OBQ24SC0512I
OBQ24SC0512I
    ETA-USA
    DIP5
    DC DC CONVERTER 24V 3W
OBQ24SC0512I 数据手册
OBQ24SC0512I 3 Watt DC/DC Power Supply FEATURES Wide input 4:1 Low noise Tight regulation ±0.5% MAX High Isolation Voltage *Image for marketing purposes only-unit may differ INPUT OUTPUT Nom Voltage (Range) UNIT OBQ24SC0512 V Current Typ. mA Start-up Time ms 12VDC 4.5~16 Vdc 30mA Typ At no load 10 ms UNIT OBQ24SC0512 Nominal Voltage VDC 24 VDC OUTPUT VDC ACCURACY % 2% Current mA 130 Total Pwr Efficiency W % 3 85 TYP @ Vin=12Vdc Line Regulation Load Regulation % ±0.5% MAX At LL TO HL, Full Load % ±0.5% MAX At 25%FL TO 100%FL 10 ms 100mVp-p MAX 0.03%/°C MAX @20MHz BANDWIDTH Startup Time Ripple Noise ms mVp-p Temp Coefficient Short circuit protect Cooling Type Continuous/ Autorecovery Convection @23.52~24.48Vdc @Vin=4.5~1 @12VDC ISOLATION Voltage Resistance 1500Vdc for 1 minute Min. 100 MΩ @ 500 Vdc -20°C ~ +71°C Operating temp Environment Dimension Storage Vibration -20°C ~ +85°C Humidity 90 % WxL/weight Mil-STD 202G mm/g DIMENSIONS AND PINOUT 32x20/4.5
OBQ24SC0512I 价格&库存
很抱歉,暂时无法提供与“OBQ24SC0512I”相匹配的价格&库存,您可以联系我们找货
OBQ24SC0512I
    • 1+535.71240
    • 200+213.75360
    • 500+206.61480
    • 1000+203.08320
