AC/DC SWITCHING POWER SUPPLY
SINGLE CHANNEL OUTPUT
30 WATTS
UNIVERSAL INPUT
ESS30 SERIES
General Description
RoHS
Features
1. Smaller than competitors by 15-20%
2. Operating temp shows full load at 50° C
(122° F), can operate at temperatures up to
71°C
3. Five-year guarantee
4. Over-current protection
5. Over-voltage protection
6. Can meet medical and appliance
standards
Application
7. Low leakage < 500µA
Broad needs
Input
Input Voltage:
Input Voltage Range:
AC100~240V
AC85~264V; (DC110~370V)
with 70V derating possibility
Frequency:
Frequency Range:
Phase:
Inrush Current:
50/60Hz
47~440 Hz
Single
14A at 100V; 28 at 200V
*1
ETA USA
16170 Vineyard Blvd. Suite 180, Morgan Hill, CA 95037
Phone: 1-800-ETA-POWR, (408) 778-2793 Fax: (408) 779-2753
Visit us at: www.e
ta-usa.com
email at: sales@eta-usa.com
Output
Characteristic
Output Voltage
Output Current
Ripple &Noise(max)
Voltage Adjust Range
Rise time
Hold up time
Regulation
a. Line Regulation
[max]
b. Load Regulation
c. Temperature
Coefficient
d. Drift(maximum)
Efficiency
*1
Models
Unit
Vdc
A
mVpp
V
mS
mS
ESS30-3.3
ESS30-05
ESS30-12
ESS30-15
3.3
6
120
5.0
6
120
12
2.5
150
15
2
150
2.97~3.63
4.50~5.50
10.8~13.2
13.5~16.5
20mS Typ.
20mS Typ.
ESS30-24
24
1.3
150
ESS30-36
36
0.8
250
ESS30-48
48
0.65
250
21.6~26.4
32.4~39.6
43.2~52.8
mV
30
60
96
144
192
mV
0 to
+50°C
-10
to
0°C
mV
40
50
40
50
100
120
120
150
150
240
240
360
240
480
60
60
150
180
290
450
600
60
96
144
192
Power Factor *1
ETA USA
At AC100V 73%-88.5%
At AC 200V 73.5%-90.5%
No power factor needed
Visit us at: www.e
ta-usa.com
Environmental Specification
Operating Temperature*3
Operating Humidity
Storage Temperature
Storage Humidity
Withstanding Voltage
-10 to +71 °C
20~90% RH
-30 to +85 °C
10~95% RH (no condensation)
Primary-Secondary
AC3,000V for 1minute
Primary-Frame Ground
AC2,500V for 1minute
Secondary-Frame Ground AC1,000V for 1minute
*Sensory Current: Secondary Frame Ground
(20[mA])/Others (10[mA])
Primary-Secondary-Frame Ground
100MΩ(minimum) by
DC500V insulation tester
5~10Hz:10mm double amplitude,10-55Hz:19.6m/s2,30 minute
cycle each along X,Y,Z axes(non-operating)
196 m/s2 on x,y,z axis
Convection
Isolation Resistance
Vibration
Shock
Cooling
Leakage current
MTBF
Environmental Agencies
500µA
>300,000 hours
Line Conducted Noise [EMI]
Line Harmonic
Distortion/Current
Safety
Function/Protection
Built to meet FCC part 15 class B, VCCI-B, CISPR22-B, EN55022-B
N/A
UL60950-1 1st ed. , CAN/CSA C22.2 No.60950-1-03 Approved
UL508 17th ed. , CAN/CSA C22.2 No.107.1-01 Approved
EN60950-1:2001+A11:2004 Approved
CE Marking:EN60950-1:2001+A11:2004(LVD) Declared
Over current Protection
Over voltage Protection
Remote Sense
Remote Control
Series Operation
Parallel Operation
Driving Indicator
Operate at 105% min of rated current, automatic return
Input reentry at shutdown
Not Available
Not Available
Available
Not available (N+1 Operation is Applicable by Diode-OR)
Power Source on LED indication; Green
Dimension [mm]
Weight [g](typical)
33W × 98L × 68H
220g
Mechanical
Conditions:
*1 Rated input and Rated output
*2 at Output current quick change 25% to 75%
*3 At 100% load (convection cooling)
ETA USA
Visit us at: www.e
ta-usa.com
Derating Curves
ETA USA
Visit us at: www.e
ta-usa.com
ETA USA
Visit us at: www.e
ta-usa.com
Efficiency Curves
Mechanical Drawing
ETA USA
Visit us at: www.eta-usa.com
Block Diagram
ETA USA
Visit us at: www.e
ta-usa.com
很抱歉,暂时无法提供与“ESS30-48”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3262.24800
- 200+1301.65920
- 500+1258.16760
- 1000+1236.67560
