A72.245JGA.00341
A72.245JGA.00341
    APACERMEMORYAMERICA(宇瞻科技)
    固态硬盘(SSD) FLASH - NAND(TLC) 240GB ATA mSATA 3.3V
A72.245JGA.00341 数据手册
RoHS Compliant Serial ATA Flash Drive SV240-300 BiCS5 Product Specifications August 24, 2022 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Specifications Overview:   Compliance with SATA Revision 3.2 – SATA 6 Gb/s interface – Backward compatible with SATA 1.5 and 3 Gb/s interfaces – ATA command set-4 (ACS-4)   Temperature Range – Capacity –  Standard: 0°C to 70°C Wide: -40°C to 85°C –  240, 480, 960, 1920 GB  – Burst read/write: 600 MB/sec – Sequential read: Up to 560 MB/sec – Sequential write: Up to 500 MB/sec – Random read (4K): Up to 95,000 IOPS – Random write (4K): Up to 84,000 IOPS Storage: -55°C to 100°C Supply Voltage – Performance1 Operating: 3.3 V ± 5% Power Consumption1 – Active mode: 620 mA – Idle mode: 90 mA  SATA Power Management Modes  DRAM Cache for Enhanced Random Performance  Connector Type Flash Management – Low-Density Parity-Check (LDPC) Code – Global Wear Leveling – Flash bad-block management – Flash Translation Layer: Page Mapping – JEDEC MO-300 – S.M.A.R.T. – – DataDefenderTM Dimensions: 50.80 x 29.85 x 4.85, unit: mm – ATA Secure Erase – Net weight: 7.8g ± 5% – Device Sleep – TRIM – AES 256-bit hardware encryption – Hyper Cache Technology – – Over-provisioning Trusted Computing Group (TCG) Opal 2.0 (optional) – DataRAIDTM – SMART Read –    RefreshTM 52-pin mSATA connector Form Factor Security Reliability – Thermal Sensor – End-to-End Data Protection  NAND Flash Type: 3D TLC (BiCS5)  MTBF: >3,000,000 hours  LED Indicators for Drive Behavior  Endurance (in drive writes per day: DWPD)  RoHS Compliant – 240 GB: 2.20 DWPD – 480 GB: 2.20 DWPD – 960 GB: 2.25 DWPD – 1920 GB: 2.23 DWPD Note: 1. Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. 1 © 2022 Apacer Technology Inc. Table of Contents 1. General Description ..........................................................................4 2. Functional Block ...............................................................................4 3. Pin Assignments ................................................................................5 4. Product Specifications ......................................................................7 4.1 Capacity ......................................................................................................................................... 7 4.2 Performance .................................................................................................................................. 7 4.3 Environmental ................................................................................................................................ 8 4.4 Mean Time Between Failures (MTBF) .......................................................................................... 8 4.5 Certification and Compliance......................................................................................................... 8 4.6 Endurance ..................................................................................................................................... 8 4.7 LED Indicator Behavior .................................................................................................................. 9 5. Flash Management ..........................................................................10 5.1 Error Correction/Detection ........................................................................................................... 10 5.2 Bad Block Management .............................................................................................................. 10 5.3 Global Wear Leveling .................................................................................................................. 10 5.4 Flash Translation Layer – Page Mapping.................................................................................... 10 5.5 ATA Secure Erase ....................................................................................................................... 10 5.6 DataDefenderTM ........................................................................................................................... 11 5.7 TRIM ............................................................................................................................................ 11 5.8 Device Sleep (DevSleep or DEVSLP) Mode ............................................................................... 11 5.9 Hyper Cache Technology ............................................................................................................ 11 5.10 Over-provisioning ...................................................................................................................... 12 5.11 SATA Power Management ........................................................................................................ 12 5.12 DataRAIDTM ............................................................................................................................... 12 5.13 SMART Read RefreshTM ........................................................................................................... 12 6. Security and Reliability Features ...................................................13 6.1 Advanced Encryption Standard ................................................................................................... 13 6.2 TCG Opal (optional) .................................................................................................................... 13 6.3 Thermal Sensor ........................................................................................................................... 13 6.4 End-to-End Data Protection......................................................................................................... 13 7. Software Interface ..........................................................................14 7.1 Command Set .............................................................................................................................. 14 2 © 2022 Apacer Technology Inc. 7.2 S.M.A.R.T. ................................................................................................................................... 15 8. Electrical Specifications.................................................................17 8.1 Operating Voltage ........................................................................................................................ 17 8.2 Power Consumption .................................................................................................................... 17 9. Mechanical Specifications..............................................................18 9.1 Dimensions .................................................................................................................................. 18 9.2 Net Weight ................................................................................................................................... 18 10. Product Ordering Information .......................................................19 10.1 Product Code Designations ....................................................................................................... 19 10.2 Valid Combinations .................................................................................................................... 20 3 © 2022 Apacer Technology Inc. 1. General Description Apacer’s SV240-300 is a well-balanced solid-state disk (SSD) drive with standard form factor and great performance. Designed with SATA-based connector pinouts and in SATA 6 Gb/s interface, SV240-300 provides full compliance with the latest SATA Revision 3.2 interface specifications and delivers exceptional performance, reaching up to 560/500 MB/s and 95,000/84,000 in sequential and IOPS read/write. Random performance is further enhanced by engineering the internal controlling unit of the SSD with DRAM, making it the ideal companion for heavy-loading industrial or server operations. SV240-300 utilizes 3D NAND for higher capacity up to 1920GB and provides more power efficiency than 2D NAND. Regarding reliability, SV240-300 is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme and implemented with LDPC (Low Density Parity Check) ECC engine to extend SSD endurance and increase data reliability. Furthermore, SV240-300 is equipped with a built-in thermal sensor to monitor the temperature of the SSD via S.M.A.R.T commands to prevent overheating. Operating under 6 Gb/s interface, SV240-300 is provided with Apacer latest S.M.A.R.T. that is primarily oriented for the latest SATA interface SSD, for drive lifetime monitoring and analysis. For highly-intensive applications, End-to-End Data Protection ensures that data integrity can be assured at multiple points in the path to enable reliable delivery of data transfers. Security-wise, Advanced Encryption Standard (AES) and Trusted Computing Group (TCG) Opal (optional) ensure data security and provide users with peace of mind knowing their data is safeguarded against unauthorized use at all times. SV240-300 also adopts the latest page mapping file translation layer and comes with various implementations including power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, Hyper Cache technology, over-provisioning, DataDefenderTM, DataRAIDTM and SMART Read RefreshTM. 2. Functional Block Apacer SV240-300 includes a single-chip controller designed with a DRAM and flash media. The controller integrates the flash management unit to support multi-channel, multi-bank flash arrays. Figure 2-1 shows the functional block diagram. Figure 2-1 Functional Block Diagram 4 © 2022 Apacer Technology Inc. 3. Pin Assignments Pin assignment of the SV240-300 is shown in Figure 3-1 and described in Table 3-1. Pin 1 Pin 51 Figure 3-1 Pin Assignments Table 3-1 Pin Assignments Pin 1 2 3 4 Type Reserved +3.3V Reserved GND Description No Connect 3.3V source No Connect Ground Pin 27 28 29 30 Type GND Reserved GND Reserved 5 Reserved No Connect 31 -A 6 Reserved No Connect 32 Reserved 7 Reserved No Connect 33 +A 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Reserved GND Reserved Reserved Reserved Reserved Reserved GND Reserved Reserved GND Reserved Reserved GND Reserved 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 GND GND Reserved GND Reserved +3.3V GND +3.3V Reserved Device Type DEVSLP Reserved Reserved Reserved Reserved 23 +B 49 DAS/DSS 24 +3.3V No Connect Ground No Connect No Connect No Connect No Connect No Connect Ground No Connect No Connect Ground Reserved for Apacer use only1 No Connect Ground No Connect Host Receiver Differential Signal Pair 3.3V Source Host Receiver Differential Signal Pair Ground 50 GND Description Ground No Connect Ground No Connect Host Transmitter Differential Signal Pair No Connect Host Transmitter Differential Signal Pair Ground Ground No Connect Ground No Connect 3.3V source Ground 3.3V source No Connect No Connect Device Sleep Reserved for Apacer use only1 No Connect Reserved for Apacer use only1 No Connect Device Activity Signal/Disable Staggered Spin-up Ground 512 Detect 0 ohm 52 +3.3V 3.3V source 25 -B 26 GND Notes: 1. Reserved by Apacer, please do not connect to a host. 2. It is a presence detection pin that shall be connected to GND by a 0 ohm to 220 ohm Resistor on device. Please see the diagram below. 5 © 2022 Apacer Technology Inc. 6 © 2022 Apacer Technology Inc. 4. Product Specifications 4.1 Capacity Capacity specifications of SV240-300 are available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1 Capacity Specifications Capacity Total bytes Cylinders Heads Sectors Total LBA 240 GB 240,057,409,536 16,383 16 63 468,862,128 480 GB 480,103,981,056 16,383 16 63 937,703,088 960 GB 960,197,124,096 16,383 16 63 1,875,385,008 1920 GB 1,920,383,410,176 16,383 16 63 3,750,748,848 Notes:  Display of total bytes varies from operating systems.  1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes.  LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of SV240-300 is listed below in Table 4-2. Table 4-2 Performance Specifications Capacity 240 GB 480 GB 960 GB 1920 GB Sequential Read (MB/s) 560 560 560 560 Sequential Write (MB/s) 470 485 500 490 Random Read IOPS (4K) 74,000 95,000 95,000 94,000 Random Write IOPS (4K) 83,000 84,000 84,000 84,000 Performance Notes:  Results may differ from various flash configurations or host system setting.  Sequential read/write is based on CrystalDiskMark 8.0.4 with file size 1,000MB.  Random read/write is measured using IOMeter with Queue Depth 32. 7 © 2022 Apacer Technology Inc. 4.3 Environmental Environmental specifications of SV240-300 product are shown in Table 4-3. Table 4-3 Environmental Specifications Environment Temperature Specifications Operation: 0°C to 70°C (Standard); -40°C to 85°C (Wide) Non-operation: -55°C to 100°C Vibration Operation: 7.69(Grms), 20~2000(Hz)/random (compliant with MIL-STD-810G) Non-operation: 4.02(Grms), 15~2000(Hz)/random (compliant with MIL-STD-810G) Shock Operation: Acceleration, 50(G)/11(ms)/half sine (compliant with MIL-STD-202G) Non-operation: Acceleration,1,500(G)/0.5(ms)/half sine (compliant with MIL-STD-883K) Note: This Environmental Specification table indicates the conditions for testing the device. Real world usages may affect the results. 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SV240-300. The prediction result for SV240-300 is more than 3,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 3” method. 4.5 Certification and Compliance SV240-300 complies with the following standards:     CE FCC RoHS MIL-STD-810G 4.6 Endurance The endurance of a storage device is predicted by Drive Writes Per Day based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 4-4 Endurance Specifications Capacity Drive Writes Per Day 240 GB 2.20 480 GB 2.20 960 GB 2.25 1920 GB 2.23 Notes:  This estimation complies with JEDEC JESD-219, Enterprise endurance workload of random data with payload size distribution.  Flash vendor guaranteed 3D NAND TLC P/E cycle: 3K  WAF may vary from capacity, flash configurations and writing behavior on each platform.  1 Terabyte = 1,024 GB  DWPD (Drive Write Per Day) is calculated based on the number of times that user overwrites the entire capacity of an SSD per day of its lifetime during the warranty period. (3D NAND TLC warranty: 3 years) 8 © 2022 Apacer Technology Inc. 4.7 LED Indicator Behavior The behavior of the SV240-300 LED indicators is described in Table 4-5. Table 4-5 LED Behavior Location LED Description LED A DAS LED blinks when the drive is being accessed 9 © 2022 Apacer Technology Inc. 5. Flash Management 5.1 Error Correction/Detection SV240-300 implements a hardware ECC scheme, based on the Low Density Parity Check (LDPC). LDPC is a class of linear block error correcting code which has apparent coding gain over BCH code because LDPC code includes both hard decoding and soft decoding algorithms. With the error rate decreasing, LDPC can extend SSD endurance and increase data reliability while reading raw data inside a flash chip. 5.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, page mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.3 Global Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Global wear leveling is an important mechanism that levels out the wearing of all blocks so that the wearing-down of all blocks can be almost evenly distributed. This will increase the lifespan of SSDs. 5.4 Flash Translation Layer – Page Mapping Page mapping is an advanced flash management technology whose essence lies in the ability to gather data, distribute the data into flash pages automatically, and then schedule the data to be evenly written. Page-level mapping uses one page as the unit of mapping. The most important characteristic is that each logical page can be mapped to any physical page on the flash memory device. This mapping algorithm allows different sizes of data to be written to a block as if the data is written to a data pool and it does not need to take extra operations to process a write command. Thus, page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 5.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 10 © 2022 Apacer Technology Inc. 5.6 DataDefenderTM Apacer’s DataDefender is an advanced technology of power failure management which combines both firmware and hardware mechanisms to ensure data integrity. When power disruption occurs, the low voltage detector will be triggered. When this happens, the SSD’s protection mechanism is activated and cuts off data transmission from the host. Once the power supply is resumed, the firmware protection mechanism will ensure the integrity of the firmware as well as the data already written into the NAND flash media. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into nonvolatile NAND flash memory. 5.7 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 5.8 Device Sleep (DevSleep or DEVSLP) Mode Device Sleep is a feature that allows SATA devices to enter a low power mode by designating a particular pin as DEVSLP signal with an aim to reducing power consumption. Figure 5-1 Device Sleep 5.9 Hyper Cache Technology Apacer proprietary Hyper Cache technology uses a portion of the available capacity as SLC (1bit-percell) NAND flash memory, called Hyper cache mode. When data is written to SSD, the firmware will direct the data to Hyper Cache mode, providing excellent performance to handle various scenarios in industrial use. 11 © 2022 Apacer Technology Inc. 5.10 Over-provisioning Over-provisioning (OP) is a certain portion of the SSD capacity exclusively for increasing Garbage Collection (GC) efficiency, especially when the SSD is filled to full capacity or performs a heavy mixed-random workload. OP has the advantages of providing extended life expectancy, reliable data integrity, and high sustained write performance. 5.11 SATA Power Management By complying with SATA 6 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, TX & RX operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: The behaviors of power management features would depend on host/device settings. 5.12 DataRAIDTM Apacer’s DataRAID algorithm applies an additional level of protection and error-checking. Using this algorithm, a certain amount of space is given over to aggregating and resaving the existing parity data used for error checking. So, in the event that data becomes corrupted, the parity data can be compared to the existing uncorrupted data and the content of the corrupted data can be rebuilt. 5.13 SMART Read RefreshTM Apacer’s SMART Read Refresh plays a proactive role in avoiding read disturb errors from occurring to ensure health status of all blocks of NAND flash. Developed for read-intensive applications in particular, SMART Read Refresh is employed to make sure that during read operations, when the read operation threshold is reached, the data is refreshed by re-writing it to a different block for subsequent use. 12 © 2022 Apacer Technology Inc. 6. Security and Reliability Features 6.1 Advanced Encryption Standard Advanced Encryption Standard (AES) is a specification for the encryption of electronic data. AES has been adopted by the U.S. government since 2001 to protect classified information and is now widely implemented in embedded computing applications. The AES algorithm used in software and hardware is symmetric so that encrypting/decrypting requires the same encryption key. Without the key, the encrypted data is inaccessible to ensure information security. Notably in flash memory applications, AES 256-bit hardware encryption is the mainstream to protect sensitive or confidential data. The hardware encryption provides better performance, reliability, and security than software encryption. It uses a dedicated processor, which is built inside the controller, to process the encryption and decryption. This enormously shortens the processing time and makes it efficient. 6.2 TCG Opal (optional) Developed by the Trusted Computing Group (TCG), an organization whose members work together to formulate industry standards, Opal is a set of security specifications used for applying hardwarebased encryption to storage devices. Hardware encryption has many advantages. First of all, it transfers the computational load of the encryption process to dedicated processors, reducing the stress on the host system's CPU. In addition, storage devices complying with Opal specifications are self-encryption devices. Opal specifications also feature boot authentication. When the drive is being accessed, the shadow MBR will request the drive password at boot. The drive will only unlock and decrypt if the correct password is supplied. The other feature is LBA-specific permissions. Users are assigned different permissions for LBA ranges created by the device administrator. Each LBA range is password-protected and can only be accessed by users with the correct key to perform permitted actions (read/write/erase). 6.3 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using a designated pin for transmission, storage device owners are able to read temperature data. 6.4 End-to-End Data Protection End-to-End Data Protection is a feature implemented in Apacer SSD products that extends error control to cover the entire path from the host computer to the drive and back, and ensure data integrity at multiple points in the path to enable reliable delivery of data transfers. Unlike ECC which does not exhibit the ability to determine the occurrence of errors throughout the process of data transmission, End-to-End Data Protection allows SSD controller to identify an error created anywhere in the path and report the error to the host computer before it is written to the drive. This errorchecking and error-reporting mechanism therefore guarantees the trustworthiness and reliability of the SSD. 13 © 2022 Apacer Technology Inc. 7. Software Interface 7.1 Command Set This section defines the software requirements and the format of the commands the host sends to SV240-300. Commands are issued to SV240-300 by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 7-1 Command Set Code Command Code Command E5h CHECK POWER MODE F4h SECURITY ERASE UNIT 06h DATA SET MANAGEMENT F5h SECURITY FREEZE LOCK 92h DOWNLOAD MICROCODE F1h SECURITY SET PASSWORD 90h EXECUTE DEVICE DIAGNOSTIC F2h SECURITY UNLOCK E7h FLUSH CACHE 70h SEEK EAh FLUSH CACHE EXT EFh SET FEATURES ECh IDENTIFY DEVICE C6h SET MULTIPLE MODE E3h IDLE E6h SLEEP E1h IDLE IMMEDIATE B0h SMART 91h INITIALIZE DEVICE PARAMETERS E2h STANDBY E4h READ BUFFER E0h STANDBY IMMEDIATE C8h READ DMA E8h WRITE BUFFER 25h READ DMA EXT CAh WRITE DMA 60h READ FPDMA QUEUED 35h WRITE DMA EXT C4h READ MULTIPLE 3Dh WRITE DMA FUA EXT 29h READ MULTIPLE EXT 61h WRITE FPDMA QUEUED 2Fh READ LOG EXT 3Fh WRITE LOG EXT 47h READ LOG DMA EXT 57h WRITE LOG DMA EXT 20h READ SECTOR C5h WRITE MULTIPLE 24h READ SECTOR EXT 39h WRITE MULTIPLE EXT 40h READ VERIFY SECTORS CEh WRITE MULTIPLE FUA EXT 42h READ VERIFY SECTORS EXT 30h WRITE SECTOR 10h RECALIBRATE 34h WRITE SECTOR EXT F6h SECURITY DISABLE PASSWORD 45h WRITE UNCORRECTABLE EXT F3h SECURITY ERASE PREPARE Table 7-2 Trusted Computing Feature Set Code Command Code Command 5Ch TRUSTED RECEIVE 5Eh TRUSTED SEND 5Dh TRUSTED RECEIVE DMA 5Fh TRUSTED SEND DMA Note: This feature set is only applicable to products implemented with AES and Opal functions. 14 © 2022 Apacer Technology Inc. 7.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Table 7-3 SMART Subcommand Set Code SMART Subcommand D0h READ DATA D1h READ ATTRIBUTE THRESHOLDS D2h ENABLE/DISABLE ATTRIBUTE AUTOSAVE D4h EXECUTE OFF-LINE IMMEDIATE D5h SMART READ LOG D6h SMART WRITE LOG D8h ENABLE OPERATIONS D9h DISABLE OPERATIONS DAh RETURN STATUS Table 7-4 General SMART Attribute Structure Byte Description 0 ID (Hex) 1–2 Status Flag 3 Value 4 Worst 5*-11 Raw Data *Byte 5: LSB 15 © 2022 Apacer Technology Inc. Table 7-5 SMART Attribute ID List ID (Hex) Attribute Name 9 (0x09) Power-on Hours 12 (0x0C) Power Cycle Count 163 (0xA3) Maximum Erase Count 164 (0xA4) Average Erase Count 166 (0xA6) Total Later Bad Block Count 167 (0xA7) SSD Protect Mode (Vendor Specific) 168 (0xA8) SATA PHY Error Count 171 (0xAB) Program Fail Count 172 (0xAC) Erase Fail Count 175 (0xAF) Bad Cluster Table Count 192 (0xC0) Unexpected Power Loss Count 194 (0xC2) Temperature 231 (0xE7) Lifetime Left 241 (0xF1) Total Sectors of Write 16 © 2022 Apacer Technology Inc. 8. Electrical Specifications 8.1 Operating Voltage Table 8-1 lists the supply voltage for SV240-300. Table 8-1 Operating Range Item Range Supply Voltage 3.3V ± 5% (3.135-3.465V) 8.2 Power Consumption Table 8-2 lists the power consumption for SV240-300. Table 8-2 Power Consumption Capacity 240 GB 480 GB 960 GB 1920 GB Active (mA) 560 580 620 620 Idle (mA) 85 85 90 90 Mode Notes:  All values are typical and may vary depending on flash configurations or host system settings.  Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 17 © 2022 Apacer Technology Inc. 9. Mechanical Specifications 9.1 Dimensions Unit: mm Figure 9-1 Physical Dimensions 9.2 Net Weight Table 9-1 Net Weight Capacity Net Weight (g ± 5%) 240GB 7.35 480GB 7.48 960GB 7.8 1920GB 7.6 18 © 2022 Apacer Technology Inc. 10. Product Ordering Information 10.1 Product Code Designations Apacer’s SV240-300 SSD is available in different configurations and densities. See the chart below for a comprehensive list of options for the SV240-300 series devices. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 A 7 2 . X X 5 X X A . X X X X X Code Code 1-3 (Product Line & Form Factor) Code 5-6 (Model/Solution) Code 7-8 (Product Capacity) Code 9 (Flash Type & Product Temp) Code 10 (Product Spec) Code 12-14 (Version Number) Code 15-16 (Firmware Version) SATA+ mSATA/MO300 24: SV240-300 A2 :SV240 with TCG Opal 5J: 240GB 5K: 480GB 5L: 960GB 5M: 1920GB G: 3D TLC Standard temperature H: 3D TLC Wide temperature MO300 Random numbers generated by system 41: Thermal Sensor with DEVSLP OP 44: Thermal Sensor with DEVSLP + TCG Opal OP 19 © 2022 Apacer Technology Inc. 10.2 Valid Combinations The following tables list the available models of the SV240-300 series which are in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 10.2.1 Without TCG Opal Capacity Standard Temperature Wide Temperature 240GB A72.245JGA.00341 A72.245JHA.00641 480GB A72.245KGA.00341 A72.245KHA.00641 960GB A72.245LGA.00441 A72.245LHA.00641 1920GB A72.245MGA.00341 A72.245MHA.00541 Capacity Standard Temperature Wide Temperature 240GB A72.A25JGA.00344 A72.A25JHA.00444 480GB A72.A25KGA.00344 A72.A25KHA.00344 960GB A72.A25LGA.00344 A72.A25LHA.00344 1920GB A72.A25MGA.00244 A72.A25MHA.00244 10.2.2 With TCG Opal 20 © 2022 Apacer Technology Inc. Revision History Revision Description Date 0.1 Preliminary release 8/4/2022 1.0 Official release 8/9/2022 1.1 Added 1920GB support 8/24/2022 21 © 2022 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 6F, Daiyontamachi Bldg., 2-17-12, Shibaura, Minato-Ku, Tokyo, 108-0023, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, 1874, South End C Cross, 9th Block Jayanagar, Bangalore-560069, India Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com 22 © 2022 Apacer Technology Inc.
A72.245JGA.00341 价格&库存
很抱歉,暂时无法提供与“A72.245JGA.00341”相匹配的价格&库存,您可以联系我们找货
