AP-FD18C22B0128GS-WC
    APACERMEMORYAMERICA(宇瞻科技)
    PATA 1.8" FLASH DRIVE SLC EXTEND
AP-FD18C22B0128GS-WC 数据手册
RoHS Compliant ATA Flash Drive 187 Specifications January 21, 2015 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX Features:  Standard ATA/IDE bus interface – ATA command set compatible – ATA operating mode supports up to: PIO Mode-4 Multiword DMA Mode-2 Ultra DMA Mode-6  Connector type – 40-pin ZIF  Power consumption (typical)* – Supply voltage: 3.3V – Active mode: 375 mA – Idle mode: 30 mA  Performance* – Sustained read: Up to 100 MB/sec – Sustained write: Up to 95 MB/sec  Capacity – 4, 8, 16, 32, 64, 128 GB  NAND Flash Type: SLC  Temperature ranges – Operation: 0°C to 70°C – Extended: -40°C to 85°C – Storage: -40°C to 100°C  Flash management – Intelligent endurance design Advanced wear-leveling algorithms S.M.A.R.T. Built-in Hardware ECC: 72bit/1KB – Power failure management – Enhanced security level ATA Secure Erase  Supports synchronous flash interface  RoHS compliant  MTBF > 2,000,000 hours *The values presented in Performance and Power consumption are typical and may vary depending on various settings and platforms. 1 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX Table of Contents 1. General Description .............................................................................. 3 2. Functional Block ................................................................................... 3 3. Pin Assignments .................................................................................... 4 4. Product Specification ........................................................................... 5 4.1 Capacity ............................................................................................................................................... 5 4.2 Performance Specifications ................................................................................................................. 5 4.3 Environmental Specifications .............................................................................................................. 5 5. Flash Management ................................................................................ 6 5.1 Intelligent Endurance Design .............................................................................................................. 6 5.1.1 Advanced wear-leveling algorithms .............................................................................................. 6 5.1.2 S.M.A.R.T. .................................................................................................................................... 6 5.1.3 Built-in Hardware ECC .................................................................................................................. 6 5.1.4 Flash Block Management ............................................................................................................. 6 5.2 Power Failure Management ................................................................................................................ 7 5.3 Enhanced Security Level ..................................................................................................................... 7 5.3.1 ATA Secure Erase ........................................................................................................................ 7 6. Software Interface ................................................................................ 8 6.1 Command Set ...................................................................................................................................... 8 7. Electrical Specification ........................................................................ 9 8. Physical Characteristics ..................................................................... 10 9. Product Ordering Information ............................................................. 11 9.1 Product Code Designations ............................................................................................................... 11 9.2 Valid Combinations ............................................................................................................................ 12 9.2.1 STD Temp................................................................................................................................... 12 9.2.2 Extended Temp........................................................................................................................... 12 2 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 1. General Description Apacer’s ATA-Flash Drive (AFD) is a high-performance, solid state drive (SSD) designed to replace a conventional IDE hard disk drive. AFD supports standard ATA/IDE protocol and can be plugged into a standard IDE connector commonly found in desktop or portable PCs. It is more rugged, reliable and power-efficient compared to the mechanical hard drive and is designed for use in rugged laptops, military devices, thin clients, Point of Sale (POS) terminals, telecom, medical instruments, surveillance systems and industrials PCs. Apacer AFD Series is the best instant replacement for high-maintenance HDD where reliability is a major concern. AFD includes a built-in microcontroller and file management firmware that communicates through with the ATA standard interfaces. AFD is designed to work at 3.3 Volts, support the standard ATA/IDE protocol up to PIO Mode-4, Multiword DMA Mode-2, and Ultra DMA Mode-6 interfaces, and use a standard ATA driver that fits to most of the mainstream operating systems. Featuring technologies as Advanced Wear-leveling algorithms, S.M.A.R.T, Power Failure Management, and ATA Secure Erase, the AFD device assures users of security in storage applications. 2. Functional Block The ATA-Flash Drive (AFD) includes the ATA controller and flash media, as well as the ATA standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1 Functional block diagram 3 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 3. Pin Assignments Table 3-1 Pin assignments Pin # SIGNALS Pin # SIGNALS 1 Reserved 21 GROUND 2 Reserved 22 DMARQ 3 RESET# 23 GROUND 4 GROUND 24 DIOW# 5 DD 7 25 DIOR# 6 DD 8 26 GROUND 7 DD 6 27 IORDY 8 DD 9 28 GROUND 9 DD 5 29 DMACK# 10 DD 10 30 INTRQ 11 DD 4 31 A1 12 DD 11 32 PDIAG# 13 DD 3 33 A0 14 DD 12 34 A2 15 DD 2 35 CS0# 16 DD 13 36 CS1# 17 DD 1 37 DASP# 18 DD 14 38 3.3V 19 DD 0 39 3.3V 20 DD 15 40* CSEL *The pin is set as “Master”. 4 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 4. Product Specification 4.1 Capacity Capacity specification of the ATA-Flash Drive (AFD) lists out unformatted, out-of-box capacity information. Table 4-1 AFD capacity specifications Capacity Total bytes* Cylinders** Heads Sectors Max LBA 4GB 4,011,614,208 7773 16 63 7,835,184 8 GB 8,012,390,400 15525 16 63 15,649,200 16 GB 16,013,942,784 16383 16 63 31,277,232 32 GB 32,017,047,552 16383 16 63 62,533,296 64 GB 64,023,257,088 16383 16 63 125,045,424 128 GB 128,035,676,160 16383 16 63 250,069,680 *Display of total bytes varies from file systems. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Specifications Performance of the ATA-Flash Drive is listed in Table 4-2. Table 4-2 Performance specifications Capacity 4 GB 8 GB 16 GB 32 GB 64 GB 128 GB Sustained read (MB/s) 100 100 100 100 100 100 Sustained write (MB/s) 45 85 90 95 95 95 Performance Note: Performance varies from flash configurations or host system configurations 4.3 Environmental Specifications Environmental specification of the ATA-Flash Drive follows the standards of MIL-STD-810F. Table 4-3 Environmental specifications Item Criteria Non-Operating Temperature -40°C ~100°C Operating Temperature 0°C to 70°C (Standard); -40°C to 85°C (Extended) Vibration* Sine wave: 15(G), 10~2000(Hz); X, Y, Z axis Shock* 1500(G), 0.5(ms), ±X, ±Y, ±Z axis *Non-operating 5 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 5. Flash Management 5.1 Intelligent Endurance Design 5.1.1 Advanced wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. On the other hand, NAND flash storage adopt flash as their primary media. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term earlier. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 5.1.2 S.M.A.R.T. S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and attributes parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our SMART feature that complies with the ATA/ATAPI-7 specifications. Based on the SFF-8035i Rev. 2.0 specifications, SMART Attribute IDs shall include Initial bad block count, Bad block count, Spare block count, Maximum erase count, Average erase count and Power cycle. When the SMART Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. 5.1.3 Built-in Hardware ECC The properties of NAND flash memory make it ideal for applications that require high integrity while operating in challenging environments. The integrity of data to NAND flash memory is generally maintained through ECC algorithms. This ATA-Flash Drive is programmed with a hardware ECC engine which correct up to 72 bits per 1KB. 5.1.4 Flash Block Management Contemporary process technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a highly minimal number of initial bad block during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. On the other hand, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 6 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 5.2 Power Failure Management Power Failure Management ensures data transmission when experiencing unstable power supply. When power disruption takes places, NAND Flash will have to cache multiple write-to-flash cycles to securely store data. This urgent operation requires about several milliseconds to get it done. When the supplied voltage is below a certain percentage of the required, the flash controller will be signaled by a detector IC component with low power detection signal and then the firmware will communicate the controller to flush all the data into the cache of Flash storage area. This can prevent incomplete data transmission. The crucial part lies in the strength of the capacitor of the SSD. The capacitor must be able to hold up some milliseconds of remaining time before the power is totally out, for the urgent write-back-into-flash operations to complete. 5.3 Enhanced Security Level 5.3.1 ATA Secure Erase Accomplished by the Secure Erase (SE) command, which added to the open ANSI standards that control disk drives, “ATA Secure Erase” is built into the disk drive itself and thus far less susceptible to malicious software attacks than external software utilities. It is a positive easy-to-use data destroy command, amounting to electronic data shredding. Executing the command causes a drive to internally completely erase all possible user data. This command is carried out within disk drives, so no additional software is required. Once executed, neither data nor the erase counter on the device would be recoverable, which blurs the accuracy of device lifespan. The process to erase will not be stopped until finished while encountering power failure, and will be continued when power is back on. 7 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 6. Software Interface 6.1 Command Set This section defines the software requirements and the format of the commands the host sends to the ATA-Flash Drive (AFD). Commands are issued to the AFD by loading the required registers in the command block with the supplied parameters, and then writing the command code to the command register. The manner in which a command is accepted varies. Table 6-1 Command set Code Command Code Command E5h Check Power Mode F6h Security Disable Password 92h Download Microcode F3h Security Erase Prepare 90h Execute Device Diagnostic F4h Security Erase Unit E7h Flush Cache F5h Security Freeze Lock EAh Flush Cache EXT F1h Security Set Password ECh Identify Device F2h Security Unlock A1h Identify Packet Device 70h Seek E3h Idle EFh Set Features E1h Idle Immediate F9h Set Max* 91h Initialize Device Parameters 91h Set Max Address EXT 00h NOP C6h Set Multiple Mode E4h Read Buffer E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT E8h Write Buffer F8h Read Native Max Address CAh Write DMA 27h Read Native Max Address EXT 35h Write DMA EXT 20h Read Sector C5h Write Multiple 24h Read Sector EXT 39h Write Multiple EXT 40h Read Verify Sectors 30h Write Sector 42h Read Verify Sectors EXT 34h Write Sector EXT 10h Recalibrate *The command can be configured as “Set Max Lock”, “Set Max Address”, “Set Max Set Password”, “Set Max Unlock” and “Set Max Freeze Lock”, depending on the transfer mode in operation. 8 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 7. Electrical Specification Table 7-1 Operating voltage & operating temperature Ambient Temperature 0°C to 70°C (standard) -40°C to 85°C (extended) Power supply 3.135 ~ 3.465V Table 7-2 Power consumption Capacity 4 GB 8 GB 16 GB 32 GB 64 GB 128 GB Active (mA) 250 265 335 375 305 340 Idle (mA) 15 15 15 17 30 30 Modes Note: Power consumption varies from flash configurations or host system configurations 9 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 8. Physical Characteristics Unit: ㎜ Tolerance: ± 0.2 Specifications Width: 20.50 ± 0.05 ㎜ Recommended Host Side FPC Thickness: 0.30 ± 0.05 ㎜ Contact resistance: Typical 50ohm Recommended plating: Gold over Nickel plating Recommended adhesive: heat-hardened adhesive 10 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 9. Product Ordering Information 9.1 Product Code Designations AP – FD18 C 2 2 B xxxxx S – X X X Flash Type FW Version Temperature: Blank: Standard W: Wide Temp. Environmental Specification S: RoHS + Halogen free Compliant Capacity: 0004G: 4GB 0008G: 8GB 0016G: 16GB 0032G: 32GB 0064G: 64GB 0128G: 128GB Product Type B=1.8 inches/180D PCB Version Outline 180D Degree Controller version 1.8 inch ATA Flash Drive Apacer Product Code 11 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX 9.2 Valid Combinations 9.2.1 STD Temp. Capacity Model Number 4GB AP-FD18C22B0004GS-T 8GB AP-FD18C22B0008GS-T 16GB AP-FD18C22B0016GS-T 32GB AP-FD18C22B0032GS-T 64GB AP-FD18C22B0064GS-C 128GB AP-FD18C22B0128GS-C 9.2.2 Extended Temp Capacity Model Number 4GB AP-FD18C22B0004GS-WT 8GB AP-FD18C22B0008GS-WT 16GB AP-FD18C22B0016GS-WT 32GB AP-FD18C22B0032GS-WT 64GB AP-FD18C22B0064GS-WC 128GB AP-FD18C22B0128GS-WC Note: Please consult with Apacer sales representatives for availabilities. 12 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX Revision History Revision Date Description Remark 0.1 07/10/2012 Preliminary release 1.0 09/04/2012 Official release 1.1 1/21/2015 Updated physical specifications 13 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Flash Drive 187 AP-FD18C22BxxxxxS-XXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 14 © 2015 Apacer Technology Inc. Rev. 1.1
AP-FD18C22B0128GS-WC 价格&库存
很抱歉,暂时无法提供与“AP-FD18C22B0128GS-WC”相匹配的价格&库存,您可以联系我们找货
