WRT23FWX-O
WRT23FWX-O
    ETA-USA
    AC/DC CONVERTER +/-15V 30W
WRT23FWX-O 数据手册
WRT**FWX-O 30 Watt AC/DC Dual Output Universal Input Compact design with Inrush current protection Dual Output -WRT20FWX-O: 5V, 5V - WRT23FWX-O: 15V, 15V -WRT21FWX-O: 5V, 24V - WRT24FWX-O: 5V, 12V -WRT22FWX-O: 12V, 12V 2 year Warranty UNIT INPUT Voltage/Freq Current Typ. V A AC100V - 240V (AC85V ~ 264V or DC125V~ 370V), 50 / 60Hz (47 ~ 440Hz) Universal Input voltage 0.65 at 110V; .035 at 220V (I₀ =100%) Power Factor Inrush Current Leakage A mA -20A typ (AC IN 110V, I₀ =100%), 40A typ (AC IN 220V, I₀ =100%) at cold start 0.75 UNIT OUTPUT Nominal Voltage VDC Efficiency typ Current Line Regulation Load Regulation Ripple Ripple Noise maximum Temperature Drift [0-+50C] Rise Time Hold up Time Grounding % A mV (max) mV(max) mVp-p mVp-p Protection Isolation Environment Safety Size WRT24FWX-O WRT21FWX-O WRT20FWX-O WRT22FWX-O WRT23FWX-O +12 +5 0.3~3 25 50 80 120 1.3 120 120 120 150 mV 75 180 mS mS 800 max [AC IN 110V/220V I₀ =100%] 16 typ [AC IN 110V/220V,I₀ =100%] Individual Ground Over Voltage Over Current Input-Output Input-F.G Output-F.G Operating temp/hum Storage temp/hum Vibration Impact CE/ CB Line Con RF Voltage MM/G +5 +24 +5 0.3~3 25 50 80 120 0.6 240 240 120 150 2 25 50 80 120 2 25 50 80 120 1.3 60 120 120 150 77 1.3 60 120 120 150 1 75 150 120 150 1 75 150 120 150 75 360 75 75 180 180 225 225 71 74 -5 +12 74 -12 +15 -15 78 Common Ground Works at 115~140% of rating Works at 105% over rated current and recovers automatically AC 3,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity) AC 2,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity) AC 500V 1 minute current 100mA, DC 500V 100MΩ (At room temperature & Humidity) -10 ~ +70℃, 20 ~ 90% RH(Non condensing) -20 ~ +75℃, 20 ~ 90% RH(Non condensing) 10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis 10G for 20ms once on each X, Y and Z axis IEC 60950-1 EN55022-A 82 x 120 x 31.5 290 grams BLOCK DIAGRAM WRT24FWX-O WRT22FWX-O WRT23FWX-O (common ground) WRT20FWX-O WRT21FWX-O DIMENSIONAL DRAWING (mm) WRT24FWX-O Mark L N FG +V O -V WRT22FWX-O WRT23FWX-O Pin Connection AC Line AC Neutral Field Ground DC output DC Ground DC Output WRT20FWX-O WRT21FWX-O Mark L N NC +V1 G1 +V2 G2 Pin Connection AC input line AC input neutral AC Chassis Ground DC V1 Output DC V1 Ground DC V2 Output DC V2 Ground DERATING CURVE AND RECCOMENDED MOUNTING DIAGRAM
WRT23FWX-O 价格&库存
很抱歉,暂时无法提供与“WRT23FWX-O”相匹配的价格&库存,您可以联系我们找货
WRT23FWX-O
    • 1+1546.77600
    • 200+617.17680
    • 500+596.54880
    • 1000+586.36440
