| WWW.CROUZET.COM
| 1
| MICROSWITCHES
| 12/2023
MINIATURE MICROSWITCHES - SEALED, COMPACT
V3DS - 8329
› C-spring snap-action mechanism with wiping contacts
› IP67 protection
› Broad range of operating forces from 1 N to 4.5 N
› Quick-connect terminals or wire lead output
› Ratings from 1 mA 4 Vc to 10 A 250 Va
› Choice of actuators on 3 possible fixing positions
(pre-assembled or retrofittable)
approved
› ENEC, cURus and CCC
Main specifications
Standard
83293
Function
Connections
I (changeover)
W3 (QC 6.3 x 0.8)
I (changeover)
F0 (wires)
R (normally closed)
W3 (QC 6.3 x 0.8)
R (normally closed)
F0 (wires)
C (normally open)
W3 (QC 6.3 x 0.8)
C (normally open)
F0 (wires)
Electrical characteristics
Rating nominal / 250 V AC (A)
Rating thermal / 250 V AC (A)
Rating UL / 125/250 VAC (A)
Mechanical characteristics
Maximum operating force (N)
Min. Release force (N)
Max. Allowable overtravel force (N)
Rest position max. (mm)
Operating position (mm)
Maximum differential travel (mm)
Min. overtravel (mm)
Ambient operating temperature (°C)
Mechanical life for 2/3 OT (operations)
Contact gap (mm)
Weight, terminal versions (g)
Weight, wire versions (g)
83293001
83293009
l
High current
83291
High current
High force
83290
83291001
83291009
83290001
83290009
l
l
Low force
83294
83294001
83294009
l
Dual-current
83298
Dual-current
Low force
83299
83298001
83298009
83299001
83299009
l
l
83293609
83291609
83290609
83294609
83298609
83299609
83293809
83291809
83290809
83294809
83298809
83299809
l
l
l
l
l
l
5
7.5
6(1)
10
10
10(2)
10
10
10(2)
3
7.5
6(1)
3*
6
6(1) - 0.1(0.04)
3*
6
6(1) - 0.1(0.04)
2
0.2
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
2.5
0.5
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
4.5
0.8
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
1
0.1
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
2
0.2
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
1
0.1
14.7 ±0.5
0.5
1
-40 ➞ +85
106
1
9
39
Additional specifications
- Degree of protection: IP67 (mechanism and wire output)
- Recommended min actuating speed: 83290: 0.1 mm/s
83291: 0.3 mm/s
83293/83298: 1 mm/s
83294/83299: 3 mm/s
- Case: PBT GF (UL 94-V0 / GWFI 850 °C)
- Button: PA66 GF
- Membrane: silicone rubber
- Contacts: silver alloy, gold-plated silver alloy (dual-current)
- Terminals: brass
- Wire leads: tinned copper, XLPE insulated
- Levers: stainless steel
- Conformity / Certifications:
Product adaptations
› Special levers: special shapes and lengths, pinned actuators, ….
› Special leads
› Special connections: 4.8 x 0.5 and 4.8 x 0.8 quick-connect, …
› Cable output
Principles
Single break snap-action switch
Changeover - SPDT (form C)
Normally closed - SPST-NC (form B)
2
2
4
4
1
Standard product
Normally open - SPST-NO (form A)
1
Product made to order
1
Contact us
| WWW.CROUZET.COM
| 2
| MICROSWITCHES
| 12/2023
Curves
Electrical life
83290 - 83291
- 250 Va 10 A resistive 50 000 cycles
83298 - 83299
- 5 Vc 1 mA resistive 200 000 cycles
- 250 Va 3A resistive 100 000 cycles
83293
- 250 Va 5 A resistive 100 000 cycles
83294
* Models 83298 and 83299 are designed to operate equally well on low-current (1 mA 4 V minimum recommended) or medium-current circuits
(3 A maximum recommended) circuits. However, a given product should only be used to switch one type of circuit during its working life.
Dimensions
Product
Ø3.1 -+ 0.15
0.05
1
15.9
20.2
Ø2.5
NC2
NO4
10.3 ± 0.1
3.1 -+ 0.15
0.05
C1
SR2
8329
3.4
22.2 ± 0.2
2.8
10.3
± 0.15
33.3
1
Total travel position = 13.2 max
Connections
W3 quick-connect 6.3 x 0.8
Other connections:
consult us
6.3
4.3
F0 wire output
1.6 +- 0.15
18.5
min.7.8
Wire characteristics
1: Black (common)
2: Red (NC)
4: Brown (NO)
Cross-section: 0.8 mm2
Standard length: 300 mm
Other lengths on request
(length in meters: e.g. 1.5)
15.8
0.8 ± 0.05
8.3
12.3
37.3
Actuators
290A4 flat
290A7 flat
R
0.5
7
0.5
R
4
161A flat
| WWW.CROUZET.COM
| 3
161F dummy roller
| MICROSWITCHES
| 12/2023
161G dummy roller
161E roller
Other shapes and dimensions: consult us
Actuator mounting positions
NC2
NO4
0.9
16
12.35
8.5
A D C
Positions A and C are standard
Position D is for factory mounted pinned actuators: consult us.
Actuators and mounting accessories
Part numbers for standard
actuators
Actuators
Fixing position
Coefficient for force *
Rest position - max
mm
Operating position
mm
Total travel position - max
mm
Differential travel - max
mm
actuators
Actuators
Fixing position
Rest position - max
mm
Operating position
mm
mm
mm
70771217
70771218
Flat 290A4
R42.3
Flat 290A7
R39.5
A
4.5
21.5
14.7±2.5
10.6
2.5
C
2.5
19
15.2±1.5
12.6
1.5
A
4.5
22
14.8±2.5
10.3
2.5
C
2.5
18.7
15.2±1.5
12.7
1.5
70507524
70507529
70507528
79218651
Flat 161A
R25.4
Roller 161E
R24.1
Dummy roller 161F
R22.2
Dummy roller 161G
R21.8
A
2.5
25
20.2±1.5
18.5
1.5
A
2.5
25.5
21.5±1.3
A
3
14.2±1.5
12
1.5
C
1.5
19
15±0.9
13.8
1
A
3
25
20±1.5
18
1.5
C
1.5
24.5
20.5±1
19.2
1
C
* To calculate force on actuator, divide the switch force by the coefficient given in the table.
Example: 83291 with lever 290A7 R39.5 Pos C (coeff. 2.5)
Max Operating force: 2.5 N /2.5 = 1 N
Min Release force: 0.5 N /2.5 = 0.2 N
Except where otherwise indicated, levers are supplied unmounted. For factory mounting, specify fixing position A or C.
Standard product
Contact us
C
1.3
25
22.2±1
21
1
| WWW.CROUZET.COM
| 4
| MICROSWITCHES
| 12/2023
Installation recommendations
See “Basic technical concepts”
How to order
Use 8 digit part numbers when they are defined
Other cases, precise: Type of microswitch - Function - Connection - Actuator* - Fixing position*
* if needed
Example: 83293 I W3 290A7 R39.5 C
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment.
Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the
responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we
be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable
material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“83290001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+134.7299650+17.48110
