APM2T80SM21032GAS-3BTMG
    APACERMEMORYAMERICA(宇瞻科技)
    M.2 SM210-M280 MLC DEVSLP 32GB S
APM2T80SM21032GAS-3BTMG 数据手册
RoHS Recast Compliant Serial ATA Flash Drive SM210-M280 Single-Side Product Specifications March 7, 2016 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX Features:  Standard SATA Interface Compliance – Serial ATA Revision 3.2 compliance – SATA 6.0 Gbps interface – ATA-8 command set  Capacity – 32, 64, 128, 256 GB   Performance* – Burst read/write: 600 MB/sec – Sustained read: up to 505 MB/sec – Sustained write: up to 350 MB/sec – Random read (4K): up to 82,000 IOPS – Random write (4K): up to 79,000 IOPS Flash Management – Built-in hardware ECC – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power failure management – ATA secure erase – TRIM  NAND Flash Type: MLC  MTBF: >1,000,000 hours  Temperature Range – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C  Supply Voltage – 3.3 V ± 5%  Power Consumption* – Active mode: 745 mA – Idle mode: 75 mA  Connector Type – 75-pin SATA-based M.2 module pinout  Form Factor – M.2 2280 form factor – Dimensions: 80.00x22.00x2.15, unit: ㎜  Shock & Vibration** – Shock:1,500 G – Vibration: 15 G  RoHS Recast Compliant (complies with 2011/65/EU standard)  DEVSLP (optional) *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX Table of Contents 1. General Description .............................................................................. 3 2. Pin Assignments .................................................................................... 4 3. Product Specifications.......................................................................... 6 3.1 Capacity ............................................................................................................................................... 6 3.2 Performance ........................................................................................................................................ 6 3.3 Environmental Specifications .............................................................................................................. 7 3.4 Mean Time Between Failures (MTBF) ................................................................................................ 7 3.5 Certification and Compliance .............................................................................................................. 7 4. Flash Management ................................................................................ 8 4.1 Error Correction/Detection ................................................................................................................... 8 4.2 Bad Block Management ...................................................................................................................... 8 4.3 Wear Leveling ...................................................................................................................................... 8 4.4 Power Failure Management ................................................................................................................ 8 4.5 ATA Secure Erase ............................................................................................................................... 8 4.6 TRIM .................................................................................................................................................... 9 4.7 SATA Power Management .................................................................................................................. 9 5. Software Interface .............................................................................. 10 5.1 Command Set .................................................................................................................................... 10 5.2 S.M.A.R.T. ......................................................................................................................................... 11 6. Electrical Specifications .................................................................... 12 7. Physical Characteristics ..................................................................... 13 8. Product Ordering Information ............................................................. 14 8.1 Product Code Designations ............................................................................................................... 14 8.2 Valid Combinations ............................................................................................................................ 15 2 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 1. General Description Apacer’s SM210-M280 is the next generation modularized Solid State Drive (SSD) with the shape of all new M.2 form factor, aimed to be the more suitable for mobile and compact computers with standard width at only 22.00 mm. SM210-M280 appears in M.2 2280 mechanical dimensions and is believed to be the leading add-in storage solution for future host computing systems. The M.2 SSD is designed with SATA-based connector pinouts, providing full compliance with the latest SATA Revision 3.2 interface specifications. Aside from SATA compliance, SM210-M280 delivers exceptional performance and power efficiency. On the other hand, the extreme thin and light form factor makes SM210-M280 the ideal choice for mobile computing systems, which appears to be the trend in near future. Regarding reliability, SM210-M280 is built with a powerful SATA controller that supports on-the-module ECC as well as efficient wear leveling scheme. In terms of power efficiency, SM210-M280 is compliant with SATA 6.0 Gbps interface standard so that it can operate on SATA power management modes, which greatly save on power consumption. 3 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 2. Pin Assignments This connector does not support hot plug capability. There are a total of 75 pins. 12 pin locations are used for mechanical key locations; this allows such a module to plug into both Key B and Key M connectors. Notch M Notch B Pin1 Table of Pin Assignments Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 Type CONFIG_3 3.3V GND 3.3V No connect Not available Not available Not available No connect DAS/DSS No connect (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) Not available CONFIG_0 Not available Not available Not available Not available Not available GND Not available PERn1 Not available PERp1 Not available GND Not available PETn1 Not available Description Ground (according to M.2 configurations for SSD-SATA definition) Supply Pin, 3.3V Ground Supply pin, 3.3V No connect No connect (used for other purposes) No connect (used for other purposes) No connect (used for other purposes) No connect Device Activity Signal/Disable Staggered Spin-up No connect (used for other purposes) Mechanical notch B Mechanical notch B Mechanical notch B Mechanical notch B Mechanical notch B Mechanical notch B Mechanical notch B Mechanical notch B No connect (used for other purposes) Ground (according to M.2 configurations for SSD-SATA definition) No connect (used for other purposes) No connect (used for other purposes) No connect (used for other purposes) No connect (used for other purposes) No connect (used for other purposes) Ground No connect (used for other purposes) Not used No connect (used for other purposes) Not used No connect (used for other purposes) Ground No connect (used for other purposes) Not used No connect (used for other purposes) 4 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX Table of Pin Assignments Pin 37 Type PETp1 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 DEVSLP GND Not available SATA-Rx+ Not available SATA-RxNot available GND Not available SATA-TxNot available SATA-Tx+ PERST# GND CLKREQ# REFCLKN PEWAKE# REFCLKP MFG1 GND MFG2 (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) (removed for key) Not available SUSCLK CONFIG_1 3.3V GND 3.3V GND 3.3V CONFIG_2 Description Not used Device Sleep, input. If driven high the host is informing the SSD to enter a low power state Ground No connect (used for other purposes) Host receiver differential signal pair No connect (used for other purposes) Host receiver differential signal pair No connect (used for other purposes) Ground No connect (used for other purposes) Host transmitter differential pair No connect (used for other purposes) Host transmitter differential pair Not used Ground Not used Not used Not used Not used Manufacturing pin. Use determined by vendor (no connect on a host) Ground Manufacturing pin. Use determined by vendor (no connect on a host) Mechanical notch M Mechanical notch M Mechanical notch M Mechanical notch M Mechanical notch M Mechanical notch M Mechanical notch M Mechanical notch M No connect (used for other purposes) Not used Ground Supply pin, 3.3V Ground Supply pin, 3.3V Ground Supply pin, 3.3V Ground 5 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 3. Product Specifications 3.1 Capacity Capacity specifications of SM210-M280 are available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1 Capacity Specifications Capacity 32 GB 64 GB 128 GB 256 GB Total Bytes Cylinders Heads Sectors 16383 16383 16383 16383 16 16 16 16 63 63 63 63 32,017,047,552 64,023,257,088 128,035,676,160 256,060,514,304 Max LBA 62,533,296 125,045,424 250,069,680 500,118,192 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performance of SM210-M280 is listed below in Table 3-2. Table 3-2 Performance Specifications Capacity 32 GB 64 GB 128 GB 256 GB Sustained read (MB/s) 210 370 500 505 Sustained write (MB/s) 46 90 180 350 Random Read IOPS (4K) 24,000 45,000 76,000 82,000 Random Write IOPS (4K) 11,000 22,000 43,000 79,000 Performance Note: Results may differ from various flash configurations or host system setting IOPS: measured on 8GB span (16777216 sectors Disk Size), 32 Outstanding I/Os (QD=32), Full Random Data pattern, 4KB Align I/Os and test durations 15minutes. 6 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 3.3 Environmental Specifications Environmental specifications of SM210-M280 series follow MIL-STD-810 standards as shown in Table 33. Table 3-3 Environmental Specifications Item Specifications Operating temperature 0°C to 70°C (Standard); -40°C to 85°C (Extended) Non-operating temperature -40°C to 85°C Frequency/Displacement: 20Hz~80Hz/1.52mm Frequency/Acceleration: 80Hz~2000Hz/20G X, Y, Z axis/60mins 1,500G, 0.5ms Vibration (Non-operating) shock (Non-operating) Drop (Non-operating) Bending (non-operating) 80cm free fall, 6 face of each unit ≧20N, hold 1min/5times Torque (non-operating) 0.5N-m or ±2.5 deg, hold 1min/5times ESD (Electrostatic) Passed (at relative temp/humidity: 24°C, 49%RH) 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SM210-M280. The prediction result for SM210-M280 is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 3.5 Certification and Compliance SM210-M280 complies with the following standards:     CE: EN55022 FCC: CISPR22 BSMI 13438 RoHS Recast 7 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 4. Flash Management 4.1 Error Correction/Detection SM210-M280 implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 72 bits error in 1K bytes. 4.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 4.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency. Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes place before the cached data is flushed into non-volatile NAND flash memory. 4.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 4.6 TRIM TRIM, though in capital letters usually, is a memory computation command rather than an abbreviation. It is mainly a SATA command that enables the operating system to inform the SSD (Solid State Drive) which blocks of previously stored data are no longer valid, due to erases by the host or operating system, such as file deletions or disk formatting. Once notified, SSD will begin the discard of the invalid LBAs and retain more space for itself, in fact, the discarded is no longer recoverable. When an LBA is replaced by the operating system, as with overwrite of a file, the SSD is informed that the originally occupied LBA is determined as no longer in use or invalid. The SSD will not save those blocks in garbage collected sectors. Noticeably, a file deletion command by host or operating system never actually erases the actual content, rather, just the file is marked as deleted. This issue is even specifically noticeable for flash based memory devices, such as SSDs. In fact, an SSD will keep garbage collecting the invalid, previously occupied LBAs, if it is not informed that these LBAs can be erased. Thus, the SSD would experience a significant performance downfall. 4.7 SATA Power Management By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:  ACTIVE: PHY ready, full power, Tx & Rx operational  PARTIAL: Reduces power, resumes in under 10 µs (microseconds)  SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)  HIPM: Host-Initiated Power Management  DIPM: Device-Initiated Power Management  Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ≦ 5 mW; host assertion time ≦ 10 ms; exit timeout from this state ≦ 20 ms (unless specified otherwise in SATA Identify Device Log). Note: The behaviors of power management features would depend on host/device settings. 9 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 5. Software Interface 5.1 Command Set This section defines the software requirements and the format of the commands the host sends to SM210-M280. Commands are issued to SM210-M280 by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 5-1 Command Set Code Command Code Command E5h Check Power Mode F3h Security Erase Prepare 06h Data Set Management F4h Security Erase Unit 90h Execute Device Diagnostic F5h Security Freeze Lock E7h Flush Cache F1h Security Set Password EAh Flush Cache EXT F2h Security Unlock ECh Identify Device 70h Seek E3h Idle EFh Set Features E1h Idle Immediate C6h Set Multiple Mode 91h Initialize Device Parameters E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT CAh Write DMA 20h Read Sector 35h Write DMA EXT 24h Read Sector EXT C5h Write Multiple 40h Read Verify Sectors 39h Write Multiple EXT 42h Read Verify Sectors EXT 30h Write Sector 10h Recalibrate 34h Write Sector EXT F6h Security Disable Password 10 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 5.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. Note: attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB SMART attribute ID list ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 11 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 6. Electrical Specifications Table 6-1 Operating Range Operating Temperature 0°C to 70°C (Standard) -40°C to 85°C (Extended) Supply Voltage 3.3V ± 5% (3.135-3.465V) Table 6-2 Typical Power Consumption Capacity Modes 32 GB 64 GB 128 GB 256 GB Active (mA) 265 335 465 745 Idle (mA) 75 75 75 75 Note: Results may differ from various flash configurations or host system setting. 12 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 7. Physical Characteristics 13 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 8. Product Ordering Information 8.1 Product Code Designations A P M2 T80 SM21 x x x G AS – 3X TMG X Operating Temperature Blank: 0°C C ~70°C W: -40°C ~85°C Flash Type Version Control Single Side Capacity 032G = 32GB 064G = 64GB 128G = 128GB 256G = 256GB Solution Version Form Factor M.2 Apacer Product Code 14 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX 8.2 Valid Combinations 8.2.1 Standard Temperature Capacity No DEVSLP DEVSLP 32GB APM2T80SM21032GAS-3ATMG APM2T80SM21032GAS-3BTMG 64GB APM2T80SM21064GAS-3ATMG APM2T80SM21064GAS-3BTMG 128GB APM2T80SM21128GAS-3ATMG APM2T80SM21128GAS-3BTMG 256GB APM2T80SM21256GAS-3ATMG APM2T80SM21256GAS-3BTMG 8.2.2 Extended Temperature Capacity No DEVSLP DEVSLP 32GB APM2T80SM21032GAS-3ATMGW APM2T80SM21032GAS-3BTMGW 64GB APM2T80SM21064GAS-3ATMGW APM2T80SM21064GAS-3BTMGW 128GB APM2T80SM21128GAS-3ATMGW APM2T80SM21128GAS-3BTMGW 256GB APM2T80SM21256GAS-3ATMGW APM2T80SM21256GAS-3BTMGW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 15 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX Revision History Revision Date Description Remark 1.0 2/3/2016 Official release 1.1 3/7/2016 Revised product ordering information 16 © 2016 Apacer Technology Inc. Rev. 1.1 M.2 2280 Flash Drive APM2T80SM21xxxGAS-3XTMGX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 17 © 2016 Apacer Technology Inc. Rev. 1.1
APM2T80SM21032GAS-3BTMG 价格&库存
很抱歉,暂时无法提供与“APM2T80SM21032GAS-3BTMG”相匹配的价格&库存,您可以联系我们找货
