APM2T42SS22004GTN-6ET
    APACERMEMORYAMERICA(宇瞻科技)
    固态硬盘(SSD) FLASH - NAND(SLC) 4GB ATA M.2 模块 3.3V
APM2T42SS22004GTN-6ET 数据手册
RoHS Recast Compliant M.2 2242 Flash Drive SS220-M242 Product Specifications May 17, 2021 Version 1.2 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Specifications Overview:   Compliance with SATA Interface   Temperature Range – Serial ATA Revision 3.1 – SATA 6 Gb/s Standard: 0°C to 70°C – ATA-8 command set Wide: -40°C to 85°C – Backward compatible with SATA 1.5/3 Gb/s – –  Capacity –    Performance* – Interface burst read/write: 600 MB/sec – Sequential read: up to 555 MB/sec – Sequential write: up to 450 MB/sec – Random read 4K: up to 85,000 IOPS – Random write 4K: up to 77,000 IOPS  Storage: -40°C to 100°C Supply Voltage – 1, 2, 4, 8, 16, 32, 64 GB Operating: 3.3 V ± 5% Power Consumption* – Active mode: 520 mA – Idle mode: 85 mA Connector Type – M.2 B & M key  NAND Flash Type: SLC  MTBF: >2,000,000 hours  Form Factor Flash Management – Built-in hardware ECC – Global Wear Leveling – Flash bad-block management – M.2 2242-D2-B-M – Flash Translation Layer: Page Mapping – Dimensions: 42.00 x 22.00 x 3.60, unit: ㎜ – S.M.A.R.T. – Power Failure Management – Device Sleep (optional) – ATA Secure Erase – TRIM – SMART Read RefreshTM  Reliability – Thermal Sensor – Thermal Throttling (optional)  SATA Power Management  LED Indicators for Drive Behavior  RoHS Recast Compliant (Complies with 2011/65/EU Standard) Endurance (in Terabytes Written: TBW) – 1 GB: 2 TBW – 2 GB: 6 TBW – 4 GB: 82 TBW – 8 GB: 270 TBW – 16 GB: 616 TBW – 32 GB: 1,358 TBW – 64 GB: 2,245 TBW *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. 1 © 2021 Apacer Technology Inc. Table of Contents 1. General Descriptions ........................................................................4 2. Functional Block ...............................................................................4 3. Pin Assignments ................................................................................5 4. Product Specifications ......................................................................8 4.1 Capacity ......................................................................................................................................... 8 4.2 Performance .................................................................................................................................. 8 4.3 Environmental Specifications ........................................................................................................ 9 4.4 Mean Time Between Failures (MTBF) .......................................................................................... 9 4.5 Certification and Compliance......................................................................................................... 9 4.6 Endurance ................................................................................................................................... 10 4.7 LED Indicator Behavior ................................................................................................................ 10 5. Flash Management ..........................................................................11 5.1 Error Correction/Detection ........................................................................................................... 11 5.2 Bad Block Management .............................................................................................................. 11 5.3 Global Wear Leveling .................................................................................................................. 11 5.4 Flash Translation Layer – Page Mapping.................................................................................... 11 5.5 ATA Secure Erase ....................................................................................................................... 11 5.6 Power Failure Management ........................................................................................................ 12 5.7 TRIM ............................................................................................................................................ 12 5.8 Device Sleep (DevSleep or DEVSLP) Mode (optional) ............................................................... 12 5.9 SMART Read RefreshTM ............................................................................................................. 12 5.10 SATA Power Management ........................................................................................................ 13 6. Reliability Features .........................................................................14 6.1 Thermal Sensor ........................................................................................................................... 14 6.2 Thermal Throttling (optional) ....................................................................................................... 14 7. Software Interface ..........................................................................15 7.1 Command Set .............................................................................................................................. 15 7.2 S.M.A.R.T. ................................................................................................................................... 15 8. Electrical Specifications.................................................................17 8.1 Operating Voltage ........................................................................................................................ 17 2 © 2021 Apacer Technology Inc. 8.2 Power Consumption .................................................................................................................... 17 9. Physical Characteristics .................................................................18 10. Product Ordering Information .......................................................19 10.1 Product Code Designations ....................................................................................................... 19 10.2 Valid Combinations .................................................................................................................... 20 3 © 2021 Apacer Technology Inc. 1. General Descriptions Apacer’s SS220-M242 (M.2 2242) is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, with the aim to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. SS220-M242 appears in M.2 2242 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.1 interface specifications. Aside from SATA compliance, SS220-M242 delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes SS220-M242 the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, SS220-M242 is built with a powerful SATA controller that supports on-themodule ECC as well as efficient wear leveling scheme. Since it is operating under SATA 6 Gb/s interface, SS220-M242 is provided with Apacer latest S.M.A.R.T. that are primarily oriented for the latest SATA interface SSD, for drive lifetime monitoring and analyzing. 2. Functional Block Apacer SS220-M242 includes a single-chip SATA 6 Gb/s and the flash media. The controller integrates the flash management unit to support multi-channel, multi-bank flash arrays. Figure 2-1 shows the functional block diagram. Host Interface SATAI/O & PHY SATA 6 Gb/s Interface Controller Flash data bus & ECC engine DDR3 DRAM Flash Flash Figure 2-1 Block Diagram 4 © 2021 Apacer Technology Inc. 3. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Table 3-1 Pin Assignments Pin Type Description 1 CONFIG_3 Ground (according to M.2 configurations for SSD-SATA definition) 2 3.3V Supply Pin, 3.3V 3 GND Ground 4 3.3V Supply pin, 3.3V 5 No connect No connect* 6 Not available No connect* 7 Not available No connect* 8 Not available No connect* 9 No connect No connect* 10 DAS/DSS Device Activity Signal/Disable Staggered Spin-up 11 No connect No connect* 12 (removed for key) Mechanical notch B 13 (removed for key) Mechanical notch B 14 (removed for key) Mechanical notch B 15 (removed for key) Mechanical notch B 16 (removed for key) Mechanical notch B 17 (removed for key) Mechanical notch B 18 (removed for key) Mechanical notch B 19 (removed for key) Mechanical notch B 20 Not available No connect* 21 CONFIG_0 Ground (according to M.2 configurations for SSD-SATA definition) 5 © 2021 Apacer Technology Inc. Pin Type Description 22 Not available No connect* 23 Not available No connect* 24 Not available No connect* 25 Not available No connect* 26 Not available No connect* 27 GND Ground 28 Not available No connect* 29 PERn1 No connect* 30 Not available No connect* 31 PERp1 No connect* 32 Not available No connect* 33 GND Ground 34 Not available No connect* 35 PETn1 No connect* 36 Not available No connect* 37 PETp1 38 DEVSLP No connect* Device Sleep, input. If driven high the host is informing the SSD to enter a low power state 39 GND Ground 40 Not available No connect* 41 SATA-Rx+ Host receiver differential signal pair 42 Not available No connect* 43 SATA-Rx- Host receiver differential signal pair 44 Not available No connect* 45 GND Ground 46 Not available No connect* 47 SATA-Tx- Host transmitter differential pair 48 Not available No connect* 49 SATA-Tx+ Host transmitter differential pair 50 PERST# No connect* 51 GND Ground 52 CLKREQ# No connect* 53 REFCLKN No connect* 54 PEWAKE# No connect* 55 REFCLKP No connect* 56 MFG1 No connect* 57 GND Ground 58 MFG2 No connect* 6 © 2021 Apacer Technology Inc. Pin Type Description 59 (removed for key) Mechanical notch M 60 (removed for key) Mechanical notch M 61 (removed for key) Mechanical notch M 62 (removed for key) Mechanical notch M 63 (removed for key) Mechanical notch M 64 (removed for key) Mechanical notch M 65 (removed for key) Mechanical notch M 66 (removed for key) Mechanical notch M 67 Not available No connect* 68 SUSCLK No connect* 69 CONFIG_1 Ground 70 3.3V Supply pin, 3.3V 71 GND Ground 72 3.3V Supply pin, 3.3V 73 GND Ground 74 3.3V Supply pin, 3.3V 75 CONFIG_2 Ground *Reserved by Apacer, please do not connect on a host. Figure 3-1 Direct Connection between the Host and Device 7 © 2021 Apacer Technology Inc. 4. Product Specifications 4.1 Capacity Capacity specifications of SS220-M242 are available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Total LBA 1 GB 1,011,032,064 1,959 16 63 1,974,672 2 GB 2,011,226,112 3,897 16 63 3,928,176 4 GB 4,011,614,208 7,773 16 63 7,835,184 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of SS220-M242 is listed below in Table 4-2. Table 4-2 Performance Specifications Capacity 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Sequential Read* (MB/s) 32 60 65 60 70 65 555 Sequential Write* (MB/s) 14 28 55 38 65 65 450 Random Read IOPS** (4K) 7,000 10,000 15,000 12,000 15,000 16,000 85,000 Random Write IOPS** (4K) 700 1,000 3,000 4,000 12,000 16,000 77,000 Performance Note: Results may differ from various flash configurations or host system setting. *Sequential performance is based on CrystalDiskMark 5.2.1 with file size 1,000MB. **Random performance measured using IOMeter with Queue Depth 32. 8 © 2021 Apacer Technology Inc. 4.3 Environmental Specifications Environmental specifications of SS220-M242 product follow MIL-STD-810 standards as shown in Table 4-3. Table 4-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Wide) Non-operating temp. -40°C to 100°C Operating vibration 7.69 Grms, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating vibration 4.02 Grms, 15 ~ 2000 Hz/sine (compliant with MIL-STD-810G) Operating shock 50(G), 11(ms), half-sine wave Non-operating shock 1,500(G), 0.5(ms), half-sine wave 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SS220-M242. The prediction result for SS220-M242 is more than 2,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR332, Issue 2” method. 4.5 Certification and Compliance SS220-M242 complies with the following standards:     CE FCC RoHS Recast MIL-STD-810G 9 © 2021 Apacer Technology Inc. 4.6 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 4-4 Endurance Specifications Capacity TeraBytes Written 1 GB 2 2 GB 6 4 GB 82 8 GB 270 16 GB 616 32 GB 1,358 64 GB 2,245 Note:  The measurement assumes the data written to the SSD for test is under a typical and constant rate.  The measurement follows the standard metric: 1 TB (Terabyte) = 1,000 GB.  This estimation complies with JEDEC JESD-219, enterprise endurance workload of random data with payload size distribution. 4.7 LED Indicator Behavior The behavior of the SS220-M242 LED indicators is described in Table 4-5. Table 4-5 LED Behavior Location LED Description LED A DAS LED blinks when the drive is being accessed LED B PHY LED blinks when PHY is connected B A 10 © 2021 Apacer Technology Inc. 5. Flash Management 5.1 Error Correction/Detection SS220-M242 implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bit error in 1K bytes. 5.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, page mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.3 Global Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Global wear leveling is an important mechanism that levels out the wearing of all blocks so that the wearing-down of all blocks can be almost evenly distributed. This will increase the lifespan of SSDs. 5.4 Flash Translation Layer – Page Mapping Page mapping is an advanced flash management technology whose essence lies in the ability to gather data, distribute the data into flash pages automatically, and then schedule the data to be evenly written. Page-level mapping uses one page as the unit of mapping. The most important characteristic is that each logical page can be mapped to any physical page on the flash memory device. This mapping algorithm allows different sizes of data to be written to a block as if the data is written to a data pool and it does not need to take extra operations to process a write command. Thus, page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 5.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 11 © 2021 Apacer Technology Inc. 5.6 Power Failure Management Power Failure Management plays a crucial role when power supply becomes unstable. Power disruption may occur when users are storing data into the SSD, leading to instability in the drive. However, with Power Failure Management, a firmware protection mechanism will be activated to scan pages and blocks once power is resumed. Valid data will be transferred to new blocks for merging and the mapping table will be rebuilt. Therefore, data reliability can be reinforced, preventing damage to data stored in the NAND Flash. 5.7 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 5.8 Device Sleep (DevSleep or DEVSLP) Mode (optional) Device Sleep is a feature that allows SATA devices to enter a low power mode by designating a particular pin as DEVSLP signal with an aim to reducing power consumption. 5.9 SMART Read RefreshTM Apacer’s SMART Read Refresh plays a proactive role in avoiding read disturb errors from occurring to ensure health status of all blocks of NAND flash. Developed for read-intensive applications in particular, SMART Read Refresh is employed to make sure that during read operations, when the read operation threshold is reached, the data is refreshed by re-writing it to a different block for subsequent use. 12 © 2021 Apacer Technology Inc. 5.10 SATA Power Management By complying with SATA 6 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: 1. The behaviors of power management features would depend on host/device settings. 2. Device Sleep mode is optional, depending on product ordering selections. 13 © 2021 Apacer Technology Inc. 6. Reliability Features 6.1 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using designated pins for transmission, storage device owners are able to read temperature data. 6.2 Thermal Throttling (optional) Thermal throttling can monitor the temperature of the SSD equipped with a built-in thermal sensor via S.M.A.R.T. commands. This method can ensure the temperature of the device stays within temperature limits by drive throttling, i.e. reducing the speed of the drive when the device temperature reaches the threshold level, so as to prevent overheating, guarantee data reliability, and prolong product lifespan. When the temperature exceeds the maximum threshold level, thermal throttling will be triggered to reduce performance step by step to prevent hardware components from being damaged. Performance is only permitted to drop to the extent necessary for recovering a stable temperature to cool down the device’s temperature. Once the temperature decreases to the minimum threshold value, transfer speeds will rise back to its optimum performance level. 14 © 2021 Apacer Technology Inc. 7. Software Interface 7.1 Command Set This section defines the software requirements and the format of the commands the host sends to SS220-M242. Commands are issued to SS220-M242 by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 7-1 Command Set Code Command Code Command E5h CHECK POWER MODE F3h SECURITY ERASE PREPARE 06h DATA SET MANAGEMENT F4h SECURITY ERASE UNIT 90h EXECUTE DEVICE DIAGNOSTIC F5h SECURITY FREEZE LOCK E7h FLUSH CACHE F1h SECURITY SET PASSWORD EAh FLUSH CACHE EXT F2h SECURITY UNLOCK ECh IDENTIFY DEVICE 70h SEEK E3h IDLE EFh SET FEATURES E1h IDLE IMMEDIATE C6h SET MULTIPLE MODE 91h INITIALIZE DEVICE PARAMETERS E6h SLEEP C8h READ DMA B0h SMART 25h READ DMA EXT E2h STANDBY C4h READ MULTIPLE E0h STANDBY IMMEDIATE 29h READ MULTIPLE EXT CAh WRITE DMA 20h READ SECTOR 35h WRITE DMA EXT 24h READ SECTOR EXT C5h WRITE MULTIPLE 40h READ VERIFY SECTORS 39h WRITE MULTIPLE EXT 42h READ VERIFY SECTORS EXT 30h WRITE SECTOR 10h RECALIBRATE 34h WRITE SECTOR EXT F6h SECURITY DISABLE PASSWORD 7.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. 15 © 2021 Apacer Technology Inc. Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Table 7-2 SMART Subcommand Set Code SMART Subcommand D0h READ DATA D1h READ ATTRIBUTE THRESHOLDS D2h ENABLE/DISABLE ATTRIBUTE AUTOSAVE D4h EXECUTE OFF-LINE IMMEDIATE D5h SMART READ LOG D6h SMART WRITE LOG D8h ENABLE OPERATIONS D9h DISABLE OPERATIONS DAh RETURN STATUS Table 7-3 General SMART Attribute Structure Byte Description 0 ID (Hex) 1–2 Status Flag 3 Value 4 Worst 5*-11 Raw Data *Byte 5: LSB Table 7-4 SMART Attribute ID List ID (Hex) Attribute Name 9 (0x09) Power-on Hours 12 (0x0C) Power Cycle Count 163 (0xA3) Max. Erase Count 164 (0xA4) Avg. Erase Count 166 (0xA6) Total Later Bad Block Count 167 (0xA7) SSD Protect Mode (Vendor Specific) 168 (0xA8) SATA PHY Error Count 171 (0xAB) Program Fail Count 172 (0xAC) Erase Fail Count 175 (0xAF) Bad Cluster Table Count 192 (0xC0) Unexpected Power Loss Count 194 (0xC2) Temperature 231 (0xE7) Lifetime Left 241 (0xF1) Total Sectors of Write 16 © 2021 Apacer Technology Inc. 8. Electrical Specifications 8.1 Operating Voltage Table 8-1 lists the supply voltage for SS220-M242. Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 8-1 Operating Range Item Range Supply Voltage 3.3V ± 5% (3.135-3.465V) 8.2 Power Consumption Table 7-2 lists the power consumption for SS220-M242. Table 8-2 Power Consumption Capacity 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Active (mA) 185 210 265 210 245 260 520 Idle (mA) 80 80 75 85 85 80 75 Mode Note: *All values are typical and may vary depending on flash configurations or host system settings. **Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 17 © 2021 Apacer Technology Inc. 9. Physical Characteristics Figure 9-1 Dimensions 18 © 2021 Apacer Technology Inc. 10. Product Ordering Information 10.1 Product Code Designations AP M2 T42 SS22 xxxG XN – 6X TX X Operating Temperature Blank: Standard Temperature W: Wide Temperature Flash Type Version Control Add-On Value TN: Thermal Sensor FN: Thermal Sensor + DEVSLP Capacity 001G = 1GB 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB Solution Version Form Factor M.2 Apacer Product Code 19 © 2021 Apacer Technology Inc. 10.2 Valid Combinations 10.2.1 Without DEVSLP Capacity Standard Temperature Wide Temperature 1GB APM2T42SS22001GTN-6ET APM2T42SS22001GTN-6ETW 2GB APM2T42SS22002GTN-6ET APM2T42SS22002GTN-6ETW 4GB APM2T42SS22004GTN-6ET APM2T42SS22004GTN-6ETW 8GB APM2T42SS22008GTN-6ET APM2T42SS22008GTN-6ETW 16GB APM2T42SS22016GTN-6ET APM2T42SS22016GTN-6ETW 32GB APM2T42SS22032GTN-6ET APM2T42SS22032GTN-6ETW 64GB APM2T42SS22064GTN-6ETG APM2T42SS22064GTN-6ETGW 10.2.2 With DEVSLP (optional) Capacity Standard Temperature Wide Temperature 1GB APM2T42SS22001GFN-6FT APM2T42SS22001GFN-6FTW 2GB APM2T42SS22002GFN-6FT APM2T42SS22002GFN-6FTW 4GB APM2T42SS22004GFN-6FT APM2T42SS22004GFN-6FTW 8GB APM2T42SS22008GFN-6FT APM2T42SS22008GFN-6FTW 16GB APM2T42SS22016GFN-6FT APM2T42SS22016GFN-6FTW 32GB APM2T42SS22032GFN-6FT APM2T42SS22032GFN-6FTW 64GB APM2T42SS22064GFN-6FTG APM2T42SS22064GFN-6FTGW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 20 © 2021 Apacer Technology Inc. Revision History Revision 1.0 Description Date Official release 12/26/2019 - Added SMART Read Refresh to Flash Management on Specifications Overview page 1.1 - Changed SATA 6.0 Gbps to SATA 6 Gb/s in accordance with SATA naming guidelines 5/15/2020 - Added 5.9 SMART Read Refresh - Capitalized every letter for commands at 7.1 Command Set and SMART subcommand at 7.2 S.M.A.R.T. 1.2 Modified valid combinations at 10.2.2 With DEVSLP (optional) 5/17/2021 21 © 2021 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 6F, Daiyontamachi Bldg., 2-17-12, Shibaura, Minato-Ku, Tokyo, 108-0023, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, 1874, South End C Cross, 9th Block Jayanagar, Bangalore-560069, India Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com 22 © 2021 Apacer Technology Inc.
APM2T42SS22004GTN-6ET 价格&库存
很抱歉,暂时无法提供与“APM2T42SS22004GTN-6ET”相匹配的价格&库存,您可以联系我们找货
  • 1+3050.118651+396.37070
  • 10+2805.6505410+364.60145
  • 25+2711.7783225+352.40251
库存:3
