APS25AFB256G-4BTM1GT
    APACERMEMORYAMERICA(宇瞻科技)
    SSD 2.5" SATA 15NM MLC 256GB
APS25AFB256G-4BTM1GT 数据手册
RoHS Compliant Serial ATA Flash Drive SM210-25 Product Specifications November 7, 2017 Version 1.9 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 Features:   Compliance with SATA Revision 3.1 – SATA 6.0 Gbps interface – Backward compatible with SATA 1.5 and 3.0 Gbps interfaces – ATA-8 command set   Temperature Range – Extended: -40°C to 85°C  16, 32, 64, 128, 256, 512 GB Performance* Burst read/write: 600 MB/sec – Sequential read: Up to 510 MB/sec – Sequential write: Up to 470 MB/sec – Random read (4K): Up to 83,000 IOPS – Random write (4K): Up to 79,000 IOPS  Flash Management  Storage: -40°C to 100°C Supply Voltage –  – Operating: Standard: 0°C to 70°C – Capacity –  5.0 V ± 5% Power Consumption* – Active mode: 680 mA – Idle mode: 75 mA Connector Type – 7-pin SATA signal connector – 15-pin SATA power connector Form Factor – Built-in hardware ECC – Global Wear Leveling – 2.5” – Flash bad-block management – – S.M.A.R.T. Dimensions with 7mm enclosure: 100.00 x 69.85 x 6.90, unit: mm – Power Failure Management – Dimensions with 9.5mm enclosure: 100.00 x 69.84 x 9.30, unit: mm – ATA Secure Erase – TRIM   NAND Flash Type: MLC  MTBF: >1,000,000 hours  Endurance (in Terabytes Written: TBW) Shock & Vibration** – Shock:1,500 G – Vibration: 15 G  DRAM Cache for Enhanced Random Performance – 16 GB: 35 TBW  SATA Power Management Modes – 32 GB: 71 TBW  Thermal Sensor – 64 GB: 142 TBW – 128 GB: 285 TBW  Device Sleep – 256 GB: 571 TBW  RoHS Compliant – 512 GB: 1,142 TBW *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. **Non-operating 1 © 2017 Apacer Technology Inc. Table of Contents 1. General Descriptions ........................................................................3 1.1 Introduction .................................................................................................................................... 3 1.2 Capacity ......................................................................................................................................... 3 1.3 Performance .................................................................................................................................. 3 1.4 Pin Assignments ............................................................................................................................ 4 2. Software Interface ............................................................................6 2.1 Command Set ................................................................................................................................ 6 2.2 S.M.A.R.T. ..................................................................................................................................... 6 3. Flash Management ............................................................................8 3.1 Error Correction/Detection ............................................................................................................. 8 3.2 Bad Block Management ................................................................................................................ 8 3.3 Global Wear Leveling .................................................................................................................... 8 3.4 Power Failure Management .......................................................................................................... 8 3.5 ATA Secure Erase ......................................................................................................................... 8 3.6 TRIM .............................................................................................................................................. 9 3.7 Thermal Sensor ............................................................................................................................. 9 3.8 DEVSLP (DevSleep or DEVSLP) Mode ........................................................................................ 9 3.9 SATA Power Management .......................................................................................................... 10 4. Reliability Specifications ............................................................... 11 4.1 Environmental .............................................................................................................................. 11 4.2 Mean Time Between Failures (MTBF) ........................................................................................ 11 4.3 Certification and Compliance ...................................................................................................... 11 4.4 Endurance ................................................................................................................................... 12 5. Electrical Specifications ............................................................... 13 5.1 Operating Voltage........................................................................................................................ 13 5.2 Power Consumption .................................................................................................................... 13 6. Physical Characteristics ................................................................ 14 6.1 7mm Type Dimensions ................................................................................................................ 14 7. Product Ordering Information ........................................................ 16 7.1 Product Code Designations ......................................................................................................... 16 7.2 Valid Combinations ...................................................................................................................... 17 2 © 2017 Apacer Technology Inc. 1. General Descriptions 1.1 Introduction Apacer’s SM210-25 is a well-balanced solid-state disk (SSD) drive with standard form factor and great performance. Designed in SATA 6.0 Gbps interface, the SSD is able to deliver exceptional read/write speed, making it the ideal companion for heavy-loading industrial or server operations. For data efficiency, the internal controlling unit of the SSD is engineered with DRAM for enhanced random performance. In regard of reliability, the drive comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling, flash block management, S.M.A.R.T., TRIM, and power failure management. 1.2 Capacity Capacity specifications of SM210-25 are available as shown in Table 1-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 1-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 256 GB 256,060,514,304 16,383 16 63 500,118,192 512 GB 512,110,190,592 16,383 16 63 1,000,215,216 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 1.3 Performance Performance of SM210-25 is listed below in Table 1-2. Table 1-2 Performance Specifications Capacity 16 GB 32 GB 64 GB 128 GB 256 GB 512 GB Sequential Read* (MB/s) 215 380 510 510 510 490 Sequential Write* (MB/s) 47 100 205 380 350 470 Random Read IOPS** (4K) 26,000 48,000 78,000 81,000 83,000 56,000 Random Write IOPS** (4K) 8,000 24,000 49,000 79,000 79,000 29,000 Performance Note: Results may differ from various flash configurations or host system setting. *Sequential performance is based on CrystalDiskMark 5.2.1 with file size 1,000MB. **Random performance measured using IOMeter with Queue Depth 32. 3 © 2017 Apacer Technology Inc. 1.4 Pin Assignments Table 1-3 describes the SFD signal segment, and Table1-4, power segment. Figure 1-1 SATA Connectors Table 1-3 Signal Segment Pin Type S1 GND Description Table 1-4 Power Segment Pin Signal/Description P1 Unused (3.3V) S2 RxP + Differential Receive Signal P2 Unused (3.3V) S3 RxN - Differential Receive Signal P3 Device Sleep S4 GND P4 Ground S5 TxN - Differential Transmit Signal P5 Ground S6 TxP + Differential Transmit Signal P6 Ground S7 GND P7 5V P8 5V P9 5V P10 Ground P11 DAS P12 Ground P13 Unused (12V) P14 Unused (12V) P15 Unused (12V) 4 © 2017 Apacer Technology Inc. Figure 1-2 SATA Cable/Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable. The connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2017 Apacer Technology Inc. 2. Software Interface 2.1 Command Set Table 2-1 summarizes the ATA commands supported by SM210-25. Table 2-1 Command Set Code Command Code Command E5h Check Power Mode F6h Security Disable Password 90h Execute Diagnostics F3h Security Erase Prepare E7h Flush Cache F4h Security Erase Unit ECh Identify Device F5h Security Freeze Lock E3h Idle F1h Security Set Password E1h Idle Immediate F2h Security Unlock 91h Initialize Device Parameters 7Xh Seek C8h Read DMA EFh Set Features 25h Read DMA EXT C6h Set Multiple Mode 60h Read FPDMA Queued E6h Sleep 47h Read Log DMA EXT B0h S.M.A.R.T. 2Fh Read Log EXT E2h Standby C4h Read Multiple E0h Standby Immediate 20 or 21h Read Sector(s) CAh Write DMA 40 or 41h Read Verify Sector(s) 35h Write DMA EXT 10h Recalibrate 61h Write FPDMA Queued 57h Write Log DMA EXT 3Fh Write Log EXT C5h Write Multiple 30h or 31h Write Sector(s) 2.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a selfmonitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. 6 © 2017 Apacer Technology Inc. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code SMART Subcommand D0h READ DATA D1h READ ATTRIBUTE THRESHOLDS D2h Enable/Disable Attribute Autosave D4h Execute Off-line Immediate D5h Read Log (optional) D6h Write Log (optional) D8h Enable Operations D9h Disable operations DAh Return Status Byte General SMART attribute structure Description 0 ID (Hex) 1–2 Status flag 3 Value 4 Worst 5*-11 Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 7 © 2017 Apacer Technology Inc. 3. Flash Management 3.1 Error Correction/Detection SM210-25 implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 3.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 3.3 Global Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Global wear leveling is an important mechanism that levels out the wearing of all blocks so that the wearing-down of all blocks can be almost evenly distributed. This will increase the lifespan of SSDs. 3.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 3.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2017 Apacer Technology Inc. 3.6 TRIM TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives (SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid data, mostly because of the erase commands from host. The invalid will be discarded permanently and the SSD will retain more space for itself. 3.7 Thermal Sensor Apacer Thermal Sensor is a digital temperature sensor with serial interface. By using designated pins for transmission, storage device owners are able to read temperature data. 3.8 DEVSLP (DevSleep or DEVSLP) Mode Device Sleep is a feature that allows SATA devices to enter a low power mode by designating pin 44 as DEVSLP signal with an aim to reducing power consumption. 9 © 2017 Apacer Technology Inc. 3.9 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  AUTO-SLUMBER: Automatic transition from partial to slumber.  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: The behaviors of power management features would depend on host/device settings. 10 © 2017 Apacer Technology Inc. 4. Reliability Specifications 4.1 Environmental Environmental specifications of SM210-25 product are shown in Table 4-1. Table 4-1 Environmental Specifications Environment Temperature Vibration Shock Specifications 0°C to 70°C (Standard); -40°C to 85°C (Extended) -40°C to 100°C (Non-operating) Non-operating: Sine wave, 15(G), 10~2000(Hz), Operating: Random, 7.69(Grms), 20~2000(Hz) Non-operating: Acceleration, 1,500 G, 0.5 ms Operating: Peak acceleration, 50 G, 11 ms 4.2 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SM210-25. The prediction result for SM210-25 is more than 1,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR332, Issue 2” method. 4.3 Certification and Compliance SM210-25 complies with the following standards:     CE FCC RoHS MIL-STD-810G 11 © 2017 Apacer Technology Inc. 4.4 Endurance The endurance of a storage device is predicted by TeraBytes Written based on several factors related to usage, such as the amount of data written into the drive, block management conditions, and daily workload for the drive. Thus, key factors, such as Write Amplifications and the number of P/E cycles, can influence the lifespan of the drive. Table 4-2 Endurance Specifications Capacity TeraBytes Written 16 GB 35 32 GB 71 64 GB 142 128 GB 285 256 GB 571 512 GB 1,142 Note:  The measurement assumes the data written to the SSD for test is under a typical and constant rate.  The measurement follows the standard metric: 1 TB (Terabyte) = 1,000 GB.  The estimated values are based on JEDEC Enterprise endurance workload comprised of random data with the payload size distribution with sequential write behavior. 12 © 2017 Apacer Technology Inc. 5. Electrical Specifications 5.1 Operating Voltage Table 5-1 lists the supply voltage for SM210-25. Table 5-1 Operating Range Item Range Supply Voltage 5V ± 5% (4.75-5.25V) 5.2 Power Consumption Table 5-2 lists the power consumption for SM210-25. Table 5-2 Power Consumption Capacity 16 GB 32 GB 64 GB 128 GB 256 GB 512 GB Active (mA) 210 240 300 470 680 635 Idle (mA) 75 50 50 50 50 60 Mode Note: *All values are typical and may vary depending on flash configurations or host system settings. **Active power is an average power measurement performed using CrystalDiskMark with 128KB sequential read/write transfers. 13 © 2017 Apacer Technology Inc. 6. Physical Characteristics 6.1 7mm Type Dimensions Unit: ㎜ Tolerance: ± 0.2 Figure 6-1 7mm Housing Physical Dimensions 14 © 2017 Apacer Technology Inc. 6.2 9.5mm Type Dimensions Unit: ㎜ Tolerance: ± 0.2 Figure 6-2 9.5mm Housing Physical Dimensions 15 © 2017 Apacer Technology Inc. 7. Product Ordering Information 7.1 Product Code Designations AP S 25A X X xxxG – 4B TM1X X T Feature T: Thermal Sensor Operating Temperature Blank: 0°C ~ 70°C W: -40°C ~ 85°C Flash Type Version Control Capacity 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB 512G = 512GB Housing Type B= 9.5mm 7= 7mm Solution Version 2.5 inch Form Factor Serial ATA Flash Drive Apacer Product Code 16 © 2017 Apacer Technology Inc. 7.2 Valid Combinations 7.2.1 9.5mm Metal Housing Capacity Standard Temperature Extended Temperature 16GB APS25AFB016G-4BTM1T APS25AFB016G-4BTM1WT 32GB APS25AFB032G-4BTM1GT APS25AFB032G-4BTM1GWT 64GB APS25AFB064G-4BTM1GT APS25AFB064G-4BTM1GWT 128GB APS25AFB128G-4BTM1GT APS25AFB128G-4BTM1GWT 256GB APS25AFB256G-4BTM1GT APS25AFB256G-4BTM1GWT 512GB APS25AFB512G-4BTM1GT APS25AFB512G-4BTM1GWT 7.2.2 7mm Plastic Housing Capacity Standard Temperature Extended Temperature 16GB APS25AF7016G-4BTM1T APS25AF7016G-4BTM1WT 32GB APS25AF7032G-4BTM1GT APS25AF7032G-4BTM1GWT 64GB APS25AF7064G-4BTM1GT APS25AF7064G-4BTM1GWT 128GB APS25AF7128G-4BTM1GT APS25AF7128G-4BTM1GWT 256GB APS25AF7256G-4BTM1GT APS25AF7256G-4BTM1GWT 512GB APS25AF7512G-4BTM1GT APS25AF7512G-4BTM1GWT Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 17 © 2017 Apacer Technology Inc. Revision History Revision 1.0 Description Official release Date 6/13/2016 - Added thermal sensor support 1.1 - Removed models with no DEVSLP support 7/25/2016 - Revised product ordering information 1.2 - Added 32-256GB support - Revised product ordering information 9/26/2016 1.3 Revised product ordering information 10/6/2016 1.4 Updated performance values for 32-256GB 11/10/2016 1.5 Updated endurance ratings 1/24/2017 1.6 1.7 - Added 16GB support - Updated product ordering information - Updated 512GB performance - Updated product ordering information 2/13/2017 3/24/2017 1.8 Updated performance and power consumption for 16GB 4/11/2017 1.9 Removed altitude spec from 4.1 Environmental 11/7/2017 18 © 2017 Apacer Technology Inc. Global Presence Taiwan (Headquarters) U.S.A. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Europe Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-290-0686 sales@apacer.nl China India Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 19 © 2017 Apacer Technology Inc.
APS25AFB256G-4BTM1GT 价格&库存
很抱歉,暂时无法提供与“APS25AFB256G-4BTM1GT”相匹配的价格&库存,您可以联系我们找货
