New
RH SERIES SNAP-IN ROCKER SWITCHES
FEATURES
Cost effective illuminated or non-illuminated models.
N
Single pole maintained action models.
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE
Actuator and case color selections.
Standard actuator marking options.
SPECIFICATIONS
Contact ratings:
16A 125VAC 1/4 HP (UL/CSA). 16A 250VAC 1/4 HP (UL/CSA).
20A 125VAC 3/4 HP 250VAC (UL) 16(4)A 250V ~ T85 1E4
10(2)A 250V ~ 5E4 (VDE, SEMCO, NEMCO, DEMCO, FIMCO, SEV).
20 milliohms max.
100 megohms min. at 500 V
1000 VAC for 1 minute
16(4)A 250VAC: 10,000 cycles 10(2)A 250VAC: 50,000 cycles
-20°C to 85°C
Initial contact resistance:
Insulation resistance:
Dielectric strength:
Electrical life:
Operating temperature range:
MATERIALS
Contacts:
Terminals:
Actuator:
Case:
Silver cadmium alloy
Lamps: Neon or fluorescent.
Silver plated copper
Illumination available
Nylon type 66 or PC (UL94V-2 min.)
only with function 1 (ON OFF).
Nylon type 66 (UL94V-2 min.)
AGENCY RECOGNITION
D
s
UL, CSA, VDE, SEMKO, NEMKO, DEMKO, FEMKO, & SEV. Models are supplied with agency markings.
Quick connect terminals - curved actuator
MODEL NO.
CIRCUIT
RH110C2NBB ON
RH120C2NBB ON
RH130C2NBB ON
OFF
ON
OFF
ON
Above models have black actuator
and black case.
Solder lug terminals - curved actuator
MODEL NO.
CIRCUIT
RH111C2NBB ON
RH121C2NBB ON
RH131C2NBB ON
OFF
ON
OFF
ON
and black case.
N40
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
New
! RH SERIES SNAP-IN ROCKER SWITCHES
Illuminated - quick connect terminals - curved actuator
N
CIRCUIT
RH110C2LBR ON
RH120C2LBR ON
RH130C2LBR ON
OFF
ON
OFF
ON
Above models have red actuator
and black case.
Additional ordering information: Commonly ordered models are shown above with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply
selecting from all available options shown and filling in the boxes.
'BUILD YOUR OWN SWITCH' ORDER FORMAT
Fill in boxes with selections shown for complete model number.
Allowable selections are shown below each respective box.
Series
Number
of poles
Electrical
functions
Terminals
Marking/
lens color
1
R H
1
2
3
6
Single pole
ON OFF
ON ON
ON OFF ON
MOM OFF MOM
0 Quick-connect
*1 Solder lug
*Solder lug terminals not avaible
with electrical function 3
Illuminated
type
L
N
*C
*R
Actuator
type
Illuminated
non-illum.
round lens
square lens
Case
color
Actuator
color
B
G
O
R
W
Y
A Gray
B Black
W White
* Curved actuator only
Black
Green
Orange
Red
White
Yellow
TERMINALS
QUICK-CONNECT
HI LO
No marking
ON OFF
O I
O
O II
Green lens
Red lens
Orange lens
Example of completely specified
model number:
RH130C6GLBR
PANEL CUT-OUTS
SOLDER LUG
pnl. tk'ness.
2
3
4
5
6
G
R
O
C Curved
F Flat
S Ergonomic
Notes: only flat actuator
is available with full
illumination-i.e.-no lens.
Ergonomic actuator
available only with
functions 1 & 2 and
no illumination.
1
.029-.049"
.050-.078"
.079-.118"
A +0, -.004
B +.006, -.0
1.181"
1.189"
1.200"
.433"
.433"
.433"
N41
MODEL NO.
很抱歉,暂时无法提供与“RH110C2NBB”相匹配的价格&库存,您可以联系我们找货
