WRB**FWX-O
50 Watt AC/DC Dual Output
Universal Input
Compact design with Inrush current protection
Dual Output
-WRB21FWX-O: 5V, 24V - WRB24FWX-O:5V, 12V
-WRB22FWX-O: 12V, 12V - WRB25FWX-O:5V, 15V
-WRB23FWX-O: 15V, 15V
2 year Warranty
RoHS
UNIT
INPUT
Voltage/Freq
Current Typ.
V
A
AC100V - 240V (AC85V ~ 264V or DC125V~ 370V), 50 / 60Hz (47 ~ 440Hz) Universal Input voltage
1.2A at 110V; .7A at 220V (I =100%)
Power Factor
Inrush Current
Leakage
A
mA
-20A typ (AC IN 110V, I =100%), 40A typ (AC IN 220V, I =100%) at cold start
0.75
UNIT
OUTPUT
VDC
Efficiency typ
Current
Line Regulation
Load Regulation
Ripple
Ripple Noise
maximum
Temperature Drift
[0-+50C]
Rise Time
Hold up Time
Grounding
A
mV (max)
mV(max)
mVp-p
mVp-p
0.5~5
50
100
80
120
mV
75
mS
mS
1000 max [AC IN 110V/220V I =100%]
17 typ [AC IN 110V/220V,I =100%]
Protection
Isolation
Environment
Safety
Size
WRB24FWX-O WRB21FWX-O WRB25FWX-O WRB22FWX-O WRB23FWX-O
Nominal Voltage
5
75
12
5
2
120
240
120
150
0.5~5
50
100
80
120
180
75
77
24
5
1
240
480
150
250
0.5~5
50
100
80
120
360
75
76
15
12
12
1.7
150
210
120
150
0.1~2.5
120
240
120
150
77
1.5
120
240
120
150
225
180
180
15
.1~2
150
300
120
150
225
Individual Ground
Over Voltage
Over Current
Input-Output
Input-F.G
Output-F.G
Operating temp/hum
Storage temp/hum
Vibration
Impact
CE/ CB
Works at 115~140% of rating
Works at 105% over rated current and recovers automatically
AC 3,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity)
AC 2,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity)
AC 500V 1 minute current 100mA, DC 500V 100MΩ (At room temperature & Humidity )
-10 ~ +70 , 20 ~ 90% RH(Non condensing)
-20 ~ +75 , 20 ~ 90% RH(Non condensing)
10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis
10G for 20ms once on each X, Y and Z axis
IEC 60950-1, EN60950-1
Line Con RF Voltage
MM/G
EN55022-A
82 x 35.5 x 135 (150) / 360
15
77
1.5
150
300
120
150
225
BLOCK DIAGRAM
WRB22FWX-O WRB23FWX-O WRB25FWX-O WRB24FWX-O WRB21FWX-O
DIMENSIONAL DRAWING (mm)
WRB21FWX-O
Mark
L
N
NC
+V1
-V1
+V2
-V2
WRB22FWX-O WRB23FWX-O WRB24FWX-O WRB25FWX-O
Pin Connection
AC input line
AC input neutral
AC Chassis Ground
DC V1 Output
DC V1 Ground
DC V2 Output
DC V2 Ground
DERATING CURVE AND RECCOMENDED MOUNTING DIAGRAM
很抱歉,暂时无法提供与“WRB01X-O”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1792.00080
- 200+715.02480
- 500+691.12440
- 1000+679.32000
