IND-10565A
IND-10565A
    AMGIS
    径向-4引线
    FIXED IND 1.8MH 175 MOHM TH
IND-10565A 数据手册
.75” NOMINAL 2.5” NOMINAL RELEASE HISTORY REL. DESCRIPTION DATE APPROVED 000 INITIAL RELEASE 06/05/2014 JJ SCHEMATIC 1 L= 1.2mH Lo= 1.8mH ± 10% I= 7.2 A APPLY LABEL ON SIDE OF HEADER 2 .20” SIDE VIEW .20” WIND BACK & FORTH IN 5 LAYERS. END VIEW NOTES: 2 NC 2 .70” ± .010” 1 NC 1 1.2” DIA .055” (4X) + .015” -.005” 1. HEADER: LODESTONE PACIFIC VTM254-4 (WITH 4 PINS #16 AWG) 2. CORE MICROMETALS T200-8/90 3. MAGNET WIRE 16 HPTZ. 4. EPOXY JB WELD OR APPROVED EQUIVALENT. 5. SOLDER SN96 TOP VIEW ELECTRICAL 1. INDUCTANCE @ 250 mV, 15 KHz: (1-2)= 1.8 mH ± 10% 2. DCR: (1-2)= 175mΩ REF LABEL: MADE BY AMGIS LLC USA INDUCTOR P/N IND-10565A L= 1.2 mH I= 7.2A DATE CODE-S/N EF-1021 Date 08/17/2013 Page 1 of 1 DRAWN APPROVED AMGIS LLC, INC PROPRIETARY AND CONFIDENTIAL THIS DRAWING IS THE PROPERTY OF AMGIS LLC, INC. IT IS LOANED WITH THE UNDERSTANDING THAT IT MAY NOT BE REPRODUCED NOR MAY THE INFORMATION CONTAINED HEREIN BE USED FOR MANUFACTURING PURPOSES WITHOUT WRITTEN CONSENT FROM AMGIS LLC, INC NAME DF JJ DATE 06/05/2014 06/05/2014 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONS : ± 1/64 ONE PLACE DECIMAL: ± .050 TWO PLACE DECIMAL: ± .010 THREE PLACE DECIMAL: ± .005 DO NOT SCALE DRAWING TITLE: INDUCTOR DWG. NO REL IND-10565A SCALE: NONE WEIGHT: .6 LBS 000 SHEET 1 OF 1
IND-10565A 价格&库存
很抱歉,暂时无法提供与“IND-10565A”相匹配的价格&库存,您可以联系我们找货
