4246A22UU
4246A22UU
    APEM(埃斐)
    插件
    钮子开关 双刀双掷 1万次 直插 6A 30V -20℃~+55℃
4246A22UU 数据手册
4100 AND 4200 SERIES TOGGLE SWITCHES - INSULATED LEVER AND BUSHING Distinctive features and specifications ❑ No external metal parts ❑ Knee lever (toggle joint) quick-break mechanism ❑ Butt action contacts ❑ UL and CSA approved ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 3A 250VAC - 6A 125VAC - 6A 30VDC • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals and between poles 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 50.000 cycles at 3A 250VAC 10.000 cycles at 6A 125VAC and 30VDC MATERIALS • Case : phenolic resin • Actuator : polyamide 6-6 • Bushing : polyamide 6-6 • Contacts : silver inlay GENERAL SPECIFICATIONS H • Torque : 0,95 Nm (.70 Ft.lb) max. applied to nut • Panel thickness : 5 mm (.196) between 2 nuts • Operating temperature : -20°C to +55°C AGENCY APPROVALS Availability : consult factory for details of approved models. Marking : To order switches marked UL and/or CSA, consult factory. ABOUT THIS SERIES Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. Mounting accessories : standard hardware supplied with all models : 1 hex nut U166 and 1insulating knurled nut U520 in the same colour as the actuator. They are presented in section N. Packaging unit : 20 pieces. A P E M H-11 4100 AND 4200 SERIES TOGGLE SWITCHES - INSULATED LEVER AND BUSHING Solder lug or straight PC terminals ➞ Keyway 2.40 (.094) 1 2 6.20 (.244) 7.20 (.283) 1.20 (.047) 5.00 (.196) • 2 maintained positions • Silver inlay contacts standard • Double pole configurations 2.80x0.50 (.11x.019) 3 1.20x0.5 (.047x.019) MODEL STRUCTURE - Ø12.00x0.75 SI (.472DIAx0.75 IS) 16.50 (.649) OFF 8.00 (.315) ON 11.50 (.453) 18.00 (.709) 4 5 2 8.40 (.33) 21.00 (.826) 1 13.50 (.531) 7.20 (.283) 3 30˚ ON - 5.80 (.228) 4146A-2 ON 6 I 4141A-2 I II II 2.80x0.50 (.11x.019) ➞ Keyway Solder lug terminals : 4100 H ➞ Keyway I OFF 4246A-2 ON - ON 8.00 (.315) 5 2 3 ACTUATOR COLOURS H-12 11.50 (.453) 19.20 (.755) PANEL CUT-OUT Ø12.20 (.48DIA) Ø12.20 (.48DIA) Ø12.50 (.492DIA) Ø3.50 (.137DIA) A P E M 1.70 (.066) 9.60 (.377) Blue Black Green Grey Yellow Red White Orange 6 5.10 (.20) 1 2 3 4 5 6 7/1 9 13.50 (.531) 4 8.40 (.33) 21.00 (.826) 1 5.00 (.197) Ø12.00x0.75 SI (.472DIAx0.75 IS) 16.50 (.649) 30˚ - 5.80 (.228) ON I 4241A-2 II II 1.20 (.047) 1.20x0.50 (.047x.019) Straight PC terminals : 4200
4246A22UU 价格&库存
很抱歉,暂时无法提供与“4246A22UU”相匹配的价格&库存,您可以联系我们找货
