DD2.22260S.001
DD2.22260S.001
    APACERMEMORYAMERICA(宇瞻科技)
    模块
    存储器 - 模块 DDR4 SDRAM 16GB 模块
DD2.22260S.001 数据手册
RoHS Compliant 16GB DDR4 SDRAM XR-DIMM Halogen free / Industrial / Underfill / Coating Product Specifications September 17, 2020 Version 0.5 Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Table of Contents General Description ....................................................................................................... 2  Ordering Information ..................................................................................................... 2  Key Parameters .............................................................................................................. 2  Specifications: ................................................................................................................ 3  Features: ......................................................................................................................... 4  Pin Assignments ............................................................................................................. 5  Pin Descriptions ............................................................................................................. 8  Functional Block Diagram ............................................................................................. 9  Absolute Maximum Ratings ........................................................................................ 11  DRAM Component Operating Temperature Range..................................................... 12  Operating Conditions ................................................................................................... 13  Environmental Requirements....................................................................................... 14  Mechanical Drawing .................................................................................................... 15  ©Apacer Technology Inc. 1 General Description Apacer DD2.22260S.001 is a 2048M x 64 DDR4 SDRAM (Synchronous DRAM) XR-DIMM. This high-density memory module consists of 16 pieces 1024M x 8 bits DDR4 synchronous DRAMs in FBGA packages and a 4K Bits EEPROM. The module is a 300-pins dual in-line memory module and is intended for mounting into a connector socket. The following provides general specifications of this module. Ordering Information Part Number Bandwidth Speed Grade Max Frequency CAS Latency DD2.22260S.001 19.2 GB/sec 2400 Mbps 1200 MHz CL17 Density Organization Component Rank 16GB 2048M x 64 1024M x8*16 2 Key Parameters MT/s DDR4-1866 DDR4-2133 DDR4-2400 Grade -CL13 -CL15 -CL17 Unit tCK (min) 1.07 0.93 0.83 ns CAS latency 13 15 17 tCK tRCD (min) 13.92 14.06 14.16 ns tRP (min) 13.92 14.06 14.16 ns tRAS (min) 34 33 32 ns tRC (min) 47.92 47.05 46.16 ns CL-tRCD-tRP 13-13-13 15-15-15 17-17-17 tCK ©Apacer Technology Inc. 2 Specifications:  On-DIMM thermal sensor : Yes  Organization: 2048 words x 64 bits, 2 ranks  Integrating 16 pieces of 8G bits DDR4 SDRAM sealed FBGA  Package: eXtreme Rugged 300-pin connector type dull in-line memory module (XR-DIMM)  PCB: height 37.25 mm, lead pitch 0.50 mm (pin),  Serial Presence Detect (SPD)  Power Supply: VDD=1.2V (1.14V to 1.26V)  VDDQ = 1.2V (1.14V to 1.26V)  VPP = 2.5V (2.375V to 2.75V)  VDDSPD = 2.2V to 3.6V  16 internal banks (4 Bank Groups)  CAS Latency (CL): 13, 14, 15, 16, 17  CAS Write Latency (CWL): 12,16  Support Industrial Temp ( -40°C~95°C ) - tREFI 7.8us at -40 °C ≤ TCASE ≤ 85°C - tREFI 3.9us at 85 °C < TCASE ≤ 95°C  Lead-free (RoHS compliant)  Halogen free  With coating (CE-1170)  BGA Underfill with JC738-8  Connector : BSH-150-01-L-D-A ©Apacer Technology Inc. 3 Features:  Functionality and operations comply with the DDR4 SDRAM datasheet  Bank Grouping is applied, and CAS to CAS latency (tCCD_L, tCCD_S) for the banks in the same or different bank group accesses are available  Bi-Directional Differential Data Strobe  8 bit pre-fetch  Burst Length (BL) switch on-the-fly BL8 or BC4(Burst Chop)  Per DRAM Addressability is supported  Internal Vref DQ level generation is available  Write CRC is supported at all speed grades  DBI (Data Bus Inversion) is supported(x8)  CA parity (Command/Address Parity) mode is supported ©Apacer Technology Inc. 4 Pin Assignments Pin Pin Pin Pin Pin Pin Pin Pin No. name-Front No. name-Back No. name-Front No. name-Back 1 NC 2 NC 3 NC 4 NC 5 NC 6 NC 7 NC 8 NC 9 NC 10 NC 11 NC 12 NC 13 NC 14 NC 15 NC 16 NC 17 NC 18 NC 19 NC 20 NC 21 VSS 22 VSS 23 DQ4 24 DQ5 25 VSS 26 VSS 27 DQ0 28 DQ1 29 VSS 30 VSS 31 DM0_N/DMI0_N 32 DQS0_C 33 VSS 34 DQS0_T 35 DQ6 36 VSS 37 VSS 38 DQ7 39 DQ2 40 VSS 41 VSS 42 DQ3 43 DQ12 44 VSS 45 VSS 46 DQ13 47 DQ8 48 VSS 49 VSS 50 DQ9 51 DQS1_C 52 VSS 53 DQS1_T 54 DM1_N/DBI1_N 55 VSS 56 VSS 57 DQ14 58 DQ15 59 VSS 60 VSS 61 DQ11 62 DQ10 63 VSS 64 VSS 65 DQ20 66 DQ21 67 VSS 68 VSS 69 DQ16 70 DQ17 71 VSS 72 VSS 73 DM2_N/DBI2_N 74 DQS2_C 75 VSS 76 DQS2_t 77 DQ22 78 VSS 79 VSS 80 DQ23 81 DQ18 82 VSS 83 VSS 84 DQ19 85 DQ28 86 VSS 87 VSS 88 DQ29 89 DQ24 90 VSS 91 VSS 92 DQ25 93 DQS3_C 94 VSS 95 DQS3_T 96 DM3_N/DBI3_N 97 VSS 98 VSS 99 DQ31 100 DQ30 101 VSS 102 VSS 103 DQ27 104 DQ26 105 VSS 106 VSS 107 CB4 108 CB5 109 VSS 110 VSS 111 CB0 112 CB1 113 VSS 114 VSS 115 DM8_N/DBI8_N 116 117 VSS 118 DQS8_T ©Apacer Technology Inc. 119 5 CB6 120 DQS8_C VSS Pin Pin Pin Pin Pin Pin Pin Pin No. name-Front No. name-Back No. name-Front No. name-Back 121 VSS 122 CB2 123 CB7 124 VSS 125 VSS 126 CB3 127 RESET_N 128 VSS 129 CKE1 130 CKE0 131 VDD 132 VDD 133 ACT_N 134 BG1 135 ALERT_N 136 BG0 137 VDD 138 VDD 139 A11 140 A12 141 A7 142 A9 143 VDD 144 VDD 145 A5 146 A8 147 A4 148 A6 149 VDD 150 VDD 151 A2 152 A3 153 EVENT_N 154 A1 155 VDD 156 VDD 157 CK1_T 158 CK0_T 159 CK1_C 160 CK0_C 161 VDD 162 VDD 163 A0 164 PARITY 165 A10/AP 166 BA1 167 VDD 168 VDD 169 BA0 170 CS0_N 171 RAS_N/A16 172 WE_N/A14 173 VDD 174 VDD 175 CAS_N/A15 176 ODT0 177 A13 178 CS1_N 179 VDD 180 VDD 181 C0/CS2_N 182 ODT1 183 VREFCA 184 VDD 185 SA2 186 C1/CS3_N 187 VSS 188 VSS 189 DQ36 190 DQ37 191 VSS 192 VSS 193 DQ32 194 DQ33 195 VSS 196 VSS DQS4_C 199 VSS 200 DQS4_T 197 DM4_N/DBI4_N 198 201 DQ39 202 VSS 203 VSS 204 DQ38 205 DQ35 206 VSS 207 VSS 208 DQ34 209 DQ45 210 VSS 211 VSS 212 DQ44 213 DQ41 214 VSS 215 VSS 216 DQ40 217 DQS5_C 218 VSS 219 DQS5_T 221 VSS 222 VSS 223 DQ47 224 DQ46 225 VSS 226 VSS 227 DQ43 228 DQ42 229 VSS 230 VSS 231 DQ53 232 DQ52 233 VSS 234 VSS 235 DQ48 236 DQ49 237 VSS 238 VSS 239 DM6_N/DBI6_N 240 241 VSS 242 DQS6_T 243 DQ54 244 VSS 245 VSS 246 DQ55 247 DQ50 248 VSS 249 VSS 250 DQ51 251 DQ60 252 VSS ©Apacer Technology Inc. 6 220 DM5_N/DBI5_N DQS6_C Pin Pin Pin Pin Pin Pin Pin Pin No. name-Front No. name-Back No. name-Front No. name-Back 253 VSS 254 DQ61 255 DQ57 256 VSS 257 VSS 258 DQ56 259 DQS7_C 260 VSS 261 DQS7_T 262 DM7_N/DBI7_N 263 VSS 264 VSS 265 DQ63 266 DQ62 267 VSS 268 VSS 269 DQ59 270 DQ58 271 VSS 272 VSS 273 SDA 274 SCL 275 SA0 276 VDDSPD 277 VTT 278 VPP 279 SA1 280 VPP 281 NC 282 NC 283 NC 284 NC 285 NC 286 NC 287 NC 288 NC 289 NC 290 NC 291 NC 292 NC 293 NC 294 NC 295 NC 296 NC 297 NC 298 NC 299 NC 300 NC *IC Component Composition : ©Apacer Technology Inc. 256Mx8 512Mx8 1024Mx8 2048Mx8 A0~A13 A0~A14, A0~A15, A0~A16, 512Mx4 1024Mx4 2048Mx4 7 A0~A14 A0~A15 A0~A16 Pin Descriptions Pin Name Ax 1* Description SDRAM address bus BAx SDRAM bank select BGx SDRAM bank group select RAS_n 2* SDRAM row address strobe CAS_n 3* SDRAM column address strobe 4* SDRAM write enable WE_n CSx_n DIMM Rank Select Lines CKEx SDRAM clock enable lines ODTx SDRAM on-die termination control lines ACT_n SDRAM input for activate input DQx DIMM memory data bus CBx DIMM ECC check bits TDQSx_t ; TDQSx_c Dummy loads for mixed populations of x4 based and x8 based RDIMMs. Not used on UDIMMs DQSx_t Data Buffer data strobes (positive line of differential pair) DQSx_c Data Buffer data strobes (negative line of differential pair) DMx_n, DBIx_n SDRAM data masks/data bus inversion(x8-based x72 DIMMs) CKx_t SDRAM clock input (positive line of differential pair) CKx_c SDRAM clocks input (negative line of differential pair) 2 SCL I C serial bus clock for SPD-TSE and register SDA I C serial bus data line for SPD-TSE and register SAx I C slave address select for SPD-TSE and register PARITY 2 2 SDRAM parity input VDD SDRAM core power supply 12 V Optional Power Supply on socket but not used on DIMM VREFCA VSS SDRAM command/address reference supply Power supply return (ground) VDDSPD Serial SPD-TSE positive power supply ALERT_n SDRAM ALERT_n output VPP SDRAM Supply RESET_n Set Register and SDRAMs to a Known State EVENT_n SPD signals a thermal event has occurred VTT SDRAM I/O termination supply RFU Reserved for future use *Notes: 1. Address A17 is only valid for 16 Gb x4 based SDRAMs. For UDIMMs this connection pin is NC. 2. RAS_n is a multiplexed function with A16. 3. CAS_n is a multiplexed function with A15. 4. WE_n is a multiplexed function with A14. ©Apacer Technology Inc. 8 Functional Block Diagram Part 1 of 2 ©Apacer Technology Inc. 9 Part 2 of 2 ©Apacer Technology Inc. 10 Absolute Maximum Ratings Parameter Symbol Description Units Notes Voltage on VDD pin relative to Vss VDD - 0.3 V ~ 1.5 V V 1,2 Voltage on VDDQ pin relative to Vss VDDQ - 0.3 V ~ 1.5 V V 1,2 Voltage on VPP pin relative to Vss VPP - 0.3 V ~ 3.0 V V 3 Voltage on any pin relative to Vss VIN, VOUT - 0.3 V ~ 1.5 V V 1,2 Notes: 1. Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. 2. VDD and VDDQ must be within 300 mV of each other at all times; and VREFCA must be not greater than 0.6 x VDDQ, When VDD and VDDQ are less than 500 mV; VREF may be equal to or less than 300 mV 3. VPP must be equal or greater than VDD/VDDQ at all times  ©Apacer Technology Inc. 11 DRAM Component Operating Temperature Range Symbol TOPER Parameter Operating Temperature Range Rating Units Notes -40 to 95 ℃ 1,2 Notes: 1. Operating Temperature TOPER is the case surface temperature on the center/top side of the DRAM. For measurement conditions, please refer to the JEDEC document JESD51-2. 2. The Normal Temperature Range specifies the temperatures where all DRAM specifications will be supported. During operation, the DRAM case temperature must be maintained between -40°C~95°C under all operating conditions. Industrial Temperature: The industrial temperature device requires that the case temperature not exceed –40°C or +95°C. JEDEC specifications require the refresh rate to double when TC exceeds+85°C; this also requires use of the high-temperature self refresh option.  MAX operating case temperature. TC is measured in the center of the package.  A thermal solution must be designed to ensure the DRAM device does not exceed the maximum TC during operation.  Device functionality is not guaranteed if the DRAM device exceeds the maximum TC during operation.  If TC exceeds +85°C, the DRAM must be refreshed externally at 2X refresh, which is a 3.9µs interval refresh rate. ©Apacer Technology Inc. 12 Operating Conditions Recommended DC Operating Conditions – DDR4 (1.2V) operation Rating Symbol VDD Parameter Supply Voltage VDDQ Supply Voltage for Output VPP Activation Supply Voltage Units Notes 1.26 V 1,2,3 1.2 1.26 V 1,2,3 2.5 2.75 V 3 Min. Typ. Max. 1.14 1.2 1.14 2.375 Notes: 1. Under all conditions VDDQ must be less than or equal to VDD.. 2. VDDQ tracks with VDD. AC parameters are measured with VDD and VDDQ tied together. 3. DC bandwidth is limited to 20MHz. ©Apacer Technology Inc. 13 Environmental Requirements Symbol Parameter Rating Units Notes HOPR Operating Humidity (relative) 10 to 90 % TSTG Storage Temperature -50 to +100 °C 1 HSTG Storage Humidity (without condensation) 5 to 95 % 1 PBAR Barometric Pressure (operating & storage) 105 to 69 kPa 1,2 Notes: 1. Stresses greater than those listed may cause permanent damage to the device. This is a stress rating only. and device functional operation at or above the conditions indicated is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. 2. Up to 9850 ft. ©Apacer Technology Inc. 14 Mechanical Drawing Connector on Memory Module (BSH-150-01-L-D-A) ©Apacer Technology Inc. 15 Revision History Revision Date Description Remark 0.1 5/5/2014 Initial release 0.2 11/2/2015 Updated VDDSPD 0.3 03/15/2017 Add Environmental Requirements 0.4 09/04/2017 Remove TOPR (Operating Temperature (ambient)) 0.5 07/23/2020 Updated DRAM Component Operating Temperature Range ©Apacer Technology Inc. 16 Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd. Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD , Shanghai , 200051, China Tel: 86-21-6228-9939 Fax:86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd. 1874, South End C Cross,9th Block Jayanagar, Bangalore-560069,INDIA. Tel: 91-80-4152-9061/62 Fax: 91-80-4170-0215 sales_india@apacer.com ©Apacer Technology Inc. 17
DD2.22260S.001 价格&库存
很抱歉,暂时无法提供与“DD2.22260S.001”相匹配的价格&库存,您可以联系我们找货
