SRJ24A3BBBNN
SRJ24A3BBBNN
    ZF
    船型开关 SPDT 20A 125VDC
SRJ24A3BBBNN 数据手册
® MINIATURE ROUND ROCKER SWITCH SR Series Features  20 amp switching in a compact design  Available in a variety of colors  Self-locking tabs and anti-rotation pin for snug fit  Mechanical life: min. 50,000 operations Crisp detent actuation Steel alloy spring Nylon button with attractive matte finish Self-locking tolerance compensation ribs for tight fit Durable silver alloy contacts for long life at heavy loads Standard terminals .187″ (4.8mm) wide x .031″ (0.8mm) thick (other sizes and types available) Electrical Ratings Switch Series EN61058 Rating UL1054 Rating SR N/A 20A, 125VAC; 12A, 250VAC Electrical Life at Rated Load According to VDE According to UL (Min. Operations) (Min. Operations) N/A Specifications Electrical Dielectric Strength: Insulation Resistance: Initial Contact Resistance: Temperature Range: 1000VAC for 1 minute 108 ohms min at 500VDC 0.020 ohms max -20°C to + 65°C Materials Actuator (non-lighted): Base: Contacts: Movable Arm: Terminals: Nylon 66 94V-2 Nylon 66 94V–2 Silver Alloy Silver-Plated Copper Alloy Tin-Plated Copper Alloy 6,000 ® Dimensions inches (mm) Panel Cut-Out Dimensions for Panel Thickness inches (mm) 0.039 to 0.078 (1.0 to 2.0) 0.142 (3.6) REF 0.094±0.004 2.40±0.10 0.079 (2.00) 04 +0.0 0 7 0.00 0.78 0 +0.1 0 0.00 20.0 - 0.031 (0.80) 0.539 (13.80) 0.827±0.004 (21.00±0.10) 0.030 (7.60) ø0.063 ø(1.60) 0.031 (0.80) 0.31 (0.80) 0.187 (4.80) 0.276 (7.00) ø0.780 (ø19.8) Ordering Information SR J Series 2 4 Code Circuitry 2 Single-Pole Switch Function On – Off On – On On – Off – On H B Code Actuator Type 3 Round Code Actuator Marking B Blank C D OFF ON E F G H O O I – • O I B N Code B C E W Y Housing Color Black Brown Charcoal Grey White Grey Code A B G R W Y Actuator Color Amber Black Green Red White Grey Code Lighted N Non-Lighted Code Body Type N No Rocker Boot HI Code Terminal Type inches (mm) A 0.187 (4.80) Quick-Connect 3 LO Code Contact Rating J 20A, 125VAC; 12A, 250VAC (UL, cUL) Code 2 3 4 A II Examples of Common Part Numbers and Descriptions inches (mm) Switch Function Terminal Type Actuator/ Housing Color SRJ22A3BBBNN On – Off 0.187 (4.80) Quick-Connect Black/ Black SRJ23A3BBBNN On – On 0.187 (4.80) Quick-Connect Black/ Black Contact SRJ24A3BBBNN On – Off – On 0.187 (4.80) Quick-Connect Black/ Black Call, fax or visit our website for more information. SRJ22A3WWNN On – Off 0.187 (4.80) Quick-Connect White/ White SRJ22A3FBBNN On – Off 0.187 (4.80) Quick-Connect Black/ Black Part Number Circuitry Legend Marking Cherry Electrical Products 11200 88th Avenue Pleasant Prairie, WI 53158 Phone: 800 927 6298 Fax: 262 942 6566 Web: www.cherrycorp.com Specifications subject to change without notice. © 2005 Cherry Corporation N
SRJ24A3BBBNN 价格&库存
很抱歉,暂时无法提供与“SRJ24A3BBBNN”相匹配的价格&库存,您可以联系我们找货
