 Apacer Technology Inc. 7. Software Interface 7.1 Command Set This section defines the software requirements and the format of the commands the host sends to SV250-300. Commands are issued to SV250-300 by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 7-1 Command Set Code Command Code Command E5h CHECK POWER MODE F4h SECURITY ERASE UNIT 06h DATA SET MANAGEMENT F5h SECURITY FREEZE LOCK 92h DOWNLOAD MICROCODE F1h SECURITY SET PASSWORD 90h EXECUTE DEVICE DIAGNOSTIC F2h SECURITY UNLOCK E7h FLUSH CACHE 70h SEEK EAh FLUSH CACHE EXT EFh SET FEATURES ECh IDENTIFY DEVICE C6h SET MULTIPLE MODE E3h IDLE E6h SLEEP E1h IDLE IMMEDIATE B0h SMART 91h INITIALIZE DEVICE PARAMETERS E2h STANDBY E4h READ BUFFER E0h STANDBY IMMEDIATE C8h READ DMA E8h WRITE BUFFER 25h READ DMA EXT CAh WRITE DMA 60h READ FPDMA QUEUED 35h WRITE DMA EXT C4h READ MULTIPLE 3Dh WRITE DMA FUA EXT 29h READ MULTIPLE EXT 61h WRITE FPDMA QUEUED 2Fh READ LOG EXT 3Fh WRITE LOG EXT 47h READ LOG DMA EXT 57h WRITE LOG DMA EXT 20h READ SECTOR C5h WRITE MULTIPLE 24h READ SECTOR EXT 39h WRITE MULTIPLE EXT 40h READ VERIFY SECTORS CEh WRITE MULTIPLE FUA EXT 42h READ VERIFY SECTORS EXT 30h WRITE SECTOR 10h RECALIBRATE 34h WRITE SECTOR EXT F6h SECURITY DISABLE PASSWORD 45h WRITE UNCORRECTABLE EXT F3h SECURITY ERASE PREPARE Table 7-2 Trusted Computing Feature Set Code Command Code Command 5Ch TRUSTED RECEIVE 5Eh TRUSTED SEND 5Dh TRUSTED RECEIVE DMA 5Fh TRUSTED SEND DMA Note: This feature set is only applicable to products implemented with AES and Opal functions. 14 © 2021 Apacer Technology Inc. 7.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Table 7-3 SMART Subcommand Set Code SMART Subcommand D0h READ DATA D1h READ ATTRIBUTE THRESHOLDS D2h ENABLE/DISABLE ATTRIBUTE AUTOSAVE D4h EXECUTE OFF-LINE IMMEDIATE D5h SMART READ LOG D6h SMART WRITE LOG D8h ENABLE OPERATIONS D9h DISABLE OPERATIONS DAh RETURN STATUS Table 7-4 General SMART Attribute Structure Byte Description 0 ID (Hex) 1–2 Status Flag 3 Value 4 Worst 5*-11 Raw Data *Byte 5: LSB 15 © 2021 Apacer Technology Inc. Table 7-5 SMART Attribute ID List ID (Hex) Attribute Name 9 (0x09) Power-on Hours 12 (0x0C) Power Cycle Count 163 (0xA3) Max. Erase Count 164 (0xA4) Avg. Erase Count 166 (0xA6) Total Later Bad Block Count 167 (0xA7) SSD Protect Mode (Vendor Specific) 168 (0xA8) SATA PHY Error Count 171 (0xAB) Program Fail Count 172 (0xAC) Erase Fail Count 175 (0xAF) Bad Cluster Table Count 192 (0xC0) Unexpected Power Loss Count 194 (0xC2) Temperature 231 (0xE7) Lifetime Left 241 (0xF1) Total Sectors of Write 16 © 2021 Apacer Technology Inc. 8. Electrical Specifications 8.1 Operating Voltage Table 8-1 lists the supply voltage for SV250-300. Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 8-1 Operating Range Item Range Supply Voltage 3.3V ± 5% (3.135-3.465V) 8.2 Power Consumption Table 8-2 lists the power consumption for SV250-300. Table 8-2 Power Consumption Capacity 30 GB 60 GB 120 GB 240 GB 480 GB Active (mA) 235 315 375 395 390 Idle (mA) 65 65 65 70 70 Mode Note: *All values are typical and may vary depending on flash configurations or host system settings. **Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 17 © 2021 Apacer Technology Inc. 9. Physical Characteristics 9.1 Dimensions Figure 9-1 Physical Dimensions 9.2 Net Weight Table 9-1 Net Weight Capacity Net Weight (g ± 5%) 30GB 5.44 60GB 6.06 120GB 7.08 240GB 6.88 480GB 7.17 18 © 2021 Apacer Technology Inc. 9.3 Write Protect Switch (optional) Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Once the system is reset and rebooted, the temporarily stored data will be lost and nowhere to be found in the system. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. Write Protect Switch Enable Disable Figure 9-2 Write Protect Switch 19 © 2021 Apacer Technology Inc. 10. Product Ordering Information 10.1 Product Code Designations 1 2 3 A 7 2 4 5 6 7 8 9 10 11 12 13 14 15 16 X X 5 X X X . X X X X X Code . Code 1-3 (Product Line & form factor) Code 5-6 (Model/Solution) Code 7-8 (Product Capacity) Code 9 (Flash Type & Product Temp) Code 10 (Product Spec) Code 12-14 (Version Number) Code 15-16 (Firmware Version) SATA + mSATA/MO300 25: SV250 A1: SV250 with TCG Opal 5F: 30GB 5G: 60GB 5H: 120GB 5J: 240GB 5K: 480GB G: 3D TLC Standard temperature H: 3D TLC Wide temperature A: MO300 B: MO300 with Write Protect switch Random numbers generated by system 46: Thermal Sensor with DEVSLP OP D5: Thermal Sensor with DEVSLP + TCG Opal OP 20 © 2021 Apacer Technology Inc. 10.2 Valid Combinations 10.2.1 Without Write Protect Switch Capacity Standard Temperature Wide Temperature 30GB A72.255FGA.00146 A72.255FHA.00146 60GB A72.255GGA.00146 A72.255GHA.00146 120GB A72.255HGA.00146 A72.255HHA.00146 240GB A72.255JGA.00146 A72.255JHA.00146 480GB A72.255KGA.00146 A72.255KHA.00146 10.2.2 With Write Protect Switch (optional) Capacity Standard Temperature Wide Temperature 30GB A72.255FGB.00146 A72.255FHB.00146 60GB A72.255GGB.00146 A72.255GHB.00146 120GB A72.255HGB.00146 A72.255HHB.00146 240GB A72.255JGB.00146 A72.255JHB.00146 480GB A72.255KGB.00146 A72.255KHB.00146 10.2.3 With TCG Opal (optional) Capacity Standard Temperature Wide Temperature 30GB A72.A15FGA.001D5 A72.A15FHA.001D5 60GB A72.A15GGA.001D5 A72.A15GHA.001D5 120GB A72.A15HGA.001D5 A72.A15HHA.001D5 240GB A72.A15JGA.001D5 A72.A15JHA.001D5 480GB A72.A15KGA.001D5 A72.A15KHA.001D5 Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 21 © 2021 Apacer Technology Inc. Revision History Revision Description Remark 1.0 Official release 4/29/2019 1.1 Changed Advanced Encryption Standard from optional to standard feature 5/2/2019 - Updated product photo on the cover page 1.2 - Changed Write Protect from standard feature to optional feature 5/6/2019 - Updated 10. Product Ordering Information by adding “A” to code 10th 1.3 Updated 3. Pin Assignments 5/20/2019 1.4 Updated 7.1 Command Set 10/24/2019 - Updated the note for DataRAID on Specifications Overview page 1.5 - Modified mechanical dimensions of SV250-300 at 1. General Description 12/16/2019 - Updated 10. Product Ordering Information 1.6 Modified total bytes at Table 4-1 Capacity Specifications 2/10/2020 1.7 Modified the model name appearing at 3. Pin Assignments 3/9/2020 1.8 - Changed SATA 6.0 Gbps to SATA 6 Gb/s in accordance with SATA naming guidelines - Capitalized every letter for commands at 7.1 Command Set and SMART subcommand at 7.2 S.M.A.R.T. 3/17/2020 - Updated compliance version with SATA Interface from 3.1 to 3.2 on Specifications Overview page - Updated the note regarding support model for DataRAID on Specifications Overview page - Updated Performance, MTBF, Endurance and Power Consumption on Specifications Overview page - Updated Table 4-1 by changing max LBA to total LBA - Updated 4.2 Performance and 8.2 Power Consumption 1.9 - Updated 4.4 Mean Time Between Failures (MTBF) by changing from >1,000,000 hours to >3,000,000 hours and issue version from 2 to 3 6/30/2020 - Updated 4.6 Endurance by changing endurance rating - Updated 4.7 LED Indicator Behavior by changing LED description - Updated the description of 5.2 Bad Block Management - Updated 10. Product Ordering Information by changing firmware code 22 © 2021 Apacer Technology Inc. Revision Description Remark - Updated storage temperature from -40°C -100°C to -55°C -100°C 2.0 - Updated 3.1 Pin Assignments - Updated 10.1 Product Code Designations 11/8/2021 - Updated 10.2.3 Firmware version code 23 © 2021 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 6F, Daiyontamachi Bldg., 2-17-12, Shibaura, Minato-Ku, Tokyo, 108-0023, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, 1874, South End C Cross, 9th Block Jayanagar, Bangalore-560069, India Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com 24 © 2021 Apacer Technology Inc.
A72.255FGA.00146 价格&库存
很抱歉,暂时无法提供与“A72.255FGA.00146”相匹配的价格&库存,您可以联系我们找货
