DWG NO.
DO NOT SCALE DRAWING WORK TO FIGURE
.465[11.81]
.670[17.02]
.565[14.35]
T1
LET
REVISIONS
1.134[28.80]
12A
20A
1 HP
T3
DATE
.669[17.45]
RATING
T2
REV.
2FAA01-73
.425[10.80]
.634[16.10]
.072 WD X .038 DP
KEYWAY
UL & CSA
250VAC
125VAC
120-240VAC
OPERATES:
POSITIONS OF TOGGLE
UP
CENTER
DOWN
ON
NONE
OFF
T2 TO T3
±.003
±.001
.250 WIDE X .031 THICK
6.35
.79
15 - 32NS - 2
32
HEX NUT
(FURN. ASSEMBLED)
NOTES:
1. KEYWAY INDICATES DOWN
POSITION
2. TOGGLE, THREADED STEM, RING
.062[15.74] NUT & HEX NUT ARE NICKEL
PLATED
Ø .562[14.27] KNURLED RING NUT
(FURNISHED IN BULK)
FINISH
DIMENSIONS SUBJECT TO CHANGE WITHOUT NOTICE
PROPRIETARY NOTE:
NOTICE TO ALL PERSONS RECEIVING THIS
DRAWING. THIS DOCUMENT IS THE
PROPERTY OF CARLING TECHNOLOGIES,
INC. AND IS NOT TO BE DISCLOSED,
REPRODUCED IN WHOLE OR IN PART OR
USED FOR MANUFACTURING PURPOSES BY
ANYONE WITHOUT THE CONSENT OF
CARLING TECHNOLOGIES, INC.
TOOL NO.
REV
DR BY
DATE
UNSPECIFIED TOLERANCES
FRAC. ±1/64 X.XXX ±.015
ANGLES ±1°
PROJECTIONS
DIMENSIONS
IN [mm]
KRAMARZ
5-12-08
CHK BY
DATE
APPD BY
DATE
F SERIES
TOGGLE SWITCH
TITLE
SIZE
A
USED ON
DWG NO.
REV.
2FAA01-73
SCALE:
NONE
SHT
1
OF
1
很抱歉,暂时无法提供与“2FAA01-73”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+84.17520
- 200+33.58800
- 500+32.46480
