APSDM001G42AN-CT
APSDM001G42AN-CT
    APACERMEMORYAMERICA(宇瞻科技)
    SATA3 DISK MODULE 22-PIN/180 DEG
APSDM001G42AN-CT 数据手册
ġ RoHS Recast Compliant SATA-Disk Module 5A SDM5A 22P/180D Product Specifications March 17, 2016 Version 1.0 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 SATA-Disk Module 5A APSDMxxxG42AN-CTX Features: z Standard Serial ATA Interface – Serial ATA Revision 3.1 – SATA 6.0 Gbps interface – ATA-8 command set – Backward compatible with SATA 1.5/3.0 Gbps z Capacity – 1, 2, 4, 8, 16, 32 GB z Performance* – Burst read/write: 600 MB/sec – Sustained read: up to 65 MB/sec – Sustained write: up to 105 MB/sec z Flash Management – Built-in hardware ECC – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power failure management – ATA secure erase z NAND Flash Type: SLC z MTBF: >2,000,000 hours z Temperature Range – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C z Supply Voltage – 5.0 V Ʋ 5% z Power Consumption* – Active mode: 215 mA – Idle mode: 85 mA z Connector Type – 7-pin SATA signal connector – 15-pin SATA power connector z Form Factor – SATA Disk Module z Shock & Vibration** – Shock:1,500 G – Vibration: 15 G z RoHS Recast compliant – Complies with 2011/65/EU standard *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX Table of Contents 1. General Description .............................................................................. 3 2. Functional Block Diagram .................................................................... 3 3. Pin Assignments .................................................................................... 4 4. Product Specifications.......................................................................... 6 4.1 Capacity ............................................................................................................................................... 6 4.2 Performance ........................................................................................................................................ 6 4.3 Environmental Specifications .............................................................................................................. 7 4.4 Mean Time Between Failures (MTBF) ................................................................................................ 7 4.5 Certification and Compliance .............................................................................................................. 7 5. Flash Management ................................................................................ 8 5.1 Error Correction/Detection ................................................................................................................... 8 5.2 Bad Block Management ...................................................................................................................... 8 5.3 Wear Leveling ...................................................................................................................................... 8 5.4 Power Failure Management ................................................................................................................ 8 5.5 ATA Secure Erase ............................................................................................................................... 8 6. Software Interface ................................................................................ 9 6.1 Command Set ...................................................................................................................................... 9 6.2 S.M.A.R.T. ........................................................................................................................................... 9 7. Electrical Specifications .................................................................... 11 8. Physical Characteristics ..................................................................... 12 8.1 Dimensions ........................................................................................................................................ 12 9. Product Ordering Information ............................................................. 13 9.1 Product Code Designations ............................................................................................................... 13 9.2 Valid Combinations ............................................................................................................................ 14 2 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 1. General Description Apacer’s SDM5A (SATA Disk Module 5A) is our next generation disk-on-module (DOM) series that offers elevated speed boost and higher error correction capabilities. Built with SATA 6.0 Gb/s interface, SDM5A delivers higher performance in data transfer than its previous SDM selections, reaching up to 65 MB/s in read and 105 MB/s in write. With its SATA interface compliance and compact size, this high-speed disk module defines an ideal balance of performance, capacities, reliability and cost. SDM5A comes in moderate capacities that are suitable to boot industrial applications and light operating systems for specific operations, while with some extra memory space for data storage. The architectural nature of SATA disk module provides higher resistance to external environmental influences and better flexibility for motherboard space. Regarding data reliability, SDM5A is built in with powerful ECC engine that can correct up to 40 bits per 1KB data. In addition, the controller unit of this DOM device supports wear-leveling, SMART and power failure management for data integrity. With its trustable reliability, performance and cost effectiveness, Apacer’s SDM5A is definitely the ideal storage or cache solution for embedded and industrial computers, servers and thin clients. 2. Functional Block Diagram SDM5A includes the SATA and Flash Management controllers, and flash media, as well as the SATA standard interface. Figure 2-1 shows the functional block diagram. Serial ATA Interface SATA Controller Flash Management Controller Flash Media Figure 2-1 Functional Block Diagram 3 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 3. Pin Assignments SATA Connectors Table 3-1 Signal Segment Pin Type S1 GND Table 3-2 Power Segment Description Pin Signal/Description P1 Unused (3.3V) S2 RxP + Differential Receive Signal P2 Unused (3.3V) S3 RxN - Differential Receive Signal P3 Unused (3.3V) S4 GND P4 Ground S5 TxN - Differential Transmit Signal P5 Ground S6 TxP + Differential Transmit Signal P6 Ground S7 GND P7 5V P8 5V P9 5V P10 Ground P11 DAS P12 Ground P13 Unused (12V) P14 Unused (12V) P15 Unused (12V) 4 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX Figure 3-1 SATA Cable/Connector Connection Diagram The connector on the left represents the Host with TX/RX differential pairs connected to a cable. The connector on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground path connecting the shielding of the cable to the Cable Receptacle. 5 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 4. Product Specifications 4.1 Capacity Capacity specifications of SDM5A are available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 1 GB 1,011,032,064 1959 16 63 1,974,672 2 GB 2,011,226,112 3897 16 63 3,928,176 4 GB 4,011,614,208 7773 16 63 7,835,184 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performance of SDM5A is listed below in Table 4-2. Table 4-2 Performance Capacity 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB Sustained read (MB/s) 31 55 65 65 65 65 Sustained write (MB/s) 15 30 60 65 105 105 Performance Note: Results may differ from various flash configurations or host system setting. 6 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 4.3 Environmental Specifications Environmental specifications of SDM5A product family follow the MIL-STD-810 standards as shown in Table 4-3. Table 4-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Extended) Non-operating temp. -40°C to 100°C Operating vibration 20~2,000(Hz), 7.69 (Grms), random wave, X, Y, Z axis Non-operating vibration 10~2,000(Hz), 15(G), sine wave, X, Y, Z axis Operating shock 50(G), 11(ms), half-sine wave Non-operating shock 1,500(G), 0.5(ms), half-sine wave 4.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SDM5A. The prediction result for SDM5A is more than 2,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 4.5 Certification and Compliance SDM5A complies with the following standards: z z z z CE FCC RoHS Recast MIL-STD-810 7 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 5. Flash Management 5.1 Error Correction/Detection SDM5A implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40 bits error in 1K bytes. 5.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 5.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 5.5 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 6. Software Interface 6.1 Command Set This section defines the software requirements and the format of the commands the host sends to SDM5A. Commands are issued to SDM5A by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 6-1 Command Set Code Command Code Command E5h Check Power Mode F3h Security Erase Prepare 06h Data Set Management F4h Security Erase Unit 90h Execute Device Diagnostic F5h Security Freeze Lock E7h Flush Cache F1h Security Set Password EAh Flush Cache EXT F2h Security Unlock ECh Identify Device 70h Seek E3h Idle EFh Set Features E1h Idle Immediate C6h Set Multiple Mode 91h Initialize Device Parameters E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT CAh Write DMA 20h Read Sector 35h Write DMA EXT 24h Read Sector EXT C5h Write Multiple 40h Read Verify Sectors 39h Write Multiple EXT 42h Read Verify Sectors EXT 30h Write Sector 10h Recalibrate 34h Write Sector EXT F6h Security Disable Password 6.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. 9 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 10 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 7. Electrical Specifications Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 7-1 Operating Range Parameter Conditions Supply voltage 5V ± 5% ( 4.75-5.25 V) Table 7-2 Typical Power Consumption Capacity Modes Active (mA) 1 GB 2GB 4 GB 8 GB 16 GB 32 GB 140 165 200 170 205 215 70 80 85 85 85 Idle (mA) Note: Results may differ from various flash configurations or host system setting. 80 11 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 8. Physical Characteristics 8.1 Dimensions Unit: ੈ Tolerance: ± 0.25 12 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 9. Product Ordering Information 9.1 Product Code Designations AP SDM xxxG 4 2 A N – C T X Operating Temperature Range Blank: 0°C to 70°C W: -40°C to 85°C Flash Type Version Control N: Standard A: Standard Solution Version Form Factor 4: 22P/180D Capacity 001G = 1GB 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB Serial ATA Flash Module Apacer Product Code 13 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX 9.2 Valid Combinations Capacity 1GB 2GB 4GB 8GB 16GB 32GB Standard APSDM001G42AN-CT APSDM002G42AN-CT APSDM004G42AN-CT APSDM008G42AN-CT APSDM016G42AN-CT APSDM032G42AN-CT Extended Temperature APSDM001G42AN-CTW APSDM002G42AN-CTW APSDM004G42AN-CTW APSDM008G42AN-CTW APSDM016G42AN-CTW APSDM032G42AN-CTW Note: Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 14 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX Revision History Revision Date Description Remark 0.1 1/7/2016 Preliminary release 1.0 3/17/2016 Official release – updated performance and power consumption values for 32GB 15 © 2016 Apacer Technology Inc. Rev. 1.0 SATA-Disk Module 5A APSDMxxxG42AN-CTX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 16 © 2016 Apacer Technology Inc. Rev. 1.0
APSDM001G42AN-CT 价格&库存
很抱歉,暂时无法提供与“APSDM001G42AN-CT”相匹配的价格&库存,您可以联系我们找货
