ICR3PAD2101
ICR3PAD2101
    APEM(埃斐)
    SWITCH PUSH SPST-NO 5A 48V
ICR3PAD2101 数据手册
IC series Pushbutton switches for harsh environments - short case - bushing Ø 12 mm - momentary Distinctive features and specifications ❑ Momentary with short case, reduced behind-panel depth ❑ Tactile feedback ❑ Flat round actuator for optional marking ❑ Glossy actuator option (round curved only) ❑ Sealed to IP67 ENVIRONMENTAL SPECIFICATIONS GENERAL SPECIFICATIONS • Front panel sealing : IP67 according to IEC 60529 • Shock resistance : 100 g according to IEC 512-4, test 6c • Vibration resistance : 10-500Hz - 10 g according to IEC 512-4, test 6d • Salt spray : IEC 512-6, test 11f • Robustness : IK06 according to EN 50102 (1 joule) • Operating temperature : -40°C to +85°C • Panel thickness : 1,5 mm (.059) min. 4 mm (.157 max.) • Total travel : 1,7 mm (.067)+/- 0,3 mm • Typical operating force : 4N +/- 2N • Mechanical life : 1.000.000 cycles • Torque : 1,5 Nm max. applied to nut • Soldering : 320°C max. for 3 sec. ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : 0,2A 48VDC, 500.000 cycles 0,5A 48VAC, 500.000 cycles • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.500 Vrms 50 HZ between terminals • Case : thermoplastic UL94-V0 • Actuator : polyamide 6/6 • Bushing/bezel : zinc die-cast (zamac), black painted • Contacts : brass, gold plated • Multi-wire lead AWG20, section 0,6 mm2 • Terminal seal : epoxy MOUNTING Matrix mounting 1.50min-4Max (.059 min-.157max) Panel cut-out 12.90 (.507) Ø13.60 (.535DIA) ➀ O-ring APEM 20.00 (.787) 20.00 (.787) 1 20.00 (.787) Back of panel space requirement Ø13.50 (.531DIA) www.apem.com 1 IC series Pushbutton switches for harsh environments - short case - bushing Ø 12 mm - momentary Overview IC Electrical function Actuator shape SERIES Square Round, curved Round, flat Round curved with gloss finish C R P B 3 Normally open (NO) Actuator colour 1 2 3 4 5 6 7/1 8 9 A B Blue Black Green Grey Yellow Red White Bright chrome Orange Satin chrome Dark blue Terminals S F P Z1 Solder lugs Flying leads Straight PC Quick-connect Contacts CD Brass, gold plated Options 100 101 104 Satin chrome bezel Bright chrome bezel High actuator (round models only) ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. A sealing boot is available to protect the switches against frost and sand. It is presented at the end of this catalogue. Mounting accessories : Standard hardware supplied : 1 hex nut 14 mm (.551) across flats and 1 O-ring. Hex nut part number U166. Packaging unit : 25 pieces 2 www.apem.com APEM IC series Pushbutton switches for harsh environments - short case - bushing Ø 12 mm - momentary Square Quick-connect Z1 1.00 (.039) MODEL STRUCTURE 3.40 (.133) 8.40 (.330) 2.40 (.094) Straight P 1.20 (.047) 2.80 (.110) CISCOSP ECH: 0.9 5-05-03 ➞ Flat Solder lug terminals CISCOSZ-A DESSIN ECH 0.9 5-05-03 ICC3SCD Normally Open Also available with straight PC terminals : ICC3PAD and quick-connect terminals : ICC3Z1AD ➞ Flat Sealed flying lead terminals ICC3FCD Normally Open Wire colours (NC/NO) : black : NO, blue : NC ACTUATOR COLOUR 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7/1 : white - 8 : bright chrome - 9 : orange A : satin chrome - B : dark blue OPTIONS 100 : Satin chrome bezel 101 : Bright chrome bezel APEM www.apem.com 3 IC series Pushbutton switches for harsh environments - short case - bushing Ø 12 mm - momentary Round Straight P Quick-connect Z1 MODEL STRUCTURE 1.20 (.047) 3.40 (.133) 1.00 (.039) 8.40 (.330) 2.40 (.094) • Gloss actuator finish Curved actuator also available with gloss finish - replace ICR by ICB in the part numbers below. 2.80 (.110) CISCOSP ECH: 0.9 Actuator marking available on ICP models (symbol 10 mm max.). On request. 5-05-03 ➞ Flat Solder lug terminals CISCOSZ-A DESSIN ECH 0.9 Curved actuator ICR3SCD 5-05-03 Flat actuator ICP3SCD Also available with straight PC terminals : IC•3PAD and quick-connect terminals : IC•3Z1AD ➞ Flat Sealed flying lead terminals Curved actuator ICR3FCD Flat actuator ICP3FCD ACTUATOR COLOUR OPTIONS 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow 6 : red - 7/1 : white - 8 : bright chrome - 9 : orange A : satin chrome - B : dark blue - 100 : Satin chrome bezel 101 : Bright chrome bezel 104 : High actuator 4 www.apem.com ICR 104 IC1201-A-prelim. 104 Ø12.00 (.472DIA) 4.70 (.185) Ø12.00 (.472DIA) 4.70 (.185) Wire colours (NC/NO) : black : NO, blue : NC ICP APEM
ICR3PAD2101 价格&库存
很抱歉,暂时无法提供与“ICR3PAD2101”相匹配的价格&库存,您可以联系我们找货
