114991659
114991659
    SEEED(矽递科技)
    RF EXPLORER SIGNAL GENERATOR COM
114991659 数据手册
RF Explorer Signal Generator Signal Generator Combo Specifications and Datasheet Updated to Firmware Version 1.31 ® Description of main features The RF Explorer Signal Generator is a powerful, wideband fully programmable RF signal generator. It is the perfect companion for Spectrum Analyzer RF Explorer product line. As a standalone unit, RFE6Gen can generate CW and Sweep signals by selecting embedded menu options. When connected to a PC, it can be fully programmed with the RF Explorer for Windows software tool and automated with Python, .NET and USB RS232 API. Furthermore, the unit can work as a powerful Tracking Generator when used with RF Explorer Spectrum Analyzer connected to the same PC, offering full Scalar Network Analyzer (SNA) capabilities. The SNA feature allows full characterization of filters, amplifiers and any 2-port RF device. Feature  Pocket size and light weight  Solid aluminum metal case  Lifetime free firmware upgrades available, open to community requested features  High capacity Lithium for 10hs+ of continuous run, rechargeable by USB  RF Explorer for Windows free software download  Can be extended with internal Expansion Modules for additional future band support and functionality  Wide band support for CW signal, Frequency and Amplitude Sweep, and advanced Tracking SNA. RF Explorer Signal Generator – Specifications and Datasheet page 2 General Specifications Parameter Combo Signal Generator Baseline Signal Generator Frequency range 100KHz to 6GHz 23.4MHz to 6GHz Frequency step/resolution 1Khz 1Khz Frequency stability 100KHz to 250MHz: ±5ppm or 800Hz 250MHz to 6GHz: ±0.5ppm ±0.5ppm Frequency accuracy (internal reference) 100KHz to 250MHz: ±10ppm or 800Hz 250MHz to 6GHz: ±1ppm ±1ppm Output power range Calibrated: -40 to +10dBm Uncalibrated: -60 to +18dBm More details in section below 40dBm to -30dBm in 3dB steps -10dBm to 0dBm in 3dB steps More details in section below Output power resolution 0.25dB 3dB Output power accuracy Typical ±1.5dB Typical ±3dB Output power stability Typical ±0.5dB Typical ±0.5dB Output amplitude settling time 500uS 500uS Output protection 25VDC 25VDC Harmonics Typical -40dBc More details in section below Typical -10dBc Spurious Typical less than -52dBc Typical less than -50dBc Phase Noise Typical less than -125dBc/Hz on 1MHz at 1GHz Typical less than -125dBc/Hz on 1MHz at 1GHz Frequency Sweep settling < 5ms < 5ms Amplitude Sweep settling < 500uS < 500uS Sweep hops range unlimited unlimited Functional modes CW Frequency Sweep Amplitude Sweep Tracking SNA CW Frequency Sweep Amplitude Sweep Tracking SNA Operating temperature 5-35C 0-45C Connector type SMA 50 ohms SMA 50 ohms Display Graphics LCD 128x64 pixels Graphics LCD 128x64 pixels Backlight 5 levels 5 levels Weight 205g 185g RF Explorer Signal Generator – Specifications and Datasheet page 3 Parameter Combo Signal Generator Baseline Signal Generator Size 113x70x25 mm 113x70x25 mm Programmable USB generic API Python API .NET API USB generic API Python API .NET API Software Windows PC Windows PC Certification CE/FCC/RoHS/MSDS CE/FCC/RoHS/MSDS Harmonics Filtering (Combo model) A more detailed section on harmonics and filtering is available in the full user manual. These values are measured at reference output signal at -20dBm, measuring all harmonics order #2 - #10, as this is representative of worst-case scenario. RF Explorer Signal Generator Combo – Harmonics filtering Frequency range (MHz) Best case (dBc) Typical (dBc) Worst case (dBc) 0.1 – 0.5 -42 -40 -20 0.5-250 -59 -57 -42 250-430 -53 -40 -22 430-630 -53 -45 -35 630-820 -39 -37 -22 820-1960 -50 -43 -34 1960-2500 -30 -26 -20 2500-4600 -50 -40 -27 4600-5200 -42 -33 -24 5200-6000 -46 -42 -37 Usually harmonics have better filtering at higher power levels up to +10dBm, and about the same response on lower power levels. Higher signal levels beyond +10dBm may increase harmonics due to saturation of internal power amplifiers. An example of harmonic filtering in action at 25MHz comparing baseline Signal Generator and filtered Combo model below. RF Explorer Signal Generator – Specifications and Datasheet page 4 RF Explorer Signal Generator – Specifications and Datasheet page 5 Same signal compared in the time domain with an oscilloscope RF Explorer Signal Generator – Specifications and Datasheet page 6 Output Power Levels (Combo model) The RF Explorer Signal Generator Combo model delivers output power signal in the nominal range -60 to +15dBm. The range is calibrated by bench laboratory grade instruments, sampling 600 measurement points, and is suitable in the range -40 to +10dBm. Output signals outside this range will not perform with the same linearity and accuracy as within the calibrated range. The calibrated range accuracy is described in next table. Uncalibrated or out-of-range power levels are described as “n/a”. In these ranges the device can be used but output power level may not be accurate. RF Explorer Signal Generator Combo – output power accuracy Frequency range (MHz) Power range (dBm) Typical Accuracy (dB) Worst case Accuracy (dB) -40 to 0 ±2 ±5 0 to +10 n/a n/a -40 to 0 ±1 ±2.5 0 to +10 n/a n/a -40 to -10 ±1 ±2.5 -10 to +10 ±1.5 ±3.5 1950 to 3600 -30 to +10 ±1 ±2.5 3600 to 5200 -30 to +10 ±1.5 ±3 -30 to 0 ±2 ±4 0 to +10 n/a n/a 0.1 to 1 1 to 10 10 to 1950 5200 to 6000 Future firmware upgrade will increase accuracy in some frequency and power ranges using internal calibration table adjusted in factory. An optional software process will be available to manually calibrate the device and adjust for amplitude deviation. Contact us for additional details. Absolute maximum and minimum power levels available are described in next table. Note these levels are not guaranteed and not calibrated. RF Explorer Signal Generator Combo – Absolute output power range Frequency range (MHz) Minimum output power (dBm) Maximum output power (dBm) 0.1 to 1 -60 0 1 to 10 -60 +5 10 to 3200 -60 +15 3200 to 3650 -60 +10 3600 to 5200 -60 +15 5200 to 6000 -60 0 RF Explorer Signal Generator – Specifications and Datasheet page 7 Output Power Levels (baseline model) The RF Explorer Signal Generator baseline model delivers 8 different power levels, nominally specified as per table below: RF output power (nominal) 0dBm (1mW) -3dBm (0.5mW) -6dBm (0.25mW) -9dBm (0.125mW) -30dBm (1uW) -33dBm (0.5uW) -36dBm (0.25uW) -39dBm (0.125uW) High Power ON ON ON ON OFF OFF OFF OFF Power Switch 4 3 2 1 4 3 2 1 These are ideal power levels that are not actually constant with frequency. Actual power levels are a function of frequency, as depicted in graph below. This graph is generic but every RF Explorer Signal Generator includes an internal calibration table, produced in the factory at calibration time, with actual values for accurate reading on screen. The delivered power levels have a linear response up to about 2GHz, for higher frequencies there are some roll off and power becomes predictable but not constant. The unit is fully calibrated and includes an internal amplitude calibration table to allow accurate power normalization and measurement done in Tracking mode. The exact power level available on each frequency point is available on screen, as well as in the RF Explorer for Windows application. If you need better accuracy please upgrade the unit to a RF Explorer Signal Generator Combo model. RF Explorer Signal Generator – Specifications and Datasheet page 8 Spurious and Phase Noise RF Explorer Signal Generator Combo uses a low noise signal source and low noise independent voltage regulators to provide a reduced phase noise output signal. Below table shows typical values measured at -20dBm output power. These values can slightly increase or decrease at different power levels. CW Frequency Phase Noise @ 1KHz Phase Noise @ 100KHz Phase Noise @ 1MHz 2MHz -93 dBc/Hz -105 dBc/Hz -122 dBc/Hz 1GHz -96 dBc/Hz -108 dBc/Hz -128 dBc/Hz 5.8GHz -74 dBc/Hz -90 dBc/Hz -115 dBc/Hz Spurious signals are created by the internal signal source at multiples of the frequency divider and, even though they are filtered, some residues signals may display at 1GHz CW output signal. Spur @ 16KHz Spur @ 32KHz Spur @ 4MHz Spur @ 8MHz -52 dBc -72 dBc -55 dBc -68 dBc Signal measured at 1GHz narrow band displaying spurs at 16KHz and 32KHz. Signal measured at 1GHz wideband displaying spurs at 4MHz and 8MHz. RF Explorer Signal Generator – Specifications and Datasheet page 9 Connecting RF Explorer Signal Generator The unit includes 50 ohm impedance RF connector standard SMA format.  The RFE6Gen baseline model includes only one connector, the RF SMA on the left in the above image. This model will display this information in the RF Connections screen: RF Explorer Signal Generator – Specifications and Datasheet page 10  The RF Explorer Signal Generator Combo model includes two SMA connectors, but only the enhanced functionality of the SMA connector on the right side is enabled. A future firmware may enable both connectors to allow double signal source but with different capabilities. It is recommended covering the left SMA connector with a dummy load 50ohm for better protection. This model will display this information in the RF Connections screen: RF Explorer Signal Generator – Specifications and Datasheet page 11 Expansion Module RF Explorer Signal Generator includes an internal expansion port to enhance the RF power capabilities and frequency coverage of the main unit with RF Explorer Signal Generator compatible Expansion Modules. Note: Spectrum Analyzer modules cannot be connected to the Signal Generator, they are incompatibles and have a changed gender connector to avoid any change of connecting incompatible modules. RF Explorer Signal Generator Expansion is an advanced expansion board. It can be used to easily extend RF Explorer RFE6GEN Signal Generator baseline model into a Combo model. For more details and assembly information please visit link below. www.rf-explorer.com/expansion Important: After assembling of the RF Explorer Signal Generator Expansion board into a RF Explorer Signal Generator RFE6GEN baseline mainboard, the device becomes fully compatible with a RF Explorer Signal Generator Combo (specifications). Same specifications will apply for harmonics filtering, frequency accuracy and RF capabilities as a Combo unit assembled and calibrated at factory. However, due to differences between mainboard electronics, the RF power level accuracy cannot be guaranteed and may not comply with RF Explorer Signal Generator Combo specifications. We offer calibration services to fully adjust to specifications, please use contact form to request more information. Connecting RF Explorer to a computer RF Explorer device can be connected to a computer (Windows, Linux, Mac and Android) for additional capabilities, including higher resolution screen, additional features and programmability. For free, open source RF Explorer for Windows tool, please check this link: www.rf-explorer.com/windows For additional software options developed by a growing list of 3rd party companies, please check this link: www.rf-explorer.com/software API programming specification for RF Explorer RF Explorer offers a compact, easy to use, USB / RS232 programming interface. It can be used to automate external solutions when connected to an external computer or device. For full specification of the current API, check www.rf-explorer.com/API . There are .NET and Python libraries available in GITHUB repository, ideal for custom work required by your application. RF Explorer Signal Generator – Specifications and Datasheet page 12 RF Explorer for Windows open source code RF Explorer is a hacker friendly device. Full open source under LPGL license is offered to the community. As hackers ourselves, we do like customizing, tinkering and expanding gadgets. We certainly designed and built RF Explorer with these factors in mind. We love and make good use all community contributions, contact us or send us a PULL request if you have source code contributions you want integrated in the final product. Check our hacker corner link for more details. FCC and CE regulations RF Explorer is a Test and Measurement device, and therefore compatible with US FCC regulation 47 CFR Part 15.103(c). RF Explorer is certified for CE compliance under regulations EN/IEC61236 and EN/IEC61000. License RF Explorer embedded firmware is copyrighted © by RF Explorer Technologies, 2010-2019 RF Explorer for Windows is Open Source software released under GPL v3, so you are free to modify, distribute and use it based on GPL terms. RF Explorer is a registered trademark in USA, Australia, China, Japan, Canada and all EU Countries. RF Explorer Signal Generator – Specifications and Datasheet page 13
114991659 价格&库存
很抱歉,暂时无法提供与“114991659”相匹配的价格&库存,您可以联系我们找货
