TR9CX1875YL4CR6BLPS
TR9CX1875YL4CR6BLPS
    GLOBTEK
    GTM96900P9048-T3, 90W, 48V@1.875
TR9CX1875YL4CR6BLPS 数据手册
GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A In Addition to GlobTek Inc.'s renewed ISO9001:2015 - Quality Management System Certification, GlobTek Inc. is now certified to: ISO13485:2016 - Medical Devices Quality Management System Certification ISO14001:2015 - Environmental Management System Certification ISO Certificates are available online at https://www.globtek.com/iso-certificates/ The acceptance of this specification and use of the product described in this document indicates the acceptance and binding of the customer to Globtek TERMS AND CONDITIONS (attached to the end of this document), which supersede all other agreements, terms, and conditions (https://en.globtek.com/terms-and-conditions/). The purchaser of this product (Customer) agrees that it is their sole responsibility to determine suitability/fitness of the product described in this specification for their application and to take precautions for protection against any hazards attendant to the handling and use of the product. Footnote: GlobTek Inc. will not be liable for the safety and performance of these power supplies/battery packs if unauthorized access and repair occurs. End user should consult applicable UL, CSA or EN standards for proper installation instruction. Limitation of Use: GlobTek products are intended for use with commercial, medical, and/or industrial equipment only. GlobTek product are not authorized for use as mission critical components in life support hazardous environment, nuclear or aircraft applications without prior written approval from the CEO of GlobTek Inc. Contents of this document are subject to change without prior notice. Customer Approval of Specification: Please approve, sign and send back to GlobTek so we can complete order processing. A delay in receipt of this form will delay delivery schedule. Company Name: Customer P/N: Quote Number: Date: Authorized Representative Name: Authorized Representative Signature: PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 1 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A REVISION HISTORY REV A DESCRIPTION SUB dhock Initial Release DATE 06/14/2019 APPROVED QA POWER SUPPLY INFORMATION TYPE TECHNOLOGY Desktop/External Regulated Switchmode AC-DC Power Supply AC Adaptor CASE COLOR GlobTek Black NAMEPLATE RATED INPUT 100-240V~, 50-60Hz, 1.5A INPUT CONFIG IEC 60320/C14 WATTS 90.00 VOLTS OUT 48.0 CURRENT OUT (Amps) 1.875 BLADE/CORD INCLUDED None (Order Separately) BLADE/CORD INSTALLED None :(Order Separately) INGRESS PROTECTION IP41 GROUNDING CONFIGURATION (E1) Earthed output OUTPUT CONNECTOR HOOK UP EFFICIENCY LEVEL USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782 OUTPUT CONFIGURATION 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313 OVERMOLDED No OUTPUT CONNECTOR GENDER Male CONNECTOR PIN OUT Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V LABEL SPECS Standard GT,L-1186 SPECIAL BARCODE LABEL MATERIAL No PACK SPEC Standard DT, Cellular packaging USER MANUAL PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 2 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A Notes/Modifications/Customizations (notes in this section supersede the values shown in the standard spec) DIMENSIONS ARE IN MM UNLESS SPECIFIED OTHERWISE "E1" configuration requested. Follow RFP RFI-497430 to implement true LPS. PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 3 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A ELECTRICAL SPECIFICATIONS Input Input Voltage: Specified: 90-264VAC, Nameplate: 100-240VAC      100% rated load current for 90-264VAC        90% rated load current for 85-264VAC      100% rated load current for 90-370VDC Input Frequency: Specified: 47-63Hz, Nameplate: 50-60Hz Power Factor: 0.90 min. @ 230VAC, 0.97 min. @ 115VAC No Load Input Power: < 150mW @ 115/230VAC Inrush Current: < 65A @ 115VAC, < 130A @ 230VAC (cold start) Efficiency: DoE Level VI and EU CoC Tier 2 compliant Output Turn-on Delay: 1 second typ. Output Regulation: ± 4% (measured at output connector) Line Regulation: ± 0.5% typ. (measured at output connector, full load) Ripple: 1% or 200mV, whichever is greater (using a 47µF low-ESR cap + 0.1µF ceramic capacitor, measured @ 20MHz BW, at output connector) Startup Overshoot: 5% max. Transient Response: 5% max. deviation, 1ms typ. recovery time (with 25% to 50% load step) Hold-up Time: 20ms min. Power Indicator: Green LED Switching Frequency: Variable, 25KHz - 125KHz, depending on load Output Type: Z-suffix only: IEC62368-1 Limited Power Source (LPS), 8A and 100W max. Protections Input Protection: 300VAC MOV transient suppressor, input line fusing Over-Current Protection (Non-LPS Version): 110 - 160% of rated output current, auto-restart Over-Current Protection: (LPS "Z" Version) Overload limited to less than 8A and less than 100W, auto-restart Short-Circuit Protection: Auto-restart Over-Voltage Protection: 110 - 135% (60V max for models rated 45 - 54V), full load condition, latched off, cycle AC to reset Over-Temperature Protection On-chip temperature sensor (integrated in primary-side switching controller), shut down at Tj = ~150°C, restart at Tj = ~140°C PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 4 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A Environmental MTBF: 1,500,000 hours @ 25°C ambient, full load (Telcordia SR-332, Issue 3) Operating Temperature: -10°C to 40°C (full load) Storage Temperature: -30°C to 80°C Humidity: 0% to 95% relative humidity, non-condensing Altitude: 5000m Cooling: Convection RoHS: Complies with EU 2011/65/EU and China SJ/T 11363-2006 Note 1: Regarding operating temperature a. See below de-rating table for output power capability at alternate temperature b. Extended low-end temperature range available as a custom option Safety Dielectric Withstand Voltage: 4000VAC or 5656VDC from input to output 3000VAC or 4242VDC from input to earth (Class I models only) Touch Current: Class I: 20µA max. Class II: 70µA max. Earth Leakage Current Class I: 300µA max. Class II: N/A Means of Protection: 2 x MOPP Output Isolation Options: Class I: C6 or C14 inlet (output negative tied to Earth contact) Class II: C8 or C18 inlet Class II FE: C6 or C14 inlet (output isolated from Earth contact) Review isolation options by reading our white paper PSU Isolation and Identity. Primary-to-Secondary Bridging Capacitors: Two IEC60384-14 Class Y1 capacitors Earth Continuity Test: < 0.1Ω between earth pin (on AC inlet) and PCB termination point (Class I models only) Compliant Standards: See listing at end of this datasheet for specific standards PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 5 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A EMC Applicable Standards: Medical: EN60601-1-2, 4th edition Emissions: EN55032, EN61000-6-3, EN61000-6-4, CISPR11, CISPR22 Immunity: EN55024, EN61000-6-1, EN61000-6-2 Conducted Emissions: Class B, FCC Part 15, Class B (with resistive load) Radiated Emissions: Class B, FCC Part 15, Class B (with resistive load) Harmonic Current Voltage Distortion: EN61000-3-2, Class A Voltage Fluctuations/Flicker: EN61000-3-3 Electrostatic Discharge (ESD) Immunity: EN61000-4-2, 10KV contact discharge, 18KV air discharge Radiated RF Immunity: EN61000-4-3, 10V/m 80-1000MHz,  3V/m 1-2.7GHz, 80% 1KHz AM EFT/Burst Immunity: EN61000-4-4, 4KV/100kHz. Line Surge Immunity: EN61000-4-5, 2KV differential, 4KV common-mode Conducted RF Immunity: EN61000-4-6, 3VRMS, 80% 1KHz AM Power Frequency Magnetic Field Immunity: EN61000-4-8, 3A/m Voltage Dip Immunity: EN61000-4-11 Enclosure Housing: High impact plastic, 94V0 polycarbonate, non-vented Size: 149.4 * 62.6 * 33.5mm, ± 1.0mm AC Input Mechanical Options: C6, C8, C14, or C18 IEC inlet Markings: Label and/or pad printed and/or laser-etched into case Special Options 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. IEC62368-1 Limited Power Source (LPS) version (add Z suffix) Reduced leakage current to meet IEC60601-1 Type-CF limits Improved EN61000-4-5 line surge immunity (3KV differential, 5KV common-mode) Reduced harmonic current levels for LED lighting (EN61000-3-2 Class C), available in three load ranges: 27-45W, 40-60W, and 60-90W Ruggedized construction with improved shock and vibration resistance Compliance to IPC-600, IPC-610, IPC-6012 Class 2 or 3 Short term output surge capability for motors or other high peak current loads (non-LPS version only) Custom cordsets, special cordage and connector types Custom housing markings Custom housing/cordage colors Tightened output voltage tolerance Reduced output ripple level Reduced output power rating Low temperature option, down to -40°C Epoxy potted version "P2" or "P3" suffix, with flying wires or custom cables  "Back EMF" upgrade, for motor loads and other high inductance applications with reverse energy flow requirements Improved ingress protection (IP) rating PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 6 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A Output Connectors Several output connector options are available with various output current ratings. GlobTek can supply 10A rated 2.1mm and 2.5mm style DC Power Jacks, to complement our 10A output rated 2.1mm and 2.5mm DC power plugs used on our output cordsets. Please visit our real-time listing of mating connector product offering: https://en.globtek.com/news/high-current-coaxial-barrel-plug-jacks-for-high-wattage-power-supplies     TO ADDRESS SYSTEM-LEVEL EMI CONCERNS, FERRITE CHOKES/BEADS MAY BE ADDED/REVISED UPON REQUEST. A SAMPLE KIT OF GLOBTEK’S STANDARD FERRITES IS AVAILABLE UNDER GLOBTEK P/N: EMI-MITIGATION-KIT1 FOR ADDITIONAL INFORMATION, PLEASE READ OUR WHITE PAPER AT: https://r.globtek.info/3QeaqtD INGRESS PROTECTION: IP41 PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 7 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A 3D File Download https://www.globtek.com/dl/GTM96900-GTM961200-T3.igs Mechanical drawing Alternative housing with input cord clamp to prevent accidental removal of the power cord. Product PN# ends with suffix "CL" PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 8 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A DERATING CURVE PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 9 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A INPUT CONFIGURATION (E1) Earthed output   Alternate grounding configurations available upon request. Blades/Cord Included:None:(Order Separately) Blades/Cord Installed:None:(Order Separately) T3 Inlet (IEC 60320/C14) IEC 60320/C14 AC Inlet Connector, Class I, Earth Ground Mates with IEC 60320/C13 Plug Optional Locking IEC60320 Receptable and cord option available on some models by request.: Standard International IEC 320/C13 Cordsets Below are standard cordsets which are "not included" (unless stated above); these can be purchased separately or packaged with the power supply. Contact your Sales Engineer if the style required is not shown below. Many more available in different lengths, colors or cable material.   PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 10 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A Stock Power Supply Cords Part Number/ Link Country Plug Termination Length (Ft) (mm) 3021457F701(R) N. American (Type B) NEMA 5-15P IEC 320/C13 2150 7 1191068F0701(R) N. American (Type B) NEMA 5-15P Hospital IEC 320/C13 2459 8 2194272M5701-T(R) Argentina (Type I) IRAM 2073 IEC 320/C13 2500 8 5502022M5701A(R) Australian (Type I) AS3112 / 3 PRONG IEC 320/C13 2500 8 204B4272M5701(R) Brazil (Type N) BRAZIL IEC 320/C13 2500 8 6023602M5701(R) China (Type I) CCC GR2099 IEC 320/C13 2500 8 G8014272M5701(R) Danish (Type K) AFSNIT SECTION 107-2-D1 IEC 320/C13 2500 8 23144272M5701-T(R) Europe (Type E) CEE 7/7 IEC 320/C13 2500 8 23134272M5701EUKR(R)Europe/Korea Combo (Type E) CEE 7/7 / KSC8305 IEC 320/C13 2500 8 205IN4272M5701(R) India (Type D) India IS 1293 (also known as IA16A3 or BS546) IEC 320/C13 2500 8 208IN4272M5701(R) India (Type M) India IS 1293 (also known as IA16A3 or BS546) 377C4272M5701(R) Israel (Type H) ISL 377C 23024272M5701(R) Italy (Type L) CEI 23-16/VII Japan (Type B) JIS 8303 / 3 PINS 3003339F701(R) [3x1.25mm2] 3003068F2701-HK(R) [3 x 2.0mm2] IEC320/C132500 8 IEC 2500 8 320/C13 IEC 2500 8 320/C13 IEC 320/C13 2500 8 302J115J6F0701J(R) North America / Japan (Type B NEMA 5-15P (cULus approved), Japan JIS C 8303 (PSE – 12A) Approved) IEC 320/C13 1830 6 302J104J6F0701J(R) North America / Japan (Type B NEMA 5-15P (cULus approved), Japan JIS C 8303 (PSE – 15A) Approved) IEC 320/C13 1830 6 302JT104J9F0701JT(R) North America / Japan / Taiwan (Type B – 15A) NEMA 5-15P (cULus approved), Japan JIS C 8303 (PSE Approved), Taiwan CNS 6797 (BSMI Approved) IEC 320/C13 2800 9 2313K3432M5701(R) Korea (Type F) KS C 8305 IEC 320/C13 2500 8 PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 11 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A 5804272M5701(R) Russia (Type F) GOST 7396 IEC 320/C13 2500 8 2084272M5701(R) South Africa (Type M) South Africa SABS164-1 (16A type) IEC 320/C13 2500 8 23214272M5701(R) Switzerland (Type J) SEV 1011 IEC 320/C13 2500 8 3003322M5701(R) Taiwan (Type B) BSMI IEC 320/C13 2500 8 6363762M5701(R) Thailand (Type O) TIS 166-2549 IEC 320/C13 2500 8 PZ0800100-2M5BK13H(R UK, Hong Kong,Singapore, Gulf States (Type G) BS 1363A IEC 320/C13 2500 8 7055002M5701A(R) International IEC 320 C14-C13 IEC 320/C13 2500 8 PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 12 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS OUTPUT CORD AND CONNECTOR: Rev A YL4/C40313 ACTUAL CONNECTORS, OVERMOLDS, FERRITES MAY VARY SLIGHTLY FROM THE PICTURE BELOW CABLE TYPE UL 2464 CABLE LENGTH (mm) 1500 CABLE TOLERANCE (mm) +150,-0 WIRE GAUGE (AWG) 18 CONDUCTORS 2 HANK DIMENSION (mm) 120 ± 10 CABLE / CONNECTOR OVERMOLD COLOR GlobTek Black FERRITE TYPE AND DIMENSION None FERRITE NUMBER OF TURNS(Definition) N/A FERRITE DIMENSION FROM STRAIN RELIEF N/A FERRITE DIMENSION FROM PLUG N/A PLUG TYPE 4 Pin Locking Kycon or Equal OUTPUT CONNECTOR GENDER Male OVERMOLDED No OVER MOLD ORIENTATION Straight CONNECTOR PIN OUT Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V ADDITIONAL REQUIREMENTS UL1310 Warning Label Up To 36 Volts with plugs Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V Please visit https://en.globtek.com/news/power-din-locking-connector-cable-assemblies-and-accessories for Power Din connector mating jacks (Sheilded and unsheilded), inline mating plugs, and extension cables in various custom and standard lengths available from stock in both black and white.   ADDITIONAL OUTPUT PLUG OPTIONS ARE AVAILABLE AT https://www.globtek.com/en/connectors STANDARD PLUGS AND CONNECTORS CAN BE SEEN ONLINE AT https://www.globtek.com/en/connectors CALCULATE VOLTAGE REGULATION/DROP WITH OUR ONLINE CALCULATOR: https://www.globtek.com/r2/PtqjjL PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 13 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A OUTPUT CONNECTOR HOOK UP TO ADDRESS SYSTEM-LEVEL EMI CONCERNS, FERRITE CHOKES/BEADS MAY BE ADDED/REVISED UPON REQUEST. A SAMPLE KIT OF GLOBTEK’S STANDARD FERRITES IS AVAILABLE UNDER GLOBTEK P/N: EMI-MITIGATION-KIT1 FOR ADDITIONAL INFORMATION, PLEASE READ OUR WHITE PAPER AT: https://www.globtek.com/en/technical-articles/ferrite-kit-radiated-emi-suppression-kit-for-globtek-power-supplies-cable-assemblies PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 14 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A LABEL:L-1186 LABEL P/N MATERIAL BACKGROUND COLOR TEXT COLOR LABEL WIDTH (mm) LABEL HEIGHT (mm) SPECIAL BARCODE LABEL MATERIAL Standard GT Flat Thermal Transfer, Imprintable, Polyester Label and/or Pad Printed and/or Molded, and/or Laser Engraved in the case Black if housing is Black, White or Silver if housing is White or Gray. White or Silver if label is Black Background for Black housing. Black if label is White or Silver background and Housing is White or Gray. 50.0 110.0 No Below is the minimum information which will appear on the label. NOTE: in the logo area additional/actual positioning of symbols and text is subjected to change as per agency updates/requirements or additional model approvals become available. Regulatory certifications/label markings may be in logo area on the label or molded into the case housing outside the label area. Information will be shown via label and/or pad printed and/or molded and/or laser engraved in the case. * Date code markings at GlobTek option .   A=ICT / ITE / Medical Power Supply/Class 2/Household Power Supply B=P/N: (料号) TR9CX1875YL4CR6BLPS C=Model (型号) GTM96900P9048-T3 D=Input (输入)100-240V~, 50-60Hz, 1.5A E=Output (输出)48.0 V 1.875 A, 90.00W PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 15 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A AGENCY ONLINE DOCUMENTS http://www.globtek.info/certs/GTM96900P90VV.V/ CE EC-Declaration for Medical https://cs.globtek.info/ec_declaration_product?id=01t0c000009Ebrr&m=1 CE EC-Declaration for Industrial/Commercial/ITE https://cs.globtek.info/ec_declaration_product?id=01t0c000009Ebrr&i=2 CE EC-Declaration for Household UKCA-Declaration for Medical https://cs.globtek.info/ukca_declaration_product?id=01t0c000009Ebrr&m=1 UKCA-Declaration for Industrial/Commercial/ITE https://cs.globtek.info/ukca_declaration_product?id=01t0c000009Ebrr&i=2 UKCA-Declaration for Household Morocco SDoC Declaration https://cs.globtek.info/Morocco_SDoC_Declaration?id=a0Oa000000MjSZHEA3 RoHS/RoHS3 Declaration https://www.globtek.com/pdf/rohs_cert/01t0c000009EbrrAAC REACH Declaration https://www.globtek.com/pdf/iso_certificates/REACH.pdf Conflict Minerals Declaration https://www.globtek.com/pdf/conflict-minerals.pdf Prop 65 Statement https://www.globtek.com/prop-65-statement.pdf IPXY rating is based on 3rd party testing and customers should check suitability and test system level IPXY rating before ordering. Regulatory Certifications/Label Markings  Below follows a link to the latest regulatory certifications and marks for this specific product. National standards as well as certification schemes are constantly changing and so is the set of certification marks and symbols applicable to this product. Various standards, marks and symbols, and certificates are subject to change at any time without notice. Additional standards or unique country certifications are available upon request. Please contact Globtek to request a quotation. LATEST PRODUCT/MODEL CERTIFICATIONS: https://www.globtek.com/ds/4djCGnXPkcV/8H328PK2nPu.html AGENCY ONLINE DOCUMENTS http://www.globtek.info/certs/GTM96900P90VV.V/ (E1) Earthed output Front View Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 16 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A PACKAGING Packing Spec P/N Standard DT, Cellular packaging Box Qty 20 Gift Box Size (mm) N/A (egg crate) Gift Box Color None Master Carton Size (mm) 405 x 427 x 158 Master Carton Cubic Volume (m³) 0.03 Master GW (Kg) 20.0 kg BLADES INCLUDED None: (Order Separately) BLADE/CORD INSTALLED None: (Order Separately) USER MANUAL* USER MANUAL WEB LINK * This specification sheet is considered the user manual for all applications. It is expected that the buyer of this product will use it to formulate their own user manual for their end product and a user manual specifically for the power adapter is not usually required. If a user manual is not specifically listed above then none will be provided with this unit. If specific packaging is required, this section must specify all requirements and note “no exceptions”. If this section does not specify packaging, it is subject to change without notice at GlobTek’s discretion. PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 17 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A INSTRUCTIONS TO THE OEM SYSTEMS ENGINEER It is the responsibility of the OEM systems engineer to provide the end system user instructions and warnings for the use of this product in the end system. If an input cord is required for this product, AC Mains voltage should be provided to the power supply by a power supply cord approved to the national standards of the country in which it will be used. This product is not designed to be repaired. No serviceable parts inside. A blown internal fuse is an indication of catastrophic failure of circuit component(s). If a Failure Analysis is required for a failed power supply/battery charger, please return the damaged unit to GlobTek for an accurate determination of the root cause of the failure. EMC Compliance of the complete OEM product, including the GlobTek power supply/battery charger needs to be verified by the OEM systems engineer. INSTRUCTION SHEET N/A PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 18 of 19 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  GTM96900P9048-T3, ICT / ITE / Medical Power Supply/Class 2/Household Power Supply, Efficiency Level: USA DOE Level VI / Eco-design Directive 2009/125/EC, (EU) 2019/1782, Case Color/Style: GlobTek Black, Desktop/External, Regulated Switchmode AC-DC Power Supply AC Adaptor, Input Rating: 100-240V~, 50-60Hz, IEC 60320/C14 , Output Rating: 90W, 48.0V@1.875A, Output Configuration: 1500 mm, 18/2 Cond, UL 2464, 4 Pin Locking Kycon or Equal, Ferrite: None, GlobTek Black, GT Cord # C40313, Pin Out: Pin 1, 3 & Shell: -V / Ground Pin 2&4: +V, Blades/Input Cord: (Order Separately), Approvals: CB 61347; RCM; LPS 60950; CCC; Patent US9838207B2; VCCI; EAC; IP41; cETLus 60601-1-11; UL 1310; cETLus 60950-1; Singapore (24V only); S-Mark 62368; IRAM; ETL (Brazil); UKCA; UL 1310; Conforms to 62368-1; ETL 62368; LPS 62368; Morocco; FCC; Korea (24-30V Only) pending; PSE (pending); Taiwan BSMI (12, 15,19,24,48 and 54V only); South Africa; Fuse 60335; NOM (48V); India BIS (24V only); CB 60950; ETL; ETL; CB 60335; S-Mark 60950; CB 62368; ETL; CB 60601-1; S-Mark; CE; China RoHS; Class I; Level VI; RoHS; Ukraine; WEEE; PSE; PSE; PSE; Model No.  GTM96900P9048-T3 Part No./Ordering No.  TR9CX1875YL4CR6BLPS Rev A PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2019 - 2024 guest / 01/15/2024 1:11:13 AM GMT CLONED FROM TR9CX1875YL4G2487R6B Page 19 of 19
TR9CX1875YL4CR6BLPS 价格&库存
很抱歉,暂时无法提供与“TR9CX1875YL4CR6BLPS”相匹配的价格&库存,您可以联系我们找货
TR9CX1875YL4CR6BLPS
  • 20+393.8212220+50.94679
